From Maor Gottlieb says:
This series extends __sg_alloc_table_from_pages to allow chaining of new
pages to an already initialized SG table.
This allows for drivers to utilize the optimization of merging contiguous
pages without a need to pre allocate all the pages and hold them in a very
large temporary buffer prior to the call to SG table initialization.
The last patch changes the Infiniband core to use the new API. It removes
duplicate functionality from the code and benefits from the optimization
of allocating dynamic SG table from pages.
In huge pages system of 2MB page size, without this change, the SG table
would contain x512 SG entries.
* branch 'dynamic_sg':
RDMA/umem: Move to allocate SG table from pages
lib/scatterlist: Add support in dynamic allocation of SG table from pages
tools/testing/scatterlist: Show errors in human readable form
tools/testing/scatterlist: Rejuvenate bit-rotten test
Was missed during the initial review of the below patch
Fixes: 227a0e142e37 ("IB/mlx4: Add support for REJ due to timeout")
Link: https://lore.kernel.org/r/1602253482-6718-1-git-send-email-haakon.bugge@oracle.com
Signed-off-by: Håkon Bugge <haakon.bugge@oracle.com>
Signed-off-by: Jason Gunthorpe <jgg@nvidia.com>
Fix a bug in rxe_rcv() that causes all multicast packets to be
dropped. Currently rxe_match_dgid() is called for each packet to verify
that the destination IP address matches one of the entries in the port
source GID table. This is incorrect for IP multicast addresses since they
do not appear in the GID table.
Add code to detect multicast addresses.
Change function name to rxe_chk_dgid() which is clearer.
Link: https://lore.kernel.org/r/20201008212753.265249-1-rpearson@hpe.com
Signed-off-by: Bob Pearson <rpearson@hpe.com>
The changes referenced below replaced sbk_clone)_ by taking additional
references, passing the skb along and then freeing the skb. This
deleted the packets before they could be processed and additionally
passed bad data in each packet. Since pkt is stored in skb->cb
changing pkt->qp changed it for all the packets.
Replace skb_get() by sbk_clone() in rxe_rcv_mcast_pkt() for cases where
multiple QPs are receiving multicast packets on the same address.
Delete kfree_skb() because the packets need to live until they have been
processed by each QP. They are freed later.
Fixes: 86af61764151 ("IB/rxe: remove unnecessary skb_clone")
Fixes: fe896ceb5772 ("IB/rxe: replace refcount_inc with skb_get")
Link: https://lore.kernel.org/r/20201008203651.256958-1-rpearson@hpe.com
Struct rxe_mem had pd, lkey and rkey values both in itself and in the
struct ib_mr which is also included in rxe_mem.
Delete these entries and replace references with the ones in ibmr.Add
mr_pd, mr_lkey and mr_rkey macros which extract these values from mr.
Link: https://lore.kernel.org/r/20201008212818.265303-1-rpearson@hpe.com
Intel has spun off the Omni-Path Architecture group which is now a new
company known as Cornelis Networks. Updating the MAINTAINERS file to
reflect this change and our new email addresses.
Link: https://lore.kernel.org/r/20201008171803.189100.43448.stgit@awfm-01.aw.intel.com
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@cornelisnetworks.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@cornelisnetworks.com>
An incorrect sizeof is being used, struct rvt_ibport ** is not correct, it
should be struct rvt_ibport *. Note that since ** is the same size as
* this is not causing any issues. Improve this fix by using
sizeof(*rdi->ports) as this allows us to not even reference the type
of the pointer. Also remove line breaks as the entire statement can
fit on one line.
Link: https://lore.kernel.org/r/20201008095204.82683-1-colin.king@canonical.com
Addresses-Coverity: ("Sizeof not portable (SIZEOF_MISMATCH)")
Fixes: ff6acd69518e ("IB/rdmavt: Add device structure allocation")
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
Acked-by: Dennis Dalessandro <dennis.dalessandro@cornelisnetworks.com>
Parvi Kaustubhi's email bounces.
