path: root/net
2018-08-20[iot] [coverity] Fix null dereferenced issuesLuo Ji
Fix the null dereferenced issues from converity scan results. issue id: 3618300:Dereference after null check 3618364:Dereference after null check 3618463:Dereference after null check 3618470:Explicit null dereferenced 3618520:Dereference after null check Test: issue fixed by converity scan. Change-Id: I577ed094a1f9b493de61b84827c0e1157a4fbd2f Signed-off-by: Luo Ji <ji.luo@nxp.com>
2018-04-27MLK-14862 net: eth-uclass: add return value checkPeng Fan
Add return value check Coverity 392391 Signed-off-by: Peng Fan <peng.fan@nxp.com> (cherry picked from commit 3f8052264b97b0bf87452876307ca115b7a518a3)
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert CONFIG LIB_HW_RAND to KconfigAdam Ford
config_fallbacks.h had some logic to automatically select LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't already selected. By migrating LIB_HW_RAND to Kconfig, we can remove this check from config_fallbacks.h and put it into Kconfig Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> [trini: Turn into a choice, add NET_RANDOM_ETHADDR] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-15net: dhcp: Allow "MAY_FAIL" to still try each adapterJoe Hershberger
This change allows the "MAY_FAIL" DHCP option to still attempt to contact a DHCP server on each adapter and only give up once each adapter has failed once. To get the existing behavior, set the already-existing ethrotate=no variable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Keng Soon Cheah <keng.soon.cheah@ni.com> Cc: Chen Yee Chew <chen.yee.chew@ni.com>
2018-01-15net: Remove nfs.h include from bootp.cJoe Hershberger
Nothing from this header is used there, so remove it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2017-09-22net/tftp: fix build if CMD_BOOTEFI is not setJörg Krause
Fixes: net/tftp.c:811: undefined reference to `efi_set_bootdev' Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-07net: nfs: Drop CONFIG_NFS_READ_SIZETom Rini
In the general case, CONFIG_NFS_READ_SIZE is unchanged from the default of 1024. There are in fact no in-tree users that increase this size. Adjust the comment to reflect what could be done in the future in conjunction with CONFIG_IP_DEFRAG. Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-07net: Use packed structures for networkingDenis Pynkin
PXE boot is broken with GCC 7.1 due option '-fstore-merging' enabled by default for '-O2': BOOTP broadcast 1 data abort pc : [<8ff8bb30>] lr : [<00004f1f>] reloc pc : [<17832b30>] lr : [<878abf1f>] sp : 8f558bc0 ip : 00000000 fp : 8ffef5a4 r10: 8ffed248 r9 : 8f558ee0 r8 : 8ffef594 r7 : 0000000e r6 : 8ffed700 r5 : 00000000 r4 : 8ffed74e r3 : 00060101 r2 : 8ffed230 r1 : 8ffed706 r0 : 00000ddd Flags: nzcv IRQs off FIQs off Mode SVC_32 Resetting CPU ... Core reason is usage of structures for network headers without packed attribute. Reviewed-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com> Signed-off-by: Denis Pynkin <denis.pynkin@collabora.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07net: Fix compile failure in net.cHolger Dengler
Add missing "defined" statement to fix the compile failures. Signed-off-by: Holger Dengler <dengler@linutronix.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07net: tftp: silence a subscript above array bounds compile time warningVladimir Zapolskiy
For strncpy() select a minimal string length of destination and source strings, here DEFAULT_NAME_LEN is preferable to MAX_LEN. Due to the NUL-terminated contents of default_string the change is a noop, however it removes a compilation warning if SH2/3/4 platform specific strncpy() function is used: In file included from include/linux/string.h:21:0, from include/common.h:28, from net/tftp.c:9: net/tftp.c: In function 'tftp_start': arch/sh/include/asm/string.h:52:42: warning: array subscript is above array bounds [-Warray-bounds] : "0" (__dest), "1" (__src), "r" (__src+__n) Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07net: Get mac address from driver as seedJimmy Du
Previously seeded by obtaining mac addr from env. If mac addr was never set, rand would output 0. This fix obtains the mac addr from driver instead. Signed-off-by: Jimmy Du <jimmy.du@ni.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-06-02net: core: avoid possible NULL pointer dereferencexypron.glpk@gmx.de
Checking if dev is NULL after dereferencing it does not make sense. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-05-12net: Disable the format-extra-args warningTom Rini
We will see warnings such as: net/eth_common.c:57:61: warning: data argument not used by format string [-Wformat-extra-args] sprintf(enetvar, index ? "%s%daddr" : "%saddr", base_name, index); ~~~~~~~~ ^ With clang. In this case we do not want to re-write our code to be less compact as the above is intentional and readable. Add a comment above the disabling so that it's clear why we want that warning off. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-12net/arp: remove superfluous assignmentsxypron.glpk@gmx.de
The value of variable pkt is never used. The problem was indicated by clang scan-build. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-03-26net: link_local: Fix netmask endianness bugAlexandre Messier
The network mask must be stored in network order when in a 'struct in_addr'. This fix removes the "gatewayip needed but not set" message on the console when using a link-local IP setup. Signed-off-by: Alexandre Messier <amessier@tycoint.com> Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-03-20net: don't override ethernet address environmentRoger Quadros
If the ethernet address environment is set with a valid ethernet address prevent overriding it as it is most likely set by the user and he/she doesn't want board code to automatically override it whatsoever. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-02-07net: core: cosmetic: A MAC address is not limited to SROMoliver@schinagl.nl
Currently, we print that the MAC from the SROM does not match. It can be many forms of ROM, so lets drop the S. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-02-07net: cosmetic: Make the MAC address string less magicaloliver@schinagl.nl
