And get rid of the license text that is no longer necessary.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Cc: Alistair Popple <alistair@popple.id.au>
Cc: Jeremy Kerr <jk@ozlabs.org>
Cc: Joel Stanley <joel@jms.id.au>
Cc: Rocky Craig <rocky.craig@hp.com>
Replace home grown set_prop_entry() macro by generic
PROPERTY_ENTRY_INTEGER()-like ones.
Cc: Corey Minyard <cminyard@mvista.com>
Many for coding-style fixes, and update the poll API with the new
type '__poll_t', this is new commit from linux-4.16-rc1.
Signed-off-by: Haiyue Wang <haiyue.wang@linux.intel.com>
This is an attempt to document the sysfs interface for the IPMI drivers.
Descriptions were collected from v2.0 of the IPMI specification and from
code comments.
Signed-off-by: Aishwarya Pant <aishpant@gmail.com>
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Addresses-Coverity-ID: 1465255 ("Missing break in switch")
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Cc: Haiyue Wang <haiyue.wang@linux.intel.com>
The KCS (Keyboard Controller Style) interface is used to perform in-band
IPMI communication between a server host and its BMC (BaseBoard Management
Controllers).
This driver exposes the KCS interface on ASpeed SOCs (AST2400 and AST2500)
as a character device. Such SOCs are commonly used as BMCs and this driver
implements the BMC side of the KCS interface.
Provides a device driver for the KCS (Keyboard Controller Style)
IPMI interface which meets the requirement of the BMC (Baseboard
Management Controllers) side for handling the IPMI request from
host system software.
[Removed the selectability of IPMI_KCS_BMC, as it doesn't do much
good to have it by itself.]
Pull Xtensa fixes from Max Filippov:
"Two fixes for reserved memory/DMA buffers allocation in high memory on
xtensa architecture
- fix memory accounting when reserved memory is in high memory region
- fix DMA allocation from high memory"
* tag 'xtensa-20180225' of git://github.com/jcmvbkbc/linux-xtensa:
xtensa: support DMA buffers in high memory
xtensa: fix high memory/reserved memory collision
Pull x86 fixes from Thomas Gleixner:
"A small set of fixes:
- UAPI data type correction for hyperv
- correct the cpu cores field in /proc/cpuinfo on CPU hotplug
- return proper error code in the resctrl file system failure path to
avoid silent subsequent failures
- correct a subtle accounting issue in the new vector allocation code
which went unnoticed for a while and caused suspend/resume
failures"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/topology: Update the 'cpu cores' field in /proc/cpuinfo correctly across CPU hotplug operations
x86/topology: Fix function name in documentation
x86/intel_rdt: Fix incorrect returned value when creating rdgroup sub-directory in resctrl file system
x86/apic/vector: Handle vector release on CPU unplug correctly
genirq/matrix: Handle CPU offlining proper
x86/headers/UAPI: Use __u64 instead of u64 in <uapi/asm/hyperv.h>
Pull perf fix from Thomas Gleixner:
"A single commit which shuts up a bogus GCC-8 warning"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/oprofile: Fix bogus GCC-8 warning in nmi_setup()
Pull locking fixes from Thomas Gleixner:
"Three patches to fix memory ordering issues on ALPHA and a comment to
clarify the usage scope of a mutex internal function"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/xchg/alpha: Fix xchg() and cmpxchg() memory ordering bugs
locking/xchg/alpha: Clean up barrier usage by using smp_mb() in place of __ASM__MB
locking/xchg/alpha: Add unconditional memory barrier to cmpxchg()
locking/mutex: Add comment to __mutex_owner() to deter usage
Pull cleanup patchlet from Thomas Gleixner:
"A single commit removing a bunch of bogus double semicolons all over
the tree"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
treewide/trivial: Remove ';;$' typo noise
Pull NFS client bugfixes from Trond Myklebust:
- fix a broken cast in nfs4_callback_recallany()
- fix an Oops during NFSv4 migration events
- make struct nlmclnt_fl_close_lock_ops static
* tag 'nfs-for-4.16-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFS: make struct nlmclnt_fl_close_lock_ops static
nfs: system crashes after NFS4ERR_MOVED recovery
NFSv4: Fix broken cast in nfs4_callback_recallany()
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fixes from Michael Ellerman:
- Add handling for a missing instruction in our 32-bit BPF JIT so that
it can be used for seccomp filtering.
- Add a missing NULL pointer check before a function call in new EEH
code.
- Fix an error path in the new ocxl driver to correctly return EFAULT.
- The support for the new ibm,drc-info device tree property turns out
to need several fixes, so for now we just stop advertising to
firmware that we support it until the bugs can be ironed out.
- One fix for the new drmem code which was incorrectly modifying the
device tree in place.
- Finally two fixes for the RFI flush support, so that firmware can
advertise to us that it should be disabled entirely so as not to
affect performance.
