commit 0c8aab8e65e450f2bfea494c1b6a86ded653f88c upstream.
It's not obvious from the label name but "err1" tries to release
"p->irq_domain" which leads to a NULL dereference.
Fixes: 119f5e448d32 ('gpio: Renesas R-Car GPIO driver V3')
Acked-by: Magnus Damm <damm@opensource.se>
commit d535922691fc026479fcc03e78ac3d931a54e75a upstream.
There is a bug in mvebu_gpio_probe() where we do:
mvchip->irqbase = irq_alloc_descs(-1, 0, ngpios, -1);
if (mvchip->irqbase < 0) {
The problem is that mvchip->irqbase is unsigned so the error handling
doesn't work. I have changed it to be a regular int.
commit 0b2aa8bed3e13892fcac77e4f50ec6e80125469d upstream.
Commit c111feabe2e2 (gpio: twl4030: Cache the direction and output
states in private data) improved things in general, but caused a
regression for setting the GPIO output direction.
The change reorganized twl_direction_out() and twl_set() and swapped
the function names around in the process. While doing that, a bug got
introduced that's not obvious while reading the patch as it appears
as no change to the code.
The bug is we now call function twl4030_set_gpio_dataout() twice in
both twl_direction_out() and twl_set(). Instead, we should first
call twl_direction_out() in twl_direction_out() followed by
twl4030_set_gpio_dataout() in twl_set().
This regression probably has gone unnoticed for a long time as the
bootloader may have set the GPIO direction properly in many cases.
This fixes at least the LCD panel not turning on omap3 LDP for
example.
Cc: linux-gpio@vger.kernel.org
Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
commit a31ab44ef5d07c6707df4a9ad2c8affd2d62ff4b upstream.
The I2C controller node needs #address-cells and #size-cells properties,
but these are currently missing. Add them. This allows child nodes to be
parsed correctly.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
commit c61248afa8190ae3f47ee67f46e3c9b584a73d31 upstream.
Without the interrupt you'll get problems if you enable
CONFIG_RTC_DRV_MAX77686. Setup the interrupt properly in the device
tree.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
commit 250ad590d6f12d93f4d85be305b0a598d609232e upstream.
Some gpio chips may have get/set operations that
can sleep. gpio_set_value() only works for chips
which do not sleep, for the others we will get a
kernel warning. Using gpio_set_value_cansleep()
will work for both chips that do sleep and those
who don't.
Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com>
Acked-by: Peter Korsgaard <peter.korsgaard@barco.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 8c0ec2500eeb89749341884a972860d7f9e56f9c upstream.
The i2c-mux driver requires that the chan_id parameter
passed to the i2c_add_mux_adapter() function is equal
to the reg value for that adapter:
for_each_child_of_node(mux_dev->of_node, child) {
ret = of_property_read_u32(child, "reg", ®);
if (ret)
continue;
if (chan_id == reg) {
priv->adap.dev.of_node = child;
break;
The i2c-mux-gpio driver uses an internal logical index
for chan_id when calling i2c_add_mux_adapter() instead
of using the reg value.
Because of this, there will problems in selecting the
right adapter when the i2c-mux-gpio's index into
mux->data.values doesn't match the reg value.
An example of such a case:
mux->data.values = { 1, 0 }
For chan_id = 0, i2c-mux will bind the adapter to the
of_node with reg = <0>, but when it will call the
select() callback with chan_id set to 0, the i2c-mux-gpio
will use it as an index into mux->data.values and it will
actually select the bus with reg = <1>.
Acked-by: Alexander Sverdlin <alexander.sverdlin@nsn.com>
commit 0d1862ea1a5bb876cf05555a7307080cb75bf379 upstream.
In the flexcan_chip_start() function first the flexcan core is going through
the soft reset sequence, then the RX FIFO is enabled.
With the hardware is put into FIFO mode, message buffers 1...7 are reserved by
the FIFO engine. The remaining message buffers are in reset default values.
This patch removes the bogus initialization of the message buffers, as it
causes an imprecise external abort on imx6.
Reported-by: Lothar Waßmann <LW@KARO-electronics.de>
Tested-by: Lothar Waßmann <LW@KARO-electronics.de>
[mkl: adjusted context for stable]
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 38c7937379276a5ea8c54481205003af2f2b5694 upstream.
