Fix this lot:
fs/binfmt_flat.c: In function `decompress_exec':
fs/binfmt_flat.c:293: warning: label `out' defined but not used
fs/binfmt_flat.c: In function `load_flat_file':
fs/binfmt_flat.c:462: warning: unsigned int format, long int arg (arg 3)
fs/binfmt_flat.c:462: warning: unsigned int format, long int arg (arg 4)
fs/binfmt_flat.c:518: warning: comparison of distinct pointer types lacks a cast
fs/binfmt_flat.c:549: warning: passing arg 1 of `ksize' makes pointer from integer without a cast
fs/binfmt_flat.c:601: warning: passing arg 1 of `ksize' makes pointer from integer without a cast
fs/binfmt_flat.c: In function `load_flat_binary':
fs/binfmt_flat.c:116: warning: 'dummy' might be used uninitialized in this function
Acked-by: Greg Ungerer <gerg@uclinux.org>
Simply fill out the bits in checkstack.pl for Blackfin. I thought I already
sent this, but I don't see it in -mm anywhere ...
Cc: Bryan Wu <bryan.wu@analog.com>
do_sigaction() returns -ERESTARTNOINTR if signal_pending(). The comment says:
* If there might be a fatal signal pending on multiple
* threads, make sure we take it before changing the action.
I think this is not needed. We should only worry about SIGNAL_GROUP_EXIT case,
bit it implies a pending SIGKILL which can't be cleared by do_sigaction.
Kill this special case.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-by: Roland McGrath <roland@redhat.com>
de_thread() yields waiting for ->group_leader to be a zombie. This deadlocks
if an rt-prio execer shares the same cpu with ->group_leader. Change the code
to use ->group_exit_task/notify_count mechanics.
This patch certainly uglifies the code, perhaps someone can suggest something
better.
Cc: Roland McGrath <roland@redhat.com>
Now that we don't pre-allocate the new ->sighand, we can kill the first fast
path, it doesn't make sense any longer. At best, it can save one "list_empty()"
check but leads to the code duplication.
de_thread() pre-allocates newsighand to make sure that exec() can't fail after
killing all sub-threads. Imho, this buys nothing, but complicates the code:
- this is (mostly) needed to handle CLONE_SIGHAND without CLONE_THREAD
tasks, this is very unlikely (if ever used) case
- unless we already have some serious problems, GFP_KERNEL allocation
should not fail
- ENOMEM still can happen after de_thread(), ->sighand is not the last
object we have to allocate
Change the code to allocate the new ->sighand on demand.
There is no any reason to do recalc_sigpending() after changing ->sighand.
To begin with, recalc_sigpending() does not take ->sighand into account.
This means we don't need to take newsighand->siglock while changing sighands.
rcu_assign_pointer() provides a necessary barrier, and if another process
reads the new ->sighand it should either take tasklist_lock or it should use
lock_task_sighand() which has a corresponding smp_read_barrier_depends().
Fix f_version type: should be u64 instead of long
There is a type inconsistency between struct inode i_version and struct file
f_version.
fs.h:
struct inode
u64 i_version;
and
struct file
unsigned long f_version;
Users do:
fs/ext3/dir.c:
if (filp->f_version != inode->i_version) {
So why isn't f_version a u64 ? It becomes a problem if versions gets
higher than 2^32 and we are on an architecture where longs are 32 bits.
This patch changes the f_version type to u64, and updates the users accordingly.
It applies to 2.6.23-rc2-mm2.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Martin Bligh <mbligh@google.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: Al Viro <viro@ftp.linux.org.uk>
Cc: <linux-ext4@vger.kernel.org>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Some months back I proposed changing the schedule() call in
read_events to an io_schedule():
http://osdir.com/ml/linux.kernel.aio.general/2006-10/msg00024.html
This was rejected as there are AIO operations that do not initiate
disk I/O. I've had another look at the problem, and the only AIO
operation that will not initiate disk I/O is IOCB_CMD_NOOP. However,
this command isn't even wired up!
