[ Upstream commit b8fd0823e0770c2d5fdbd865bccf0d5e058e5287 ]
Use AF_INET6 instead of AF_INET in IPv6-related code path
Signed-off-by: Andrii Vladyka <tulup@mail.ru>
[ Upstream commit 23263ec86a5f44312d2899323872468752324107 ]
When an ip6_tunnel is in mode 'any', where the transport layer
protocol can be either 4 or 41, dst_cache must be disabled.
This is because xfrm policies might apply to only one of the two
protocols. Caching dst would cause xfrm policies for one protocol
incorrectly used for the other.
Signed-off-by: Eli Cooper <elicooper@gmx.com>
[ Upstream commit 78bbb15f2239bc8e663aa20bbe1987c91a0b75f6 ]
A vlan device with vid 0 is allow to creat by not able to be fully
cleaned up by unregister_vlan_dev() which checks for vlan_id!=0.
Also, VLAN 0 is probably not a valid number and it is kinda
"reserved" for HW accelerating devices, but it is probably too
late to reject it from creation even if makes sense. Instead,
just remove the check in unregister_vlan_dev().
Fixes: ad1afb003939 ("vlan_dev: VLAN 0 should be treated as "no vlan tag" (802.1p packet)")
Cc: Vlad Yasevich <vyasevich@gmail.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
This is a stable-only fix for the backport of commit 5d9b70f7d52e
("xhci: Don't add a virt_dev to the devs array before it's fully
allocated").
In branches that predate commit c5628a2af83a ("xhci: remove endpoint
ring cache") there is an additional failure path in
xhci_alloc_virt_device() where ring cache allocation fails, in
which case we need to free the ring allocated for endpoint 0.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Mathias Nyman <mathias.nyman@intel.com>
commit a9e840a2081ed28c2b7caa6a9a0041c950b3c37d upstream.
We need to ensure there is enough headroom to push extra header,
but we also need to check if we are allowed to change headers.
skb_cow_head() is the proper helper to deal with this.
Fixes: cc28a20e77b2 ("introduce cx82310_eth: Conexant CX82310-based ADSL router USB ethernet driver")
Cc: James Hughes <james.hughes@raspberrypi.org>
Signed-off-by: Oliver Neukum <oneukum@suse.com>
commit b7c6d2675899cfff0180412c63fc9cbd5bacdb4d upstream.
Fixes: d0cad871703b ("smsc75xx: SMSC LAN75xx USB gigabit ethernet adapter driver")
commit d532c1082f68176363ed766d09bf187616e282fe upstream.
Fixes: c9b37458e956 ("USB2NET : SR9700 : One chip USB 1.1 USB2NET SR9700Device Driver Support")
commit d4ca73591916b760478d2b04334d5dcadc028e9c upstream.
Fixes: 55d7de9de6c3 ("Microchip's LAN7800 family USB 2/3 to 10/100/1000 Ethernet device driver")
Cc: Woojung Huh <woojung.huh@microchip.com>
commit fd5bb66cd934987e49557455b6497fc006521940 upstream.
Change the zpool/compressor param callback function to release the
zswap_pools_lock spinlock before calling param_set_charp, since that
function may sleep when it calls kmalloc with GFP_KERNEL.
While this problem has existed for a while, I wasn't able to trigger it
using a tight loop changing either/both the zpool and compressor params; I
think it's very unlikely to be an issue on the stable kernels, especially
since most zswap users will change the compressor and/or zpool from sysfs
only one time each boot - or zero times, if they add the params to the
kernel boot.
Fixes: c99b42c3529e ("zswap: use charp for zswap param strings")
Link: http://lkml.kernel.org/r/20170126155821.4545-1-ddstreet@ieee.org
Signed-off-by: Dan Streetman <dan.streetman@canonical.com>
Reported-by: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Minchan Kim <minchan@kernel.org>
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
commit 4ee2ec1b122599f7b10c849fa7915cebb37b7edb upstream.
The new function mp_register_ioapic_irq() is a subset of the code in
mp_override_legacy_irq().
Replace the code duplication by invoking mp_register_ioapic_irq() from
Signed-off-by: Vikas C Sajjan <vikas.cha.sajjan@hpe.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: linux-pm@vger.kernel.org
Cc: kkamagui@gmail.com
Cc: linux-acpi@vger.kernel.org
Link: https://lkml.kernel.org/r/1510848825-21965-3-git-send-email-vikas.cha.sajjan@hpe.com
Cc: Jean Delvare <jdelvare@suse.de>
commit 898dfe4687f460ba337a01c11549f87269a13fa2 upstream.