Break SOCK_NONBLOCK out to its own asm-file as other arches do. This
fixes build errors with auditd and probably other packages.
Signed-off-by: Helge Deller <deller@gmx.de>
commit 66da0e1f9034140ae2f571ef96e254a25083906c upstream.
When devpts is unmounted, there may be a no-longer-used IDR tree hanging
off the superblock we are about to kill. This needs to be cleaned up
before destroying the SB.
The leak is usually not a big deal because unmounting devpts is typically
done when shutting down the whole machine. However, shutting down an LXC
container instead of a physical machine exposes the problem (the garbage
is detectable with kmemleak).
Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com>
Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
commit 6d0a4ed2b90a12e1403d3e7d9d8c2cc7fdc301b5 upstream.
This fixes a typo which left twsi config3 option enabled.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
commit 98d6f4dd84a134d942827584a3c5f67ffd8ec35f upstream.
Fedora Ruby maintainer reported latest Ruby doesn't work on Fedora Rawhide
on ARM. (http://bugs.ruby-lang.org/issues/9008)
Because of, commit 1c6b39ad3f (alarmtimers: Return -ENOTSUPP if no
RTC device is present) intruduced to return ENOTSUPP when
clock_get{time,res} can't find a RTC device. However this is incorrect.
First, ENOTSUPP isn't exported to userland (ENOTSUP or EOPNOTSUP are the
closest userland equivlents).
Second, Posix and Linux man pages agree that clock_gettime and
clock_getres should return EINVAL if clk_id argument is invalid.
While the arugment that the clockid is valid, but just not supported
on this hardware could be made, this is just a technicality that
doesn't help userspace applicaitons, and only complicates error
handling.
Thus, this patch changes the code to use EINVAL.
Reported-by: Vit Ondruch <v.ondruch@tiscali.cz>
[jstultz: Tweaks to commit message to include full rational]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 53805eca3d89b095062c11a6798689bb0af09216 upstream.
The 4fb71074a570 (perf ui/hist: Consolidate hpp helpers) cset introduced
a cast of percent_color_snprintf to a function pointer type with
varargs. Change percent_color_snprintf to be variadic and remove the
cast.
The symptom of this was all percentages being reported as 0.00% in perf
report --stdio output on the armhf arch.
Signed-off-by: Michael Hudson-Doyle <michael.hudson@linaro.org>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Jean Pihet <jean.pihet@linaro.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/87zjppvw7y.fsf@canonical.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit f69f86b1ba6493126a7f093a65a8952bcb183de2 upstream.
Certain registers require patching after the SYSCLK has been brought up
add support for this into the CODEC driver.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 3e68ce1bc72e5d6615677ec5a8b0a9bcb6c7a490 upstream.
The FLL must be placed into free-run mode before disabling
to allow it to entirely shut down.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
commit fc7dc61d9a87011aaf8a6eb3144ebf9552adf5d2 upstream.
Unbalanced calls to snd_imx_pcm_trigger() may result in endless
FIQ activity and thus provoke eternal sound. While on the first glance,
the switch statement looks pretty symmetric, the SUSPEND/RESUME
pair is not: the suspend case comes along snd_pcm_suspend_all(),
which for fsl/imx-pcm-fiq is called only at snd_soc_suspend(),
but the resume case originates straight from the SNDRV_PCM_IOCTL_RESUME.
This way userland may provoke an unbalanced resume, which might cause
the fiq_enable counter to increase and never return to zero again,
so eventually imx_pcm_fiq is never disabled.
Simply removing the fiq_enable will solve the problem, as long as
one never goes play and capture game simultaneously, but beware
trying both at once, the early TRIGGER_STOP will cut off the other
activity prematurely. So now playing and capturing is scrutinized
separately, instead of by counting.
Signed-off-by: Oskar Schirmer <oskar@scara.com>
commit afed4dbe3a043dbd833a53b6b4951e155708afd2 upstream.
Fixes: 4b2ffc205cb9 ('ASoC: Blackfin I2S: add 8-bit sample support')
Reported-by: David Binderman
commit 50bfcf2df2fadf77e143d6099150e6fa7ef4d78c upstream.
It's safer to turn on regcache_cache_only before disabling regulator since
the driver will turn off the regcache_cache_only after enabling regulator.
If we remain cache_only false, some command like 'amixer cset' would get
failure if being run before wm8962_resume().