Thanks to: Bharata B Rao, Frederic Barrat, Juan J. Alvarez, Mark Lord,
Michael Bringmann.
* tag 'powerpc-4.16-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/powernv: Support firmware disable of RFI flush
powerpc/pseries: Support firmware disable of RFI flush
powerpc/mm/drmem: Fix unexpected flag value in ibm,dynamic-memory-v2
powerpc/bpf/jit: Fix 32-bit JIT for seccomp_data access
powerpc/pseries: Revert support for ibm,drc-info devtree property
powerpc/pseries: Fix duplicate firmware feature for DRC_INFO
ocxl: Fix potential bad errno on irq allocation
powerpc/eeh: Fix crashes in eeh_report_resume()
Pull networking fixes from David Miller:
1) Fix TTL offset calculation in mac80211 mesh code, from Peter Oh.
2) Fix races with procfs in ipt_CLUSTERIP, from Cong Wang.
3) Memory leak fix in lpm_trie BPF map code, from Yonghong Song.
4) Need to use GFP_ATOMIC in BPF cpumap allocations, from Jason Wang.
5) Fix potential deadlocks in netfilter getsockopt() code paths, from
Paolo Abeni.
6) Netfilter stackpointer size checks really are needed to validate
user input, from Florian Westphal.
7) Missing timer init in x_tables, from Paolo Abeni.
8) Don't use WQ_MEM_RECLAIM in mac80211 hwsim, from Johannes Berg.
9) When an ibmvnic device is brought down then back up again, it can be
sent queue entries from a previous session, handle this properly
instead of crashing. From Thomas Falcon.
10) Fix TCP checksum on LRO buffers in mlx5e, from Gal Pressman.
11) When we are dumping filters in cls_api, the output SKB is empty, and
the filter we are dumping is too large for the space in the SKB, we
should return -EMSGSIZE like other netlink dump operations do.
Otherwise userland has no signal that is needs to increase the size
of its read buffer. From Roman Kapl.
12) Several XDP fixes for virtio_net, from Jesper Dangaard Brouer.
13) Module refcount leak in netlink when a dump start fails, from Jason
Donenfeld.
14) Handle sub-optimal GSO sizes better in TCP BBR congestion control,
from Eric Dumazet.
15) Releasing bpf per-cpu arraymaps can take a long time, add a
condtional scheduling point. From Eric Dumazet.
16) Implement retpolines for tail calls in x64 and arm64 bpf JITs. From
Daniel Borkmann.
17) Fix page leak in gianfar driver, from Andy Spencer.
18) Missed clearing of estimator scratch buffer, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (76 commits)
net_sched: gen_estimator: fix broken estimators based on percpu stats
gianfar: simplify FCS handling and fix memory leak
ipv6 sit: work around bogus gcc-8 -Wrestrict warning
macvlan: fix use-after-free in macvlan_common_newlink()
bpf, arm64: fix out of bounds access in tail call
bpf, x64: implement retpoline for tail call
rxrpc: Fix send in rxrpc_send_data_packet()
net: aquantia: Fix error handling in aq_pci_probe()
bpf: fix rcu lockdep warning for lpm_trie map_free callback
bpf: add schedule points in percpu arrays management
regulatory: add NUL to request alpha2
ibmvnic: Fix early release of login buffer
net/smc9194: Remove bogus CONFIG_MAC reference
net: ipv4: Set addr_type in hash_keys for forwarded case
tcp_bbr: better deal with suboptimal GSO
smsc75xx: fix smsc75xx_set_features()
netlink: put module reference if dump start fails
selftests/bpf/test_maps: exit child process without error in ENOMEM case
selftests/bpf: update gitignore with test_libbpf_open
selftests/bpf: tcpbpf_kern: use in6_* macros from glibc
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem fixes from James Morris:
- keys fixes via David Howells:
"A collection of fixes for Linux keyrings, mostly thanks to Eric
Biggers:
- Fix some PKCS#7 verification issues.
- Fix handling of unsupported crypto in X.509.
