path: root/scripts
2015-01-08scripts: fix binutils-version.sh for 'as' without a package.Bill Pringlemeir
Commit 73c25753 fixed the common issue that binutil packages (tool/organization that packaged or built the bin-utils) are included in brackets and this may falsely be recognized as a version. However, some tools do not provide a 'package' and previously we add the 'Gnu assembler..' to the version. Strip out the '(package version text)' and then look for a ##.## string. Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Hans de Goede <hdegoede@redhat.com>
2014-12-29scripts: fix binutils-version.shMasahiro Yamada
The current binutils-version.sh expects the version string at the end of the first line. It turned out to not work with Linaro toolchain: It has "Linaro 2014.09" at the back. To fix this issue, let's parse the word right after the close parenthesis. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: York Sun <yorksun@freescale.com> Acked-by: Dirk Behme <dirk.behme@gmail.com>
2014-12-08kconfig: Fix warning "‘jump’ may be used uninitialized"Peter Kümmel
Warning: In file included from scripts/kconfig/zconf.tab.c:2537:0: scripts/kconfig/menu.c: In function ‘get_symbol_str’: scripts/kconfig/menu.c:590:18: warning: ‘jump’ may be used uninitialized in this function [-Wmaybe-uninitialized] jump->offset = strlen(r->s); Simplifies the test logic because (head && local) means (jump != 0) and makes GCC happy when checking if the jump pointer was initialized. Signed-off-by: Peter Kümmel <syntheticpp@gmx.net> Signed-off-by: Michal Marek <mmarek@suse.cz> [ imported from Linux Kernel, commit 2d5603060967 ] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08Kbuild: introduce Makefile in arch/$ARCH/Daniel Schwierzeck
Introduce a Makefile under arch/$ARCH/ and include it in the top Makefile (similar to Linux kernel). This allows further refactoringi like moving architecture-specific code out of global makefiles, deprecating config variables (CPU, CPUDIR, SOC) or deprecating arch/$ARCH/config.mk. In contrary to Linux kernel, U-Boot defines the ARCH variable by Kconfig, thus the arch Makefile can only included conditionally after the top config.mk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08get_maintainer.pl: fix source tree detectionDaniel Schwierzeck
get_maintainer.pl always fails with following message: ./scripts/get_maintainer.pl: The current directory does not appear to be a linux kernel source tree. This was caused by commit: commit 548b310c68ac99a0330d8b56c797c09ff0742d1e Author: Masahiro Yamada <yamada.m@jp.panasonic.com> Date: Thu Oct 30 15:50:15 2014 +0900 Remove the CREDITS file This file is not maintained these days. We use MAINTAINERS for the maintainership of the supported boards. For dead boards, we have some clues in doc/README.scrapyard and also imperishable history in git-log. Remove CREDITS from source tree detection to fix this. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-25Align embedded device tree correctlySimon Glass
Device trees must be aligned to a 4-byte boundary. This was dropped in the Kbuild conversion. Bring it back, and use 16-byte alignment for good measure. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23spl: fix descending condition to drivers/mtd/nand/Masahiro Yamada
SPL should not reference CONFIG_CMD_NAND to decide whether or not it should build drivers/mtd/nand. CONFIG_CMD_NAND should be only used to select the NAND utility command on the command parser. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23kbuild: Descend into SOC directory from CPU directoryMasahiro Yamada
Some CPUs of some architectures have SOC directories. At present, the build system directly descends into SOC directories from the top Makefile, but it should generally descend into each directory from its parent directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-21dm: spl: Allow driver model to be usedSimon Glass
When enabled, set up driver model for SPL. This allows SPL to use the same drivers as the main U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-11-17arm, at91: generate boot.bin file for all atmel SoCHeiko Schocher
generate the boot.bin file for all atmel SoC (arm920, arm926, armv7) Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com> [fix subject] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-12kbuild: Make scripts executableMasahiro Yamada
The Makefiles call the respective interpreter explicitly, but this makes it easier to use the scripts manually. (This commit follows commit 06ed5c2bfaca of Linux Kernel) Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: sync misc scripts with Linux 3.18-rc1Masahiro Yamada
