'misc', 'red-hat-bz-727865', 'thermal', 'throttling', 'turbostat' and 'video' into release
Signed-off-by: Len Brown <len.brown@intel.com>
Using a u64 here creates an endian bug. We store a u32 number in the
top byte which is a larger number than intended on big endian systems.
There is no reason to use a 64 bit data type here, I guess it was just
an oversight.
I removed the initialization to zero as well. It's needed with a u64
but with a u32, the variable gets initialized properly inside the call
to acpi_os_read_port().
On a system on the thermal limit these are quite noisy and flood the logs.
Better would be a counter anyways. But given that we don't even have
anything for normal throttling this doesn't seem to be urgent either.
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
been allocated
Quoth Dmitry Torokhov:
In addition to bus notifier we do install device notifier explicitly
so it might fire up early. The easiest fox would be to move
acpi_video_bus_start_devices() after input_allocate_device() but
before input_register_device() - unregistered input devices can handle
input_event() calls just fine.
May fix crashes reported in:
https://bugzilla.kernel.org/show_bug.cgi?id=40672
Signed-off-by: Igor Murzov <e-mail@date.by>
It is always better to check return values, so add some new checks and
correct existing ones.
v2: Be consistent and don't mix errors from -E* and AE_* namespaces.
ACPI 5.0 adds the BGRT, a table that contains a pointer to the firmware
boot splash and associated metadata. This simple driver exposes it via
/sys/firmware/acpi in order to allow bootsplash applications to draw their
splash around the firmware image and reduce the number of jarring graphical
transitions during boot.
Drivers may wish to add entries to /sys/firmware/acpi, so export acpi_kobj
in order to let them do that.
Clean the redundant codes of apci_bus_get_power_flags().
Signed-off-by: Alex He <alex.he@amd.com>
The acpi_processor_cst_has_changed() function is invoked from a
CPU_ONLINE or CPU_DEAD function, which might well execute on CPU 0
even though the CPU being hotplugged is some other CPU. In addition,
acpi_processor_cst_has_changed() invokes smp_processor_id() without
protection, resulting in splats when onlining CPUs.
This commit therefore changes the smp_processor_id() to pr->id, as is
used elsewhere in the code, for example, in acpi_processor_add().
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Tested-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
... so that acpi_unmap()'s behavior gets in sync with acpi_map()'s.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
During testing pci root bus removal, found some root bus bridge is not freed.
If booting with pnpacpi=off, those hostbridge could be freed without problem.
It turns out that some devices reference are not released during acpi_pnp_match.
that match should not hold one device ref during every calling.
Add pu_device calling before returning.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: stable@vger.kernel.org
When processor is being hot-added to the system, acpi_map_lsapic invokes
ACPI _MAT method to find APIC ID and flags, verifies that returned structure
is indeed ACPI's local APIC structure, and that flags contain MADT_ENABLED
bit. Then saves APIC ID, frees structure - and accesses structure when
computing arguments for acpi_register_lapic call. Which sometime leads
to acpi_register_lapic call being made with second argument zero, failing
to bring processor online with error 'Unable to map lapic to logical cpu
number'.
As lapic->lapic_flags & ACPI_MADT_ENABLED was already confirmed to be non-zero
few lines above, we can just pass unconditional ACPI_MADT_ENABLED to the
acpi_register_lapic.
Signed-off-by: Petr Vandrovec <petr@vmware.com>
Signed-off-by: Alok N Kataria <akataria@vmware.com>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
The function acpi_processor_add is stored in the ops.add field of a
acpi_driver structure. This function is then called in
acpi_bus_driver_init. On failure, this function clears the field
device->driver_data, but does not free its contents. Thus the free has to
be done by the add function. In acpi_processor_add, the corresponding
value is pr. This value is currently freed on failure before storing it in
device->driver_data, but not after. This free is added in the error
handling code at the end of the function. The per_cpu variable
processors is also cleared so that it does not refer to a dangling pointer.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
power_usage is always assigned a negative value and should be declared
a signed integer
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
Currently when a CPU is off-lined it enters either MWAIT-based idle or,
if MWAIT is not desired or supported, HLT-based idle (which places the
processor in C1 state). This patch allows processors without MWAIT
support to stay in states deeper than C1.
acpi_processor_install_hotplug_notify() registers processor objects to
receive ACPI CPU hotplug event notifications. This patch additionally
registers processor device objects (ACPI0007) to receive the notifications
as well.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Bjorn Helgaas <bhelgaas@google.com>
Print physical address info in a style consistent with the %pR style used
elsewhere in the kernel.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
An HP laptop (Pavilion G4-1016tx) has the following code in _TMP:
Store (\_SB.PCI0.LPCB.EC0.RTMP, Local0)
If (LGreaterEqual (Local0, S4TP))
Store (One, HTS4)
S4TP is initialised at 0 and not programmed further until either _HOT or
_CRT is called. If we evaluate _TMP before the trip points then HTS4 will
always be set, causing the firmware to generate a message on boot
complaining that the system shut down because of overheating. The simplest
solution is just to reverse the checking of trip points and _TMP in thermal
init.