Link: https://lore.kernel.org/r/f7726a1873f14972f137f64a4d6cd35e530c6c95.camel@perches.com
Acked-by: Christian Benvenuti <benve@cisco.com>
An incorrect sizeof is being used, u64 * is not correct, it should be just
u64 for a table of umem_pgs number of u64 items in the pbl_tbl. Use the
idiom sizeof(*pbl_tbl) to get the object type without the need to
explicitly use u64.
Link: https://lore.kernel.org/r/20201006114700.537916-1-colin.king@canonical.com
Fixes: 1ac5a4047975 ("RDMA/bnxt_re: Add bnxt_re RoCE driver")
This driver is taking the SGL out of the umem and passing it through a
struct bnxt_qplib_sg_info. Instead of passing the SGL pass the umem and
then use rdma_umem_for_each_dma_block() directly.
Move the calls of ib_umem_num_dma_blocks() closer to their actual point of
use, npages is only set for non-umem pbl flows.
Link: https://lore.kernel.org/r/0-v1-b37437a73f35+49c-bnxt_re_dma_block_jgg@nvidia.com
Acked-by: Selvin Xavier <selvin.xavier@broadcom.com>
Tested-by: Selvin Xavier <selvin.xavier@broadcom.com>
Remove the implementation of ib_umem_add_sg_table and instead
call to __sg_alloc_table_from_pages which already has the logic to
merge contiguous pages.
Besides that it removes duplicated functionality, it reduces the
memory consumption of the SG table significantly. Prior to this
patch, the SG table was allocated in advance regardless consideration
of contiguous pages.
E.g. for 100GB memory registration:
Number of entries Size
Before 26214400 600.0MB
After 51200 1.2MB
Link: https://lore.kernel.org/r/20201004154340.1080481-5-leon@kernel.org
Signed-off-by: Maor Gottlieb <maorg@nvidia.com>
Signed-off-by: Leon Romanovsky <leonro@nvidia.com>
Extend __sg_alloc_table_from_pages to support dynamic allocation of
SG table from pages. It should be used by drivers that can't supply
all the pages at one time.
This function returns the last populated SGE in the table. Users should
pass it as an argument to the function from the second call and forward.
As before, nents will be equal to the number of populated SGEs (chunks).
With this new extension, drivers can benefit the optimization of merging
contiguous pages without a need to allocate all pages in advance and
hold them in a large buffer.
E.g. with the Infiniband driver that allocates a single page for hold the
pages. For 1TB memory registration, the temporary buffer would consume only
4KB, instead of 2GB.
Link: https://lore.kernel.org/r/20201004154340.1080481-2-leon@kernel.org
Instead of just asserting dump some more useful info about what the test
saw versus what it expected to see.
Link: https://lore.kernel.org/r/20201004154340.1080481-4-leon@kernel.org
Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Cc: Maor Gottlieb <maorg@nvidia.com>
A couple small tweaks are needed to make the test build and run
on current kernels.
Link: https://lore.kernel.org/r/20201004154340.1080481-3-leon@kernel.org
Report the "ipoib pkey", "mode" and "umcast" netlink attributes for every
IPoiB interface type, not just children created with 'ip link add'.
After setting the rtnl_link_ops for the parent interface, implement the
dellink() callback to block users from trying to remove it.