Given that it doesn't work, and hasn't for *years*, I'm going to
suggest again that we do proper I/O accounting when using AIO.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Zach Brown <zach.brown@oracle.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: Suparna Bhattacharya <suparna@in.ibm.com>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Repost of http://lkml.org/lkml/2007/8/10/472 made available by request.
The locking used by get_random_bytes() can conflict with the
preempt_disable() and synchronize_sched() form of RCU. This patch changes
rcutorture's RNG to gather entropy from the new cpu_clock() interface
(relying on interrupts, preemption, daemons, and rcutorture's reader
thread's rock-bottom scheduling priority to provide useful entropy), and
also adds and EXPORT_SYMBOL_GPL() to make that interface available to GPLed
kernel modules such as rcutorture.
Passes several hours of rcutorture.
[ego@in.ibm.com: Use raw_smp_processor_id() in rcu_random()]
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
To avoid lock contention, we distribute the sched_timer calls across the
cpus so they do not trigger at the same instant. However, I used NR_CPUS,
which can cause needless grouping on small smp systems depending on your
kernel config. This patch converts to using num_possible_cpus() so we
spread it as evenly as possible on every machine.
Briefly tested w/ NR_CPUS=255 and verified reduced contention.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Lomesh reported poll returning EINTR during suspend/resume cycle. This is
caused by the STOP/CONT cycle that the freezer uses, generating a pending
signal for what in effect is an ignored signal. In general poll is a
little eager in returning EINTR, when it could try not bother userspace and
simply restart the syscall. Both select and ppoll do use ERESTARTNOHAND to
restart the syscall. Oleg points out that simply using ERESTARTNOHAND will
cause poll to restart with original timeout value. which could ultimately
lead to process never returning to userspace. Instead use
ERESTART_RESTARTBLOCK, and restart poll with updated timeout value.
Inspired by Manfred's use ERESTARTNOHAND in poll patch.
[bunk@kernel.org: do_restart_poll() can become static]
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: "Agarwal, Lomesh" <lomesh.agarwal@intel.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Allow disabling DNOTIFY with CONFIG_EMBEDDED=n.
I'm currently running a kernel with dnotify disabled and I haven't run into
any problem. Is there any popular application left that breaks without
dnotify support in the kernel?
Note that this patch does not remove dnotify support, it still defaults to
"y", and the help text recommends enabling it.
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
simple_commit_write() can now become static.
- remove the no longer required __attribute__((weak)) of xtime_lock
- remove the following no longer used EXPORT_SYMBOL's:
- xtime
- xtime_lock
Cc: john stultz <johnstul@us.ibm.com>
This attempts to address CVE-2006-6058
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2006-6058
first reported at http://projects.info-pull.com/mokb/MOKB-17-11-2006.html
Essentially a corrupted minix dir inode reporting a very large
i_size will loop for a very long time in minix_readdir, minix_find_entry,
etc, because on EIO they just move on to try the next page. This is
under the BKL, printk-storming as well. This can lock up the machine
for a very long time. Simply ratelimiting the printks gets things back
under control. Make the message a bit more informative while we're here.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Cc: Bodo Eggert <7eggert@gmx.de>
Replace n & (n - 1) with is_power_of_2(n)
Signed-off-by: vignesh babu <vignesh.babu@wipro.com>
oomkilladj is int, but values which can be assigned to it are -17, [-16,
15], thus fitting into s8.
While patch itself doesn't help in making task_struct smaller, because of
natural alignment of ->link_count, it will make picture clearer wrt futher
task_struct reduction patches. My plan is to move ->fpu_counter and
->oomkilladj after ->ioprio filling hole on i386 and x86_64. But that's
for later, because bloated distro configs need looking at as well.
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on
32bit targets.
GCC can be made to warn about usage of long long types with ISO C90
(-ansi), but only with -pedantic. You can write this in a way that even
then it doesn't cause warnings, namely by:
#ifdef __GNUC__
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
#endif
The __extension__ keyword in front of this switches off any pedantic
warnings for this expression.