- Fix too-large allocation in big_key"
- Seccomp updates via Kees Cook:
"These are fixes for the get_metadata interface that landed during
-rc1. While the new selftest is strictly not a bug fix, I think
it's in the same spirit of avoiding bugs"
- an IMA build fix from Randy Dunlap
* 'fixes-v4.16-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
integrity/security: fix digsig.c build error with header file
KEYS: Use individual pages in big_key for crypto buffers
X.509: fix NULL dereference when restricting key with unsupported_sig
X.509: fix BUG_ON() when hash algorithm is unsupported
PKCS#7: fix direct verification of SignerInfo signature
PKCS#7: fix certificate blacklisting
PKCS#7: fix certificate chain verification
seccomp: add a selftest for get_metadata
ptrace, seccomp: tweak get_metadata behavior slightly
seccomp, ptrace: switch get_metadata types to arch independent
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Catalin Marinas:
"arm64 and perf fixes:
- build error when accessing MPIDR_HWID_BITMASK from .S
- fix CTR_EL0 field definitions
- remove/disable some kernel messages on user faults (unhandled
signals, unimplemented syscalls)
- fix kernel page fault in unwind_frame() with function graph tracing
- fix perf sleeping while atomic errors when booting with ACPI"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: fix unwind_frame() for filtered out fn for function graph tracing
arm64: Enforce BBM for huge IO/VMAP mappings
arm64: perf: correct PMUVer probing
arm_pmu: acpi: request IRQs up-front
arm_pmu: note IRQs and PMUs per-cpu
arm_pmu: explicitly enable/disable SPIs at hotplug
arm_pmu: acpi: check for mismatched PPIs
arm_pmu: add armpmu_alloc_atomic()
arm_pmu: fold platform helpers into platform code
arm_pmu: kill arm_pmu_platdata
ARM: ux500: remove PMU IRQ bouncer
arm64: __show_regs: Only resolve kernel symbols when running at EL1
arm64: Remove unimplemented syscall log message
arm64: Disable unhandled signal log messages by default
arm64: cpufeature: Fix CTR_EL0 field definitions
arm64: uaccess: Formalise types for access_ok()
arm64: Fix compilation error while accessing MPIDR_HWID_BITMASK from .S files
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips
Pull MIPS fix from James Hogan:
"A single MIPS fix for mismatching struct compat_flock, resulting in
bus errors starting Firefox on Debian 8 since 4.13"
* tag 'mips_fixes_4.16_3' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips:
MIPS: Drop spurious __unused in struct compat_flock
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk
Pull printk fixlet from Petr Mladek:
"People expect to see the real pointer value for %px.
Let's substitute '(null)' only for the other %p? format modifiers that
need to deference the pointer"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk:
vsprintf: avoid misleading "(null)" for %px
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"Two bugfixes, one v4.16 regression fix, and two documentation fixes"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: designware: Consider SCL GPIO optional
i2c: busses: i2c-sirf: Fix spelling: "formular" -> "formula".
i2c: bcm2835: Set up the rising/falling edge delays
i2c: i801: Add missing documentation entries for Braswell and Kaby Lake
i2c: designware: must wait for enable
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"These are mostly fixes for problems with merge window code.
In addition we have one doc update (alua) and two dead code removals
(aiclib and octogon) a spurious assignment removal (csiostor) and a
performance improvement for storvsc involving better interrupt
spreading and increasing the command per lun handling"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi: qla4xxx: skip error recovery in case of register disconnect.
scsi: aacraid: fix shutdown crash when init fails
scsi: qedi: Cleanup local str variable
scsi: qedi: Fix truncation of CHAP name and secret
scsi: qla2xxx: Fix incorrect handle for abort IOCB
scsi: qla2xxx: Fix double free bug after firmware timeout
scsi: storvsc: Increase cmd_per_lun for higher speed devices
scsi: qla2xxx: Fix a locking imbalance in qlt_24xx_handle_els()
scsi: scsi_dh: Document alua_rtpg_queue() arguments
scsi: Remove Makefile entry for oktagon files
scsi: aic7xxx: remove aiclib.c
scsi: qla2xxx: Avoid triggering undefined behavior in qla2x00_mbx_completion()
scsi: mptfusion: Add bounds check in mptctl_hp_targetinfo()
scsi: sym53c8xx_2: iterator underflow in sym_getsync()
scsi: bnx2fc: Fix check in SCSI completion handler for timed out request
scsi: csiostor: remove redundant assignment to pointer 'ln'
scsi: ufs: Enable quirk to ignore sending WRITE_SAME command
scsi: ibmvfc: fix misdefined reserved field in ibmvfc_fcp_rsp_info
scsi: qla2xxx: Fix memory corruption during hba reset test
scsi: mpt3sas: fix an out of bound write
git://people.freedesktop.org/~airlied/linux
Pull drm fixes from Dave Airlie:
"A bunch of fixes for rc3:
Exynos:
- fixes for using monotonic timestamps
- register definitions
- removal of unused file
ipu-v3L
- minor changes
- make some register arrays const+static
- fix some leaks
meson:
- fix for vsync
atomic:
- fix for memory leak
EDID parser:
- add quirks for some more non-desktop devices
- 6-bit panel fix.
drm_mm:
- fix a bug in the core drm mm hole handling
cirrus:
- fix lut loading regression
Lastly there is a deadlock fix around runtime suspend for secondary
GPUs.
There was a deadlock between one thread trying to wait for a workqueue
job to finish in the runtime suspend path, and the workqueue job it
was waiting for in turn waiting for a runtime_get_sync to return.