Signed-off-by: Nicolin Chen <b42378@freescale.com>
commit 3d800c6d75b8c92fa928a0bcaf95cd7ac5fd1ce5 upstream.
The mask for CS42L52_MIC_CTL_TYPE_MASK was wrong keeping the mic config
from being set correctly.
Signed-off-by: Brian Austin <brian.austin@cirrus.com>
commit 7b5bfb82882b9b1c8423ce0ed6852ca3762d967a upstream.
If you record the sound during playback,
the playback sound becomes silent.
Modify so that the codec driver does not clear
SG_SL1::DACL bit which is controlled under widget
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
commit 185d91442550110db67a7dc794a32efcea455a36 upstream.
The driver supports 16-bit brightness values, but the value returned
from get_brightness was truncated to eight bits.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Cc: Jingoo Han <jg1.han@samsung.com>
commit ad5066d4c2b1d696749f8d7816357c23b648c4d3 upstream.
Make sure to honour gpio polarity also at remove so that the backlight is
actually disabled on boards with active-low enable pin.
Acked-by: Jingoo Han <jg1.han@samsung.com>
commit 9df682927c2e3a92f43803d6b52095992e3b2ab8 upstream.
This fixes resets on heavy TX data traffic.
Vendor driver
VT6656_Linux_src_v1.21.03_x86_11.04.zip
http://www.viaembedded.com/servlet/downloadSvl?id=1890&download_file_id=14704
This is GPL-licensed code.
original code
BBbVT3184Init
//2007-0725, RobertChang add, Enable Squelch detect reset option(SQ_RST_Opt), USB (register4, bit1)
CONTROLnsRequestIn(pDevice,
MESSAGE_TYPE_READ,
(WORD)0x600+4, // USB's Reg4's bit1
MESSAGE_REQUEST_MEM,
1,
(PBYTE) &byData);
byData = byData|2 ;
CONTROLnsRequestOut(pDevice,
MESSAGE_TYPE_WRITE,
1,
(PBYTE) &byData);
return TRUE;//ntStatus;
A back port patch is needed for kernels less than 3.10.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit 67296874eb1cc80317bf2a8fba22b494e21eb29b upstream.
zsmalloc encodes a handle using the pfn and an object
index. On hardware platforms with physical memory starting
at 0x0 the pfn can be 0. This causes the encoded handle to be
0 and is incorrectly interpreted as an allocation failure.
This issue affects all current and future SoCs with physical
memory starting at 0x0. All MSM8974 SoCs which includes
Google Nexus 5 devices are affected.
To prevent this false error we ensure that the encoded handle
will not be 0 when allocation succeeds.
Signed-off-by: Olav Haugan <ohaugan@codeaurora.org>
commit 930ba4a374b96560ef9fde2145cdc454a164ddcc upstream.
There seems to be no active maintainer for the driver, and there is an
unfixed security bug, so disable the driver for now.
Hopefully someone steps up to be the maintainer, and works to get this
out of staging, otherwise it will be deleted soon.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Omar Ramirez Luna <omar.ramirez@copitl.com>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Kanigeri, Hari <h-kanigeri2@ti.com>
Cc: Ameya Palande <ameya.palande@nokia.com>
Cc: Guzman Lugo, Fernando <fernando.lugo@ti.com>
Cc: Hebbar, Shivananda <x0hebbar@ti.com>
Cc: Ramos Falcon, Ernesto <ernesto@ti.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Anna, Suman <s-anna@ti.com>
Cc: Gupta, Ramesh <grgupta@ti.com>
Cc: Gomez Castellanos, Ivan <ivan.gomez@ti.com>
Cc: Andy Shevchenko <ext-andriy.shevchenko@nokia.com>
Cc: Armando Uribe De Leon <x0095078@ti.com>
Cc: Deepak Chitriki <deepak.chitriki@ti.com>
Cc: Menon, Nishanth <nm@ti.com>
Cc: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: stable <stable@vger.kernel.org>
commit 9b3d423707c3b1f6633be1be7e959623e10c596b upstream.
instead of pll3_usb_otg the parent of can_root clock
should be pll3_60m.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
commit 94c4c79f2f1acca6e69a50bff5a7d9027509c16b upstream.
Make sure the RTT-interrupts are masked at boot by adding a new helper
function to be used at SOC-init.