Signed-off-by: Olaf Hering <olh@suse.de>
Cc: <linux-arch@vger.kernel.org>
The README file in the cramfs subdirectory says: "All data is currently in
host-endian format; neither mkcramfs nor the kernel ever do swabbing."
If somebody tries to mount a cramfs with the wrong endianess, cramfs only
complains about a wrong magic but doesn't inform the user that only the
endianess isn't right.
The following patch adds an error message to the cramfs sources. If a user
tries to mount a cramfs with the wrong endianess using the patched sources,
cramfs will display the message "cramfs: wrong endianess".
Signed-off-by: Andi Drebes <lists-receive@programmierforen.de>
include/linux/if_fddi.h is an exported header.
It uses __be16. Include linux/types.h to get this prototype.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Cc: "Maciej W. Rozycki" <macro@linux-mips.org>
It looks like in the end all pruners want parents removed.
So remove unused code and function arguments.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
vfs_permission(MAY_EXEC) checks if the filesystem is mounted with "noexec", so
there's no need to repeat this check in sys_uselib() and open_exec().
permission() checks that MAY_EXEC is only allowed on regular files if at least
one execute bit is set in the file mode.
generic_permission() already ensures this, so the extra check in permission()
is superfluous.
If the filesystem defines it's own ->permission() the check may still be
needed. In this case move it after ->permission(). This is needed because
filesystems such as FUSE may need to refresh the inode attributes before
checking permissions.
This check should be moved inside ->permission(), but that's another story.
utimensat() (and possibly other callers of do_utimes()) didn't check if the
nanosecond value was within the allowed range.
Cc: Ulrich Drepper <drepper@redhat.com>
Hello, I fixed and tested a small bug in lib/sort.c file, heap sort
function.
The fix avoids unnecessary swap of contents when i is 0 (saves few loads
and stores), which happens every time sort function is called. I felt the
fix is worth bringing it to your attention given the importance and
frequent use of the sort function.
Acked-by: Matt Mackall <mpm@selenic.com>
Remove linux/consolemap.h from make headers_install
It contains no user interfaces.
The defines in this file are used only for kernel internal state.
Remove some remaining vestiges of the old hacks jsm had to work around the old
tty buffering. With the new tty buffering it simply doesn't matter any more.
[michal.k.k.piotrowski@gmail.com: fix warning]
Signed-off-by: Alan Cox <alan@redhat.com>
Acked-by: Scott Kilau <scottk@digi.com>
Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
We simply define it to the same value. Nowdays the TTY flip value is
irrelevant but the value it used is as good as any so why risk breaking it
There have been issues with non-latin1 diacritics and unicode.
http://bugzilla.kernel.org/show_bug.cgi?id=7746
Git 759448f459234bfcf34b82471f0dba77a9aca498 `Kernel utf-8 handling'
partly resolved it by adding conversion between diacritics and
unicode. The patch below goes further by just turning diacritics into
unicode, hence providing better future support. The kbd support can be
fetched from
http://bugzilla.kernel.org/attachment.cgi?id=12313
This was tested in all of latin1, latin9, latin2 and unicode with french
and czech dead keys.
Turn the kernel accent_table into unicode, and extend ioctls KDGKBDIACR
and KDSKBDIACR into their equivalents KDGKBDIACRUC and KDSKBDIACR.
New function int conv_uni_to_8bit(u32 uni) for converting unicode into 8bit
_input_. No, we don't want to store the translation, as it is potentially
sparse and large.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Jan Engelhardt <jengelh@gmx.de>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
We can just use skb_mac_header now, and we don't need a wrapper function to
perform the cast. Instead of requiring the reader to check aoe.h to look
up what an aoe_hdr function does, I'd rather do without it.
When a new block bitmap is read from disk in read_block_bitmap() there are
a few bits that should ALWAYS be set. In particular, the blocks given by
ext4_blk_bitmap, ext4_inode_bitmap and ext4_inode_table. Validate the
block bitmap against these blocks.