The fixes avoids it by not doing the runtime sync in the workqueue as
then we always wait for all those tasks to complete before we runtime
suspend"
* tag 'drm-fixes-for-v4.16-rc3' of git://people.freedesktop.org/~airlied/linux: (25 commits)
drm/tve200: fix kernel-doc documentation comment include
drm/edid: quirk Sony PlayStation VR headset as non-desktop
drm/edid: quirk Windows Mixed Reality headsets as non-desktop
drm/edid: quirk Oculus Rift headsets as non-desktop
drm/meson: fix vsync buffer update
drm: Handle unexpected holes in color-eviction
drm: exynos: Use proper macro definition for HDMI_I2S_PIN_SEL_1
drm/exynos: remove exynos_drm_rotator.h
drm/exynos: g2d: Delete an error message for a failed memory allocation in two functions
drm/exynos: fix comparison to bitshift when dealing with a mask
drm/exynos: g2d: use monotonic timestamps
drm/edid: Add 6 bpc quirk for CPT panel in Asus UX303LA
gpu: ipu-csi: add 10/12-bit grayscale support to mbus_code_to_bus_cfg
gpu: ipu-cpmem: add 16-bit grayscale support to ipu_cpmem_set_image
gpu: ipu-v3: prg: fix device node leak in ipu_prg_lookup_by_phandle
gpu: ipu-v3: pre: fix device node leak in ipu_pre_lookup_by_phandle
drm/amdgpu: Fix deadlock on runtime suspend
drm/radeon: Fix deadlock on runtime suspend
drm/nouveau: Fix deadlock on runtime suspend
drm: Allow determining if current task is output poll worker
pfifo_fast got percpu stats lately, uncovering a bug I introduced last
year in linux-4.10.
I missed the fact that we have to clear our temporary storage
before calling __gnet_stats_copy_basic() in the case of percpu stats.
Without this fix, rate estimators (tc qd replace dev xxx root est 1sec
4sec pfifo_fast) are utterly broken.
Fixes: 1c0d32fde5bd ("net_sched: gen_estimator: complete rewrite of rate estimators")
Alexei Starovoitov says:
pull-request: bpf 2018-02-22
The following pull-request contains BPF updates for your *net* tree.
The main changes are:
1) two urgent fixes for bpf_tail_call logic for x64 and arm64 JITs, from Daniel.
2) cond_resched points in percpu array alloc/free paths, from Eric.
3) lockdep and other minor fixes, from Yonghong, Arnd, Anders, Li.
Previously, buffer descriptors containing only the frame check sequence
(FCS) were skipped and not added to the skb. However, the page reference
count was still incremented, leading to a memory leak.
Fixing this inside gfar_add_rx_frag() is difficult due to reserved
memory handling and page reuse. Instead, move the FCS handling to
gfar_process_frame() and trim off the FCS before passing the skb up the
networking stack.
Signed-off-by: Andy Spencer <aspencer@spacex.com>
Signed-off-by: Jim Gruen <jgruen@spacex.com>
gcc-8 has a new warning that detects overlapping input and output arguments
in memcpy(). It triggers for sit_init_net() calling ipip6_tunnel_clone_6rd(),
which is actually correct:
net/ipv6/sit.c: In function 'sit_init_net':
net/ipv6/sit.c:192:3: error: 'memcpy' source argument is the same as destination [-Werror=restrict]
The problem here is that the logic detecting the memcpy() arguments finds them
to be the same, but the conditional that tests for the input and output of
ipip6_tunnel_clone_6rd() to be identical is not a compile-time constant.
We know that netdev_priv(t->dev) is the same as t for a tunnel device,
and comparing "dev" directly here lets the compiler figure out as well
that 'dev == sitn->fb_tunnel_dev' when called from sit_init_net(), so
it no longer warns.
This code is old, so Cc stable to make sure that we don't get the warning
for older kernels built with new gcc.
Cc: Martin Sebor <msebor@gmail.com>
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=83456
The following use-after-free was reported by KASan when running
LTP macvtap01 test on 4.16-rc2:
[10642.528443] BUG: KASAN: use-after-free in
macvlan_common_newlink+0x12ef/0x14a0 [macvlan]
[10642.626607] Read of size 8 at addr ffff880ba49f2100 by task ip/18450
[10642.963873] Call Trace:
[10642.994352] dump_stack+0x5c/0x7c
[10643.035325] print_address_description+0x75/0x290
[10643.092938] kasan_report+0x28d/0x390
[10643.137971] ? macvlan_common_newlink+0x12ef/0x14a0 [macvlan]
[10643.207963] macvlan_common_newlink+0x12ef/0x14a0 [macvlan]
[10643.275978] macvtap_newlink+0x171/0x260 [macvtap]
[10643.334532] rtnl_newlink+0xd4f/0x1300
[10646.256176] Allocated by task 18450:
[10646.299964] kasan_kmalloc+0xa6/0xd0
[10646.343746] kmem_cache_alloc_trace+0xf1/0x210
[10646.397826] macvlan_common_newlink+0x6de/0x14a0 [macvlan]
[10646.464386] macvtap_newlink+0x171/0x260 [macvtap]
[10646.522728] rtnl_newlink+0xd4f/0x1300
[10647.022028] Freed by task 18450:
[10647.061549] __kasan_slab_free+0x138/0x180
[10647.111468] kfree+0x9e/0x1c0
[10647.147869] macvlan_port_destroy+0x3db/0x650 [macvlan]
[10647.211411] rollback_registered_many+0x5b9/0xb10
[10647.268715] rollback_registered+0xd9/0x190
[10647.319675] register_netdevice+0x8eb/0xc70
[10647.370635] macvlan_common_newlink+0xe58/0x14a0 [macvlan]
[10647.437195] macvtap_newlink+0x171/0x260 [macvtap]
Commit d02fd6e7d293 ("macvlan: Fix one possible double free") handles
the case when register_netdevice() invokes ndo_uninit() on error and
as a result free the port. But 'macvlan_port_get_rtnl(dev))' check
(returns dev->rx_handler_data), which was added by this commit in order
to prevent double free, is not quite correct:
* for macvlan it always returns NULL because 'lowerdev' is the one that
was used to register rx handler (port) in macvlan_port_create() as
well as to unregister it in macvlan_port_destroy().
