path: root/post
2011-01-25powerpc: Fix FPU post related link warningsKumar Gala
If we built POST on PPC's that didn't enable CONFIG_SYS_POST_FPU we'd get the following warning with newer toolchains: powerpc-linux-gnu-ld: Warning: lib_powerpc/fpu/libpostpowerpcfpu.o uses hard float, libpost.o uses soft float We actually worked around this sometime ago with the following commit: commit ce82ff05388b5ddafdf6082ef0776cce72c40b1c Author: Yuri Tikhonov <yur@emcraft.com> Date: Sat Dec 20 14:54:21 2008 +0300 FPU POST: fix warnings when building with 2.18 binutils However, this only took into effect if CONFIG_SYS_POST_FPU was enabled. We can simply move the GNU_FPOST_ATTR out of the CONFIG_SYS_POST_FPU ifdef block to address the issue. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-12-17ppc4xx/POST: Change ethernet test loop count to a default of 10Stefan Roese
This patch changes the PPC4xx ethernet POST loop test count from currently 192 (256 - 64) to a default of 10. While doing this the max frame size is increased. Each loop run uses a different frame size, starting with a max of 1514 bytes, down to 64. The default loop count of 10 can be overriden using CONFIG_SYS_POST_ETH_LOOPS in the board config header. The TEST_NUM loop has been removed as it was never used. The main reason for this change is to reduce the boot time on boards using this POST test, like the lwmon5 board. This change reduces the boot time by about 600ms on the lwmon5 board. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2010-11-28ppc4xx/POST: Handle cached SDRAM correctly in Denali (440EPx) ECC POSTStefan Roese
This patch fixes a problem in the Denali (440EPx) SDRAM ECC POST test. When cache is enabled in the SDRAM area, the values written to SDRAM need to be flushed from cache to SDRAM using the dcfb instruction. Without this patch the POST ECC test failed. Now its working again on platforms with cache enabled in SDRAM. Signed-off-by: Stefan Roese <sr@denx.de>
2010-11-19Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2010-11-17post, i2c: add missing curly bracket in i2c_post_testHeiko Schocher
If CONFIG_SYS_POST_I2C_ADDRS is not defined and CONFIG_SYS_POST_I2C is activated, i2c_probe() is not called in the for statement, because missing curly bracket. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-27post/drivers/i2c.c: fix compile errorWolfgang Denk
Commit 7e263ce "post/i2c: Clean up detection logic" added a "const" qualifier to the declaration of i2c_addr_list[], missing the fact that the list gets modified later in the code, which results in build errors like these: i2c.c: In function 'i2c_post_test': i2c.c:88: error: assignment of read-only location Remove the incorrect "const". Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2010-10-22post/i2c: Add ability to ignore I2C devicesPeter Tyser
Add the ability to not report an I2C POST error for a set of given I2C addresses on bootup. This is useful for cases when a device may or may not be present, and neither case is considered an error. For example: - Some form factors such as XMC and Compact PCI Express have an I2C EEPROM whose address changes based on geographical address. Eg installed in one slot its EEPROM address is, 0x50, in another its 0x51, etc. This allows multiple devices to have their EEPROMs present on the same I2C bus. Thus the I2C devices present for an XMC or CPCIe card depend on if and where other cards are installed in the same system. - Some cards have optional I2C devices. Eg one hardware build configuration has different I2C devices than another and software can't determine if the optional device should be present or not. - Some cards have optional daughtercards with I2C devices on them. - I2C EEPROMs address range depends on their size. Its possible to support differently size EEPROMs by only probing the EEPROM's base address and ignoring the other addresses that are impacted by its size. A new CONFIG_SYS_POST_I2C_IGNORES define has been added which specifies a list of I2C addresses for the I2C POST to ignore. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: Rename I2C_ADDR_LIST to CONFIG_SYS_POST_I2C_ADDRSPeter Tyser
2010-10-22post/i2c: Don't probe address 0Peter Tyser
According to the I2C specification device address 0 is the "general call address", ie a broadcast address. The I2C specification states that the format of a general call uses at least 2 bytes, which U-Boot's probing routine does not adhere to. Not probing device address 0 will prevent possible issues with devices that accept general calls. Additionally, this change shouldn't reduce POST coverage since each I2C device should still be accessed via its own, unique address. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: Clean up detection logicPeter Tyser
The logic previously used in the I2C post was a bit convoluted. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: General clean upPeter Tyser
- Clean up ifdeffery - Update coding style No functional change should have occurred. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20ppc4xx/POST: Add board specific UART POST test to lwmon5Stefan Roese
Add CONFIG_POST_UART to implement a board specific UART POST test. This is done since lwmon5 needs to set POST_ALWAYS to run this test on each reboot. And we don't want to change the default behavious of this this. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-19Expand POST memory test to support arch-depended implementation.York Sun
Add weak functions to enable architecture depended preparation, address advancing, cleaning up and error handling. These weak functions provides the framwork to implemente arch/platform dependent code for initializing/maintenance/restore the start address, size, physical address as well as memory mapping before/between/after memory test. arch_memory_failure_handle can also be implemented in case more care is needed for arch/platform. Signed-off-by: York Sun <yorksun@freescale.com>
2010-10-04ppc4xx: Use common ns16550 functions in 4xx UART POST driverStefan Roese