This commit imports some updates in misc scripts from Linux 3.18-rc1. [1] commit cbb4d3e6510b99522719c5ef0 by Horia Geanta scripts/kernel-doc: handle object-like macros [2] commit 164f0d2efaaef83 by Michal Marek kbuild: Fix handling of backslashes in *.cmd files [3] commit 270a00963cd367214e by Randy Dunlap scripts/kernel-doc: recognize __meminit [4] commit a4954fd7724c0f55361eb5 by Masahiro Yamada kbuild: remove obj-n and lib-n handling [5] commit 5b2389b45d1a9c12b9f by Masahiro Yamada kbuild: simplify build, clean, modbuiltin shorthands Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kconfig: sync kconfig files with Linux 3.18-rc1Masahiro Yamada
This commit imports Kconfig updates from Linux 3.18-rc1. 'kvmconfig' and 'tinyconfig' help message have been commented out since they are unavailable at least now; in the future perhaps we can implement 'tinyconfig' to disable most of CONFIG_CMD_* to create a very small U-Boot image. [1] commit 3aaefce10351 by Josh Triplett x86, platform, kconfig: move kvmconfig functionality to a helper [2] commit 0da1d4a0b951 by Josh Triplett x86: Add "make tinyconfig" to configure the tiniest possible kernel [3] commit c40724d3f381 by Brian Norris kconfig: lxdialog: fix spelling [4] commit 7285996aa000 by Brian Norris kconfig: nconfig: fix multi-byte UTF handling Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: sync top Makefile with Linux 3.18-rc1Masahiro Yamada
Since Linux 3.15, relative path feature and related fixes, cleanups have been merged to the top Makefile. The relative path feature looks stable enough, so let's import it to U-Boot along with various cleanups. Commits imported from Linux (some need adjustment) are: [1] commit 7e1c04779efd by Michal Marek kbuild: Use relative path for $(objtree) [2] commit 890676c65d69 by Michal Marek kbuild: Use relative path when building in the source tree [3] commit 9da0763bdd82 by Michal Marek kbuild: Use relative path when building in a subdir of the source tree [4] commit c2e28dc975ea by Michal Marek kbuild: Print the name of the build directory [5] commit 066b7ed95580 by Michal Marek kbuild: Do not print the build directory with make -s [6] commit 3f1d9a6cec01 by Michal Marek kbuild: make -s should be used with kernelrelease/kernelversion/image_name [7] commit 7ff525712acf by Masahiro Yamada kbuild: fake the "Entering directory ..." message more simply [8] commit 745a254322c8 by Masahiro Yamada kbuild: use $(Q) for sub-make target [9] commit aa55c8e2f7a3 by Masahiro Yamada kbuild: handle C=... and M=... after entering into build directory [10] commit ab7474ea5361 by Borislav Petkov Kbuild: Ignore GREP_OPTIONS env variable To use relative path feature, tools/Makefile and scripts/Makefile.autoconf must be tweaked. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: improve multi-objs dependency and cleanupsMasahiro Yamada
Since Linux 3.18-rc1, Kbuild is able to handle multi-objs dependency correctly, which also allows us futher cleanups of some makefiles. This commit imports those commits: [1] commit c8589d1e9e01 by Masahiro Yamada kbuild: handle multi-objs dependency appropriately [2] commit 97e3226e6e98 by Masahiro Yamada kbuild: handle the dependency of multi-objs hostprogs appropriately [3] commit 022af62d0190 by Masahiro Yamada kbuild: refactor script/kconfig/Makefile [4] commit 221ecca6cafe by Masahiro Yamada kbuild: remove redundant clean-files from scripts/kconfig/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: bug fixes and cleanups of Makefile.hostMasahiro Yamada
This commit imports updates of scripts/Makefile.host from Linux 3.18-rc1. Imported commits are: [1] commit d8d9efe22709 by Masahiro Yamada kbuild: fix a typo in scripts/Makefile.host [2] commit edb950c17de0 by Masahiro Yamada kbuild: fix a bug of C++ host program handling [3] commit 62e2210798ed by Masahiro Yamada kbuild: drop shared library support from Makefile.host [4] commit 663935593915 by Masahiro Yamada kbuild: clean up scripts/Makefile.host [5] commit 1791ff7179f6 by Masahiro Yamada kbuild: clean-up and bug fix of scripts/Makefile.host Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-05sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.Ian Campbell
$ make BOARD_felconfig is more convenient than $ make BOARD_defconfig $ echo CONFIG_SPL_FEL=y >> .config $ echo CONFIG_SPL_FEL=y >> spl/.config Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-04kbuild: do not hide clang warnings during build with W=1Masahiro Yamada
