Record and propagate NUMA information for devices.
No longer exists.
This is handled with config options now.
We'll need this to handle NUMA properly on some systems.
We have to do it like this before we can move the PROM and MDESC device
tree code over to using lmb_alloc().
This allows us to kill the incredibly complicated and stupid function
trim_pavail().
Call lmb_add() on available regions, and call lmb_reserve()
on the main kernel image and the ramdisk (if any).
And add some comments explaining all of the quirks involved in
the way the bootloader provides this information.
Changeset d9024df02ffe74d723d97d552f86de3b34beb8cc ("[LMB] Restructure
allocation loops to avoid unsigned underflow") removed the alignment
of the 'size' argument to call lmb_add_region() done by __lmb_alloc_base().
In doing so it reintroduced the bug fixed by changeset
eea89e13a9c61d3928223d2f9bf2295e22e0efb6 ("[LMB]: Fix bug in
__lmb_alloc_base().").
This puts it back.
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/ipath: Correct capitalization "IntX" -> "INTx"
IB/ipath: Remove tests of PCI_MSI in ipath_iba7220.c
IB/ipath: Remove dependency on PCI_MSI || HT_IRQ
IB/ipath: Build IBA7220 code unconditionally
IB/ipath: Remove reference to dev->class_dev
IB/ipath: Fix module parameter description for disable_sma
RDMA/nes: Remove unneeded function declarations
Fix up conflict in drivers/infiniband/hw/ipath/ipath_verbs.c (by picking
the solution from the infiniband branch)
Match what the PCI specification uses.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The PCI MSI interface is stubbed out properly so that all the
functions just return failure if PCI_MSI=n, so there's no reason to
have "#ifdef CONFIG_PCI_MSI" blocks in ipath_iba7220.c.
Before IBA7220 support was added, the ipath driver didn't support any
hardware unless PCI_MSI and/or HT_IRQ was enabled. However, the
IBA7220 can generate INTx interrupts, so it makes sense to allow the
driver to be build even if PCI_MSI=n and HT_IRQ=n.
The new IBA7220 code added a call to ipath_init_iba7220_funcs() that
is compiled unconditionally, but only built the IBA7220 code if
PCI_MSI is enabled. Fix this by building the IBA7220 file
unconditonally.
This fixes build breakage when PCI_MSI=n, HT_IRQ=y and
INFINIBAND_IPATH=y reported by Ingo Molnar <mingo@elte.hu>:
drivers/built-in.o: In function `ipath_init_one':
ipath_driver.c:(.devinit.text+0x1e5bc): undefined reference to `ipath_init_iba7220_funcs'
Commit 124b4dcb ("IB/ipath: add calls to new 7220 code and enable in
build") inadvertently added core to set dev->class_dev.dev back into
ib_ipath. This is completely redundant since commit 1912ffbb ("IB: Set
class_dev->dev in core for nice device symlink"), which removed
class_dev setting from low-level drivers, and also will break the build
when class_dev is removed completely from struct ib_device.
Describe disable_sma parameter with its name rather than the internal
ib_ipath_disable_sma variable name, so that the description shows up
properly in modinfo.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Ralph Campbell <ralph.campbell@qlogic.com>
Remove redundant static declarations of functions that are defined
before they are used in the source.
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (26 commits)
mmc: sdio_ops.c should #include "sdio_ops.h"
mmc: proper prototypes for mmc_attach_*()
mmc: make __mmc_release_bus() static
sdhci: improve no card, no reset quirk
MMC: OMAP: Do not busy wait for end of command for ever
MMC: OMAP: Start new commands from work queue instead of irq
MMC: OMAP: Lazy clock shutdown
MMC: OMAP: Move failing command abortion to workqueue
MMC: OMAP: Use tasklet instead of workqueue for cover switch notification
MMC: OMAP: Check the get_cover_state function pointer if not set
MMC: OMAP: Using setup_timer instead of init_timer
MMC: OMAP: Abort stuck commands
MMC: OMAP: General cleanup for MMC multislot support
MMC: OMAP: Power functions modified to MMC multislot support
MMC: OMAP: Fix timeout calculation for MMC multislot support
MMC: OMAP: New release dma and abort xfer functions
MMC: OMAP: Add back cover switch support
MMC: OMAP: Introduce new multislot structure and change driver to use it
MMC: OMAP: Remove cover switch handling to allow adding multislot support
MMC: OMAP: Fix the BYTEBLOCK capability removal
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC]: Remove SunOS and Solaris binary support.