This fixes hanged boot on all AT91 SOCs with an RTT, for example, if an
RTT-alarm goes off after a non-clean shutdown (e.g. when using RTC
wakeup).
The RTC and RTT-peripherals are powered by backup power (VDDBU) (on all
AT91 SOCs but RM9200) and are not reset on wake-up, user, watchdog or
software reset. This means that their interrupts may be enabled during
early boot if, for example, they where not disabled during a previous
shutdown (e.g. due to a buggy driver or a non-clean shutdown such as a
user reset). Furthermore, an RTC or RTT-alarm may also be active.
The RTC and RTT-interrupts use the shared system-interrupt line, which
is also used by the PIT, and if an interrupt occurs before a handler
(e.g. RTC-driver) has been installed this leads to the system interrupt
being disabled and prevents the system from booting.
Note that when boot hangs due to an early RTC or RTT-interrupt, the only
way to get the system to start again is to remove the backup power (e.g.
battery) or to disable the interrupt manually from the bootloader. In
particular, a user reset is not sufficient.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 6de714c21a8ea315fffba6a93bbe537f4c1bf4f0 upstream.
Make sure the RTC-interrupts are masked at boot by adding a new helper
This fixes hanged boot on all AT91 SOCs with an RTC (but RM9200), for
example, after a reset during an RTC-update or if an RTC-alarm goes off
after shutdown (e.g. when using RTC wakeup).
commit 30aeadd44deea3f3b0df45b9a70ee0fd5f8d6dc2 upstream.
This turns on the internal integrator LCD display(s). It seems that the code
to do this got lost in refactoring of the CLCD driver.
Signed-off-by: Jonathan Austin <jonathan.austin@arm.com>
commit e16b31bf47738f4498d7ce632e12d7d2a6a2492a upstream.
The exception handling code fails to clear the IT state, potentially
leading to incorrect execution of the fixup if the size of the IT
block is more than one.
Let fixup_exception do the IT sanitizing if a fixup has been found,
and restore CPSR from the stack when returning from a data abort.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
commit f3964fe1c9d9a887d65faf594669852e4dec46e0 upstream.
The CS2 region contains the Assabet board configuration and status
registers, which are 32-bit. Unfortunately, some boot loaders do not
configure this region correctly, leaving it setup as a 16-bit region.
Fix this.
commit 0bebda684857f76548ea48c8886785198701d8d3 upstream.
am33xx has a INTC_PENDING_IRQ3 register that is not checked for pending
interrupts. This patch adds AM33XX to the ifdef of SOCs that have to
check this register.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
commit 0219132fe7c26574371232b50db085573f6fbd3f upstream.
STI text console (sticon) was broken on 64bit machines with more than
4GB RAM and this lead in some cases to a kernel crash.
Since sticon uses the 32bit STI API it needs to keep pointers to memory
below 4GB. But on a 64bit kernel some memory regions (e.g. the kernel
stack) might be above 4GB which then may crash the kernel in the STI
functions.
Additionally sticon didn't selected the built-in framebuffer fonts by
default. This is now fixed.
On a side-note: Theoretically we could enhance the sticon driver to
use the 64bit STI API. But - beside the fact that some machines don't
provide a 64bit STI ROM - this would just add complexity.
commit 645378d85ee524e429aa4cf52806047b56cdc596 upstream.
The Intel D410PT(LW) and D425KT Mini-ITX desktop boards both show up as
having LVDS but the hardware is not populated. This patch adds them to
the list of such systems. Patch is against 3.11.4
v2: Patch revised to match the D425KT exactly as the D425KTW does have
LVDS. According to Intel's documentation, the D410PTL and D410PLTW
don't.
Signed-off-by: Rob Pearce <rob@flitspace.org.uk>
[danvet: Pimp commit message to my liking and add cc: stable.]
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit e5614f0c2d0f4d7f0b8ef745d34593baf2c5dbf8 upstream.
This replaceable mainboard only has a VGA-out, yet it claims to also have
a connected LVDS header.
Addresses https://bugs.freedesktop.org/show_bug.cgi?id=63860
[jani.nikula@intel.com: use DMI_EXACT_MATCH for board name.]
