For platforms that have not migrated to MULTI_CONSOLE_API == 1, there
are a lot of confusing deprecated declaration warnings relating to
use of console_init() and console_uninit(). Some of these relate to use
by the generic code, not the platform code. These functions are not really
deprecated but *removed* when MULTI_CONSOLE_API == 1.
This patch consolidates these warnings into a single preprocessor warning.
The __deprecated attribute is removed from the console_init() and
console_uninit() declarations.
For preprocessor warnings like this to not cause fatal build errors,
this patch adds -Wno-error=cpp to the build flags when
ERROR_DEPRECATED == 0.
This option (and -Wno-error=deprecated-declarations) is now added to
CPPFLAGS instead of TF_CFLAGS to ensure the build flags are used in the
assembler as well as the compiler.
This patch also disentangles the MULTI_CONSOLE_API and ERROR_DEPRECATED
build flags by defaulting MULTI_CONSOLE_API to 0 instead of
ERROR_DEPRECATED. This allows platforms that have not migrated to
MULTI_CONSOLE_API to use ERROR_DEPRECATED == 1 to emit a more meaningful
build error.
Finally, this patch bans use of MULTI_CONSOLE_API == 1 and AARCH32, since
the AArch32 console implementation does not support
Change-Id: If762165ddcb90c28aa7a4951aba70cb15c2b709c
Signed-off-by: Dan Handley <dan.handley@arm.com>
New console API and coreboot support [v4]
This patch adds the foundation for a platform-independent coreboot
support library that can be shared by all platforms that boot BL31 from
coreboot (acting as BL2). It adds code to parse the "coreboot table", a
data structure that coreboot uses to communicate different kinds of
information to later-stage firmware and certain OS drivers.
As a first small use case for this information, allow platforms to
access the serial console configuration used by coreboot, removing the
need to hardcode base address and divisors and allowing Trusted Firmware
to benefit from coreboot's user configuration (e.g. which UART to pick
and which baud rate to use).
Change-Id: I2bfb39cd2609ce6640b844ab68df6c9ae3f28e9e
Signed-off-by: Julius Werner <jwerner@chromium.org>
This patch enables BL2 to execute at the highest exception level
without any dependancy on TF BL1. This enables platforms which already
have a non-TF Boot ROM to directly load and execute BL2 and subsequent BL
stages without need for BL1. This is not currently possible because
BL2 executes at S-EL1 and cannot jump straight to EL3.
Change-Id: Ief1efca4598560b1b8c8e61fbe26d1f44e929d69
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
This patch overhauls the console API to allow for multiple console
instances of different drivers that are active at the same time. Instead
of binding to well-known function names (like console_core_init),
consoles now provide a register function (e.g. console_16550_register())
that will hook them into the list of active consoles. All console
operations will be dispatched to all consoles currently in the list.
The new API will be selected by the build-time option MULTI_CONSOLE_API,
which defaults to ${ERROR_DEPRECATED} for now. The old console API code
will be retained to stay backwards-compatible to older platforms, but
should no longer be used for any newly added platforms and can hopefully
be removed at some point in the future.
The new console API is intended to be used for both normal (bootup) and
crash use cases, freeing platforms of the need to set up the crash
console separately. Consoles can be individually configured to be active
active at boot (until first handoff to EL2), at runtime (after first
handoff to EL2), and/or after a crash. Console drivers should set a sane
default upon registration that can be overridden with the
console_set_scope() call. Code to hook up the crash reporting mechanism
to this framework will be added with a later patch.
This patch only affects AArch64, but the new API could easily be ported
to AArch32 as well if desired.
Change-Id: I35c5aa2cb3f719cfddd15565eb13c7cde4162549
Enable SVE for Non-secure world
Replace macro ASM_ASSERTION with macro ENABLE_ASSERTIONS
This patch adds a new build option, ENABLE_SVE_FOR_NS, which when set
to one EL3 will check to see if the Scalable Vector Extension (SVE) is
implemented when entering and exiting the Non-secure world.
If SVE is implemented, EL3 will do the following:
- Entry to Non-secure world: SIMD, FP and SVE functionality is enabled.