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits)
DOC: A couple corrections and clarifications in USB doc.
Generate a slightly more informative error msg for bad HZ
fix typo "is" -> "if" in Makefile
ext*: spelling fix prefered -> preferred
DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs.
KEYS: Fix the comment to match the file name in rxrpc-type.h.
RAID: remove trailing space from printk line
DMA engine: typo fixes
Remove unused MAX_NODES_SHIFT
MAINTAINERS: Clarify access to OCFS2 development mailing list.
V4L: Storage class should be before const qualifier (sn9c102)
sonypi: Storage class should be before const qualifier
intel_menlow: Storage class should be before const qualifier
DVB: Storage class should be before const qualifier
arm: Storage class should be before const qualifier
ALSA: Storage class should be before const qualifier
acpi: Storage class should be before const qualifier
firmware_sample_driver.c: fix coding style
MAINTAINERS: Add ati_remote2 driver
Fixed up trivial conflicts in firmware_sample_driver.c
* 'for-2.6.26' of git://git.kernel.dk/linux-2.6-block:
block: fix blk_register_queue() return value
block: fix memory hotplug and bouncing in block layer
block: replace remaining __FUNCTION__ occurrences
Kconfig: clean up block/Kconfig help descriptions
cciss: fix warning oops on rmmod of driver
cciss: Fix race between disk-adding code and interrupt handler
block: move the padding adjustment to blk_rq_map_sg
block: add bio_copy_user_iov support to blk_rq_map_user_iov
block: convert bio_copy_user to bio_copy_user_iov
loop: manage partitions in disk image
cdrom: use kmalloced buffers instead of buffers on stack
cdrom: make unregister_cdrom() return void
cdrom: use list_head for cdrom_device_info list
cdrom: protect cdrom_device_info list by mutex
cdrom: cleanup hardcoded error-code
cdrom: remove ifdef CONFIG_SYSCTL
This patch removes the no longer used export of kmap_atomic_to_page.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
HARD_RESET_NOW() was unused.
And one of the few remaining cli() users.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6:
SELinux: one little, two little, three little whitespaces, the avc.c saga.
SELinux: cleanup on isle selinuxfs.c
changing whitespace for fun and profit: policydb.c
SELinux: whitespace and formating fixes for hooks.c
SELinux: clean up printks
SELinux: sidtab.c whitespace, syntax, and static declaraction cleanups
SELinux: services.c whitespace, syntax, and static declaraction cleanups
SELinux: mls.c whitespace, syntax, and static declaraction cleanups
SELinux: hashtab.c whitespace, syntax, and static declaraction cleanups
SELinux: ebitmap.c whitespace, syntax, and static declaraction cleanups
SELinux: conditional.c whitespace, syntax, and static declaraction cleanups
SELinux: avtab.c whitespace, syntax, and static declaraction cleanups
SELinux: xfrm.c whitespace, syntax, and static declaraction cleanups
SELinux: nlmsgtab.c whitespace, syntax, and static declaraction cleanups
SELinux: netnode.c whitespace, syntax, and static declaraction cleanups
SELinux: netlink.c whitespace, syntax, and static declaraction cleanups
SELinux: netlabel.c whitespace, syntax, and static declaraction cleanups
SELinux: netif.c whitespace, syntax, and static declaraction cleanups
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: (42 commits)
PCI: Change PCI subsystem MAINTAINER
PCI: pci-iommu-iotlb-flushing-speedup
PCI: pci_setup_bridge() mustn't be __devinit
PCI: pci_bus_size_cardbus() mustn't be __devinit
PCI: pci_scan_device() mustn't be __devinit
PCI: pci_alloc_child_bus() mustn't be __devinit
PCI: replace remaining __FUNCTION__ occurrences
PCI: Hotplug: fakephp: Return success, not ENODEV, when bus rescan is triggered
PCI: Hotplug: Fix leaks in IBM Hot Plug Controller Driver - ibmphp_init_devno()
PCI: clean up resource alignment management
PCI: aerdrv_acpi.c: remove unneeded NULL check
PCI: Update VIA CX700 quirk
PCI: Expose PCI VPD through sysfs
PCI: iommu: iotlb flushing
PCI: simplify quirk debug output
PCI: iova RB tree setup tweak
PCI: parisc: use generic pci_enable_resources()
PCI: ppc: use generic pci_enable_resources()
PCI: powerpc: use generic pci_enable_resources()
