Add vendor name "netlogic" in vendor-prefixes.txt, which will be used for
the Netlogic XLP and XLPII MIPS SoCs. These processors were from NetLogic
Microsystems that is now a part of Broadcom Corporation.
Signed-off-by: Subhendu Sekhar Behera <sbehera@broadcom.com>
Signed-off-by: Jayachandran C <jchandra@broadcom.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Having a board where the I2C bus locks up occasionally made it clear
that the bus recovery in the i2c-davinci driver will only work on
some boards, because on regular boards, this will only toggle GPIO
lines that aren't muxed to the actual pins.
The I2C controller on SoCs like da850 (and da830), Keystone 2 has the
built-in capability to bit-bang its lines by using the ICPFUNC registers
of the i2c controller.
Implement the suggested procedure by toggling SCL and checking SDA using
the ICPFUNC registers of the I2C controller when present. Allow platforms
to indicate the presence of the ICPFUNC registers with a has_pfunc platform
data flag and add optional DT property "ti,has-pfunc" to indicate
the same in DT.
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Tested-by: Michael Lawnick <michael.lawnick@nokia.com>
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
Signed-off-by: Mike Looijmans <milo-software@users.sourceforge.net>
[grygorii.strashko@ti.com: combined patches from Ben Gardiner and
Mike Looijmans and reimplemented ICPFUNC bus recovery using I2C
bus recovery infrastructure]
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
This patch converts Davinci I2C driver to use I2C bus recovery
infrastructure, introduced by commit 5f9296ba21b3 ("i2c: Add
bus recovery infrastructure").
The i2c_bus_recovery_info is configured for Davinci I2C adapter
only in case scl_pin is provided in platform data.
As the controller must be held in reset while doing so, the
recovery routine must re-init the controller. Since this was already
being done after each call to i2c_recover_bus, move those calls into
the recovery_prepare/unprepare routines and as well.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
This patch changes type of input parameter for
prepare/unprepare_recovery() callbacks from struct i2c_bus_recovery_info
* to struct i2c_adapter *. This allows to simplify implementation of
these callbacks and avoid type conversations from i2c_bus_recovery_info
to i2c_adapter. The i2c_bus_recovery_info can be simply retrieved from
struct i2c_adapter which contains pointer on it. There are no users
currently, so this is safe to do.
Probe deferral is not an error case. It happens only when
the necessary dependencies are not there yet.
The driver core is already printing a message when a driver
requests probe deferral, so this can be traced in the logs
without these error prints.
This patch removes the error messages for these deferral cases.
Signed-off-by: Ionut Nicu <ioan.nicu.ext@nokia.com>
Acked-by: Peter Korsgaard <peter.korsgaard@barco.com>
Adds the i2c bus controller driver for the Ingenic JZ4780 SoC.
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
This patch makes sure the platform device tree node is inherited by
the adapter device. This allows the DLN2 bus to work with i2c devices
defined in the device tree.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
wait_for_completion_timeout return 0 (timeout) or >=1 (completion) so the check
for >= 0 is always true and can be dropped implying that r==-EREMOTEIO and thus
the return of -EREMOTEIO can be done in the if (dev->buf_len) branch.
As wait_for_completion_timeout returns unsigned long not int, and int r is
exclusively used for wait_for_completion_timeout it is renamed and the type
changed to unsigned long.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
ISR should not return IRQ_HANDLED for not handling anything.
This patch fixes the return value of ISR for the same case.
Signed-off-by: Amit Singh Tomar <amit.tomar@freescale.com>
Acked-by: Danielle Costantino <danielle.costantino@gmail.com>
It is a bit subtle when to correctly increase the buffer index when
reading. Make this clearer by adding some more comments and pointers to
the docs.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
After more discussion, brave users, and additional datasheet evaluation,
some API updates for the new I2C slave framework became imminent. The
slave events now get some easier to understand naming. Also, the event
handling has been simplified to only need a single call to the slave
callback when an action by the backend is required.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
The CX92755 is an SoC in the Conexant Digicolor series. The devicetree binding
document describes the I2C controller on the CX92755 SoC, that is also shared
by some other SoCs in the Digicolor series. The driver adds support.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
[wsa: fixed spaces around operators]
Make sure dynamic ids do not interfere with fixed ones and let them
start after the highest fixed id. This patch might cause different
bus-numbers than before for dynamic ids, however it fixes a bug. Assume:
- fixed id0 defers probe
- fixed id1 succeeds and registers a muxed bus with dynamic id
- muxed bus gets id0
- fixed id0 wants to probe again, but its fixed id is gone now
- fixed id0 probe fails
With this patch, the fixed ids are always reserved in the DT case.
For legacy board init, we already have a mechanism like this in
i2c_register_board_info().