[akpm@linux-foundation.org: cleanups]
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Andreas Dilger <adilger@clusterfs.com>
Acked-by: Mingming Cao <cmm@us.ibm.com>
This adds the MMF_DUMP_ELF_HEADERS option to /proc/pid/coredump_filter.
This dumps the first page (only) of a private file mapping if it appears to
be a mapping of an ELF file. Including these pages in the core dump may
give sufficient identifying information to associate the original DSO and
executable file images and their debugging information with a core file in
a generic way just from its contents (e.g. when those binaries were built
with ld --build-id). I expect this to become the default behavior
eventually. Existing versions of gdb can be confused by the core dumps it
creates, so it won't enabled by default for some time to come. Soon many
people will have systems with a gdb that handle these dumps, so they can
arrange to set the bit at boot and have it inherited system-wide.
This also cleans up the checking of the MMF_DUMP_* flag bits, which did not
need to be using atomic macros.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
/usr/include/scsi is provided by glibc.
Remove the scsi export from make headers_install target.
Cc: James Bottomley <James.Bottomley@steeleye.com>
The child was found on ->children list under tasklist_lock, it must have a
valid ->signal. __exit_signal() both removes the task from parent->children
and clears ->signal "atomically" under write_lock(tasklist).
Remove unneeded checks.
Cleanup. __group_complete_signal() wakes up ->group_exit_task twice. The
second wakeup's state includes TASK_UNINTERRUPTIBLE, which is not very
appropriate.
Change the code to pass the "correct" argument to signal_wake_up() and kill
now unneeded wake_up_process().
The "p->exit_signal == -1 && p->ptrace == 0" check and the comment are
bogus. We already did exactly the same check in eligible_child(), we did
not drop tasklist_lock since then, and both variables need
write_lock(tasklist) to be changed.
Nowadays thread_group_empty() and next_thread() are simple list operations,
this optimization doesn't make sense: we are doing exactly same check one
line below.
->siglock provides enough protection to iterate over the thread group.
Two threads, T1 and T2. T2 ptraces P, and P is not a child of ptracer's
thread group. P exits and goes to TASK_ZOMBIE.
T1 does wait_task_zombie(P):
P->exit_state = TASK_DEAD;
read_unlock(&tasklist_lock);
T2 does exit(), takes tasklist,
forget_original_parent() does
__ptrace_unlink(P) but doesn't
call do_notify_parent(P) because
p->exit_state == EXIT_DEAD.
Now, P is not visible to our process: __ptrace_unlink() removed it from
->children. We should send notification to P->parent and release P if and
only if SIGCHLD is ignored.
And we have 3 bugs:
1. P->parent does do_wait() and gets -ECHILD (P is on ->parent->children,
but its state is TASK_DEAD).
2. // wait_task_zombie() continues
if (put_user(...)) {
// TODO: is this safe?
p->exit_state = EXIT_ZOMBIE;
return;
we return without notification/release, task_struct leaked.
Solution: ignore -EFAULT and proceed. It is an application's bug if
we can't fill infop/stat_addr (in case of VM_FAULT_OOM we have much
more problems).
3. // wait_task_zombie() continues
if (p->real_parent != p->parent) {
// Not taken, it was untraced'ed
release_task(p);
we released the task which we shouldn't.
Solution: check ->real_parent != ->parent before, under tasklist_lock,
but use ptrace_unlink() instead of __ptrace_unlink() to check ->ptrace.
This patch hopefully solves 2 and 3, the 1st bug will be fixed later, we need
some cleanups in forget_original_parent/reparent_thread.
However, the first race is very unlikely and not critical, so I hope it makes
sense to fix 1 and 2 for now.
4. Small cleanup: don't "restore" EXIT_ZOMBIE unless we know we are not going
to realease the child.