PCI: ia64: use generic pci_enable_resources()
A couple of corrections and clarifications in USB
documentation.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
[HWRNG] omap: Minor updates
[CRYPTO] kconfig: Ordering cleanup
[CRYPTO] all: Clean up init()/fini()
[CRYPTO] padlock-aes: Use generic setkey function
[CRYPTO] aes: Export generic setkey
[CRYPTO] api: Make the crypto subsystem fully modular
[CRYPTO] cts: Add CTS mode required for Kerberos AES support
[CRYPTO] lrw: Replace all adds to big endians variables with be*_add_cpu
[CRYPTO] tcrypt: Change the XTEA test vectors
[CRYPTO] tcrypt: Shrink the tcrypt module
[CRYPTO] tcrypt: Change the usage of the test vectors
[CRYPTO] api: Constify function pointer tables
[CRYPTO] aes-x86-32: Remove unused return code
[CRYPTO] tcrypt: Shrink speed templates
[CRYPTO] tcrypt: Group common speed templates
[CRYPTO] sha512: Rename sha512 to sha512_generic
[CRYPTO] sha384: Hardware acceleration for s390
[CRYPTO] sha512: Hardware acceleration for s390
[CRYPTO] s390: Generic sha_update and sha_final
[CRYPTO] api: Switch to proc_create()
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6
* 'irq-cleanups-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6:
[ISDN] minor irq handler cleanups
drivers/char: minor irq handler cleanups
[PPC] minor irq handler cleanups
[BLACKFIN] minor irq handler cleanups
[SPARC] minor irq handler cleanups
ARM minor irq handler cleanup: avoid passing unused info to irq
in include/linux/jiffies.h
* 'isdn-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6:
[ISDN] Hisax: eliminate many unnecessary references to CardType[]
[ISDN] HiSax: modularization prep
It should be "if" but is written as "is"..
Signed-off-by: Uwe Kleine-Koenig <Uwe.Kleine-Koenig@digi.com>
This adds support for PTRACE_GETSIGINFO and PTRACE_SETSIGINFO in
compat_ptrace_request. It relies on existing arch definitions for
copy_siginfo_to_user32 and copy_siginfo_from_user32.
On powerpc, this fixes a longstanding regression of 32-bit ptrace
calls on 64-bit kernels vs native calls (64-bit calls or 32-bit
kernels). This can be seen in a 32-bit call using PTRACE_GETSIGINFO
to examine e.g. siginfo_t.si_addr from a signal that sets it.
(This was broken as of 2.6.24 and, I presume, many or all prior versions.)
Signed-off-by: Roland McGrath <roland@redhat.com>
Add kernel-doc notation for ndisc_nodetype:
Warning(linux-2.6.25-git2//include/linux/skbuff.h:340): No description found for parameter 'ndisc_nodetype'
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits)
[POWERPC] Fix compile breakage for 64-bit UP configs
[POWERPC] Define copy_siginfo_from_user32
[POWERPC] Add compat handler for PTRACE_GETSIGINFO
[POWERPC] i2c: Fix build breakage introduced by OF helpers
[POWERPC] Optimize fls64() on 64-bit processors
[POWERPC] irqtrace support for 64-bit powerpc
[POWERPC] Stacktrace support for lockdep
[POWERPC] Move stackframe definitions to common header
[POWERPC] Fix device-tree locking vs. interrupts
[POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const
[POWERPC] Remove unused __max_memory variable
[POWERPC] Simplify xics direct/lpar irq_host setup
[POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ()
[POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade()
[POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c
[POWERPC] Use asm-generic/bitops/find.h in bitops.h
[POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup
[POWERPC] 85xx: Fix the size of qe muram for MPC8568E
[POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier.
[POWERPC] 86xx: mark functions static, other minor cleanups
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits)
SCSI: convert struct class_device to struct device
DRM: remove unused dev_class
IB: rename "dev" to "srp_dev" in srp_host structure
IB: convert struct class_device to struct device
memstick: convert struct class_device to struct device
driver core: replace remaining __FUNCTION__ occurrences
sysfs: refill attribute buffer when reading from offset 0
PM: Remove destroy_suspended_device()
Firmware: add iSCSI iBFT Support
PM: Remove legacy PM (fix)
Kobject: Replace list_for_each() with list_for_each_entry().
SYSFS: Explicitly include required header file slab.h.