The aloop driver tries to update the hw constraints of the connected
target on the cable of the opened PCM substream. This is done by
adding the extra hw constraints rules referring to the substream
runtime->hw fields, while the other substream may update the runtime
hw of another side on the fly.
This is, however, racy and may result in the inconsistent values when
both PCM streams perform the prepare concurrently. One of the reason
is that it overwrites the other's runtime->hw field; which is not only
racy but also broken when it's called before the open of another side
finishes. And, since the reference to runtime->hw isn't protected,
the concurrent write may give the partial value update and become
inconsistent.
This patch is an attempt to fix and clean up:
- The prepare doesn't change the runtime->hw of other side any longer,
but only update the cable->hw that is referred commonly.
- The extra rules refer to the loopback_pcm object instead of the
runtime->hw. The actual hw is deduced from cable->hw.
- The extra rules take the cable_lock to protect against the race.
Fixes: b1c73fc8e697 ("ALSA: snd-aloop: Fix hw_params restrictions and checking")
commit b088b53e20c7d09b5ab84c5688e609f478e5c417 upstream.
The extra hw constraint rule for the formats the aloop driver
introduced has a slight flaw, where it doesn't return a positive value
when the mask got changed. It came from the fact that it's basically
a copy&paste from snd_hw_constraint_mask64(). The original code is
supposed to be a single-shot and it modifies the mask bits only once
and never after, while what we need for aloop is the dynamic hw rule
that limits the mask bits.
This difference results in the inconsistent state, as the hw_refine
doesn't apply the dependencies fully. The worse and surprisingly
result is that it causes a crash in OSS emulation when multiple
full-duplex reads/writes are performed concurrently (I leave why it
triggers Oops to readers as a homework).
For fixing this, replace a few open-codes with the standard
snd_mask_*() macros.
Reported-by: syzbot+3902b5220e8ca27889ca@syzkaller.appspotmail.com
commit 9685347aa0a5c2869058ca6ab79fd8e93084a67f upstream.
The aloop runtime object and its assignment in the cable are left even
when opening a substream fails. This doesn't mean any memory leak,
but it still keeps the invalid pointer that may be referred by the
another side of the cable spontaneously, which is a potential Oops
cause.
Clean up the cable assignment and the empty cable upon the error path
properly.
Fixes: 597603d615d2 ("ALSA: introduce the snd-aloop module for the PCM loopback")
commit 900498a34a3ac9c611e9b425094c8106bdd7dc1c upstream.
PCM OSS read/write loops keep taking the mutex lock for the whole
read/write, and this might take very long when the exceptionally high
amount of data is given. Also, since it invokes with mutex_lock(),
the concurrent read/write becomes unbreakable.
This patch tries to address these issues by replacing mutex_lock()
with mutex_lock_interruptible(), and also splits / re-takes the lock
at each read/write period chunk, so that it can switch the context
more finely if requested.
commit 29159a4ed7044c52e3e2cf1a9fb55cec4745c60b upstream.
The loops for read and write in PCM OSS emulation have no proper check
of pending signals, and they keep processing even after user tries to
break. This results in a very long delay, often seen as RCU stall
when a huge unprocessed bytes remain queued. The bug could be easily
triggered by syzkaller.
As a simple workaround, this patch adds the proper check of pending
signals and aborts the loop appropriately.
Reported-by: syzbot+993cb4cfcbbff3947c21@syzkaller.appspotmail.com
commit 6708913750344a900f2e73bfe4a4d6dbbce4fe8d upstream.
In the OSS emulation plugin builder where the frame size is parsed in
the plugin chain, some places miss the possible errors returned from
the plugin src_ or dst_frames callback.
This patch papers over such places.
commit fe08f34d066f4404934a509b6806db1a4f700c86 upstream.
syzkaller triggered kernel warnings through PCM OSS emulation at
closing a stream:
WARNING: CPU: 0 PID: 3502 at sound/core/pcm_lib.c:1635
snd_pcm_hw_param_first+0x289/0x690 sound/core/pcm_lib.c:1635
Call Trace:
snd_pcm_hw_param_near.constprop.27+0x78d/0x9a0 sound/core/oss/pcm_oss.c:457
snd_pcm_oss_change_params+0x17d3/0x3720 sound/core/oss/pcm_oss.c:969
snd_pcm_oss_make_ready+0xaa/0x130 sound/core/oss/pcm_oss.c:1128
snd_pcm_oss_sync+0x257/0x830 sound/core/oss/pcm_oss.c:1638
snd_pcm_oss_release+0x20b/0x280 sound/core/oss/pcm_oss.c:2431
__fput+0x327/0x7e0 fs/file_table.c:210
This happens while it tries to open and set up the aloop device
concurrently. The warning above (invoked from snd_BUG_ON() macro) is
to detect the unexpected logical error where snd_pcm_hw_refine() call
shouldn't fail. The theory is true for the case where the hw_params
config rules are static. But for an aloop device, the hw_params rule
condition does vary dynamically depending on the connected target;
when another device is opened and changes the parameters, the device
connected in another side is also affected, and it caused the error
from snd_pcm_hw_refine().
