Previously, Juno used to depend on the SSC_GPRETN register to inform
about the reset syndrome. This method was removed when SCP migrated
to the SDS framework. But even the SDS framework doesn't report the
reset syndrome correctly and hence Juno failed to enter Firmware
update mode if BL2 authentication failed.
In addition to that, the error code populated in V2M_SYS_NVFLAGS register
does not seem to be retained any more on Juno across resets. This could
be down to the motherboard firmware not doing the necessary to preserve
the value.
Hence this patch modifies the Juno platform to use the same mechanism to
trigger firmware update as FVP which is to corrupt the FIP TOC on
authentication failure. The implementation in `fvp_err.c` is made common
for ARM platforms and is moved to the new `arm_err.c` file in
plat/arm/common folder. The BL1 and BL2 mmap table entries for Juno
are modified to allow write to the Flash memory address.
Change-Id: Ica7d49a3e8a46a90efd4cf340f19fda3b549e945
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Rule 8.4: A compatible declaration shall be visible when
an object or function with external linkage is defined
Fixed for:
make DEBUG=1 PLAT=juno LOG_LEVEL=50 all
Change-Id: Ic8f611da734f356566e8208053296e6c62b54709
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
This patch adds a WFI instruction in the default implementations of
plat_error_handler() and plat_panic_handler(). This potentially reduces
power consumption by allowing the hardware to enter a low-power state.
The same change has been made to the FVP and Juno platform ports.
Change-Id: Ia4e6e1e5bf1ed42efbba7d0ebbad7be8d5f9f173
This patch adds watchdog support on ARM platforms (FVP and Juno).
A secure instance of SP805 is used as Trusted Watchdog. It is
entirely managed in BL1, being enabled in the early platform setup
hook and disabled in the exit hook. By default, the watchdog is
enabled in every build (even when TBB is disabled).
A new ARM platform specific build option `ARM_DISABLE_TRUSTED_WDOG`
has been introduced to allow the user to disable the watchdog at
build time. This feature may be used for testing or debugging
purposes.
Specific error handlers for Juno and FVP are also provided in this
patch. These handlers will be called after an image load or
authentication error. On FVP, the Table of Contents (ToC) in the FIP
is erased. On Juno, the corresponding error code is stored in the
V2M Non-Volatile flags register. In both cases, the CPU spins until
a watchdog reset is generated after 256 seconds (as specified in
the TBBR document).
Change-Id: I9ca11dcb0fe15af5dbc5407ab3cf05add962f4b4