As far as I can see, this field is never used in the code.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
All the modules name are ro-data, it is never copied to the array.
eg.
static struct cpuidle_driver intel_idle_driver = {
.name = "intel_idle",
.owner = THIS_MODULE,
It safe to assign the pointer of this ro-data to a const char *.
By this way we save 12 bytes.
Tested-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
If the state_count is not initialized for the device use
the driver's state count as the default. That will prevent
to add it manually in the cpuidle driver initialization
routine and will save us from duplicate line of code.
Some C states of new CPU might be not good. One reason is BIOS might
configure them incorrectly. To help developers root cause it quickly, the
patch adds a new sysfs entry, so developers could disable specific C state
manually.
In addition, C state might have much impact on performance tuning, as it
takes much time to enter/exit C states, which might delay interrupt
processing. With the new debug option, developers could check if a deep C
state could impact performance and how much impact it could cause.
Also add this option in Documentation/cpuidle/sysfs.txt.
[akpm@linux-foundation.org: check kstrtol return value]
Signed-off-by: ShuoX Liu <shuox.liu@intel.com>
Reviewed-by: Yanmin Zhang <yanmin_zhang@intel.com>
Reviewed-and-Tested-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Version 20120320.
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Repair a common problem with objects that are defined to return
a variable-length Package of sub-objects. If there is only one
sub-object, some BIOS code mistakenly simply declares the single
object instead of a Package with one sub-object. This function
attempts to repair this error by wrapping a Package object around
the original object, creating the correct and expected Package
Some ACPI interrupt actions may need to wait, and it's easiest to
have a thread context for this. So turn the ACPI interrupt
into a threaded interrupt.
WARN() is not supposed to have side effects, so move the request_regions
outside.
Sometimes users have turbostat running in interval mode
when they take processors offline/online.
Previously, turbostat would survive, but not gracefully.
Tighten up the error checking so turbostat notices
changesn sooner, and print just 1 line on change:
turbostat: re-initialized with num_cpus %d
turbostat uses /dev/cpu/*/msr interface to read MSRs.
For modern systems, it reads 10 MSR/CPU. This can
be observed as 10 "Function Call Interrupts"
per CPU per sample added to /proc/interrupts.
This overhead is measurable on large idle systems,
and as Yoquan Song pointed out, it can even trick
cpuidle into thinking the system is busy.
Here turbostat re-schedules itself in-turn to each
CPU so that its MSR reads will always be local.
This replaces the 10 "Function Call Interrupts"
with a single "Rescheduling interrupt" per sample
per CPU.
On an idle 32-CPU system, this shifts some residency from
the shallow c1 state to the deeper c7 state:
# ./turbostat.old -s
%c0 GHz TSC %c1 %c3 %c6 %c7 %pc2 %pc3 %pc6 %pc7
0.27 1.29 2.29 0.95 0.02 0.00 98.77 20.23 0.00 77.41 0.00
0.25 1.24 2.29 0.98 0.02 0.00 98.75 20.34 0.03 77.74 0.00
0.27 1.22 2.29 0.54 0.00 0.00 99.18 20.64 0.00 77.70 0.00
0.26 1.22 2.29 1.22 0.00 0.00 98.52 20.22 0.00 77.74 0.00
0.26 1.38 2.29 0.78 0.02 0.00 98.95 20.51 0.05 77.56 0.00
^C
i# ./turbostat.new -s
0.27 1.20 2.29 0.24 0.01 0.00 99.49 20.58 0.00 78.20 0.00
0.27 1.22 2.29 0.25 0.00 0.00 99.48 20.79 0.00 77.85 0.00
0.27 1.20 2.29 0.25 0.02 0.00 99.46 20.71 0.03 77.89 0.00
0.28 1.26 2.29 0.25 0.01 0.00 99.46 20.89 0.02 77.67 0.00
0.27 1.20 2.29 0.24 0.01 0.00 99.48 20.65 0.00 78.04 0.00
cc: Youquan Song <youquan.song@intel.com>
turbostat -s
cuts down on the amount of output, per user request.
also treak some output whitespace and the man page.