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reported-by: <annndddrr@gmail.com>
Cc: Cornel Panceac <cpanceac@gmail.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 5017b2851373ee15c7035151853bb1448800cae2 upstream.
dmi_match() considers a substring match to be a successful match. This is
not always sufficient to distinguish between DMI data for different
systems. Add support for exact string matching using strcmp() in addition
to the substring matching using strstr().
The specific use case in the i915 driver is to allow us to use an exact
match for D510MO, without also incorrectly matching D510MOV:
.ident = "Intel D510MO",
.matches = {
DMI_MATCH(DMI_BOARD_VENDOR, "Intel"),
DMI_EXACT_MATCH(DMI_BOARD_NAME, "D510MO"),
Cc: <annndddrr@gmail.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
commit 72a0c5571351f5184195754d23db3e14495b2080 upstream.
On cris arch, the functions below aren't defined:
drivers/media/platform/sh_veu.c: In function 'sh_veu_reg_read':
drivers/media/platform/sh_veu.c:228:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
drivers/media/platform/sh_veu.c: In function 'sh_veu_reg_write':
drivers/media/platform/sh_veu.c:234:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_read':
drivers/media/platform/vsp1/vsp1.h:66:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_write':
drivers/media/platform/vsp1/vsp1.h:71:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_setup':
drivers/media/platform/soc_camera/rcar_vin.c:284:3: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_request_capture_stop':
drivers/media/platform/soc_camera/rcar_vin.c:353:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
Yet, they're available, as CONFIG_GENERIC_IOMAP is defined. What happens
is that asm/io.h was not including asm-generic/iomap.h.
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
commit 76ae281f6307331aa063288edb6422ae99f435f0 upstream.
A race window in configfs, it starts from one dentry is UNHASHED and end
before configfs_d_iput is called. In this window, if a lookup happen,
since the original dentry was UNHASHED, so a new dentry will be
allocated, and then in configfs_attach_attr(), sd->s_dentry will be
updated to the new dentry. Then in configfs_d_iput(),
BUG_ON(sd->s_dentry != dentry) will be triggered and system panic.
sys_open: sys_close:
... fput
dput
dentry_kill
__d_drop <--- dentry unhashed here,
but sd->dentry still point
to this dentry.
lookup_real
configfs_lookup
configfs_attach_attr---> update sd->s_dentry
to new allocated dentry here.
d_kill
configfs_d_iput <--- BUG_ON(sd->s_dentry != dentry)
triggered here.
To fix it, change configfs_d_iput to not update sd->s_dentry if
sd->s_count > 2, that means there are another dentry is using the sd
beside the one that is going to be put. Use configfs_dirent_lock in
configfs_attach_attr to sync with configfs_d_iput.
With the following steps, you can reproduce the bug.
1. enable ocfs2, this will mount configfs at /sys/kernel/config and
fill configure in it.
2. run the following script.
while [ 1 ]; do cat /sys/kernel/config/cluster/$your_cluster_name/idle_timeout_ms > /dev/null; done &
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
commit 4560e7c3317c7a2b370e36dadd3a3bac2ed70818 upstream.
Use the ACCESS_ONCE macro for both accesses to idle->sequence in the
loops to calculate the idle time. If only one access uses the macro,
the compiler is free to cache the value for the second access which
can cause endless loops.
commit 36165fd5b00bf8163f89c21bb16a3e9834555b10 upstream.
Polling TX statuses too frequently has two negative effects. First is
randomly peek CPU usage, causing overall system functioning delays.
Second bad effect is that device is not able to fill TX statuses in
H/W register on some workloads and we get lot of timeouts like below:
ieee80211 phy4: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 7 in queue 2
ieee80211 phy4: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
This not only cause flood of messages in dmesg, but also bad throughput,
since rate scaling algorithm can not work optimally.
In the future, we should probably make polling interval be adjusted
automatically, but for now just increase values, this make mentioned
problems gone.
Resolve:
https://bugzilla.kernel.org/show_bug.cgi?id=62781
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit e92aee330837e4911553761490a8fb843f2053a6 upstream.
This patch adds the Port Reset Change flag to the set of bits that are
preemptively cleared on init/resume of a hub. In theory this bit should
never be set unexpectedly... in practice it can still happen if BIOS,
SMM or ACPI code plays around with USB devices without cleaning up
correctly. This is especially dangerous for XHCI root hubs, which don't
generate any more Port Status Change Events until all change bits are
cleared, so this is a good precaution to have (similar to how it's
already done for the Warm Port Reset Change flag).