That is, the simplest "solution" for this is to remove the incorrect
assumption of static rules, and treat such an error as a normal error
path. As there are a couple of other places using snd_BUG_ON()
incorrectly, this patch removes these spurious snd_BUG_ON() calls.
Reported-by: syzbot+6f11c7e2a1b91d466432@syzkaller.appspotmail.com
commit 252714155f04c5d16989cb3aadb85fd1b5772f99 upstream.
Platforms which support only IOAPIC mode, pass the SCI information above
the legacy space (0-15) via the FADT mechanism and not via MADT.
In such cases mp_override_legacy_irq() which is invoked from
acpi_sci_ioapic_setup() to register SCI interrupts fails for interrupts
greater equal 16, since it is meant to handle only the legacy space and
emits error "Invalid bus_irq %u for legacy override".
Add a new function to handle SCI interrupts >= 16 and invoke it
conditionally in acpi_sci_ioapic_setup().
The code duplication due to this new function will be cleaned up in a
separate patch.
Co-developed-by: Sunil V L <sunil.vl@hpe.com>
Signed-off-by: Sunil V L <sunil.vl@hpe.com>
Tested-by: Abdul Lateef Attar <abdul-lateef.attar@hpe.com>
Link: https://lkml.kernel.org/r/1510848825-21965-2-git-send-email-vikas.cha.sajjan@hpe.com
commit 98b8e4e5c17bf87c1b18ed929472051dab39878c upstream.
Calling acpi_wmi_init() at the subsys_initcall() level causes ordering
issues to appear on some systems and they are difficult to reproduce,
because there is no guaranteed ordering between subsys_initcall()
calls, so they may occur in different orders on different systems.
In particular, commit 86d9f48534e8 (mm/slab: fix kmemcg cache
creation delayed issue) exposed one of these issues where genl_init()
and acpi_wmi_init() are both called at the same initcall level, but
the former must run before the latter so as to avoid a NULL pointer
dereference.
For this reason, move the acpi_wmi_init() invocation to the
initcall_sync level which should still be early enough for things
to work correctly in the WMI land.
Link: https://marc.info/?t=151274596700002&r=1&w=2
Reported-by: Jonathan McDowell <noodles@earth.li>
Reported-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Tested-by: Jonathan McDowell <noodles@earth.li>
Signed-off-by: Darren Hart (VMware) <dvhart@infradead.org>
commit 0cb5b30698fdc8f6b4646012e3acb4ddce430788 upstream.
Guest GPR values are live in the hardware GPRs at VM-exit. Do not
leave any guest values in hardware GPRs after the guest GPR values are
saved to the vcpu_vmx structure.
This is a partial mitigation for CVE 2017-5715 and CVE 2017-5753.
Specifically, it defeats the Project Zero PoC for CVE 2017-5715.
Suggested-by: Eric Northup <digitaleric@google.com>
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Eric Northup <digitaleric@google.com>
Reviewed-by: Benjamin Serebrin <serebrin@google.com>
Reviewed-by: Andrew Honig <ahonig@google.com>
[Paolo: Add AMD bits, Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>]
commit c8c5a3a24d395b14447a9a89d61586a913840a3b upstream.
Complement commit c23b3d1a5311 ("MIPS: ptrace: Change GP regset to use
correct core dump register layout") and also reject outsized
PTRACE_SETREGSET requests to the NT_PRFPREG regset, like with the
NT_PRSTATUS regset.
Signed-off-by: Maciej W. Rozycki <macro@mips.com>
Fixes: c23b3d1a5311 ("MIPS: ptrace: Change GP regset to use correct core dump register layout")
Cc: James Hogan <james.hogan@mips.com>
Cc: Paul Burton <Paul.Burton@mips.com>
Cc: Alex Smith <alex@alex-smith.me.uk>
Cc: Dave Martin <Dave.Martin@arm.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/17930/
commit 006501e039eec411842bb3150c41358867d320c2 upstream.