Move linux specific module parameter gts and bfs out of ACPICA core
code to sleep.c.
Enhanced the sleep/wake interfaces to optionally execute the
_GTS method (Going To Sleep), and the _BFS method (Back From
Sleep). Windows apparently does not execute these methods, and
therefore these methods are often untested. It has been seen on
some systems where the execution of these methods causes errors
and also prevents the machine from entering S5. It is therefore
suggested that host operating systems do not execute these methods
by default. In the future, perhaps these methods can be optionally
executed based on the age of the system and/or what is the newest
version of Windows that the BIOS asks for via _OSI.
On Intel CPUs the processor typically uses the highest frequency
set by any logical CPU. When the system overheats
Linux first forces the frequency to the lowest available one
to lower the temperature.
However this was done only per logical CPU, which means all
logical CPUs in a package would need to go through this before
the frequency is actually lowered.
Worse this delay actually prevents real throttling, because
the real throttle code only proceeds when the lowest frequency
is already reached.
So when a throttle event happens force the lowest frequency
for all CPUs in the package where it happened. The per CPU
state is now kept per package, not per logical CPU. An alternative
would be to do it per cpufreq unit, but since we want to bring
down the temperature of the complete chip it's better
to do it for all.
In principle it may even make sense to do it for all CPUs,
but I kept it on the package for now.
With this change the frequency is actually lowered, which
in terms also allows real throttling to proceed.
I also removed an unnecessary per cpu variable initialization.
v2: Fix package mapping
Cc: <stable@vger.kernel.org>
Many namespace node types must have an attached object. For
these node types, print a message about a missing object during
a namespace dump.
Change the returned exception code from AE_BAD_PARAMETER to the
more appropriate AE_BAD_PATHNAME, when the input pathname to
evaluate object is invalid.
Changed the METHOD_NAME* defines that define a full pathname to
the method to METHOD_PATHNAME* in order to make it clear that
it is not a simple 4-character ACPI name. Used for the various
sleep/wake methods.
Version 20120215.
Simplifies the code, especially the compile-time
ACPI_REDUCED_HARDWARE option.
The functions for the original/legacy sleep/wake registers are in
hwsleep.c, and the functions for the new extended FADT V5 sleep
registers are in hwesleep.c
Adds acpi_hw_execute_sleep_method to handle the various sleep methods
such as _GTS, _BFS, _WAK, and _SST. Removes the specialized
functions previously used for each of these methods.
This interface allows the host to override a table via a
physical address, instead of the logical address required by
acpi_os_table_override. This simplifies the host implementation.
Initial implementation by Thomas Renninger. ACPICA implementation
creates a single function for table overrides that attempts both
a logical and a physical override.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Add new notify values, add support for "hardware specific" notifies.
This change expands acpi_os_read_memory and acpi_os_write_memory to a
full 64 bits. This allows 64 bit transfers via the acpi_read and
acpi_write interfaces. Note: The internal acpi_hw_read and acpi_hw_write
interfaces remain at 32 bits, because 64 bits is not needed to
access the standard ACPI registers.
Add ACPI_REDUCED_HARDWARE flag that removes all hardware-related
code (about 10% code, 5% static data).
These prototypes were incorrectly declared in achware.h.
Adds sleep and wake support for systems with these registers.
One new file, hwxfsleep.c
_REV returns the supported ACPI revision level, which is now 5.
The recent cpuidle consolidation changes erroneously omitted one
critical line of code.
Signed-off-by: Robert Lee <rob.lee@linaro.org>
Tested-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Basically without this patch changing the mode of thermal zone
is not possible as wrong string size is passed to strncmp.
Signed-off-by: Amit Daniel Kachhap <amit.kachhap@linaro.org>
Acked-by: Jean Delvare <khali@linux-fr.org>
thermal_zone_device_register() never returns NULL, on error it returns and
ERR_PTR().
Reviewed-by: Viresh Kumar <viresh.kumar@st.com>
Reviewed-by: Vincenzo Frascino <vincenzo.frascino@st.com>
readl/writel versions for ARM contain memory barrier instruction for
synchronizing DMA buffers. These are not required at least on this
module. So use lighter _relaxed variants.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
