path: root/lib
2012-10-30Merge branch 'chromeos-v2011.06' into colibriMarcel Ziswiler
Conflicts: arch/arm/cpu/armv7/tegra3/warmboot_avp.c arch/arm/include/asm/arch-tegra/clk_rst.h
2012-08-22Initial Toradex Colibri T20 L4T R15 support.T20_LinuxImageV2.0Alpha1_20120808Marcel Ziswiler
2012-04-25Provide alternative config for netbootingVadim Bendebury
This change allows to build a customized u-boot image, which includes networking capabilities, provides diagnostic commands and supports command line editing. These features are necessary to facilitate the factory flow. This image needs to be clearly distinguishable by ChromeOS. This is achieved by modifying the value presented by the BINF.3 ACPI object. To build this modified image one needs to add BUILD_FACTORY_IMAGE=1 to the make invocation line. BUG=chrome-os-partner:7952 TEST=manual . build the new firmware image as follows: USE='pcserial factory-mode' emerge-link chromeos-u-boot \ chromeos-coreboot chromeos-bootimage . program the new image on the Link target with ChromeOS installed on the SSD and restart it . observe the target stop at u-boot command prompt (boot >) . connect the target to an Ethernet network with a DHCP server using a USB Ethernet dongle . run the following commands at the u-boot prompt boot > usb start (Re)start USB... USB: Register 203007 NbrPorts 7 USB EHCI 1.00 Register 20400b NbrPorts 11 USB EHCI 1.00 8 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found scanning bus for ethernet devices... 1 Ethernet Device(s) found boot > dhcp Waiting for Ethernet connection... done. BOOTP broadcast 1 BOOTP broadcast 2 [a few warnings of unsupported DHCP options] DHCP client bound to address 172.22.75.25 Using asx0 device TFTP from server 172.16.255.7; our IP address is 172.22.75.25; sending through gateway 172.22.75.254 Filename 'pxelinux.0'. Load address: 0x100000 Loading: ## done Bytes transferred = 15840 (3de0 hex) boot > . start ChromeOS on the target by issuing vboot_twostop . once ChromeOS boots check the mainfw_type crossystem reported value localhost ~ # echo $(crossystem mainfw_type) netboot localhost ~ # Change-Id: I1c50517754b6b5f773e432b9adec4b290f303e6f Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/21071 Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2012-02-28Print firmware version in tab screenStefan Reinauer
In bug reports with screen shots of the firmware screens with tab pressed, it would be extremely useful to see the version of the currently running firmware and the read-only firmware, so output this information. BUG=none TEST=press TAB at dev screen, see firmware versions printed on the screen. Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: If91d4b1da8a7f69ff797b0b00c507248139601cd Reviewed-on: https://gerrit.chromium.org/gerrit/17002 Tested-by: Stefan Reinauer <reinauer@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Randall Spangler <rspangler@chromium.org>
2012-02-17usb: properly detect empty mass storage media readerVincent Palatin
When a USB card reader is empty, it will return "Not Ready - medium not present" as Key Code Qualifier. In that situation, it's useless waiting for the full timeout since the result won't change until the user inserts a card. U-Boot mass storage returns empty mass storage devices with a size of 0, skip them in the VBoot devices enumeration. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=None TEST=On Link, run without a MMC card. Change-Id: Iac37887742e5738e249f595e0413eec16b391fae Reviewed-on: https://gerrit.chromium.org/gerrit/15582 Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2012-02-15chromium: Report Ctrl-Enter key to verified boot.Tom Wai-Hong Tam
Add this special handle of Ctrl-Enter, which is converted into '\n' by i8042 driver. BUG=chrome-os-partner:6759 TEST=compile the firmware and update it to Lumpy; during the dev screen, press Ctrl-Enter to trigger USB boot. Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Change-Id: Ifde312f4ef6de9b328dc22b96ca02a2a9ccf6068 Reviewed-on: https://gerrit.chromium.org/gerrit/15805 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Tom Wai-Hong Tam <waihong@chromium.org> Commit-Ready: Tom Wai-Hong Tam <waihong@chromium.org>
