PPP synchronous tty channel driver: convert the semaphore dead_sem to a
completion
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Now that external users may increment the counters directly, we need
to ensure that udp_stats_in6 is always available. Otherwise we'd
either have to requrie the external users to be built as modules or
ipv6 to be built-in.
This isn't too bad because udp_stats_in6 is just a pair of pointers
plus an EXPORT, e.g., just 40 (16 + 24) bytes on x86-64.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This introduces a CCMPS field for setting a CCID-specific upper bound on the application payload
size, as is defined in RFC 4340, section 14.
Only the TX CCID is considered in setting this limit, since the RX CCID generates comparatively
small (DCCP-Ack) feedback packets. The CCMPS field includes network and transport layer header
lengths. The only current CCMPS customer is CCID4 (via RFC 4828).
A wrapper is used to allow querying the CCMPS even at times where the CCID modules may not have
been fully negotiated yet.
In dccp_sync_mss() the variable `mss_now' has been renamed into `cur_mps', to reflect that we are
dealing with an MPS, but not an MSS.
Since the DCCP code closely follows the TCP code, the identifiers `dccp_sync_mss' and
`dccps_mss_cache' have been kept, as they have direct TCP counterparts.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The patch makes the registration messages of CCID 2/3 a bit more
informative: instead of repeating the CCID number as currently done,
"CCID: Registered CCID 2 (ccid2)" or
"CCID: Registered CCID 3 (ccid3)",
the descriptive names of the CCID's (from RFCs) are now used:
"CCID: Registered CCID 2 (TCP-like)" and
"CCID: Registered CCID 3 (TCP-Friendly Rate Control)".
To allow spaces in the name, the slab name string has been changed to
refer to the numeric CCID identifier, using the same format as before.
This adds documentation for the ccid_operations structure.
There are several thresholds for trie fib hash management. They are used
in the code as a constants. Make them constants from the compiler point of
view.
Signed-off-by: Denis V. Lunev <den@openvz.org>
This is similar to the change already done for IPIP tunnels.
Once created, a SIT tunnel can't be bound to another device.
To reproduce:
# create a tunnel:
ip tunnel add tunneltest0 mode sit remote 10.0.0.1 dev eth0
# try to change the bounding device from eth0 to eth1:
ip tunnel change tunneltest0 dev eth1
# show the result:
ip tunnel show tunneltest0
tunneltest0: ipv6/ip remote 10.0.0.1 local any dev eth0 ttl inherit
Notice the bound device has not changed from eth0 to eth1.
This patch fixes it. When changing the binding, it also recalculates the
MTU according to the new bound device's MTU.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Once created, a GRE tunnel can't be bound to another device.
To reproduce:
# create a tunnel:
ip tunnel add tunneltest0 mode gre remote 10.0.0.1 dev eth0
# show the result:
tunneltest0: gre/ip remote 10.0.0.1 local any dev eth0 ttl inherit
This makes the code in the inet6_rt_notify more straightforward and provides
groud for namespace passing.
Further testing shows that my ICMP relookup patch can cause xfrm_lookup
to return zero on error which isn't very nice since it leads to the caller
dying on null pointer dereference. The bug is due to not setting err
to ENOENT just before we leave xfrm_lookup in case of no policy.
This patch moves the err setting to where it should be.
This implements [RFC 4340, p. 32]: "any feature negotiation options received
on DCCP-Data packets MUST be ignored".
Also added a FIXME for further processing, since the code currently (wrongly)
classifies empty Confirm options as invalid - this needs to be resolved in
a separate patch.
This removes several `XXX' references which indicate a missing support
for non-1-byte feature values: this is unnecessary, as all currently known
(standardised) SP feature values are 1-byte quantities.
This removes two inlines which were both called in a single function only:
1) dccp_feat_change() is always called with either DCCPO_CHANGE_L or DCCPO_CHANGE_R as argument
* from dccp_set_socktopt_change() via do_dccp_setsockopt() with DCCP_SOCKOPT_CHANGE_R/L
* from __dccp_feat_init() via dccp_feat_init() also with DCCP_SOCKOPT_CHANGE_R/L.