* for macvtap it always returns a valid pointer because macvtap registers
its own rx handler before macvlan_common_newlink().
Fixes: d02fd6e7d293 ("macvlan: Fix one possible double free")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
do_task_stat() calls get_wchan(), which further does unwind_frame().
unwind_frame() restores frame->pc to original value in case function
graph tracer has modified a return address (LR) in a stack frame to hook
a function return. However, if function graph tracer has hit a filtered
function, then we can't unwind it as ftrace_push_return_trace() has
biased the index(frame->graph) with a 'huge negative'
offset(-FTRACE_NOTRACE_DEPTH).
Moreover, arm64 stack walker defines index(frame->graph) as unsigned
int, which can not compare a -ve number.
Similar problem we can have with calling of walk_stackframe() from
save_stack_trace_tsk() or dump_backtrace().
This patch fixes unwind_frame() to test the index for -ve value and
restore index accordingly before we can restore frame->pc.
Reproducer:
cd /sys/kernel/debug/tracing/
echo schedule > set_graph_notrace
echo 1 > options/display-graph
echo wakeup > current_tracer
ps -ef | grep -i agent
Above commands result in:
Unable to handle kernel paging request at virtual address ffff801bd3d1e000
pgd = ffff8003cbe97c00
[ffff801bd3d1e000] *pgd=0000000000000000, *pud=0000000000000000
Internal error: Oops: 96000006 [#1] SMP
CPU: 5 PID: 11696 Comm: ps Not tainted 4.11.0+ #33
task: ffff8003c21ba000 task.stack: ffff8003cc6c0000
PC is at unwind_frame+0x12c/0x180
LR is at get_wchan+0xd4/0x134
pc : [<ffff00000808892c>] lr : [<ffff0000080860b8>] pstate: 60000145
sp : ffff8003cc6c3ab0
x29: ffff8003cc6c3ab0 x28: 0000000000000001
x27: 0000000000000026 x26: 0000000000000026
x25: 00000000000012d8 x24: 0000000000000000
x23: ffff8003c1c04000 x22: ffff000008c83000
x21: ffff8003c1c00000 x20: 000000000000000f
x19: ffff8003c1bc0000 x18: 0000fffffc593690
x17: 0000000000000000 x16: 0000000000000001
x15: 0000b855670e2b60 x14: 0003e97f22cf1d0f
x13: 0000000000000001 x12: 0000000000000000
x11: 00000000e8f4883e x10: 0000000154f47ec8
x9 : 0000000070f367c0 x8 : 0000000000000000
x7 : 00008003f7290000 x6 : 0000000000000018
x5 : 0000000000000000 x4 : ffff8003c1c03cb0
x3 : ffff8003c1c03ca0 x2 : 00000017ffe80000
x1 : ffff8003cc6c3af8 x0 : ffff8003d3e9e000
Process ps (pid: 11696, stack limit = 0xffff8003cc6c0000)
Stack: (0xffff8003cc6c3ab0 to 0xffff8003cc6c4000)
[<ffff00000808892c>] unwind_frame+0x12c/0x180
[<ffff000008305008>] do_task_stat+0x864/0x870
[<ffff000008305c44>] proc_tgid_stat+0x3c/0x48
[<ffff0000082fde0c>] proc_single_show+0x5c/0xb8
[<ffff0000082b27e0>] seq_read+0x160/0x414
[<ffff000008289e6c>] __vfs_read+0x58/0x164
[<ffff00000828b164>] vfs_read+0x88/0x144
[<ffff00000828c2e8>] SyS_read+0x60/0xc0
[<ffff0000080834a0>] __sys_trace_return+0x0/0x4
Fixes: 20380bb390a4 (arm64: ftrace: fix a stack tracer's output under function graph tracer)
Signed-off-by: Pratyush Anand <panand@redhat.com>
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
[catalin.marinas@arm.com: replace WARN_ON with WARN_ON_ONCE]
Without this fix, /proc/cpuinfo will display an incorrect amount
of CPU cores, after bringing them offline and online again, as
exemplified below:
$ cat /proc/cpuinfo | grep cores
cpu cores : 4
cpu cores : 8
cpu cores : 8
cpu cores : 20
cpu cores : 4
cpu cores : 3
cpu cores : 2
cpu cores : 2
This patch fixes this by always zeroing the booted_cores variable
upon turning off a logical CPU.
