Change-Id: I0a81f4ea94d41245cd5150de341b51fc70babffe
Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
doc: Update contribution guidelines
Update the documentation for trustedfirmware.org migration
Change-Id: Ibb7052b0becbec3326164f1503806ca2c2fd4dcc
Signed-off-by: Louis Mayencourt <louis.mayencourt@arm.com>
Also adds a maintainer for GXL.
Signed-off-by: Remi Pommarel <repk@triplefau.lt>
These SPM-related specifications are mentioned in the readme and
the change log. Update references to these specs to make it clear
that they are in draft form and are expected to change.
Change-Id: Ia2791c48c371a828246d96f102a402747cd69f96
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
Update both the readme and user guide on their shared "platform"
section.
Change-Id: Ia1f30acda45ac8facdcb7d540800191cdf6cdacf
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Change-Id: Id3ae11a401a2e5290bb1980f1f349fc3cf49c7d6
The security advisories would all appear on a single line. Use bullet
points instead to improve the readability.
Change-Id: Id631985d7d559b3632f43d695cffa6735520b64a
Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Change-Id: I53a4649b17614f711957424ddffed1dcccfc7880
This patch covers two changes:
- Links that refer to GitHub are updated to point to the
relevant content on trustedfirmware.org
- Internal links between documents have been updated,
with the required .rst suffix being added or due
to a change in the relative locations of the files.
Change-Id: Ibf87da7d2ece726d1c94a9b33a2bbc3129de7779
Signed-off-by: Joel Hutton <Joel.Hutton@Arm.com>
Replace all usage of 'sgiclark' with 'rdn1e1edge' and 'sgiclarkh' with
'rde1edge' as per the updated product names.
Change-Id: I14e9b0332851798531de21d70eb54f1e5557a7bd
Signed-off-by: Chandni Cherukuri <chandni.cherukuri@arm.com>
Replace all usage of 'sgiclark' with 'rdn1e1edge' and 'sgiclarka' with
'rdn1edge' as per the updated product names.
Change-Id: Idbc157c73477ec32f507ba2d4a4e907d8813374c
Change-Id: Ideb49011da35f39ff1959be6f5015fa212ca2b6b
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
Change-Id: I13b7b16a13f51bcb83098d7c55701f9ee03859a8
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Improves wording and sentence structure of the readme, including:
- Using "TF-A" in place of "the TF-A" in a couple of places
- "Support for X" in place of "Support X"
- Explicitly naming the Secure Payload Dispatcher when introducing the
SPD acronym.
Change-Id: I4e7b7e7dc6748f631d07c02d97adcca10ae60ea4
Change-Id: I7e0ba692277c1c120c86d47ab966dcd11682428a
Currently the examples of Arm interface standards all include
abbreviationsof the full names, except for SCMI.
Change-Id: I8417ada780d51ecf93426aa5d265c507c7dac08c
Change-Id: Ie2465c1ccc482bd8eb5e5a71c580543095e4ba94
Change-Id: Iaa5c586b65f0abdd4ddbdee4c73d07811a0aff49
Signed-off-by: Joanna Farley <joanna.farley@arm.com>
Change-Id: I7855c9d3de104975bf3249bdf291c428f001d07a
Taken from http://git.simple-cc.org/scc/ from the following commit:
67508ad14af314cea2229783d3c084f28c41daf0
Permission has been granted from the author to use them under the
license BSD-3-Clause instead of ISC.
Change-Id: I65c0ce3ab60c49d34a57533af12a74bd7bde88e5
readme: Add information about the TF-A IRC channel
Added information on how disjunctively dual licensed code from
other projects is treated in the TF-A project.
Change-Id: Idca329abba4d36bd3c4fd722ac1556940b9135a2
Signed-off-by: Dan Handley <dan.handley@arm.com>
Fixes ARM-software/tf-issues#607
Change-Id: I5637f53e7f4857c85ee8b3af06ebcf86b9e4f1bc
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
Add Makefile and plaform definations file.
My thanks to Daniel Thompson and Ard Biesheuvel for the bits and pieces
I've taken from their earlier work regarding build and deploy steps for
Developerbox based on Synquacer SoCs. They deserve much of the credit
for this work although, since I assembled and tested things, any blame
is probably mine.
Signed-off-by: Sumit Garg <sumit.garg@linaro.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Create the baseline Makefile, platform definitions file and platform
specific assembly macros file. This includes first set of constants
for the platform including cache sizes and linker format and a stub for
BL31 and the basic memory layout
K3 SoC family of processors do not use require a BL1 or BL2 binary,
since such functions are provided by an system controller on the SoC.
This lowers the burden of ATF to purely managing the local ARM cores
themselves.
Signed-off-by: Benjamin Fair <b-fair@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Andrew F. Davis <afd@ti.com>
Change-Id: Id9bd0c20a5af4f41269a51a675018dcc59e93f6c
Update Arm Trusted Firmware references in the upstream documents to
Trusted Firmware-A (TF-A). This is for consistency with and
disambiguation from Trusted Firmware-M (TF-M).
Also update other Arm trademarks, e.g. ARM->Arm, ARMv8->Armv8-A.
Change-Id: I8bb0e18af29c6744eeea2dc6c08f2c10b20ede22
Signed-off-by: David Cunado <david.cunado@arm.com>
Clarify the license information for imported third party code in
the readme.rst file.
Change-Id: I96e26fda687a290a6dffb475aca20b169d85784d
Update the release notes (readme.rst) for the ARM Trusted Firmware v1.4 release.
Also, reorder and fix some of the links following the conversion to
reStructured text format.
Change-Id: I8f5e8aa86cb891f61b6b62cf9fab0ad0f0ebb36b
Due to recent issues in the rendering of the documentation on GitHub and
some long-standing issues like the lack of automatic table of content in
Markdown, the documentation has been converted to reStructuredText.
Basic constructs looks pretty similar to Markdown.
Automatically convert GitHub markdown documentation to reStructuredText
using pandoc.
Change-Id: If20b695acedc6d1b49c8d9fb64efd6b6ba23f4a9
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