These lines originate in Linux; it looks like Linux folks chose to hide bunch of warnings reported by clang rather than fixing C code. In U-boot, warnings are being fixed thanks to Jeroen's great efforts. Let's stop suppressing clang warnings. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-27Correct two non-functional misspellings "overrided".Robert P. J. Day
2014-10-23kconfig: invoke silentoldconfig if spl, tpl/.config is updatedMasahiro Yamada
When spl/.config is updated by "make spl/menuconfig" or friends, spl/include/config/auto.conf, spl/include/generated/autoconf.h and some other files must be updated by "make silentoldconfig". There is no hook for SPL in the top Makefile, so this commit touches .config when spl/.config is updated to invoke silentoldconfig. Likewise for TPL. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-23kbuild: fix a bug of the u-boot-spl link ruleMasahiro Yamada
cmd_u-boot-spl includes $(PLATFORM_LIBS) which changes when CONFIG_USE_PRIVATE_GCC is updated. The u-boot-spl image should be re-linked if any prerequisite is newer than it or the command line has changed. $(call, if_changed,...) should be used instead of $(call cmd,...). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10scripts/multiconfig.sh: Fix a typoYork Sun
Fix the spelling of "configs". Signed-off-by: York Sun <yorksun@freescale.com> CC: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10multiconfig.sh: replace GNU sed specific matchJeroen Hofstee
A SPL/TPL enabled target would was not recognized as such by BSD sed, since it relies on a GNU extension. Instead of or-ing just spell out both matches. Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10kconfig: fix another bug of "make savedefconfig"Masahiro Yamada
In some cases, the last lines of SPL or TPL are not output to a file. The entries remaining in the "unmatched" variable must be flushed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-25checkpatch: remove unnecessary + after {8,8}Joe Perches
Pick the following commit from Linux kernel: commit 66cb4ee0e52ca721f609fd5eec16187189ae5fda Author: Joe Perches <joe@perches.com> Date: Wed Sep 10 09:40:47 2014 +1000 checkpatch: remove unnecessary + after {8,8} There's a useless "+" use that needs to be removed as perl 5.20 emits a "Useless use of greediness modifier '+'" message each time it's hit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2014-09-24kconfig: remove config_cmd_defaults.hMasahiro Yamada
Now config_cmd_defaults.h is empty so it can be deleted safely. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16kconfig: add sanity checks for SPL configurationMasahiro Yamada
For the SPL configuration, "make <dir>/<target>" is used. Here, <dir> is either "spl" or "tpl" <target> is one of "config", "menuconfig", "xconfig", etc. This commit adds two checks: [1] If <dir> is given an unsupported subimage, the configuration should error out like this: $ make qpl/menuconfig *** *** "make qpl/menuconfig" is not supported. *** [2] Make sure that "CONFIG_SPL" is enabled in the ".config" before running "make spl/menuconfig. Otherwise, the SPL image is not built at all. Having "spl/.config" makes no sense. In such a case, the configuration should exit with a message: $ make spl/menuconfig *** *** Create ".config" with "CONFIG_SPL" enabled *** before "make spl/menuconfig". *** Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Simon Glass <sjg@chromium.org>
2014-09-16scripts/Makefile.clean: clean also $(extra-m) and $(extra-)Masahiro Yamada
This commit is a backport from Linux Kernel, commit 9d5db8949f1ecf4019785b04d8986835d3c0e99e, written by me. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-16kconfig: show an error message when defconfig is not foundMasahiro Yamada
When a non-existing defconfig is specified, display an easy-to-understand message (fake the error message on Linux Kernel): $ make foo_defconfig *** *** Can't find default configuration "confis/foo_defconfig"! *** Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-09-16kconfig: fix savedefconfig to handle TPL correctlyMasahiro Yamada
Since 3ff291f371fa9858426774f3732924bacb61ed1c (kconfig: convert Kconfig helper script into a shell script), "make savedefconfig" of TPL boards has not been working. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.o.rg Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16kconfig: fix whitespace handling bug of savedefconfigMasahiro Yamada
Commit 3ff291f371fa9858426774f3732924bacb61ed1c (kconfig: convert Kconfig helper script into a shell script) introduced another regression. Shell usually handles whitespaces as separators, so "make saveconfig" outputs # CONFIG_FOO is not set into: # CONFIG_FOO is not set Whitespaces should not be treated as separators here. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16kconfig: fix savedefconfig to output empty defconfigMasahiro Yamada