Complement commit d614fd58a283 ("mips/ptrace: Preserve previous
registers for short regset write") and like with the PTRACE_GETREGSET
ptrace(2) request also apply a BUILD_BUG_ON check for the size of the
`elf_fpreg_t' type in the PTRACE_SETREGSET request handler.
Fixes: d614fd58a283 ("mips/ptrace: Preserve previous registers for short regset write")
Patchwork: https://patchwork.linux-mips.org/patch/17929/
commit be07a6a1188372b6d19a3307ec33211fc9c9439d upstream.
Fix a commit 72b22bbad1e7 ("MIPS: Don't assume 64-bit FP registers for
FP regset") public API regression, then activated by commit 1db1af84d6df
("MIPS: Basic MSA context switching support"), that caused the FCSR
register not to be read or written for CONFIG_CPU_HAS_MSA kernel
configurations (regardless of actual presence or absence of the MSA
feature in a given processor) with ptrace(2) PTRACE_GETREGSET and
PTRACE_SETREGSET requests nor recorded in core dumps.
This is because with !CONFIG_CPU_HAS_MSA configurations the whole of
`elf_fpregset_t' array is bulk-copied as it is, which includes the FCSR
in one half of the last, 33rd slot, whereas with CONFIG_CPU_HAS_MSA
configurations array elements are copied individually, and then only the
leading 32 FGR slots while the remaining slot is ignored.
Correct the code then such that only FGR slots are copied in the
respective !MSA and MSA helpers an then the FCSR slot is handled
separately in common code. Use `ptrace_setfcr31' to update the FCSR
too, so that the read-only mask is respected.
Retrieving a correct value of FCSR is important in debugging not only
for the human to be able to get the right interpretation of the
situation, but for correct operation of GDB as well. This is because
the condition code bits in FSCR are used by GDB to determine the
location to place a breakpoint at when single-stepping through an FPU
branch instruction. If such a breakpoint is placed incorrectly (i.e.
with the condition reversed), then it will be missed, likely causing the
debuggee to run away from the control of GDB and consequently breaking
the process of investigation.
Fortunately GDB continues using the older PTRACE_GETFPREGS ptrace(2)
request which is unaffected, so the regression only really hits with
post-mortem debug sessions using a core dump file, in which case
execution, and consequently single-stepping through branches is not
possible. Of course core files created by buggy kernels out there will
have the value of FCSR recorded clobbered, but such core files cannot be
corrected and the person using them simply will have to be aware that
the value of FCSR retrieved is not reliable.
Which also means we can likely get away without defining a replacement
API which would ensure a correct value of FSCR to be retrieved, or none
at all.
This is based on previous work by Alex Smith, extensively rewritten.
Signed-off-by: Alex Smith <alex@alex-smith.me.uk>
Signed-off-by: James Hogan <james.hogan@mips.com>
Fixes: 72b22bbad1e7 ("MIPS: Don't assume 64-bit FP registers for FP regset")
Patchwork: https://patchwork.linux-mips.org/patch/17928/
commit 80b3ffce0196ea50068885d085ff981e4b8396f4 upstream.
Update commit d614fd58a283 ("mips/ptrace: Preserve previous registers
for short regset write") bug and consistently consume all data supplied
to `fpr_set_msa' with the ptrace(2) PTRACE_SETREGSET request, such that
a zero data buffer counter is returned where insufficient data has been
given to fill a whole number of FP general registers.
In reality this is not going to happen, as the caller is supposed to
only supply data covering a whole number of registers and it is verified
in `ptrace_regset' and again asserted in `fpr_set', however structuring
code such that the presence of trailing partial FP general register data
causes `fpr_set_msa' to return with a non-zero data buffer counter makes
it appear that this trailing data will be used if there are subsequent
writes made to FP registers, which is going to be the case with the FCSR
once the missing write to that register has been fixed.
Patchwork: https://patchwork.linux-mips.org/patch/17927/
commit dc24d0edf33c3e15099688b6bbdf7bdc24bf6e91 upstream.
registers for short regset write") and ensure that no partial register
write attempt is made with PTRACE_SETREGSET, as we do not preinitialize
any temporaries used to hold incoming register data and consequently
random data could be written.
It is the responsibility of the caller, such as `ptrace_regset', to
arrange for writes to span whole registers only, so here we only assert
that it has indeed happened.
Patchwork: https://patchwork.linux-mips.org/patch/17926/
commit a03fe72572c12e98f4173f8a535f32468e48b6ec upstream.