A zombie must have a valid ->signal, we are going to release it and
__exit_signal() starts with BUG_ON(!sig).
There's a small and unlikely memory leak in
drivers/pnp/pnpbios/proc.c::proc_read_escd(). It's inside a sanity check,
so it probably won't trigger often (if at all), however it *is* a potential
leak and it's easy to avoid, so let's just fix it :)
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
This makes powerpc64's compat code use the new linux/elfcore-compat.h,
reducing some hand-copied duplication.
Cc: Andi Kleen <ak@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
This adds the linux/elfcore-compat.h header file, which is the CONFIG_COMPAT
analog of the linux/elfcore.h header. Each arch that needs to fake out
fs/binfmt_elf.c for its compat code can use this header to replace the
hand-copied definitions of the compat variants of struct elf_prstatus et al.
Only the pr_reg field varies by arch, so asm/{compat,elf}.h must define
compat_elf_gregset_t before linux/elfcore-compat.h can be used.
It's a clean-up that every arch with compat core dumping code can benefit
from. I only touched the ones I have handy to test at home. Doing the same
for each other arch should be straightforward, and I'm happy to offer tips.
The current code skips the check to verify whether the filesystem was
previously cleanly unmounted, if (flags & UFS_ST_MASK) == UFS_ST_44BSD or
UFS_ST_OLD. This looks like an inadvertent bug that slipped in due to
parantheses in the compound conditional to me, especially given that
ufs_get_fs_state() handles the UFS_ST_44BSD case perfectly well. So, let's
fix the compound condition appropriately.
Signed-off-by: Satyam Sharma <satyam@infradead.org>
Cc: Evgeniy Dushistov <dushistov@mail.ru>
Move prototypes and in-core structures to fs/ufs/ similar to what most
other filesystems already do.
I made little modifications: move also ufs debug macros and
mount options constants into fs/ufs/ufs.h, this stuff
also private for ufs.
Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru>
Driver does
proc_mkdir("ipmi", NULL);
but
remove_proc_entry(proc_ipmi_root->name, &proc_root);
This is OK and working if only slightly inconsistent. Also changing
proc_root to NULL will help OpenVZ which has multiple proc roots and, as we
now know, requires matching parents in such cases.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Cc: Corey Minyard <minyard@acm.org>
With or without this patch, multi-threaded init's are not fully supported,
but do_exit() is completely wrong. This becomes a real problem when we
support pid namespaces.
1. do_exit() panics when the main thread of /sbin/init exits. It should not
until the whole thread group exits. Move the code below, under the
"if (group_dead)" check.
Note: this means that forget_original_parent() can use an already dead
child_reaper()'s task_struct. This is OK for /sbin/init because
- do_wait() from alive sub-thread still can reap a zombie, we iterate
over all sub-thread's ->children lists
- do_notify_parent() will wakeup some alive sub-thread because it sends
the group-wide signal
However, we should remove choose_new_parent()->BUG_ON(reaper->exit_state)
for this.
2. We are playing games with ->nsproxy->pid_ns. This code is bogus today, and
it has to be changed anyway when we really support pid namespaces, just
remove it.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
The Linux ELF loader is quite complicated and messy code (that could
probably need a rewrite, but that's a different chapter). One particular
messy part in it is the support for non ELF a.out ld.sos. This was
originally added to make transition from a.out to ELF easier because an
a.out ELF ld.so could be still build using an older a.out toolkit. But by
now that should be fully obsolete and removing it would clean up
binfmt_elf.c up a bit.
I propose to deprecate this support and remove for 2.6.25.
Drawback is that someone still runs their system with a.out ld.so
they would need to update the ld.so when updating to a new kernel.
This patch just adds an entry to the deprecation file and a printk
warning users.
[akpm@linux-foundation.org: better warning message]
Signed-off-by: Andi Kleen <ak@suse.de>
With the recent changes, do_sigaction()->recalc_sigpending_and_wake() can
never clear TIF_SIGPENDING. Instead, it can set this flag and wake up the
thread without any reason. Harmless, but unneeded and wastes CPU.