Fixes: 862096a8bbf8 ("IB/ipoib: Add more rtnl_link_ops callbacks")
Link: https://lore.kernel.org/r/20201004132948.26669-1-kamalheib1@gmail.com
Signed-off-by: Kamal Heib <kamalheib1@gmail.com>
Pull kvm fixes from Paolo Bonzini:
"Two bugfixes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: VMX: update PFEC_MASK/PFEC_MATCH together with PF intercept
KVM: arm64: Restore missing ISB on nVHE __tlb_switch_to_guest
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fix from Juergen Gross:
"Fix a regression introduced in 5.9-rc3 which caused a system running
as fully virtualized guest under Xen to crash when using legacy
devices like a floppy"
* tag 'for-linus-5.9b-rc8-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/events: don't use chip_data for legacy IRQs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB/PHY fixes from Greg KH:
"Here are some small USB and PHY driver fixes for 5.9-rc8
The PHY driver fix resolves an issue found by Dan Carpenter for a
memory leak.
The USB fixes fall into two groups:
- usb gadget fix from Bryan that is a fix for a previous security fix
that showed up in in-the-wild testing
- usb core driver matching bugfixes. This fixes a bug that has
plagued the both the usbip driver and syzbot testing tools this -rc
release cycle. All is now working properly so usbip connections
will work, and syzbot can get back to fuzzing USB drivers properly.
All have been in linux-next for a while with no reported issues"
* tag 'usb-5.9-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usbcore/driver: Accommodate usbip
usbcore/driver: Fix incorrect downcast
usbcore/driver: Fix specific driver selection
Revert "usbip: Implement a match function to fix usbip"
USB: gadget: f_ncm: Fix NDP16 datagram validation
phy: ti: am654: Fix a leak in serdes_am654_probe()
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"Some more driver fixes for i2c"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: npcm7xx: Clear LAST bit after a failed transaction.
i2c: cpm: Fix i2c_ram structure
i2c: i801: Exclude device from suspend direct complete optimization
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov:
"A couple more driver quirks, now enabling newer trackpoints from
Synaptics for real"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: i8042 - add nopnp quirk for Acer Aspire 5 A515
Input: trackpoint - enable Synaptics trackpoints
One of the entries has three fields "mistake||correction||correction"
rather than the expected two fields "mistake||correction". Fix it.
Link: https://lkml.kernel.org/r/20200930234359.255295-1-ebiggers@kernel.org
memalloc_nocma_{save/restore} APIs can be used to skip page allocation
on CMA area, but, there is a missing case and the page on CMA area could
be allocated even if APIs are used. This patch handles this case to fix
the potential issue.
For now, these APIs are used to prevent long-term pinning on the CMA
page. When the long-term pinning is requested on the CMA page, it is
migrated to the non-CMA page before pinning. This non-CMA page is
allocated by using memalloc_nocma_{save/restore} APIs. If APIs doesn't
work as intended, the CMA page is allocated and it is pinned for a long
time. This long-term pin for the CMA page causes cma_alloc() failure
and it could result in wrong behaviour on the device driver who uses the
cma_alloc().
Missing case is an allocation from the pcplist. MIGRATE_MOVABLE pcplist
could have the pages on CMA area so we need to skip it if ALLOC_CMA
isn't specified.
Fixes: 8510e69c8efe (mm/page_alloc: fix memalloc_nocma_{save/restore} APIs)
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: "Aneesh Kumar K . V" <aneesh.kumar@linux.ibm.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Link: https://lkml.kernel.org/r/1601429472-12599-1-git-send-email-iamjoonsoo.kim@lge.com
The routine that applies debug flags to the kmem_cache slabs
inadvertantly prevents non-debug flags from being applied to those
same objects. That is, if slub_debug=<flag>,<slab> is specified,
non-debugged slabs will end up having flags of zero, and the slabs
may be unusable.
Fix this by including the input flags for non-matching slabs with the
contents of slub_debug, so that the caches are created as expected
alongside any debugging options that may be requested. With this, we
can remove the check for a NULL slub_debug_string, since it's covered
by the loop itself.