Tested-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Signed-off-by: Samuel Neves <sneves@dei.uc.pt>
Cc: jgross@suse.com
Cc: luto@kernel.org
Cc: prarit@redhat.com
Cc: vkuznets@redhat.com
Link: http://lkml.kernel.org/r/20180221205036.5244-1-sneves@dei.uc.pt
topology_sibling_cpumask() is the correct thread-related topology
function in the kernel:
s/topology_sibling_mask/topology_sibling_cpumask
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Cc: corbet@lwn.net
Cc: linux-doc@vger.kernel.org
Link: http://lkml.kernel.org/r/20180222084812.14497-1-douly.fnst@cn.fujitsu.com
Successful RMW operations are supposed to be fully ordered, but
Alpha's xchg() and cmpxchg() do not meet this requirement.
Will Deacon noticed the bug:
> So MP using xchg:
> WRITE_ONCE(x, 1)
> xchg(y, 1)
> smp_load_acquire(y) == 1
> READ_ONCE(x) == 0
> would be allowed.
... which thus violates the above requirement.
Fix it by adding a leading smp_mb() to the xchg() and cmpxchg() implementations.
Reported-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Andrea Parri <parri.andrea@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: linux-alpha@vger.kernel.org
Link: http://lkml.kernel.org/r/1519291488-5752-1-git-send-email-parri.andrea@gmail.com
__ASM__MB
Replace each occurrence of __ASM__MB with a (trailing) smp_mb() in
xchg(), cmpxchg(), and remove the now unused __ASM__MB definitions;
this improves readability, with no additional synchronization cost.
Suggested-by: Will Deacon <will.deacon@arm.com>
Link: http://lkml.kernel.org/r/1519291469-5702-1-git-send-email-parri.andrea@gmail.com
If no monitoring feature is detected because all monitoring features are
disabled during boot time or there is no monitoring feature in hardware,
creating rdtgroup sub-directory by "mkdir" command reports error:
mkdir: cannot create directory ‘/sys/fs/resctrl/p1’: No such file or directory
But the sub-directory actually is generated and content is correct:
cpus cpus_list schemata tasks
The error is because rdtgroup_mkdir_ctrl_mon() returns non zero value after
the sub-directory is created and the returned value is reported as an error
to user.
Clear the returned value to report to user that the sub-directory is
actually created successfully.
Signed-off-by: Wang Hui <john.wanghui@huawei.com>
Signed-off-by: Zhang Yanfei <yanfei.zhang@huawei.com>
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Cc: Ravi V Shankar <ravi.v.shankar@intel.com>
Cc: Vikas <vikas.shivappa@intel.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Link: http://lkml.kernel.org/r/1519356363-133085-1-git-send-email-fenghua.yu@intel.com
When a irq vector is replaced, then the previous vector is normally
released when the first interrupt happens on the new vector. If the target
CPU of the previous vector is already offline when the new vector is
installed, then the previous vector is silently discarded, which leads to
accounting issues causing suspend failures and other problems.
Adjust the logic so that the previous vector is freed in the underlying
matrix allocator to ensure that the accounting stays correct.
Fixes: 69cde0004a4b ("x86/vector: Use matrix allocator for vector assignment")
Reported-by: Yuriy Vostrikov <delamonpansie@gmail.com>
Tested-by: Yuriy Vostrikov <delamonpansie@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20180222112316.930791749@linutronix.de
Some versions of firmware will have a setting that can be configured
to disable the RFI flush, add support for it.
Fixes: 6e032b350cd1 ("powerpc/powernv: Check device-tree for RFI flush settings")
Fixes: 8989d56878a7 ("powerpc/pseries: Query hypervisor for RFI flush settings")
Memory addtion and removal by count and indexed-count methods
temporarily mark the LMBs that are being added/removed by a special
flag value DRMEM_LMB_RESERVED. Accessing flags value directly at a few
places without proper accessor method is causing two unexpected
side-effects:
- DRMEM_LMB_RESERVED bit is becoming part of the flags word of
drconf_cell_v2 entries in ibm,dynamic-memory-v2 DT property.
- This results in extra drconf_cell entries in ibm,dynamic-memory-v2.