- Exit from Non-secure world: SIMD, FP and SVE functionality is
disabled. As SIMD and FP registers are part of the SVE Z-registers
then any use of SIMD / FP functionality would corrupt the SVE
registers.
The build option default is 1. The SVE functionality is only supported
on AArch64 and so the build option is set to zero when the target
archiecture is AArch32.
This build option is not compatible with the CTX_INCLUDE_FPREGS - an
assert will be raised on platforms where SVE is implemented and both
ENABLE_SVE_FOR_NS and CTX_INCLUDE_FPREGS are set to 1.
Also note this change prevents secure world use of FP&SIMD registers on
SVE-enabled platforms. Existing Secure-EL1 Payloads will not work on
such platforms unless ENABLE_SVE_FOR_NS is set to 0.
Additionally, on the first entry into the Non-secure world the SVE
functionality is enabled and the SVE Z-register length is set to the
maximum size allowed by the architecture. This includes the use case
where EL2 is implemented but not used.
Change-Id: Ie2d733ddaba0b9bef1d7c9765503155188fe7dae
Signed-off-by: David Cunado <david.cunado@arm.com>
The Cortex A75 has 5 AMU counters. The first three counters are fixed
and the remaining two are programmable.
A new build option is introduced, `ENABLE_AMU`. When set, the fixed
counters will be enabled for use by lower ELs. The programmable
counters are currently disabled.
Change-Id: I4bd5208799bb9ed7d2596e8b0bfc87abbbe18740
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
This patch replaces the macro ASM_ASSERTION with the macro
ENABLE_ASSERTIONS in ARM Cortex-A53/57/72 MPCore Processor
related files. There is build error when ASM_ASSERTION is set
to 1 and ENABLE_ASSERTIONS is set to 0 because function
asm_assert in common/aarch32/debug.S is defined in the macro
ENABLE_ASSERTIONS but is called with the macro ASM_ASSERTION.
There is also the indication to use ENABLE_ASSERTIONS but not
ASM_ASSERTION in the Makefile.
Signed-off-by: Matt Ma <matt.ma@spreadtrum.com>
It is not possible to detect at compile-time whether support for an
optional extension such as SPE should be enabled based on the
ARM_ARCH_MINOR build option value. Therefore SPE is now enabled by
default.
Change-Id: I670db164366aa78a7095de70a0962f7c0328ab7c
The implementation currently supports only interrupt-based SDEI events,
and supports all interfaces as defined by SDEI specification version
1.0 [1].
Introduce the build option SDEI_SUPPORT to include SDEI dispatcher in
BL31.
Update user guide and porting guide. SDEI documentation to follow.
[1] http://infocenter.arm.com/help/topic/com.arm.doc.den0054a/ARM_DEN0054A_Software_Delegated_Exception_Interface.pdf
Change-Id: I758b733084e4ea3b27ac77d0259705565842241a
Co-authored-by: Yousuf A <yousuf.sait@arm.com>
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
EHF is a framework that allows dispatching of EL3 interrupts to their
respective handlers in EL3.
This framework facilitates the firmware-first error handling policy in
which asynchronous exceptions may be routed to EL3. Such exceptions may
be handed over to respective exception handlers. Individual handlers
might further delegate exception handling to lower ELs.
The framework associates the delegated execution to lower ELs with a
priority value. For interrupts, this corresponds to the priorities
programmed in GIC; for other types of exceptions, viz. SErrors or
Synchronous External Aborts, individual dispatchers shall explicitly
associate delegation to a secure priority. In order to prevent lower
priority interrupts from preempting higher priority execution, the
framework provides helpers to control preemption by virtue of
programming Priority Mask register in the interrupt controller.
This commit allows for handling interrupts targeted at EL3. Exception
handlers own interrupts by assigning them a range of secure priorities,
and registering handlers for each priority range it owns.
Support for exception handling in BL31 image is enabled by setting the
build option EL3_EXCEPTION_HANDLING=1.
Documentation to follow.
NOTE: The framework assumes the priority scheme supported by platform
interrupt controller is compliant with that of ARM GIC architecture (v2
or later).