Fixes: e17f1dfba37b ("mm, slub: extend slub_debug syntax for multiple blocks")
Signed-off-by: Eric Farman <farman@linux.ibm.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Link: https://lkml.kernel.org/r/20200930161931.28575-1-farman@linux.ibm.com
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master
KVM/arm64 fixes for 5.9, take #3
- Fix synchronization of VTTBR update on TLB invalidation for nVHE systems
The PFEC_MASK and PFEC_MATCH fields in the VMCS reverse the meaning of
the #PF intercept bit in the exception bitmap when they do not match.
This means that, if PFEC_MASK and/or PFEC_MATCH are set, the
hypervisor can get a vmexit for #PF exceptions even when the
corresponding bit is clear in the exception bitmap.
This is unexpected and is promptly detected by a WARN_ON_ONCE.
To fix it, reset PFEC_MASK and PFEC_MATCH when the #PF intercept
is disabled (as is common with enable_ept && !allow_smaller_maxphyaddr).
Reported-by: Qian Cai <cai@redhat.com>>
Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org>
Tested-by: Naresh Kamboju <naresh.kamboju@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
"Some pin control fixes here. All of them are driver fixes, the Intel
Cherryview being the most interesting one.
- Fix a mux problem for I2C in the MVEBU driver.
- Fix a really hairy inversion problem in the Intel Cherryview
driver.
- Fix the register for the sdc2_clk in the Qualcomm SM8250 driver.
- Check the virtual GPIO boot failur in the Mediatek driver"
* tag 'pinctrl-v5.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl: mediatek: check mtk_is_virt_gpio input parameter
pinctrl: qcom: sm8250: correct sdc2_clk
pinctrl: cherryview: Preserve CHV_PADCTRL1_INVRXTX_TXDATA flag on GPIOs
pinctrl: mvebu: Fix i2c sda definition for 98DX3236
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
- Fix rockchip regression in rockchip_pcie_valid_device() (Lorenzo
Pieralisi)
- Add Pali Rohár as aardvark PCI maintainer (Pali Rohár)
* tag 'pci-v5.9-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
MAINTAINERS: Add Pali Rohár as aardvark PCI maintainer
PCI: rockchip: Fix bus checks in rockchip_pcie_valid_device()
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"Two patches in driver frameworks. The iscsi one corrects a bug induced
by a BPF change to network locking and the other is a regression we
introduced"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi: iscsi: iscsi_tcp: Avoid holding spinlock while calling getpeername()
scsi: target: Fix lun lookup for TARGET_SCF_LOOKUP_LUN_FROM_TAG case
Pull io_uring fixes from Jens Axboe:
- fix for async buffered reads if read-ahead is fully disabled (Hao)
- double poll match fix
- ->show_fdinfo() potential ABBA deadlock complaint fix
* tag 'io_uring-5.9-2020-10-02' of git://git.kernel.dk/linux-block:
io_uring: fix async buffered reads when readahead is disabled
io_uring: fix potential ABBA deadlock in ->show_fdinfo()
io_uring: always delete double poll wait entry on match
Pull block fix from Jens Axboe:
"Single fix for a ->commit_rqs failure case"
* tag 'block-5.9-2020-10-02' of git://git.kernel.dk/linux-block:
blk-mq: call commit_rqs while list empty but error happen
Pull epoll fixes from Al Viro:
"Several race fixes in epoll"
* 'work.epoll' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ep_create_wakeup_source(): dentry name can change under you...
epoll: EPOLL_CTL_ADD: close the race in decision to take fast path
epoll: replace ->visited/visited_list with generation count
epoll: do not insert into poll queues until all sanity checks are done
git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux
Pull RISC-V fixes from Palmer Dabbelt:
"Two fixes for this week:
- The addition of a symbol export for clint_time_val, which has been
inlined into some timex functions and can be used by drivers.
- A fix to avoid calling get_cycles() before the timers have been
probed.
These both only effect !MMU systems"
* tag 'riscv-for-linus-5.9-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux:
RISC-V: Check clint_time_val before use
clocksource: clint: Export clint_time_val for modules
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux
Pull btrfs fixes from David Sterba:
"Two more fixes.