Hence the dccp_feat_is_valid_type() is completely unnecessary and always returns true.
2) Due to (1), the length test reduces to 'len >= 4', which in turn makes
dccp_feat_is_valid_length() unnecessary.
Furthermore, the inline function dccp_feat_is_reserved() was unfolded,
since only called in a single place.
This provides a separate routine to insert options during the initial handshake.
The main purpose is to conduct feature negotiation, for the moment the only user
is the timestamp echo needed for the (CCID3) handshake RTT sample.
Padding of options has been put into a small separate routine, to be shared among
the two functions. This could also be used as a generic routine to finish inserting
options.
Also removed an `XXX' comment since its content was obvious.
In DCCP, timestamps can occur on packets anytime, CCID3 uses a timestamp(/echo) on the Request/Response
exchange. This patch addresses the following situation:
* timestamps are recorded on the listening socket;
* Responses are sent from dccp_request_sockets;
* suppose two connections reach the listening socket with very small time in between:
* the first timestamp value gets overwritten by the second connection request.
This is not really good, so this patch separates timestamps into
* those which are received by the server during the initial handshake (on dccp_request_sock);
* those which are received by the client or the client after connection establishment.
As before, a timestamp of 0 is regarded as indicating that no (meaningful) timestamp has been
received (in addition, a warning message is printed if hosts send 0-valued timestamps).
The timestamp-echoing now works as follows:
* when a timestamp is present on the initial Request, it is placed into dreq, due to the
call to dccp_parse_options in dccp_v{4,6}_conn_request;
* when a timestamp is present on the Ack leading from RESPOND => OPEN, it is copied over
from the request_sock into the child cocket in dccp_create_openreq_child;
* timestamps received on an (established) dccp_sock are treated as before.
Since Elapsed Time is measured in hundredths of milliseconds (13.2), the new dccp_timestamp()
function is used, as it is expected that the time between receiving the timestamp and
sending the timestamp echo will be very small against the wrap-around time. As a byproduct,
this allows smaller timestamping-time fields.
Furthermore, inserting the Timestamp Echo option has been taken out of the block starting with
'!dccp_packet_without_ack()', since Timestamp Echo can be carried on any packet (5.8 and 13.3).
Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz>
This adds option-parsing code to processing of Acks in the listening state
on request_socks on the server, serving two purposes
(i) resolves a FIXME (removed);
(ii) paves the way for feature-negotiation during connection-setup.
There is an intended subtlety here with regard to dccp_check_req:
Parsing options happens only after testing whether the received packet is
a retransmitted Request. Otherwise, if the Request contained (a possibly
large number of) feature-negotiation options, recomputing state would have to
happen each time a retransmitted Request arrives, which opens the door to an
easy DoS attack. Since in a genuine retransmission the options should not be
different from the original, reusing the already computed state seems better.
The other point is - if there are timestamp options on the Request, they will
not be answered; which means that in the presence of retransmission (likely
due to loss and/or other problems), the use of Request/Response RTT sampling
is suspended, so that startup problems here do not propagate.
The option parsing code currently only parses on full sk's. This causes a problem for
options sent during the initial handshake (in particular timestamps and feature-negotiation
options). Therefore, this patch extends the option parsing code with an additional argument
for request_socks: if it is non-NULL, options are parsed on the request socket, otherwise
the normal path (parsing on the sk) is used.
Subsequent patches, which implement feature negotiation during connection setup, make use
of this facility.
This replaces 4 individual assignments for `len' with a single
one, placed where the control flow of those 4 leads to.
This adds a socket option and signalling support for the case where the server
holds timewait state on closing the connection, as described in RFC 4340, 8.3.
Since holding timewait state at the server is the non-usual case, it is enabled
via a socket option. Documentation for this socket option has been added.
The setsockopt statement has been made resilient against different possible cases
of expressing boolean `true' values using a suggestion by Ian McDonald.