Reported-by: Bob Feretich <bob.feretich@rafresearch.com>
I2C supports adding adapters using either a dynamic or fixed id. The
latter is provided by aliases in the DT case. To prevent id collisions
of those two types, install this function which gives us the highest
fixed id, so we can then let the dynamically created ones come after
this highest number.
Acked-by: Rob Herring <robh@kernel.org>
With -EPROBE_DEFER, this message is confusing and we hope for a
centralized printout in the future anyhow.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Christian Ruppert <christian.ruppert@alitech.com>
For the 85xx platforms, the source clock for the i2c-mpc can change from
one SoC to another. This is documented in the AN2919 "Determining the
I2C Frequency Divider Ratio for SCL" by Freescale. Not taking this into
account can lead to the output SCL frequency to by off by an offset. It
was observed on the P2041 from the QorIQ family.
This patch fixes this problem by setting the prescaler value to the
appropriate value when required. The SoCs that required a different
prescaler than 1 are identified by reading out the SVR as discussed in
http://thread.gmane.org/gmane.linux.drivers.devicetree/94247/focus=20556
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Return type of wait_for_completion_timeout is unsigned long not int.
Appropriately typed/named variable are added and assignment fixed up.
Acked-by: James Hogan <james.hogan@imgtec.com>
Return type of wait_for_completion_timeout is unsigned long not int. This
patch adds a timeout variable of appropriate type and fixes up the assignment.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
return type of wait_for_completion_timeout is unsigned long not int. The
return variable is renamed to reflect its use and the type adjusted to
unsigned long.
return type of read_i2c() is int not u32. As the assignments to status
are consistent with int here its type is changed to int.
return type of wait_for_completion_timeout is unsigned long not int. as
timeout is used for wait_for_completion_timeout exclusively here its
type is simply changed to unsigned long.
An appropriate variable of type unsigned long is introduced and the
assignments fixed up.
return type of wait_for_completion_timeout is unsigned long not int. As
ret is in used for other calls a new appropriately typed variable timeout
is added to handle wait_for_completion_timeout
wait_result is only used for wait_for_completion_timeout here the type
time_left is used for wait_for_completion_timeout exclusively here its
Acked-by: Lee Jones <lee.jones@linaro.org>
return type of wait_for_completion_timeout is unsigned long not int, rather
than introducing a new variable the wait_for_completion_timeout is moved
into the if condition as the return value is only used to detect timeout.
Reviewed-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
return variable is renamed to make the timeout condition clearly readable
and the type adjusted to unsigned long.
This is only an API consolidation and should make things more readable
it replaces var * HZ / 1000 by msecs_to_jiffies(var).
return type of wait_for_completion_timeout is unsigned long not int. As ret
was only used for wait_for_completion_timeout here it is renamed to time_left
the type changed to unsigned long and references fixed up.
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Thierry Reding <treding@nvidia.com>
An appropriately named unsigned long is added and the assignment fixed up.
Hardware can do write-then-anything. Activate that.
Signed-off-by: Neelesh Gupta <neelegup@linux.vnet.ibm.com>
[wsa: cosmetic updates]
Tested-by: Ray Jui <rjui@broadcom.com>
Tested-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Tested-by: Neelesh Gupta <neelegup@linux.vnet.ibm.com>
Tested-By: Ludovic Desroches <ludovic.desroches@atmel.com>
Let the core do the checks if HW quirks prevent a transfer. Saves code
from drivers and adds consistency.
The number of I2C adapters which are not fully I2C compatible is rising,
sadly. Drivers usually do handle the flaws, still the user receives only
some errno for a transfer which normally can be expected to work. This
patch introduces a formal description of flaws. One advantage is that
the core can check before the actual transfer if the messages could be
transferred at all. This is done in the next patch. Another advantage is
that we can pass this information to the user so the restrictions are
exactly known and further actions can be based on that. This will be
done later after some stabilization period for this description.
Since 39b2bbe3d715 (gpio: add flags argument to gpiod_get*() functions)
which appeared in v3.17-rc1, the gpiod_get* functions take an additional
parameter that allows to specify direction and initial value for
outputs.
Also there is an *_optional variant that serves well here. The sematics
is slightly changed here by using it. Now if a reset gpio is specified
and getting hold on it fails, pca954x_probe fails, too.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Simplifies the code a bit and makes easier to disable PCI device on driver
detach by removing the pcim_pin_device() call in the future if needed.
Reason why i2c-i801.c doesn't ever call pci_disable_device() was because it
made some systems to hang during power-off. See commit d6fcb3b9cf77
("[PATCH] i2c-i801.c: don't pci_disable_device() after it was just enabled")
and
http://marc.info/?l=linux-kernel&m=115160053309535&w=2
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Since pci_disable_device() is not called from i801_suspend() and power
state is set already it means that subsequent pci_enable_device() calls do
practically nothing but monotonically increase struct pci_dev enable_cnt.
This simplifies the error and remove paths.