This patch changes the PPC4xx POST UART driver to use the common NS16550 functions for receiving and sending. Additionally the local function for SoC divisor setup are removed. Instead the functions from arch/powerpc/cpu/ppc4xx/4xx_uart.c are used. This removes code duplication. Also the common CONFIG_SYS_NS16550_COMx defines are now used to describe the POST UART's. And a compile breakage is fixed, introduced by a git merge of the ppc4xx/next branch into master. Now "ppc4xx.h" is moved to "asm/ppc4xx.h". Fixed as well with this patch. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-04ppc4xx: Big lwmon5 board support rework/updateSascha Laue
This patch brings the lwmon5 board support up-to-date. Here a summary of the changes: lwmon5 board port related: - GPIO's changed to control the LSB transmitter - Reset USB PHY's upon power-up - Enable CAN upon power-up - USB init error workaround (errata CHIP_6) - EBC: Enable burstmode and modify the timings for the GDC memory - EBC: Speed up NOR flash timings lwmon5 board POST related: - Add FPGA memory test - Add GDC memory test - DSP POST reworked - SYSMON POST: Fix handling of negative temperatures - Add output for sysmon1 POST - HW-watchdog min. time test reworked Additionally some coding-style changes were done. Signed-off-by: Sascha Laue <sascha.laue@liebherr.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Move gpio.h to ppc4xx-gpio.h since its ppc4xx specificStefan Roese
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: POST UART: Use in/out_8() io-accessor functionsStefan Roese
This patch fixes a problem in the PPC4xx POST UART driver. This driver incorrectly used the in/out8() io-accessor functions. This could lead to problems since these functions don't guarantee execution ordering. This patch now replaces these functions with the correct ones. Additionally the driver is converted to using the NS16550 struct instead of macros for the register offsets. And some common code is factored out for better maintainability. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-05-06POST: Added ECC memory test for mpc83xx.Michael Zaidman
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Fixed minor coding style issue. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-24mpc5121: pdm360ng: add coprocessor POSTAnatolij Gustschin
Adds coprocessor communication POST code Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-03-21POST: add progress APIMichael Zaidman
Add POST progress API implemented as weak calls before and after each call to the POST test callback in the post_run_single routine of the post.c file. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03Conditionally perform common relocation fixupsPeter Tyser
Add #ifdefs where necessary to not perform relocation fixups. This allows boards/architectures which support relocation to trim a decent chunk of code. Note that this patch doesn't add #ifdefs to architecture-specific code which does not support relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03lwmon, lwmon5: Remove sysmon POST relocation fixupsPeter Tyser
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Replace 4xx lowercase SPR referencesMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-28mpc8xx/ether.c: fix warning: unused variable 'bd'Wolfgang Denk
Also minor coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20cpu/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The cpus that get converted here: at91rm9200 mpc512x mpc5xxx mpc8260 mpc8xx ppc4xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: John Rigby <jrigby@freescale.com> CC: Stefan Roese <sr@denx.de>
2009-01-24FPU POST: fix warnings when building with 2.18 binutilsYuri Tikhonov
When compile u-boot with the 2.18 binutils the following warning messages for each object file in post/lib_ppc/fpu/ is produced at the linking stage: post/libpost.a(acc1.o) uses hard float, u-boot uses soft-float ... This is because of the fact that, in general, the soft-float and hard-float ABIs are incompatible; the 2.18 binutils do checking of the Tag_GNU_Power_ABI_FP attribute of the files to be linked, and produce the worning like above if these are not compatible. The incompatibility of ABIs is concerned only the float values: e.g. the soft-float ABI assumes the float argument passing in the pair of rX registers, and the hard-float ABI assumes passing of the float argument in the fX register. When we don't pass the float arguments between the functions compiled with different floatness, then such an application will work correctly. This is the case for the FPU POST: u-boot (compiled with soft-float) doesn't pass to (and doesn't get from) the FPU POST functions any floats; there are no functions exported from the post/lib_ppc/fpu/ objects which would work with float parameters/returns too. So, we can reassure the linker not to worry about the difference in ABI attributes of linking files just by setting the 'soft-float' attribute for the objects in post/lib_ppc/fpu. And this patch does this. Also, to avoid passing both soft- and hard-float options in CFLAGS when compiling the files from post/lib_ppc/fpu (which is OK, but looks rather dirty) this patch removes the soft-float string from CFLAGS in post/lib_ppc/fpu/Makefile. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-12-16post/Makefile: fix dependency problem with parallel buildsWolfgang Denk
Parallel builds (using "make -jN") would occasionally fail with error messages like ppc_4xxFP-objdump: string.o: File format not recognized or post/libpost.a(cpu.o): In function `cpu_post_test': /home/wd/git/u-boot/work/post/lib_ppc/cpu.c:130: undefined reference to `cpu_post_test_string' or similar. We now make sure to run the 'postdeps" step before attempting to build the specific POST libraries. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-15POST Make: fix the sub-dir dependencies missing.Yuri Tikhonov
2008-08-06Fix merge problemsStefan Roese
2008-06-29Configure DSP POST; add watchdog reset to diag commandSascha Laue
2008-06-11Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-06-06ppc4xx: Fix misspelled CONFIG_440SPE/440EPX/GRX config optionsStefan Roese
We use upper case letters for the AMCC processor defines (like CONFIG_440SPE) in U-Boot. So the 440SPe is labeled CONFIG_440SPE and not CONFIG_440SPe. This patch fixes the last misspelled config options. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03lwmon5: add memory-pattern-test to FPGA POST.Sascha Laue
2008-05-21Merge branch 'lwmon5' of /home/wd/git/u-boot/projectsWolfgang Denk