One is for a lockdep warning/lockup (also caught by syzbot), that one
has been seen in practice. Regarding the other syzbot reports
mentioned last time, they don't seem to be urgent and reliably
reproducible so they'll be fixed later.
The second fix is for a potential corruption when device replace
finishes and the in-memory state of trim is not copied to the new
device"
* tag 'for-5.9-rc7-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux:
btrfs: fix filesystem corruption after a device replace
btrfs: move btrfs_rm_dev_replace_free_srcdev outside of all locks
btrfs: move btrfs_scratch_superblocks into btrfs_dev_replace_finishing
Pull power management fixes from Rafael Wysocki:
"These fix one more issue related to the recent RCU-lockdep changes, a
typo in documentation and add a missing return statement to
intel_pstate.
Specifics:
- Fix up RCU usage for cpuidle on the ARM imx6q platform (Ulf
Hansson)
- Fix typo in the PM documentation (Yoann Congal)
- Add return statement that is missing after recent changes in the
intel_pstate driver (Zhang Rui)"
* tag 'pm-5.9-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ARM: imx6q: Fixup RCU usage for cpuidle
Documentation: PM: Fix a reStructuredText syntax error
cpufreq: intel_pstate: Fix missing return statement
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull IIO fixes from Greg KH:
"Here are two small IIO driver fixes for 5.9-rc8 that resolve some
reported issues:
- driver name fixed in one driver
- device name typo fixed
Both have been in linux-next for a while with no reported problems"
* tag 'staging-5.9-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
iio: adc: qcom-spmi-adc5: fix driver name
iio: adc: ad7124: Fix typo in device name
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"Some late GPIO fixes for the v5.9 series:
- Fix compiler warnings on the OMAP when PM is disabled
- Clear the interrupt when setting edge sensitivity on the Spreadtrum
driver.
- Fix up spurious interrupts on the TC35894.
- Support threaded interrupts on the Siox controller.
- Fix resource leaks on the mockup driver.
- Fix line event handling in syscall compatible mode for the
character device.
- Fix an unitialized variable in the PCA953A driver.
- Fix access to all GPIO IRQs on the Aspeed AST2600.
- Fix line direction on the AMD FCH driver.
- Use the bitmap API instead of compiler intrinsics for bit
manipulation in the PCA953x driver"
* tag 'gpio-v5.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: pca953x: Correctly initialize registers 6 and 7 for PCA957x
gpio: pca953x: Use bitmap API over implicit GCC extension
gpio: amd-fch: correct logic of GPIO_LINE_DIRECTION
gpio: aspeed: fix ast2600 bank properties
gpio/aspeed-sgpio: don't enable all interrupts by default
gpio/aspeed-sgpio: enable access to all 80 input & output sgpios
gpio: pca953x: Fix uninitialized pending variable
gpiolib: Fix line event handling in syscall compatible mode
gpio: mockup: fix resource leak in error path
gpio: siox: explicitly support only threaded irqs
gpio: tc35894: fix up tc35894 interrupt configuration
gpio: sprd: Clear interrupt when setting the type as edge
gpio: omap: Fix warnings if PM is disabled
git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc
Pull MMC fixes from Ulf Hansson:
- Fix deadlock when removing MEMSTICK host
- Workaround broken CMDQ on Intel GLK based IRBIS models
* tag 'mmc-v5.9-rc4-3' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc:
mmc: sdhci: Workaround broken command queuing on Intel GLK based IRBIS models
memstick: Skip allocating card when removing host
Commit f227e3ec3b5c ("random32: update the net random state on interrupt
and activity") broke compilation and was temporarily fixed by Linus in
83bdc7275e62 ("random32: remove net_rand_state from the latent entropy
gcc plugin") by entirely moving net_rand_state out of the things handled
by the latent_entropy GCC plugin.