2012-01-26lzma: update to lzma sdk 9.20Stefan Reinauer
Our security reviewers suggested that we update all copies of lzma sdk code used in boot loaders to the latest version. Updated code taken from latest lzma sdk release 9.20 at http://downloads.sourceforge.net/sevenzip/lzma920.tar.bz2 Signed-off-by: Stefan Reinauer <reinauer@google.com> BUG=chromium-os:24221 TEST=boot on stumpy, see it still work Change-Id: I884546f3aaf013a083fa25f306d7d921245fbc16 Reviewed-on: https://gerrit.chromium.org/gerrit/14757 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
2012-01-25vbexport: report correct number of scsi drivesStefan Reinauer
Right now our code makes the assumption that there always is one SCSI drive in the system (the AHCI attached SDD). However, this might not be the case. This patch prevents vboot from using an uninitialized disk entry when instead it should go into recovery mode. BUG=chrome-os-partner:7716 TEST=none Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: I761bbb3c92a60d4205a217c7b025f699deed83b0 Reviewed-on: https://gerrit.chromium.org/gerrit/14753 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2012-01-19Enable frequency selection in VbExBeep().Bill Richardson
BUG=none TEST=manual In dev-mode, press "Ctrl-U" with no USB stick inserted. If "crossystem dev_boot_usb" is 0, you'll hear two 400Hz beeps. If "crossystem dev_boot_usb" is 1, you'll hear one 200Hz beep. Signed-off-by: Bill Richardson <wfrichar@google.com> Change-Id: Ifd45a067ec8b922863331f13f3f4525ef40f7346 Reviewed-on: https://gerrit.chromium.org/gerrit/14529 Tested-by: Bill Richardson <wfrichar@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Commit-Ready: Bill Richardson <wfrichar@chromium.org>
2012-01-18Make the memory wiping code use arch_phys_memsetGabe Black
By using arch_phys_memset, the wiping code doesn't need to worry about what addresses can be accessed by memset or how to actually get at them. BUG=chrome-os-partner:7579 TEST=From the original, larger patch: Built and booted on Lumpy, Stumpy, and Kaen. Looked at the log to see that the regions in high memory are listed as cleared. Artificially injected a range to "clear" with 0xA5 and then 0x5A which was over the framebuffer and covered part or all of the screen on Lumpy. Verified that the screen was partially or completely filled with an appropriate looking color. Had U-Boot print the PDTs it was generating to verify that the high address bits were preserved. Identity mapped only some of memory and verified that things that should be mapped were accessible and things that shouldn't be weren't. Signed-off-by: Gabe Black <gabeblack@google.com> Change-Id: Ia1859e8df5a0bbe41839a697829dfc775e1b1e48 Reviewed-on: https://gerrit.chromium.org/gerrit/14419 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com> Tested-by: Gabe Black (Do Not Use) <gabeblack@google.com>
2012-01-18Introduce arch_phys_memset which works like memset but on physical memoryGabe Black
The default implementation of this function is just memset, but other implementations will be needed when physical memory isn't accessible by U-Boot using normal addressing mechanisms. BUG=chrome-os-partner:7579 TEST=From the original, larger patch: Built and booted on Lumpy, Stumpy, and Kaen. Looked at the log to see that the regions in high memory are listed as cleared. Artificially injected a range to "clear" with 0xA5 and then 0x5A which was over the framebuffer and covered part or all of the screen on Lumpy. Verified that the screen was partially or completely filled with an appropriate looking color. Had U-Boot print the PDTs it was generating to verify that the high address bits were preserved. Identity mapped only some of memory and verified that things that should be mapped were accessible and things that shouldn't be weren't. Signed-off-by: Gabe Black <gabeblack@google.com> Change-Id: Ie1ba5bbb8ee2847f450d0057611deee397c316cf Reviewed-on: https://gerrit.chromium.org/gerrit/14417 Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com> Tested-by: Gabe Black (Do Not Use) <gabeblack@google.com>
2012-01-13Make the memory wipe code handle 64 bit addresses properlyGabe Black