In preparation to fix a commit 72b22bbad1e7 ("MIPS: Don't assume 64-bit
FP registers for FP regset") FCSR access regression factor out
NT_PRFPREG regset access helpers for the non-MSA and the MSA variants
respectively, to avoid having to deal with excessive indentation in the
actual fix.
No functional change, however use `target->thread.fpu.fpr[0]' rather
than `target->thread.fpu.fpr[i]' for FGR holding type size determination
as there's no `i' variable to refer to anymore, and for the factored out
`i' variable declaration use `unsigned int' rather than `unsigned' as
its type, following the common style.
Patchwork: https://patchwork.linux-mips.org/patch/17925/
commit b67336eee3fcb8ecedc6c13e2bf88aacfa3151e2 upstream.
Fix an API loophole introduced with commit 9791554b45a2 ("MIPS,prctl:
add PR_[GS]ET_FP_MODE prctl options for MIPS"), where the caller of
prctl(2) is incorrectly allowed to make a change to CP0.Status.FR or
CP0.Config5.FRE register bits even if CONFIG_MIPS_O32_FP64_SUPPORT has
not been enabled, despite that an executable requesting the mode
requested via ELF file annotation would not be allowed to run in the
first place, or for n64 and n64 ABI tasks which do not have non-default
modes defined at all. Add suitable checks to `mips_set_process_fp_mode'
and bail out if an invalid mode change has been requested for the ABI in
effect, even if the FPU hardware or emulation would otherwise allow it.
Always succeed however without taking any further action if the mode
requested is the same as one already in effect, regardless of whether
any mode change, should it be requested, would actually be allowed for
the task concerned.
Fixes: 9791554b45a2 ("MIPS,prctl: add PR_[GS]ET_FP_MODE prctl options for MIPS")
Reviewed-by: Paul Burton <paul.burton@mips.com>
Patchwork: https://patchwork.linux-mips.org/patch/17800/
commit bec40c26041de61162f7be9d2ce548c756ce0f65 upstream.
With the SRP protocol all RDMA operations are initiated by the target.
Since no RDMA operations are initiated by the initiator, do not grant
the initiator permission to submit RDMA reads or writes to the target.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
commit d5b42e6607661b198d8b26a0c30969605b1bf5c7 upstream.
The "set_bittiming" callback treats a positive return value as error!
For that reason "can_changelink()" will quit silently after setting
the bittiming values without processing ctrlmode, restart-ms, etc.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit e39d200fa5bf5b94a0948db0dae44c1b73b84a56 upstream.
Reported by syzkaller:
BUG: KASAN: stack-out-of-bounds in write_mmio+0x11e/0x270 [kvm]
Read of size 8 at addr ffff8803259df7f8 by task syz-executor/32298
CPU: 6 PID: 32298 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #18
Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016
Call Trace:
dump_stack+0xab/0xe1
print_address_description+0x6b/0x290
kasan_report+0x28a/0x370
emulator_read_write_onepage+0x311/0x600 [kvm]
emulator_read_write+0xef/0x240 [kvm]
emulator_fix_hypercall+0x105/0x150 [kvm]
em_hypercall+0x2b/0x80 [kvm]
x86_emulate_insn+0x2b1/0x1640 [kvm]
x86_emulate_instruction+0x39a/0xb90 [kvm]
handle_exception+0x1b4/0x4d0 [kvm_intel]
vcpu_enter_guest+0x15a0/0x2640 [kvm]
kvm_arch_vcpu_ioctl_run+0x549/0x7d0 [kvm]
kvm_vcpu_ioctl+0x479/0x880 [kvm]
do_vfs_ioctl+0x142/0x9a0
SyS_ioctl+0x74/0x80
entry_SYSCALL_64_fastpath+0x23/0x9a
The path of patched vmmcall will patch 3 bytes opcode 0F 01 C1(vmcall)
to the guest memory, however, write_mmio tracepoint always prints 8 bytes
through *(u64 *)val since kvm splits the mmio access into 8 bytes. This
leaks 5 bytes from the kernel stack (CVE-2017-17741). This patch fixes
it by just accessing the bytes which we operate on.
Before patch:
syz-executor-5567 [007] .... 51370.561696: kvm_mmio: mmio write len 3 gpa 0x10 val 0x1ffff10077c1010f
After patch:
syz-executor-13416 [002] .... 51302.299573: kvm_mmio: mmio write len 3 gpa 0x10 val 0xc1010f
Reviewed-by: Darren Kenny <darren.kenny@oracle.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit 7eccb738fce57cbe53ed903ccf43f9ab257b15b3 upstream.