From what I understand when reading the plugin code, using the
__latent_entropy attribute on a declaration was the wrong part and
simply keeping the __latent_entropy attribute on the variable definition
was the correct fix.
Fixes: 83bdc7275e62 ("random32: remove net_rand_state from the latent entropy gcc plugin")
Acked-by: Willy Tarreau <w@1wt.eu>
Cc: Emese Revfy <re.emese@gmail.com>
Signed-off-by: Thibaut Sautereau <thibaut.sautereau@ssi.gouv.fr>
* pm-cpufreq:
Since commit ea426c2a7de8 ("mm: memcg: prepare for byte-sized vmstat
items") the write side of slab counters accepts a value in bytes and
converts it to pages. It happens in __mod_node_page_state().
However a non-SMP version of __mod_node_page_state() doesn't perform
this conversion. It leads to incorrect (unrealistically high) slab
counters values. Fix this by adding a similar conversion to the non-SMP
version of __mod_node_page_state().
Signed-off-by: Roman Gushchin <guro@fb.com>
Reported-and-tested-by: Bastian Bittorf <bb@npl.de>
Fixes: ea426c2a7de8 ("mm: memcg: prepare for byte-sized vmstat items")
The pipe splice code still used the old model of waiting for pipe IO by
using a non-specific "pipe_wait()" that waited for any pipe event to
happen, which depended on all pipe IO being entirely serialized by the
pipe lock. So by checking the state you were waiting for, and then
adding yourself to the wait queue before dropping the lock, you were
guaranteed to see all the wakeups.
Strictly speaking, the actual wakeups were not done under the lock, but
the pipe_wait() model still worked, because since the waiter held the
lock when checking whether it should sleep, it would always see the
current state, and the wakeup was always done after updating the state.
However, commit 0ddad21d3e99 ("pipe: use exclusive waits when reading or
writing") split the single wait-queue into two, and in the process also
made the "wait for event" code wait for _two_ wait queues, and that then
showed a race with the wakers that were not serialized by the pipe lock.
It's only splice that used that "pipe_wait()" model, so the problem
wasn't obvious, but Josef Bacik reports:
"I hit a hang with fstest btrfs/187, which does a btrfs send into
/dev/null. This works by creating a pipe, the write side is given to
the kernel to write into, and the read side is handed to a thread that
splices into a file, in this case /dev/null.
The box that was hung had the write side stuck here [pipe_write] and
the read side stuck here [splice_from_pipe_next -> pipe_wait].
[ more details about pipe_wait() scenario ]
The problem is we're doing the prepare_to_wait, which sets our state
each time, however we can be woken up either with reads or writes. In
the case above we race with the WRITER waking us up, and re-set our
state to INTERRUPTIBLE, and thus never break out of schedule"
Josef had a patch that avoided the issue in pipe_wait() by just making
it set the state only once, but the deeper problem is that pipe_wait()
depends on a level of synchonization by the pipe mutex that it really
shouldn't. And the whole "wait for any pipe state change" model really
isn't very good to begin with.
So rather than trying to work around things in pipe_wait(), remove that
legacy model of "wait for arbitrary pipe event" entirely, and actually
create functions that wait for the pipe actually being readable or
writable, and can do so without depending on the pipe lock serializing
everything.
Fixes: 0ddad21d3e99 ("pipe: use exclusive waits when reading or writing")
Link: https://lore.kernel.org/linux-fsdevel/bfa88b5ad6f069b2b679316b9e495a970130416c.1601567868.git.josef@toxicpanda.com/
Reported-by: Josef Bacik <josef@toxicpanda.com>
Reviewed-and-tested-by: Josef Bacik <josef@toxicpanda.com>
Expose the query GID table and entry API to user space by adding two new
methods and method handlers to the device object.
This API provides a faster way to query a GID table using single call and
will be used in libibverbs to improve current approach that requires
multiple calls to open, close and read multiple sysfs files for a single
GID table entry.