This removes another Fixme, using the TCP maximum RTO rather than the value
specified by the DCCP specification. Across the sections in RFC 4340, 64
seconds is consistently suggested as maximum RTO backoff value; and this is
the value which is now used.
I have checked both termination cases for retransmissions of Close/CloseReq:
with the default value 15 of `retries2', and an initial icsk_retransmit = 0,
it takes about 614 seconds to declare a non-responding peer as dead, after
which the final terminating Reset is sent. With the TCP maximum RTO value of
120 seconds it takes (as might be expected) almost twice as long, about 23
minutes.
When performing active close, RFC 4340, 8.3. requires to retransmit the
Close/CloseReq with a backoff-retransmit timer starting at intially 2 RTTs.
This patch shifts the existing code for active-close retransmit timer
into output.c, so that the retransmit timer is started when the first
Close/CloseReq is sent. Previously, the timer was started when, after
releasing the socket in dccp_close(), the actively-closing side had not yet
reached the CLOSED/TIMEWAIT state.
The patch further reduces the initial timeout from 3 seconds to the required
2 RTTs, where - in absence of a known RTT - the fallback value specified in
RFC 4340, 3.4 is used.
Removed useless and buggy __exit section in the different
ipv6 subsystems. Otherwise they will be called inside an
init section during rollbacking in case of an error in the
protocol initialization.
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
This patch performs two changes:
1) Close the write-end in addition to the read-end when a fin-like segment
(Close or CloseReq) is received by DCCP. This accounts for the fact that DCCP,
in contrast to TCP, does not have a half-close. RFC 4340 says in this respect
that when a fin-like segment has been sent there is no guarantee at all that
any further data will be processed.
Thus this patch performs SHUT_WR in addition to the SHUT_RD when a fin-like
segment is encountered.
2) Minor change: I noted that code appears twice in different places and think it
makes sense to put this into a self-contained function (dccp_enqueue()).
My previous patch made the wait flag take the opposite value to what
it should be. This patch fixes that.
The caller must hold the RTNL so let's check it in unregister_netdevice.
This fixes a logical error in ICMP policy checks which lets
packets through if the state ICMP flag is off.
This patch converts all callers of xfrm_lookup that used an
explicit value of 1 to indiciate blocking to use the new flag
XFRM_LOOKUP_WAIT.
The policy check I added for ICMP on IPv6 is reversed. This
patch fixes that.
It also adds an skb->sp check so that unprotected packets that
fail the policy check do not crash the machine.
Change bnx2_init_napi() to void.
Warning was noted by DaveM.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Enable new tx ring and add new MSIX handler and NAPI poll function
for the new tx ring. Enable MSIX when the hardware supports it.
To separate TX IRQs into a different MSIX vector, we need to
support a new tx ring. The original tx ring will still be used
when not using MSIX.
Change bnx2_napi struct into an array and add code to manage multiple
IRQs. MSIX hardware structures and new registers are also added.
Rx related fields used in NAPI polling are moved from the main
bnx2 struct to the bnx2_napi struct.
Tx related fields used in NAPI polling are moved from the main
Introduce a bnx2_napi structure that will hold a napi_struct and
other fields to handle NAPI polling for the napi_struct. Various tx
and rx indexes and status block pointers will be moved from the main
bnx2 structure to this bnx2_napi structure.
Most NAPI path functions are modified to be passed this bnx2_napi
struct pointer.
Add a table to keep track of multiple IRQs and restructure the IRQ
request and free functions so that they can be easily expanded to
handle multiple IRQs.
This makes the code cleaner and easier to support different tx rings.
If the MTU requires more than 1 page for the SKB, enable the page ring
and calculate the size of the page ring. This will guarantee order-0
allocation regardless of the MTU size.
Fixup loopback test packet size so that we don't deal with the pages
during loopback test.
Add function to reuse a page in case of allocation or other errors.
Add code to construct the completed SKB with the additional data in
the pages.
Add new fields to keep track of the pages and the page rings.
Add functions to allocate and free pages.