Commit 3ff291f371fa9858426774f3732924bacb61ed1c (kconfig: convert Kconfig helper script into a shell script) introduced a minor regression. make alldefconfig; make savedefconfig should create an empty 'defconfig'. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-09cc-option: also detect unsupported warnings optionsJeroen Hofstee
By default clang will echo a warning if a warning option is unknown. Turning warnings into errors when polling for options also catches such cases and prevents passing arguments to the compiler which cause warnings. cc: Masahiro Yamada <yamada.m@jp.panasonic.com> cc: Tom Rini <trini@ti.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-08-28README.kconfig: document backward compatibility "make *_config"Masahiro Yamada
Commit 3ff291f371fa9858426774f3732924bacb61ed1c (kconfig: convert Kconfig helper script into a shell script) restored "<board>_config" target for backward compatibility. It should be documented. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2014-08-28scripts: refetch scripts/setlocalversion from Linux 3.16Masahiro Yamada
Now we have CONFIG_LOCALVERSION and CONFIG_LOCALVERSION_AUTO in Kconfig so we can use scripts/setlocalversion without any adjustment. Copy it from Linux 3.16 as is. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-22kconfig: convert Kconfig helper script into a shell scriptMasahiro Yamada
Commit 51148790 added scripts/multiconfig.py written in Python 2 to adjust Kconfig for U-Boot. It has been hard for Python 3 users because Python 2 and Python 3 are not compatible with each other. We are not happy about adding a new host tool dependency (in this case, Python version dependency) for the core build process. After some discussion, we decided to use only basic tools. The script may get a bit more unreadable by shell scripting, but we believe it is worthwhile. In addition, this commit revives "<board>_config" target that is equivalent to "<board>_defconfig" for backwards compatibility. It is annoying to adjust various projects which use U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Stephen Warren <swarren@nvidia.com>
2014-08-21scripts/Lindent: import from Linux 3.16Masahiro Yamada
2014-08-21scripts: objdiff: sync with Linux 3.16Masahiro Yamada
Import scripts/objdiff improvements from Linux v3.16, which consists of 7 commits written by me. commit 7fa0e6db3cedc9b70d68a4170f1352e2b1aa0f90 scripts: objdiff: support directories for the augument of record command commit 8ac28bee76eec006aac5ba5c418878a607d53a9b scripts: objdiff: fix a comment commit 8b5d0f20d64f00ffd5685879f8eb3659379f5aaa scripts: objdiff: change the extension of disassembly from .o to .dis commit 18165efa8203a34d82f60a1831ea290e7304c654 scripts: objdiff: improve path flexibility for record command commit 1ecc8e489abfdaa6d8d1689f7ff62fdf1adda30c scripts: objdiff: remove unnecessary code commit 5ab370e91af70d5f1b1dbaec78798a2ff236a2d5 scripts: objdiff: direct error messages to stderr commit fd6e12423311697860f30d10398a0f9eb91977d2 scripts: objdiff: get the path to .tmp_objdiff more simply Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21kbuild: sync mixed targets handling with Linux 3.16Masahiro Yamada
"make %_config all" was supported for the first time in U-Boot: commit 53bca5ab kbuild: support simultaneous board configuration and "make all" Surprisingly it had not been working in Linux Kernel for a long time. So I sent back the patch to the Linux Kbuild community and it was accepted with a little code improvement, at commit 9319f453. Now, you can do "make defconfig all" or "make %_defconfig all" in Linux too. This commit updates some scripts to fill the code-diff between Linux and U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21kbuild: move extra gcc checks to scripts/Makefile.extrawarnMasahiro Yamada
This commit was imported from Linux Kernel: commit a86fe353 written by me. W=... provides extra gcc checks. Having such code in scripts/Makefile.build results in the same flags being added to KBUILD_CFLAGS multiple times becuase scripts/Makefile.build is invoked every time Kbuild descends into the subdirectories. Since the top Makefile is already too cluttered, this commit moves all of extra gcc check stuff to a new file scripts/Makefile.extrawarn, which is included from the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21tools, scripts: refactor error-out statements of Python scriptsMasahiro Yamada