Rx data frames notified through HTT_T2H_MSG_TYPE_RX_IND and
HTT_T2H_MSG_TYPE_RX_FRAG_IND expect PN/TSC check to be done
on host (mac80211) rather than firmware. Rebuild cipher header
in every received data frames (that are notified through those
HTT interfaces) from the rx_hdr_status tlv available in the
rx descriptor of the first msdu. Skip setting RX_FLAG_IV_STRIPPED
flag for the packets which requires mac80211 PN/TSC check support
and set appropriate RX_FLAG for stripped crypto tail. Hw QCA988X,
QCA9887, QCA99X0, QCA9984, QCA9888 and QCA4019 currently need the
rebuilding of cipher header to perform PN/TSC check for replay
attack.
Please note that removing crypto tail for CCMP-256, GCMP and GCMP-256 ciphers
in raw mode needs to be fixed. Since Rx with these ciphers in raw
mode does not work in the current form even without this patch and
removing crypto tail for these chipers needs clean up, raw mode related
issues in CCMP-256, GCMP and GCMP-256 can be addressed in follow up
patches.
Tested-by: Manikanta Pubbisetty <mpubbise@qti.qualcomm.com>
Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qti.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
commit cef0acd4d7d4811d2d19cd0195031bf0dfe41249 upstream.
Add a flag that indicates that the WEP ICV was stripped from an
RX packet, allowing the device to not transfer that if it's
already checked.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
commit fbc7c07ec23c040179384a1f16b62b6030eb6bdd upstream.
When system is under memory pressure it is observed that dm bufio
shrinker often reclaims only one buffer per scan. This change fixes
the following two issues in dm bufio shrinker that cause this behavior:
1. ((nr_to_scan - freed) <= retain_target) condition is used to
terminate slab scan process. This assumes that nr_to_scan is equal
to the LRU size, which might not be correct because do_shrink_slab()
in vmscan.c calculates nr_to_scan using multiple inputs.
As a result when nr_to_scan is less than retain_target (64) the scan
will terminate after the first iteration, effectively reclaiming one
buffer per scan and making scans very inefficient. This hurts vmscan
performance especially because mutex is acquired/released every time
dm_bufio_shrink_scan() is called.
New implementation uses ((LRU size - freed) <= retain_target)
condition for scan termination. LRU size can be safely determined
inside __scan() because this function is called after dm_bufio_lock().
2. do_shrink_slab() uses value returned by dm_bufio_shrink_count() to
determine number of freeable objects in the slab. However dm_bufio
always retains retain_target buffers in its LRU and will terminate
a scan when this mark is reached. Therefore returning the entire LRU size
from dm_bufio_shrink_count() is misleading because that does not
represent the number of freeable objects that slab will reclaim during
a scan. Returning (LRU size - retain_target) better represents the
number of freeable objects in the slab. This way do_shrink_slab()
returns 0 when (LRU size < retain_target) and vmscan will not try to
scan this shrinker avoiding scans that will not reclaim any memory.
Test: tested using Android device running
<AOSP>/system/extras/alloc-stress that generates memory pressure
and causes intensive shrinker scans
Signed-off-by: Suren Baghdasaryan <surenb@google.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit fee4380f368e84ed216b62ccd2fbc4126f2bf40b upstream.
In the current driver, OOB bytes are accessed in raw mode, and when a
page access is done with NDCR_SPARE_EN set and NDCR_ECC_EN cleared, the
driver must read the whole spare area (64 bytes in case of a 2k page,
16 bytes for a 512 page). The driver was only reading the free OOB
bytes, which was leaving some unread data in the FIFO and was somehow
leading to a timeout.
We could patch the driver to read ->spare_size + ->ecc_size instead of
just ->spare_size when READOOB is requested, but we'd better make
in-band and OOB accesses consistent.
Since the driver is always accessing in-band data in non-raw mode (with
the ECC engine enabled), we should also access OOB data in this mode.
That's particularly useful when using the BCH engine because in this
mode the free OOB bytes are also ECC protected.
Fixes: 43bcfd2bb24a ("mtd: nand: pxa3xx: Add driver-specific ECC BCH support")
Reported-by: Sean Nyekjær <sean.nyekjaer@prevas.dk>
Tested-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Tested-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Richard Weinberger <richard@nod.at>
This needs to happen early in kaiser_pagetable_walk(), before the
hierarchy is established so that _PAGE_USER permission can be really
set.
A proper fix would be to teach kaiser_pagetable_walk() to update those
permissions but the vsyscall page is the only exception here so ...
commit 1e5476815fd7f98b888e01a0f9522b63085f96c9 upstream.