For example if 1G memory is added, it leads to one entry for 3 LMBs
and 1 separate entry for the last LMB. All the 4 LMBs should be
defined by one entry here.
Fix this by always accessing the flags by its accessor method
drmem_lmb_flags().
Fixes: 2b31e3aec1db ("powerpc/drmem: Add support for ibm, dynamic-memory-v2 property")
Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com>
Reviewed-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
security/integrity/digsig.c has build errors on some $ARCH due to a
missing header file, so add it.
security/integrity/digsig.c:146:2: error: implicit declaration of function 'vfree' [-Werror=implicit-function-declaration]
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: linux-integrity@vger.kernel.org
Link: http://kisskb.ellerman.id.au/kisskb/head/13396/
Signed-off-by: James Morris <james.morris@microsoft.com>
https://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into fixes-v4.16-rc3
Keyrings fixes.
git://git.pengutronix.de/git/pza/linux into drm-fixes
drm/imx: ipu-v3 fixups and grayscale support
- Make const interrupt register arrays static, reduces object size.
- Fix device_node leaks in PRE/PRG phandle lookup functions.
- Add 8-bit and 16-bit grayscale buffer support to ipu_cpmem_set_image,
- add 10-bit and 12-bit grayscale media bus support to ipu-csi,
to be used by the imx-media driver.
* tag 'imx-drm-next-2018-02-22' of git://git.pengutronix.de/git/pza/linux:
gpu: ipu-cpmem: add 8-bit grayscale support to ipu_cpmem_set_image
gpu: ipu-v3: make const arrays int_reg static, shrinks object size
The MIPS %.its.S compiler command did not define __ASSEMBLY__, which meant
when compiler_types.h was added to kconfig.h, unexpected things appeared
(e.g. struct declarations) which should not have been present. As done in
the general %.S compiler command, __ASSEMBLY__ is now included here too.
The failure was:
Error: arch/mips/boot/vmlinux.gz.its:201.1-2 syntax error
FATAL ERROR: Unable to parse input tree
/usr/bin/mkimage: Can't read arch/mips/boot/vmlinux.gz.itb.tmp: Invalid argument
/usr/bin/mkimage Can't add hashes to FIT blob
Reported-by: kbuild test robot <lkp@intel.com>
Fixes: 28128c61e08e ("kconfig.h: Include compiler types to avoid missed struct attributes")
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull siginfo fix from Eric Biederman:
"This fixes a build error that only shows up on blackfin"
* 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
fs/signalfd: fix build error for BUS_MCEERR_AR
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto fix from Herbert Xu:
"Fix an oops in the s5p-sss driver when used with ecb(aes)"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: s5p-sss - Fix kernel Oops in AES-ECB mode
I recently noticed a crash on arm64 when feeding a bogus index
into BPF tail call helper. The crash would not occur when the
interpreter is used, but only in case of JIT. Output looks as
follows:
[ 347.007486] Unable to handle kernel paging request at virtual address fffb850e96492510
[ 347.043065] [fffb850e96492510] address between user and kernel address ranges
[ 347.050205] Internal error: Oops: 96000004 [#1] SMP
[ 347.190829] x13: 0000000000000000 x12: 0000000000000000
[ 347.196128] x11: fffc047ebe782800 x10: ffff808fd7d0fd10
[ 347.201427] x9 : 0000000000000000 x8 : 0000000000000000
[ 347.206726] x7 : 0000000000000000 x6 : 001c991738000000
[ 347.212025] x5 : 0000000000000018 x4 : 000000000000ba5a
[ 347.217325] x3 : 00000000000329c4 x2 : ffff808fd7cf0500
[ 347.222625] x1 : ffff808fd7d0fc00 x0 : ffff808fd7cf0500
[ 347.227926] Process test_verifier (pid: 4548, stack limit = 0x000000007467fa61)
[ 347.235221] Call trace:
[ 347.237656] 0xffff000002f3a4fc
[ 347.240784] bpf_test_run+0x78/0xf8
[ 347.244260] bpf_prog_test_run_skb+0x148/0x230
[ 347.248694] SyS_bpf+0x77c/0x1110
[ 347.251999] el0_svc_naked+0x30/0x34
[ 347.255564] Code: 9100075a d280220a 8b0a002a d37df04b (f86b694b)
In this case the index used in BPF r3 is the same as in r1
at the time of the call, meaning we fed a pointer as index;
here, it had the value 0xffff808fd7cf0500 which sits in x2.
While I found tail calls to be working in general (also for
hitting the error cases), I noticed the following in the code
emission:
# bpftool p d j i 988
38: ldr w10, [x1,x10]
3c: cmp w2, w10
40: b.ge 0x000000000000007c <-- signed cmp
44: mov x10, #0x20 // #32
48: cmp x26, x10
4c: b.gt 0x000000000000007c
50: add x26, x26, #0x1
54: mov x10, #0x110 // #272
58: add x10, x1, x10
5c: lsl x11, x2, #3
60: ldr x11, [x10,x11] <-- faulting insn (f86b694b)
64: cbz x11, 0x000000000000007c
Meaning, the tests passed because commit ddb55992b04d ("arm64:
bpf: implement bpf_tail_call() helper") was using signed compares
instead of unsigned which as a result had the test wrongly passing.
