It is possible for tun_chr_close to race with dellink on the
a tun device. In which case if __tun_get runs before dellink
but dellink runs before tun_chr_close calls unregister_netdevice
we will attempt to unregister the netdevice after it is already
gone.
The two cases are already serialized on the rtnl_lock, so I have
gone for the cheap simple fix of moving rtnl_lock to cover __tun_get
in tun_chr_close. Eliminating the possibility of the tun device
being unregistered between __tun_get and unregister_netdevice in
tun_chr_close.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
Tested-by: David Woodhouse <David.Woodhouse@intel.com>
BUG_ON(!test_bit(NAPI_STATE_SCHED, &n->state)) was being hit
during e100 EEH recovery. The problem source was a napi_enable
call being made during e100_io_error_detected. Napi should remain
disabled after e100_down, and only be reenabled when the interface
is recovered.
This patch also updates e100_io_error_detected in order to make
it similar to the current versions of the error_detected callback
in drivers such as e1000e and ixgbe.
Signed-off-by: Andre Detsch <adetsch@br.ibm.com>
vfree() does its own 'NULL' check, so no need for check before
calling it.
Signed-off-by: Figo.zhang <figo1802@gmail.com>
If mlx4_create_eq() would fail for one of EQ's assigned for
completion handling, the code would try to free the same EQ
we failed to create.
The crash was found by Christoph Lameter
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
Use the right structure while incrementing the offset in tun_get_user.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Increment the iovec base by the offset passed in for the initial
copy_to_user() in memcpy_to_iovecend().
I am working on enabling UFO between KVM guests using virtio-net and i have
some patches that i got working with 2.6.30-rc8. When i wanted to try them
with net-next-2.6, i noticed that virtio-net is not working with that tree.
After some debugging, it turned out to be several bugs in the recent patches
to fix aio with tun driver, specifically the following 2 commits.
http://git.kernel.org/?p=linux/kernel/git/davem/net-next-2.6.git;a=commitdiff;h=0a1ec07a67bd8b0033dace237249654d015efa21
http://git.kernel.org/?p=linux/kernel/git/davem/net-next-2.6.git;a=commitdiff;h=6f26c9a7555e5bcca3560919db9b852015077dae
Fix the call to memcpy_from_iovecend() in skb_copy_datagram_from_iovec
to pass the right iovec offset.
skb_dma_unmap() is quite expensive for small packets,
because we use two different cache lines from skb_shared_info.
One to access nr_frags, one to access dma_maps[0]
Instead of dma_maps being an array of MAX_SKB_FRAGS + 1 elements,
let dma_head alone in a new dma_head field, close to nr_frags,
to reduce cache lines misses.
Tested on my dev machine (bnx2 & tg3 adapters), nice speedup !
Get rid of num_dma_maps in struct skb_shared_info, as it seems unused.
Remove the private definition of TRUE/FALSE and use the ones from
linux/stddef.h. Also remove the definition of BOOL which is not referenced
inside the driver anyway.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt>
This is a driver for the Micrel KS8842 ethernet switch.
The supplied code is for driving the KS8842 through the Timberdale FPGA
on the Russellville board, a development board for Intel Atom CPU
in the automotive area.
Signed-off-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com>
On Thu, Jun 04, 2009 at 09:06:00PM +1000, Herbert Xu wrote:
> tun: Optimise handling of bogus gso->hdr_len
> As all current versions of virtio_net generate a value for the
> header length that's too small, we should optimise this so that
> we don't copy it twice. This can be done by ensuring that it is
> at least as large as the place where we'll write the checksum.
> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
With this applied we can strengthen the partial checksum check:
In skb_partial_csum_set we check to see if the checksum offset
is within the packet. However, we really should check that it
is within the skb head as that's the only bit we can modify
without copying.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Through a bug in the tun driver, I noticed that virtio_net is
producing bogus hdr_len values. In particular, it only includes
the IP header in the linear area, and excludes the entire TCP
header. This causes the TCP header to be copied twice for each
packet. (The bug omitted the second copy :)
This patch corrects this.
Fixes an initialization error; the chip negotiates gigabit, but
the driver mistakenly handled it as 100Mb.
Changes based on both SiS own GPL driver and forcedeth.
Hopefully should fix
http://bugzilla.kernel.org/show_bug.cgi?id=9735
http://bugzilla.kernel.org/show_bug.cgi?id=11149
Signed-off-by: Riccardo Ghetta <birrachiara@tin.it>
Corrected dma sync handling on small packets. Should fix
http://bugzilla.kernel.org/show_bug.cgi?id=11509
Note:
While this bug was reported only on x86_64, it could have affected
any architecture.
Some firmware mailbox commands require the firmware to
communicate with the FCoE driver running on another
PCI function. This can potentially take several seconds.
This wait is done in process context only.
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com>
There are 8 banks of 'sub-registers' each of which are accessed
through address/data register pair. An example would be reading
flash or the xgmac. Accessing these require the driver to wait for
a ready bit before writing the address and then accessing the data.
This patch increases the timeout to 100us to prevent timeouts
that have been seen on some platforms.
These register are accessed in process context only.
Since an FCoE function shares a port with this NIC function, the
jumbo settings must always be in place. This patch causes the
hardware to be set up for jumbo if it is not already done.