The recent changes for PTI touch cpu_tlbstate from various tlb_flush
inlines. cpu_tlbstate is exported as GPL symbol, so this causes a
regression when building out of tree drivers for certain graphics cards.
Aside of that the export was wrong since it was introduced as it should
have been EXPORT_PER_CPU_SYMBOL_GPL().
Use the correct PER_CPU export and drop the _GPL to restore the previous
state which allows users to utilize the cards they payed for.
As always I'm really thrilled to make this kind of change to support the
#friends (or however the hot hashtag of today is spelled) from that closet
sauce graphics corp.
Fixes: 1e02ce4cccdc ("x86: Store a per-cpu shadow copy of CR4")
Fixes: 6fd166aae78c ("x86/mm: Use/Fix PCID to optimize user/kernel switches")
Reported-by: Kees Cook <keescook@google.com>
Cc: Thomas Backlund <tmb@mageia.org>
commit 310d82784fb4d60c80569f5ca9f53a7f3bf1d477 upstream.
Add qemu idle sleep support when running under qemu with SeaBIOS PDC
firmware.
Like the power architecture we use the "or" assembler instructions,
which translate to nops on real hardware, to indicate that qemu shall
idle sleep.
Signed-off-by: Helge Deller <deller@gmx.de>
Cc: Richard Henderson <rth@twiddle.net>
commit 88776c0e70be0290f8357019d844aae15edaa967 upstream.
Qemu for PARISC reported on a 32bit SMP parisc kernel strange failures
about "Not-handled unaligned insn 0x0e8011d6 and 0x0c2011c9."
Those opcodes evaluate to the ldcw() assembly instruction which requires
(on 32bit) an alignment of 16 bytes to ensure atomicity.
As it turns out, qemu is correct and in our assembly code in entry.S and
pacache.S we don't pay attention to the required alignment.
This patch fixes the problem by aligning the lock offset in assembly
code in the same manner as we do in our C-code.
commit f4e9b7af0cd58dd039a0fb2cd67d57cea4889abf upstream.
The size for the Microcode Patch Block (MPB) for an AMD family 17h
processor is 3200 bytes. Add a #define for fam17h so that it does
not default to 2048 bytes and fail a microcode load/update.
Reviewed-by: Borislav Petkov <bp@alien8.de>
Link: https://lkml.kernel.org/r/20171130224640.15391.40247.stgit@tlendack-t1.amdoffice.net
Cc: Alice Ferrazzi <alicef@gentoo.org>
commit 10d900303f1c3a821eb0bef4e7b7ece16768fba4 upstream.
The touchpad of Lenovo Thinkpad L480 reports it's version as 15.
Signed-off-by: Aaron Ma <aaron.ma@canonical.com>
commit 79435ac78d160e4c245544d457850a56f805ac0d upstream.
This used to setup the LP_COUNT register automatically, but now has been
removed.
There was an earlier fix 3c7c7a2fc8811 which fixed instance in delay.h but
somehow missed this one as gcc change had not made its way into
production toolchains and was not pedantic as it is now !
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 563b5cbe334e9503ab2b234e279d500fc4f76018 upstream.
For PCI devices behind an aliasing PCIe-to-PCI/X bridge, the bridge
alias to DevFn 0.0 on the subordinate bus may match the original RID of
the device, resulting in the same SID being present in the device's
fwspec twice. This causes trouble later in arm_smmu_write_strtab_ent()
when we wind up visiting the STE a second time and find it already live.
Avoid the issue by giving arm_smmu_install_ste_for_dev() the cleverness
to skip over duplicates. It seems mildly counterintuitive compared to
preventing the duplicates from existing in the first place, but since
the DT and ACPI probe paths build their fwspecs differently, this is
actually the cleanest and most self-contained way to deal with it.
Fixes: 8f78515425da ("iommu/arm-smmu: Implement of_xlate() for SMMUv3")
Reported-by: Tomasz Nowicki <tomasz.nowicki@caviumnetworks.com>
Tested-by: Tomasz Nowicki <Tomasz.Nowicki@cavium.com>
Tested-by: Jayachandran C. <jnair@caviumnetworks.com>
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
commit 57d72e159b60456c8bb281736c02ddd3164037aa upstream.
Kasan reports a double free when finalise_stage_fn fails: the io_pgtable
ops are freed by arm_smmu_domain_finalise and then again by
arm_smmu_domain_free. Prevent this by leaving pgtbl_ops empty on failure.