Link: https://lore.kernel.org/r/20200923165015.2491894-5-leon@kernel.org
Signed-off-by: Avihai Horon <avihaih@nvidia.com>
Introduce rdma_query_gid_table which enables querying all the GID tables
of a given device and copying the attributes of all valid GID entries to a
provided buffer.
GID table entry.
Link: https://lore.kernel.org/r/20200923165015.2491894-4-leon@kernel.org
Separate IB_GID_TYPE_IB and IB_GID_TYPE_ROCE to two different values, so
enum ib_gid_type will match the gid types of the new query GID table API
which will be introduced in the following patches.
This change in enum ib_gid_type requires to change also enum
rdma_network_type by separating RDMA_NETWORK_IB and RDMA_NETWORK_ROCE_V1
values.
Link: https://lore.kernel.org/r/20200923165015.2491894-3-leon@kernel.org
Change the error code returned from rdma_get_gid_attr when the GID entry
is invalid but the GID index is in the gid table size range to -ENODATA
instead of -EINVAL.
This change is done in order to provide a more accurate error reporting to
be used by the new GID query API in user space. Nevertheless, -EINVAL is
still returned from sysfs in the aforementioned case to maintain
compatibility with user space that expects -EINVAL.
Link: https://lore.kernel.org/r/20200923165015.2491894-2-leon@kernel.org
The various array_size functions use SIZE_MAX define, but missed limits.h
causes to failure to compile code that needs overflow.h.
In file included from drivers/infiniband/core/uverbs_std_types_device.c:6:
./include/linux/overflow.h: In function 'array_size':
./include/linux/overflow.h:258:10: error: 'SIZE_MAX' undeclared (first use in this function)
258 | return SIZE_MAX;
Fixes: 610b15c50e86 ("overflow.h: Add allocation size calculation helpers")
Link: https://lore.kernel.org/r/20200913102928.134985-1-leon@kernel.org
Making a change to fix following sparse warnings reported by kbuild bot.
CHECK drivers/infiniband/hw/qedr/verbs.c
drivers/infiniband/hw/qedr/verbs.c:3872:59: warning: incorrect type in assignment (different base types)
drivers/infiniband/hw/qedr/verbs.c:3872:59: expected restricted __le32 [usertype] sge_prod
drivers/infiniband/hw/qedr/verbs.c:3872:59: got unsigned int [usertype] sge_prod
drivers/infiniband/hw/qedr/verbs.c:3875:59: warning: incorrect type in assignment (different base types)
drivers/infiniband/hw/qedr/verbs.c:3875:59: expected restricted __le32 [usertype] wqe_prod
drivers/infiniband/hw/qedr/verbs.c:3875:59: got unsigned int [usertype] wqe_prod
Link: https://lore.kernel.org/r/20201001100959.19940-1-palok@marvell.com
Reported-by: kbuild test robot <lkp@intel.com>
Fixes: acca72e2b031 ("RDMA/qedr: SRQ's bug fixes")
Signed-off-by: Igor Russkikh <irusskikh@marvell.com>
Signed-off-by: Michal Kalderon <mkalderon@marvell.com>
Signed-off-by: Alok Prasad <palok@marvell.com>
The only usage of these is to pass their address to sysfs_create_group()
and sysfs_remove_group(), both which takes const pointers. Make it const
to allow the compiler to put them in read-only memory.
Link: https://lore.kernel.org/r/20200930224004.24279-3-rikard.falkeborn@gmail.com
Signed-off-by: Rikard Falkeborn <rikard.falkeborn@gmail.com>
The only usage of the pma_table field in the ib_port struct is to pass its
address to sysfs_create_group() and sysfs_remove_group(). Make it const to
make it possible to constify a couple of static struct
attribute_group. This allows the compiler to put them in read-only memory.
Link: https://lore.kernel.org/r/20200930224004.24279-2-rikard.falkeborn@gmail.com