In Python, sys.exit() function can also take an object other than an integer. If an integer is given to the argument, Python exits with the return code of it. If a non-integer argument is given, Python outputs it to stderr and exits with the return code of 1. That means, print >> sys.stderr, "Blah Blah" sys.exit(1) is equivalent to sys.exit("Blah Blah") The latter is a useful shorthand. Note: Some error messages in Buildman and Patman were output to stdout. But they should go to stderr. They are also fixed by this commit. This is a nice side effect. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-08-09get_maintainer.pl: add support for scanning multiple MAINTAINERS filesDaniel Schwierzeck
2014-08-09get_maintainer.pl: adapt to U-Boot treeDaniel Schwierzeck
Switch core maintainer to Tom Rini. Adapt directory layout for git tree detection. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-09get_maintainer.pl: import script from linux 3.15Daniel Schwierzeck
2014-07-30kconfig: switch to KconfigMasahiro Yamada
This commit enables Kconfig. Going forward, we use Kconfig for the board configuration. mkconfig will never be used. Nor will include/config.mk be generated. Kconfig must be adjusted for U-Boot because our situation is a little more complicated than Linux Kernel. We have to generate multiple boot images (Normal, SPL, TPL) from one source tree. Each image needs its own configuration input. Usage: Run "make <board>_defconfig" to do the board configuration. It will create the .config file and additionally spl/.config, tpl/.config if SPL, TPL is enabled, respectively. You can use "make config", "make menuconfig" etc. to create a new .config or modify the existing one. Use "make spl/config", "make spl/menuconfig" etc. for spl/.config and do likewise for tpl/.config file. The generic syntax of configuration targets for SPL, TPL is: <target_image>/<config_command> Here, <target_image> is either 'spl' or 'tpl' <config_command> is 'config', 'menuconfig', 'xconfig', etc. When the configuration is done, run "make". (Or "make <board>_defconfig all" will do the configuration and build in one time.) For futher information of how Kconfig works in U-Boot, please read the comment block of scripts/multiconfig.py. By the way, there is another item worth remarking here: coexistence of Kconfig and board herder files. Prior to Kconfig, we used C headers to define a set of configs. We expect a very long term to migrate from C headers to Kconfig. Two different infractructure must coexist in the interim. In our former configuration scheme, include/autoconf.mk was generated for use in makefiles. It is still generated under include/, spl/include/, tpl/include/ directory for the Normal, SPL, TPL image, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-30kconfig: import Kconfig files from Linux 3.16-rc7Masahiro Yamada
Import - scripts/kconfig/* - include/linux/kconfig.h from Linux 3.16-rc7. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-29scripts: add scripts/show-gnu-make to get GNU Make command nameMasahiro Yamada
U-Boot is expected to be built on various platforms. We should keep in mind that the command 'make' is not always GNU Make, while all the makefiles are written for GNU Make. For example, on Linux, people generally do: make <board>_config; make But FreeBSD folks do gmake <board>_config; gmake (The command 'make' on FreeBSD is BSD Make, not GNU Make) It is not a good idea to hard-code the command name 'make' in MAKEALL or buildman. They should call this helper script and get the command name for GNU Make. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-22scripts: add mailmapper, a tool to create/update mailmap fileMasahiro Yamada
This tool helps to create/update the mailmap file. It runs 'git shortlog' internally and searches differently spelled author names which share the same email address. The author name with the most commits is asuumed to be a canonical real name. If the number of commits from the cananonical name is equal to or greater than 'MIN_COMMITS' (=50), the entry for the cananical name will be output. ('MIN_COMMITS' is used here because we do not want to create a fat mailmap by adding every author with only a few commits.) If there exists a mailmap file specified by the mailmap.file configuration options or '.mailmap' at the toplevel of the repository, it is used as a base file. The base file and the newly added entries are merged together and sorted alphabetically (but the comment block is kept untouched), and then printed to standard output. Usage ----- scripts/mailmapper prints the mailmapping to standard output. scripts/mailmapper > tmp; mv tmp .mailmap will be useful for updating '.mailmap' file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-20Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