In u-boot printf has been extended with the %pM formatter to allow printing of MAC addresses. However buffers that want to store a MAC address cannot safely get the size. Add a define for this case so the string of a MAC address can be reliably obtained. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-02-07net: cosmetic: Do not use magic values for ARP_HLENoliver@schinagl.nl
Commit 674bb249825a ("net: cosmetic: Replace magic numbers in arp.c with constants") introduced a nice define to replace the magic value 6 for the ethernet hardware address. Replace more hardcoded instances of 6 which really reference the ARP_HLEN (iow the MAC/Hardware/Ethernet address). Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2016-11-13net: write enetaddr down to hardware on env_callbackMarek Vasut
If mac-address is changed using "setenv ethaddr ...." command the new mac-adress also must be written into the responsible ethernet driver. This fixes the legacy ethernet handling. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2016-11-07net: use random ethernet address if invalid and not zeroSiva Durga Prasad Paladugu
Use random ethernet address if the ethernet address found is invalid, not zero and config for random address is defined. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-13net: write enetaddr down to hardware on env_callbackHannes Schmelzer
If mac-address is changed using "setenv ethaddr ...." command the new mac-adress also must be written into the responsible ethernet driver. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-09-16Kconfig: spl: Add SPL support options to KconfigSimon Glass
There are a lot of SPL options in U-Boot to enable various features and drivers. Currently these do not use Kconfig. Add them to Kconfig along with suitable help, and drop them from the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-09Revert "net: nfs: Correct the reply data buffer size"Joe Hershberger
This reverts commit 6279b49e6c2fdaf8665355d1777bc90cd41fcf90. This caused a bad data crc. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Guillaume GARDET <guillaume.gardet@free.fr>
2016-09-09Revert "net: nfs: Use the tx buffer to construct rpc msgs"Joe Hershberger
This reverts commit 998372b4798fd7ebb666f571950df925b8d80f69. This caused a data abort on some platform. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Guillaume GARDET <guillaume.gardet@free.fr>
2016-08-22net: nfs: Simplify rpc_add_credentials()Joe Hershberger
We use an empty hostname, so remove all the "processing" of the known-to-be-empty hostname and just write 0's where needed. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Use the tx buffer to construct rpc msgsJoe Hershberger
Instead of always allocating a huge temporary buffer on the stack and then memcpy()ing the result into the transmit buffer, simply figure out where in the transmit buffer the bytes will belong and write them there directly as each message is built. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Move some prints to debug statementsJoe Hershberger
Much of the information is verbose and derived directly from the environment. Only output in debug mode. This also saves about 300 bytes from the code size. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Use consistent names for the rpc_pktJoe Hershberger
Use the same name throughout the nfs code and use the same member of the union to avoid casts. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Correct a commentJoe Hershberger
The buffer is of 32-bit elements, not bytes. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Consolidate handling of NFSv3 attributesJoe Hershberger
Instead of repeating the same large snippet for dealing with attributes it should be shared with a helper function. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Fix lines that are too longJoe Hershberger
Fix complaints from checkpatch.pl. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Correct the reply data buffer sizeJoe Hershberger
The type of the buffer is uint32_t, but the parameter used to size it is referring to bytes. Divide by the size of the array elements. Strictly speaking, this shouldn't be needed at all... It could just be 1 just like the request. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Share the file handle buffer for v2 / v3Joe Hershberger
The v3 handles can be larger than v2, but that doesn't mean we need a separate buffer. Reuse the same (larger) buffer for both. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: NFS: Add NFSv3 supportGuillaume GARDET
This patch enables NFSv3 support. If NFSv2 is available use it as usual. If NFSv2 is not available, but NFSv3 is available, use NFSv3. If NFSv2 and NFSv3 are not available, print an error message since NFSv4 is not supported. Tested on iMX6 sabrelite with 4 Linux NFS servers: * NFSv2 + NFSv3 + NFSv4 server: use NFSv2 protocol * NFSv2 + NFSv3 server: use NFSv2 protocol * NFSv3 + NFSv4 server: use NFSv3 protocol * NFSv3 server: use NFSv3 protocol Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@konsulko.com> Cc: joe.hershberger@ni.com Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Remove unused defineJoe Hershberger
Unreferenced, so remove the noise. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Remove separate buffer for default nameJoe Hershberger
There is no reason to store the default filename in a separate buffer only to immediately copy it to the main name buffer. Just write it there directly and remove the other buffer. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: Stop including NFS overhead in defragment maxJoe Hershberger
At least on bfin, this "specimen" is actually allocated in the BSS and wastes lots of memory in already tight memory conditions. Also, with the introduction of NFSv3 support, this waste got substantially larger. Just remove it. If a board needs a specific different defragment size, that board can override this setting. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