Signed-off-by: Julius Werner <jwerner@chromium.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 4bff7208f332b2b1d7cf1338e50527441283a198 upstream.
The flow may reach the err label without freeing cl and cl_info
cl and cl_info weren't assigned to ndev->cl and cl_info
so they weren't freed in mei_nfc_free called on error path
Cc: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit a6b31d18b02ff9d7915c5898c9b5ca41a798cd73 upstream.
The following scenario can cause silent data corruption when doing
NFS writes. It has mainly been observed when doing database writes
using O_DIRECT.
1) The RPC client uses sendpage() to do zero-copy of the page data.
2) Due to networking issues, the reply from the server is delayed,
and so the RPC client times out.
3) The client issues a second sendpage of the page data as part of
an RPC call retransmission.
4) The reply to the first transmission arrives from the server
_before_ the client hardware has emptied the TCP socket send
buffer.
5) After processing the reply, the RPC state machine rules that
the call to be done, and triggers the completion callbacks.
6) The application notices the RPC call is done, and reuses the
pages to store something else (e.g. a new write).
7) The client NIC drains the TCP socket send buffer. Since the
page data has now changed, it reads a corrupted version of the
initial RPC call, and puts it on the wire.
This patch fixes the problem in the following manner:
The ordering guarantees of TCP ensure that when the server sends a
reply, then we know that the _first_ transmission has completed. Using
zero-copy in that situation is therefore safe.
If a time out occurs, we then send the retransmission using sendmsg()
(i.e. no zero-copy), We then know that the socket contains a full copy of
the data, and so it will retransmit a faithful reproduction even if the
RPC call completes, and the application reuses the O_DIRECT buffer in
the meantime.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit c6f58d9b362b45c52afebe4342c9137d0dabe47f upstream.
Andreas Herrmann writes:
When I've used slub_debug kernel option (e.g.
"slub_debug=,skbuff_fclone_cache" or similar) on a debug session I've
seen a panic like:
Highbank #setenv bootargs console=ttyAMA0 root=/dev/sda2 kgdboc.kgdboc=ttyAMA0,115200 slub_debug=,kmalloc-4096 earlyprintk=ttyAMA0
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 5 [#1] SMP ARM
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Tainted: G W 3.12.0-00048-gbe408cd #314
task: c0898360 ti: c088a000 task.ti: c088a000
PC is at strncmp+0x1c/0x84
LR is at kmem_cache_flags.isra.46.part.47+0x44/0x60
pc : [<c02c6da0>] lr : [<c0110a3c>] psr: 200001d3
sp : c088bea8 ip : c088beb8 fp : c088beb4
r10: 00000000 r9 : 413fc090 r8 : 00000001
r7 : 00000000 r6 : c2984a08 r5 : c0966e78 r4 : 00000000
r3 : 0000006b r2 : 0000000c r1 : 00000000 r0 : c2984a08
Flags: nzCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 0000404a DAC: 00000015
Process swapper (pid: 0, stack limit = 0xc088a248)
Stack: (0xc088bea8 to 0xc088c000)
bea0: c088bed4 c088beb8 c0110a3c c02c6d90 c0966e78 00000040
bec0: ef001f00 00000040 c088bf14 c088bed8 c0112070 c0110a04 00000005 c010fac8
bee0: c088bf5c c088bef0 c010fac8 ef001f00 00000040 00000000 00000040 00000001
bf00: 413fc090 00000000 c088bf34 c088bf18 c0839190 c0112040 00000000 ef001f00
bf20: 00000000 00000000 c088bf54 c088bf38 c0839200 c083914c 00000006 c0961c4c
bf40: c0961c28 00000000 c088bf7c c088bf58 c08392ac c08391c0 c08a2ed8 c0966e78
bf60: c086b874 c08a3f50 c0961c28 00000001 c088bfb4 c088bf80 c083b258 c0839248
bf80: 2f800000 0f000000 c08935b4 ffffffff c08cd400 ffffffff c08cd400 c0868408
bfa0: c29849c0 00000000 c088bff4 c088bfb8 c0824974 c083b1e4 ffffffff ffffffff
bfc0: c08245c0 00000000 00000000 c0868408 00000000 10c5387d c0892bcc c0868404
bfe0: c0899440 0000406a 00000000 c088bff8 00008074 c0824824 00000000 00000000
[<c02c6da0>] (strncmp+0x1c/0x84) from [<c0110a3c>] (kmem_cache_flags.isra.46.part.47+0x44/0x60)