Fixes: 48ec83bcbcf5 ("iommu/arm-smmu: Add initial driver support for ARM SMMUv3 devices")
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
complete_signal()
commit 426915796ccaf9c2bd9bb06dc5702225957bc2e5 upstream.
complete_signal() checks SIGNAL_UNKILLABLE before it starts to destroy
the thread group, today this is wrong in many ways.
If nothing else, fatal_signal_pending() should always imply that the
whole thread group (except ->group_exit_task if it is not NULL) is
killed, this check breaks the rule.
After the previous changes we can rely on sig_task_ignored();
sig_fatal(sig) && SIGNAL_UNKILLABLE can only be true if we actually want
to kill this task and sig == SIGKILL OR it is traced and debugger can
intercept the signal.
This should hopefully fix the problem reported by Dmitry. This
test-case
static int init(void *arg)
for (;;)
pause();
int main(void)
char stack[16 * 1024];
for (;;) {
int pid = clone(init, stack + sizeof(stack)/2,
CLONE_NEWPID | SIGCHLD, NULL);
assert(pid > 0);
assert(ptrace(PTRACE_ATTACH, pid, 0, 0) == 0);
assert(waitpid(-1, NULL, WSTOPPED) == pid);
assert(ptrace(PTRACE_DETACH, pid, 0, SIGSTOP) == 0);
assert(syscall(__NR_tkill, pid, SIGKILL) == 0);
assert(pid == wait(NULL));
triggers the WARN_ON_ONCE(!(task->jobctl & JOBCTL_STOP_PENDING)) in
task_participate_group_stop(). do_signal_stop()->signal_group_exit()
checks SIGNAL_GROUP_EXIT and return false, but task_set_jobctl_pending()
checks fatal_signal_pending() and does not set JOBCTL_STOP_PENDING.
And his should fix the minor security problem reported by Kyle,
SECCOMP_RET_TRACE can miss fatal_signal_pending() the same way if the
task is the root of a pid namespace.
Link: http://lkml.kernel.org/r/20171103184246.GD21036@redhat.com
Reported-by: Kyle Huey <me@kylehuey.com>
Tested-by: Kyle Huey <me@kylehuey.com>
signals
commit ac25385089f673560867eb5179228a44ade0cfc1 upstream.
Change sig_task_ignored() to drop the SIG_DFL && !sig_kernel_only()
signals even if force == T. This simplifies the next change and this
matches the same check in get_signal() which will drop these signals
anyway.
Link: http://lkml.kernel.org/r/20171103184227.GC21036@redhat.com
commit 628c1bcba204052d19b686b5bac149a644cdb72e upstream.
The comment in sig_ignored() says "Tracers may want to know about even
ignored signals" but SIGKILL can not be reported to debugger and it is
just wrong to return 0 in this case: SIGKILL should only kill the
SIGNAL_UNKILLABLE task if it comes from the parent ns.
Change sig_ignored() to ignore ->ptrace if sig == SIGKILL and rely on
sig_task_ignored().
SISGTOP coming from within the namespace is not really right too but at
least debugger can intercept it, and we can't drop it here because this
will break "gdb -p 1": ptrace_attach() won't work. Perhaps we will add
another ->ptrace check later, we will see.
Link: http://lkml.kernel.org/r/20171103184206.GB21036@redhat.com
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
commit 429a787be6793554ee02aacc7e1f11ebcecc4453 upstream.
For writes, we can get a completion in while we're still iterating
the request and bio chain. If that happens, we're reading freed
memory and we can crash.
Break out after the last segment and avoid having the iterator
read freed memory.
Reviewed-by: Josef Bacik <jbacik@fb.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 98801506552593c9b8ac11021b0cdad12cab4f6b upstream.
Fix the default for fscache_maybe_release_page() for when the cookie isn't
valid or the page isn't cached. It mustn't return false as that indicates
the page cannot yet be freed.
The problem with the default is that if, say, there's no cache, but a
network filesystem's pages are using up almost all the available memory, a
system can OOM because the filesystem ->releasepage() op will not allow
them to be released as fscache_maybe_release_page() incorrectly prevents
it.
This can be tested by writing a sequence of 512MiB files to an AFS mount.
It does not affect NFS or CIFS because both of those wrap the call in a
check of PG_fscache and it shouldn't bother Ceph as that only has
PG_private set whilst writeback is in progress. This might be an issue for
9P, however.
Note that the pages aren't entirely stuck. Removing a file or unmounting
will clear things because that uses ->invalidatepage() instead.
Fixes: 201a15428bd5 ("FS-Cache: Handle pages pending storage that get evicted under OOM conditions")
Reported-by: Marc Dionne <marc.dionne@auristor.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Marc Dionne <marc.dionne@auristor.com>