Each firmware mailbox command can have a different number of
valid data elements. When waiting for a mailbox command to
complete it the process passes it's element count and
waits for the completion. It is possible that while waiting
an unrelated firmware async event (AE) can arrive. When this
happens, the handler will over write the element count
with the value for the newly arrived AE. This can cause
the mailbox command to not get all of it's data.
This patch restores original mailbox count at the end
of the handler.
Check status on every iteration of event handler loop and exit
if an error occurred. If an error occurred then recover process
will be queued so this loop should no continue.
The smsc911x_drv_remove() function is declared with __devexit, so the
assignment to the driver structure needs __devexit_p() wrappings to prevent
build failure when hotplug is disabled.
The smsc911x driver works fine on Blackfin systems, so add it to the arch
list in the Kconfig.
With all the last patchsets going in for 82599 feature enablement, the
driver version needs to be increased for better identification.
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
82599 has a FW running that helps manage the internal SFI PHY. There are
also a number of pre-production samples of these SFI-based devices in the
field. This patch adds a check to look for the firmware running on all
SFP+ based adapters, and displays a warning to the system log if a
pre-production adapter is identified. The driver will continue loading
though, with no functional degradation.
Also remove an old function prototype from ixgbe_82599.c that isn't being
used.
This patch rearranges the ixgbe_ring struct to make better use of
cacheline efficiency.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
This patch enables Flow Director's ATR functionality to the main base
driver for 82599.
Acked-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com>
This patch adds the functions for ixgbe to initialize Flow Director. It
also has the function APIs to add Flow Director filters from the base
driver. This also includes ATR, Application Targeted Routing, which is a
feature set of Flow Director. This is the hash-based mechanism to
automatically identify flows and add filters based on the hash, and direct
the Rx of that flow back to that same CPU.
Flow Director is a Rx filter mechanism designed to match Rx flows back to
the same CPU that the flow's Tx occurred from. This patch adds the first
piece, the defines for the hardware registers, to enable this feature in
82599 hardware.
This adds a second feature flag variable to use for future feature
expansion. Add HW RSC to this new feature flags variable.
This patch moves the tx cleanup processing out of the MSI-X interrupt
processing and gives it it's own napi routine. This allows the driver to
process TX cleanup in a polling context instead of in an interrupt context
which prevents TX from starving RX.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
The v_idx value was being used as both a bitmask and an index. This change
makes it so that the q_vector contains the index and allows for much of the
code to be simplified since disabling a q_vector involves only clearing one
bit in the interrupt bitmask.
This patch changes the driver so that it uses rx_buffer_info->dma to
determine if it needs to unmap the page instead of sh_info->nr_frags. This
helps to prevent a cache line miss when receiving small packets as the
rx_buffer_info data should already be in the cache.
Add ethtool support to change advertised link modes/autoneg settings of
82599 multispeed fiber adapters.
Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com>
Fix autoneg restart issues in flow control path which might create
endless link flickering due to known timing issues with 82599
adapters.
Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakakla@intel.com>
82599 supports multispeed fiber optical modules (10Gbps/1Gbps). Some
scenarios can cause the autotry mechanism to not negotiate link properly.
What needs to happen is the driver must flap the Tx laser to induce an Rx
Loss of Signal on the link partner. This will restart the autotry
mechanism to get link into a known state. The software definable pin (SDP)
3 on the 0x10fb NIC is wired to cause a Tx LOS event, which triggers the
Rx LOS we require.
This patch adds support for the ethtool internal test engine.
When reprogramming the 82599 analog PHY to either SFI optical or Direct
Attach Twinax, we need to restart the DSP in the PHY. The current method
can cause contention with our FW which is managing PHY state, and will
cause unexpected link flaps. This patch fixes the DSP restart by issuing
an AN_RESTART in the MAC, which will properly propagate the DSP restart to
the PHY. This ensures we don't collide with the FW.
The 82599 KX4 device defaults to legacy power management, or APME. This
puts the device into ACPI mode, which allows more robust WoL setups to
work properly.
Commit 1f87f7d3 (cfg80211: add rfkill support) added ERFKILL
to asm-generic/errno.h, but alpha, mips, parisc and sparc use
their own numbering scheme and do not include asm-generic/errno.h.
We need to add definition of ERFKILL for them.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
This patch removes the forcedeth device ids from pci_ids.h
The forcedeth driver uses the device id constants directly in its source
file.
[ Need to keep PCI_DEVICE_ID_NVIDIA_NVENET_15 in order to keep
drivers/pci/quirks.c building -DaveM ]
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
This patch adds a new device id for mcp89 chipset.
This patch removes the device id macros and instead uses the constants
directly.
The areas in which logic expressions where using the macros now instead
use feature/workaround flags.
No new functionality has been introduced in this patch, only clean up of
flags and macros.
My mistake, I should have added that when cleaning up
rfkill and changing wimax.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
This patch removes code (deprecated by "cfg80211: add rfkill support" )
main.c: In function 'ar9170_op_config':
main.c:1306: warning: '__IEEE80211_CONF_CHANGE_RADIO_ENABLED'
is deprecated (declared at include/net/mac80211.h:551)
and a useless device state.
Signed-off-by: Christian Lamparter <chunkeey@web.de>
Fixing a comment in the code describing this module parameter.
The description printed when user runs "modinfo" is correct.
Reported-by: Jiajia Zheng <jiajia.zheng@intel.com>
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