[<c0110a3c>] (kmem_cache_flags.isra.46.part.47+0x44/0x60) from [<c0112070>] (__kmem_cache_create+0x3c/0x410)
[<c0112070>] (__kmem_cache_create+0x3c/0x410) from [<c0839190>] (create_boot_cache+0x50/0x74)
[<c0839190>] (create_boot_cache+0x50/0x74) from [<c0839200>] (create_kmalloc_cache+0x4c/0x88)
[<c0839200>] (create_kmalloc_cache+0x4c/0x88) from [<c08392ac>] (create_kmalloc_caches+0x70/0x114)
[<c08392ac>] (create_kmalloc_caches+0x70/0x114) from [<c083b258>] (kmem_cache_init+0x80/0xe0)
[<c083b258>] (kmem_cache_init+0x80/0xe0) from [<c0824974>] (start_kernel+0x15c/0x318)
[<c0824974>] (start_kernel+0x15c/0x318) from [<00008074>] (0x8074)
Code: e3520000 01a00002 089da800 e5d03000 (e5d1c000)
---[ end trace 1b75b31a2719ed1d ]---
Kernel panic - not syncing: Fatal exception
Problem is that slub_debug option is not parsed before
create_boot_cache is called. Solve this by changing slub_debug to
early_param.
Kernels 3.11, 3.10 are also affected. I am not sure about older
kernels.
Christoph Lameter explains:
kmem_cache_flags may be called with NULL parameter during early boot.
Skip the test in that case.
Reported-by: Andreas Herrmann <andreas.herrmann@calxeda.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit c13f20ac48328b05cd3b8c19e31ed6c132b44b42 upstream.
The VSX MSR bit in the user context indicates if the context contains VSX
state. Currently we set this when the process has touched VSX at any stage.
Unfortunately, if the user has not provided enough space to save the VSX state,
we can't save it but we currently still set the MSR VSX bit.
This patch changes this to clear the MSR VSX bit when the user doesn't provide
enough space. This indicates that there is no valid VSX state in the user
context.
This is needed to support get/set/make/swapcontext for applications that use
VSX but only provide a small context. For example, getcontext in glibc
provides a smaller context since the VSX registers don't need to be saved over
the glibc function call. But since the program calling getcontext may have
used VSX, the kernel currently says the VSX state is valid when it's not. If
the returned context is then used in setcontext (ie. a small context without
VSX but with MSR VSX set), the kernel will refuse the context. This situation
has been reported by the glibc community.
Based on patch from Carlos O'Donell.
Tested-by: Haren Myneni <haren@linux.vnet.ibm.com>
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit 5a049f14902982c26538250bdc8d54156d357252 upstream.
Commit fba2369e6ceb (mm: use vm_unmapped_area() on powerpc architecture)
has a bug in slice_scan_available() where we compare an unsigned long
(high_slices) against a shifted int. As a result, comparisons against
the top 32 bits of high_slices (representing the top 32TB) always
returns 0 and the top of our mmap region is clamped at 32TB
This also breaks mmap randomisation since the randomised address is
always up near the top of the address space and it gets clamped down
to 32TB.
Acked-by: Michel Lespinasse <walken@google.com>
commit 631ad691b5818291d89af9be607d2fe40be0886e upstream.
We need add PE to its own PELTV. Otherwise, the errors originated
from the PE might contribute to other PEs. In the result, we can't
clear up the error successfully even we're checking and clearing
errors during access to PCI config space.
Reported-by: kalshett@in.ibm.com
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
commit 411cabf79e684171669ad29a0628c400b4431e95 upstream.
Commit e82b89a6f19bae73fb064d1b3dd91fcefbb478f4 used strcat instead of
strcpy which can result in an overflow of newlines on the buffer.
Signed-off-by: Prarit Bhargava
Cc: benh@kernel.crashing.org
Cc: ben@decadent.org.uk
commit 2bf75084f6d9f9a91ba6e30a501ff070d8a1acf6 upstream.
The MPC5200 LPBFIFO driver requires the bestcomm module to be
enabled, otherwise building will fail. Fix it.
Reported-by: Wolfgang Denk <wd@denx.de>