Driver core: make device_is_registered() work for class devices
PM: Convert wakeup flag accessors to inline functions
PM: Make wakeup flags available whenever CONFIG_PM is set
PM: Fix misuse of wakeup flag accessors in serial core
Driver core: Call device_pm_add() after bus_add_device() in device_add()
PM: Handle device registrations during suspend/resume
block: send disk "change" event for rescan_partitions()
sysdev: detect multiple driver registrations
Fixed trivial conflict in include/linux/memory.h due to semaphore header
file change (made irrelevant by the change to mutex).
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
rose: Socket lock was not released before returning to user space
hci_usb: remove code obfuscation
drivers/net/appletalk: use time_before, time_before_eq, etc
drivers/atm: use time_before, time_before_eq, etc
hci_usb: do not initialize static variables to 0
tg3: 5701 DMA corruption fix
atm nicstar: Removal of debug code containing deprecated calls to cli()/sti()
iwlwifi: Fix unconditional access to station->tidp[].agg.
netfilter: Fix SIP conntrack build with NAT disabled.
netfilter: Fix SCTP nat build.
Spelling fix: prefered -> preferred
Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org>
git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: (25 commits)
avr32: Add hardware power-down function call
avr32: add include/asm-avr32/serial.h
avr32: don't offer PARPORT_PC
avr32: don't offer CONFIG_GEN_RTC
avr32: don't offer CONFIG_RTC
add include/asm-avr32/xor.h
avr32: Remove two unused #defines from mm/init.c
avr32: Implement set_rate(), set_parent() and mode() for pll1
avr32: Generic clockevents support
avr32: Move sleep code into mach-at32ap
avr32: Use constants from sysreg.h in asm.h
avr32: Delete mostly unused header asm/intc.h
avr32: start clocksource cleanup
avr32: pass i2c board info through at32_add_device_twi
avr32: cleanup - use _AC macro to define PAGE_SIZE
Generate raw keyboard codes for AVR32 architecture
atmel_usba_udc: Add support for AT91CAP9 UDPHS
atmel_usba_udc: Add missing kfree() in usba_udc_remove()
atmel_usba_udc: move endpoint declarations into platform data.
atmel_usba_udc: Kill GPIO_PIN_NONE
git://git.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-hrt
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-hrt:
hrtimer: optimize the softirq time optimization
hrtimer: reduce calls to hrtimer_get_softirq_time()
clockevents: fix typo in tick-broadcast.c
jiffies: add time_is_after_jiffies and others which compare with jiffies
drivers/md/*.[ch] contains only one more printk line with a trailing space.
Remove it.
Signed-off-by: Nick Andrew <nick@nick-andrew.net>
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc
* 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc:
Deprecate the asm/semaphore.h files in feature-removal-schedule.
Convert asm/semaphore.h users to linux/semaphore.h
security: Remove unnecessary inclusions of asm/semaphore.h
lib: Remove unnecessary inclusions of asm/semaphore.h
kernel: Remove unnecessary inclusions of asm/semaphore.h
include: Remove unnecessary inclusions of asm/semaphore.h
fs: Remove unnecessary inclusions of asm/semaphore.h
drivers: Remove unnecessary inclusions of asm/semaphore.h
net: Remove unnecessary inclusions of asm/semaphore.h
arch: Remove unnecessary inclusions of asm/semaphore.h
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (212 commits)
[ARM] pxa: Phycore pcm-990-specific code for the PXA270 Quick Capture driver
[ARM] pxa: V4L2 soc_camera driver for PXA270
[ARM] pxa: restrict availability of pxa2xx PCMCIA drivers
[ARM] 5005/1: BAST: Fix kset_name initialiser
[ARM] 4967/1: Adds functions to set clkout rate for Samsung S3C2410
[ARM] 4988/1: Add GPIO lib support to the EP93xx
[ARM] Add initial sparsemem support
[ARM] pxa: initialise PXA devices before platform init code
[ARM] 5002/1: tosa: add two more leds
[ARM] 5004/1: Tosa: make several unreferenced structures static.
[ARM] 5003/1: Shut up sparse warnings
[ARM] 4977/2: soc - pxa2xx-ac97 - Add missing clk_enable()
[ARM] 4976/1: zylonite: Configure GPIO for WM9713 IRQ line
[ARM] 4974/1: Drop unused leds-tosa.
[ARM] 4973/1: Tosa: use leds-gpio driver.
[ARM] 4972/1: Tosa: convert scoop GPIOs usage to generic gpio code
[ARM] 4971/1: pxaficp_ir: provide startup and shutdown hooks
[ARM] pxa: lubbock: move mis-placed SPI info
[ARM] 4970/1: tosa: correct gpio used for wake up.
[ARM] 4966/1: magician: add MFP pin configuration