Change-Id: I7224337e4cea47c6ca7d7a4ca22a3716939f7e42
A Secure Partition is a software execution environment instantiated in
S-EL0 that can be used to implement simple management and security
services. Since S-EL0 is an unprivileged exception level, a Secure
Partition relies on privileged firmware e.g. ARM Trusted Firmware to be
granted access to system and processor resources. Essentially, it is a
software sandbox that runs under the control of privileged software in
the Secure World and accesses the following system resources:
- Memory and device regions in the system address map.
- PE system registers.
- A range of asynchronous exceptions e.g. interrupts.
- A range of synchronous exceptions e.g. SMC function identifiers.
A Secure Partition enables privileged firmware to implement only the
absolutely essential secure services in EL3 and instantiate the rest in
a partition. Since the partition executes in S-EL0, its implementation
cannot be overly complex.
The component in ARM Trusted Firmware responsible for managing a Secure
Partition is called the Secure Partition Manager (SPM). The SPM is
responsible for the following:
- Validating and allocating resources requested by a Secure Partition.
- Implementing a well defined interface that is used for initialising a
Secure Partition.
- Implementing a well defined interface that is used by the normal world
and other secure services for accessing the services exported by a
Secure Partition.
- Implementing a well defined interface that is used by a Secure
Partition to fulfil service requests.
- Instantiating the software execution environment required by a Secure
Partition to fulfil a service request.
Change-Id: I6f7862d6bba8732db5b73f54e789d717a35e802f
Co-authored-by: Douglas Raillard <douglas.raillard@arm.com>
Co-authored-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Co-authored-by: Achin Gupta <achin.gupta@arm.com>
Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
The back end GIC driver converts and assigns the interrupt type to
suitable group.
For GICv2, a build option GICV2_G0_FOR_EL3 is introduced, which
determines to which type Group 0 interrupts maps to.
- When the build option is set 0 (the default), Group 0 interrupts are
meant for Secure EL1. This is presently the case.
- Otherwise, Group 0 interrupts are meant for EL3. This means the SPD
will have to synchronously hand over the interrupt to Secure EL1.
The query API allows the platform to query whether the platform supports
interrupts of a given type.
API documentation updated.
Change-Id: I60fdb4053ffe0bd006b3b20914914ebd311fc858
The `KEY_ALG` variable is used to select the algorithm for key
generation by `cert_create` tool for signing the certificates. This
variable was previously undocumented and did not have a global default
value. This patch corrects this and also adds changes to derive the
value of `TF_MBEDTLS_KEY_ALG` based on `KEY_ALG` if it not set by the
platform. The corresponding assignment of these variables are also now
removed from the `arm_common.mk` makefile.
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Change-Id: I78e2d6f4fc04ed5ad35ce2266118afb63127a5a4
The current build system and driver requires the CCI product to be
specified at build time. The device constraints can be determined at run
time from its ID registers, obviating the need for specifying them
ahead.
This patch adds changes to identify and validate CCI at run time. Some
global variables are renamed to be in line with the rest of the code
base.
The build option ARM_CCI_PRODUCT_ID is now removed, and user guide is
updated.
Change-Id: Ibb765e349d3bc95ff3eb9a64bde1207ab710a93d
SPE is only supported in non-secure state. Accesses to SPE specific
registers from SEL1 will trap to EL3. During a world switch, before
`TTBR` is modified the SPE profiling buffers are drained. This is to
avoid a potential invalid memory access in SEL1.
SPE is architecturally specified only for AArch64.
Change-Id: I04a96427d9f9d586c331913d815fdc726855f6b0
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
It doesn't make sense to use the `-pedantic` flag when building the
Trusted Firmware as we use GNU extensions and so our code is not
fully ISO C compliant. This flag only makes sense if the code intends to
be ISO C compliant.
Change-Id: I6273564112759ff57f03b273f5349733a5f38aef
Platforms aligned with TBBR are supposed to use their own OIDs, but
defining the same macros with different OIDs does not provide any
value (at least technically).
For easier use of TBBR, this commit allows platforms to reuse the OIDs
obtained by ARM Ltd. This will be useful for non-ARM vendors that
do not need their own extension fields in their certificate files.