Change this but also the tail call count test both into unsigned
and cap the index as u32. Latter we did as well in 90caccdd8cc0
("bpf: fix bpf_tail_call() x64 JIT") and is needed in addition here,
too. Tested on HiSilicon Hi1616.
Result after patch:
# bpftool p d j i 268
3c: add w2, w2, #0x0
40: cmp w2, w10
44: b.cs 0x0000000000000080
48: mov x10, #0x20 // #32
4c: cmp x26, x10
50: b.hi 0x0000000000000080
54: add x26, x26, #0x1
58: mov x10, #0x110 // #272
5c: add x10, x1, x10
60: lsl x11, x2, #3
64: ldr x11, [x10,x11]
68: cbz x11, 0x0000000000000080
Fixes: ddb55992b04d ("arm64: bpf: implement bpf_tail_call() helper")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Implement a retpoline [0] for the BPF tail call JIT'ing that converts
the indirect jump via jmp %rax that is used to make the long jump into
another JITed BPF image. Since this is subject to speculative execution,
we need to control the transient instruction sequence here as well
when CONFIG_RETPOLINE is set, and direct it into a pause + lfence loop.
The latter aligns also with what gcc / clang emits (e.g. [1]).
JIT dump after patch:
# bpftool p d x i 1
0: (18) r2 = map[id:1]
2: (b7) r3 = 0
3: (85) call bpf_tail_call#12
4: (b7) r0 = 2
5: (95) exit
With CONFIG_RETPOLINE:
# bpftool p d j i 1
33: cmp %edx,0x24(%rsi)
36: jbe 0x0000000000000072 |*
38: mov 0x24(%rbp),%eax
3e: cmp $0x20,%eax
41: ja 0x0000000000000072 |
43: add $0x1,%eax
46: mov %eax,0x24(%rbp)
4c: mov 0x90(%rsi,%rdx,8),%rax
54: test %rax,%rax
57: je 0x0000000000000072 |
59: mov 0x28(%rax),%rax
5d: add $0x25,%rax
61: callq 0x000000000000006d |+
66: pause |
68: lfence |
6b: jmp 0x0000000000000066 |
6d: mov %rax,(%rsp) |
71: retq |
72: mov $0x2,%eax
* relative fall-through jumps in error case
+ retpoline for indirect jump
Without CONFIG_RETPOLINE:
# bpftool p d j i 1
36: jbe 0x0000000000000063 |*
3e: cmp $0x20,%eax
41: ja 0x0000000000000063 |
43: add $0x1,%eax
54: test %rax,%rax
57: je 0x0000000000000063 |
5d: add $0x25,%rax
61: jmpq *%rax |-
63: mov $0x2,%eax
- plain indirect jump as before
[0] https://support.google.com/faqs/answer/7625886
[1] https://github.com/gcc-mirror/gcc/commit/a31e654fa107be968b802786d747e962c2fcdb2b
At CPU hotunplug the corresponding per cpu matrix allocator is shut down and
the allocated interrupt bits are discarded under the assumption that all
allocated bits have been either migrated away or shut down through the
managed interrupts mechanism.
This is not true because interrupts which are not started up might have a
vector allocated on the outgoing CPU. When the interrupt is started up
later or completely shutdown and freed then the allocated vector is handed
back, triggering warnings or causing accounting issues which result in
suspend failures and other issues.
Change the CPU hotplug mechanism of the matrix allocator so that the
remaining allocations at unplug time are preserved and global accounting at
hotplug is correctly readjusted to take the dormant vectors into account.
Fixes: 2f75d9e1c905 ("genirq: Implement bitmap matrix allocator")
Link: https://lkml.kernel.org/r/20180222112316.849980972@linutronix.de
Fix build error in fs/signalfd.c by using same method that is used in
kernel/signal.c: separate blocks for different signal si_code values.
./fs/signalfd.c: error: 'BUS_MCEERR_AR' undeclared (first use in this function)
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
All the kernel_sendmsg() calls in rxrpc_send_data_packet() need to send
both parts of the iov[] buffer, but one of them does not. Fix it so that
it does.
Without this, short IPv6 rxrpc DATA packets may be seen that have the rxrpc
header included, but no payload.
Fixes: 5a924b8951f8 ("rxrpc: Don't store the rxrpc header in the Tx queue sk_buffs")
Reported-by: Marc Dionne <marc.dionne@auristor.com>
We should check "self->aq_hw" for allocation failure, and also we should
free it on the error paths.
Fixes: 23ee07ad3c2f ("net: aquantia: Cleanup pci functions module")