The OIDs of ARM Ltd. have been moved to include/tools_share/tbbr_oid.h
Platforms can include <tbbr_oid.h> instead of <platform_oid.h> by
defining USE_TBBR_DEFS as 1. USE_TBBR_DEFS is 0 by default to keep the
backward compatibility.
For clarification, I inserted a blank line between headers from the
include/ directory (#include <...>) and ones from a local directory
(#include "..." ).
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
This patch introduces a build option to enable D-cache early on the CPU
after warm boot. This is applicable for platforms which do not require
interconnect programming to enable cache coherency (eg: single cluster
platforms). If this option is enabled, then warm boot path enables
D-caches immediately after enabling MMU.
Fixes ARM-Software/tf-issues#456
Change-Id: I44c8787d116d7217837ced3bcf0b1d3441c8d80e
Introduce new build option ENABLE_STACK_PROTECTOR. It enables
compilation of all BL images with one of the GCC -fstack-protector-*
options.
A new platform function plat_get_stack_protector_canary() is introduced.
It returns a value that is used to initialize the canary for stack
corruption detection. Returning a random value will prevent an attacker
from predicting the value and greatly increase the effectiveness of the
protection.
A message is printed at the ERROR level when a stack corruption is
detected.
To be effective, the global data must be stored at an address
lower than the base of the stacks. Failure to do so would allow an
attacker to overwrite the canary as part of an attack which would void
the protection.
FVP implementation of plat_get_stack_protector_canary is weak as
there is no real source of entropy on the FVP. It therefore relies on a
timer's value, which could be predictable.
Change-Id: Icaaee96392733b721fa7c86a81d03660d3c1bc06
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
The boolean build option HW_ASSISTED_COHERENCY is introduced to enable
various optimizations in ARM Trusted Software, when built for such
systems. It's set to 0 by default.
Change-Id: I638390da6e1718fe024dcf5b402e07084f1eb014
The ARMv8v.1 architecture extension has introduced support for far
atomics, which includes compare-and-swap. Compare and Swap instruction
is only available for AArch64.
Introduce build options to choose the architecture versions to target
ARM Trusted Firmware:
- ARM_ARCH_MAJOR: selects the major version of target ARM
Architecture. Default value is 8.
- ARM_ARCH_MINOR: selects the minor version of target ARM
Architecture. Default value is 0.
When:
(ARM_ARCH_MAJOR > 8) || ((ARM_ARCH_MAJOR == 8) && (ARM_ARCH_MINOR >= 1)),
for AArch64, Compare and Swap instruction is used to implement spin
locks. Otherwise, the implementation falls back to using
load-/store-exclusive instructions.
Update user guide, and introduce a section in Firmware Design guide to
summarize support for features introduced in ARMv8 Architecture
Extensions.
Change-Id: I73096a0039502f7aef9ec6ab3ae36680da033f16
The current fiptool packs all the images without any padding between
them. So, the offset to each image has no alignment. This is not
efficient, for example, when the FIP is read from a block-oriented
device.
For example, (e)MMC is accessed by block-addressing. The block size
is 512 byte. So, the best case is each image is aligned by 512 byte
since the DMA engine can transfer the whole of the image to its load
address directly. The worst case is the offset does not have even
DMA-capable alignment (this is where we stand now). In this case,
we need to transfer every block to a bounce buffer, then do memcpy()
from the bounce buffer to our final destination. At least, this
should work with the abstraction by the block I/O layer, but the
CPU-intervention for the whole data transfer makes it really slow.
This commit adds a new option --align to the fiptool. This option,
if given, requests the tool to align each component in the FIP file
by the specified byte. Also, add a new Make option FIP_ALIGN for
easier access to this feature; users can give something like
FIP_ALIGN=512 from the command line, or add "FIP_ALIGN := 512" to
their platform.mk file.
When build variables are assigned or processed en masse, they'd appear
neater in alphabetical order.
Static initializations are moved to a separate file,
make_helpers/defaults.mk, which in itself is sorted alphabetically.
No functional changes.
Change-Id: I966010042b33de6b67592fb9ffcef8fc44d7d128