When telling the memory wipe infrastructure about regions it should and shouldn't wipe, some of those addresses may be 64 bits on x86. This change makes the infrastructure pass around those addresses intact instead of truncating them, and then simply ignore the regions that are unaddressable by U-Boot. BUG=None TEST=Built and booted on Lumpy. Built on Kaen Signed-off-by: Gabe Black <gabeblack@google.com> Change-Id: I657cd5480ca9a33614b032bf2a727d1a74d38b48 Reviewed-on: https://gerrit.chromium.org/gerrit/14149 Reviewed-by: Bill Richardson <wfrichar@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Commit-Ready: Gabe Black (Do Not Use) <gabeblack@google.com> Tested-by: Gabe Black (Do Not Use) <gabeblack@google.com>
2012-01-06CHROMIUM: Support vboot without a displaySimon Glass
This allows booting without a display, mostly as a way of calculating the time that LCD init and maintenance costs us. Perhaps we might integrate the lcd and video APIs within U-Boot - it would be a much nicer solution. With that in mind I feel it is not work refactoring this into three separate (lcd, video, none) files to implement the display API. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: Iea4656f8939f7f2fd78292827091de4ee379954b Reviewed-on: https://gerrit.chromium.org/gerrit/13369 Tested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
2012-01-05Add bootstage timing to TPM operationsSimon Glass
Records the total time taken by TPM operations for display as part of the bootstage report. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I7ce6efa3c2bb90858d17ab6613724e6ae73d918b Reviewed-on: https://gerrit.chromium.org/gerrit/13371 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-20Security: Make sure not to overflow the in memory version of the GBBGabe Black
This is a revised version of this patch which fixes an ARM bug. This change plumbs the size of the GBB specified in the device tree to the functions that read it from the flash into memory, and adds checks to those functions to make sure they don't spill out of the in memory GBB. From a security standpoint this is a largely theoretical problem since the GBB is in the read only portion of flash and if that can be modified the machine is totally compromised, but it's possible somehow an attacker could force vboot to read the GBB from the wrong place. From a practical perspective it's not a bad idea to check this to avoid accidental memory corruption. BUG=chromium-os:24223 TEST=Built and booted on Lumpy. Built for Kaen. Change-Id: I90d23fd6e055db595af12b1bd63d9932cbffe7ae Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13279 Tested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Gabe Black <gabeblack@chromium.org>
2011-12-20Revert "Security: Make sure not to overflow the in memory version of the GBB"Simon Glass
This breaks recovery mode on Kaen - the bitmaps are not displayed. This reverts commit e1153e1f56ebebff188f3693e534f10bd68e6f07 Change-Id: I300ae39382dc1960bb0375ad660a88b65181edc9 Reviewed-on: https://gerrit.chromium.org/gerrit/13274 Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-20CHROMIUMOS: fix key stroke detection in recovery modeVincent Palatin
When we re-enumerate USB devices to configure new USB mass storage key, we must also properly configure the USB keyboard if there is one connected. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=chrome-os-partner:5752 chrome-os-partner:6344 chromeos-partner:7188 TEST=on Lumpy, insert and remove a USB key in recovery mode and check that TAB still triggers the recovery reason screen. Change-Id: I4bf908023e21c027f6abcb49f168abb3013ed707 Reviewed-on: https://gerrit.chromium.org/gerrit/13251 Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Tested-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-20CHROMIUMOS: optimize USB mass storage detectionVincent Palatin
Instead of doing USB enumeration in a tight loop, let's check first if anything has changed first, then do the enumeration only if needed. This saves time (the full enumeration currently takes 1.2s while the insertion/removal detection runs in 19ms), and will allow to do the keypress detection on USB keyboard in parallel. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=chrome-os-partner:5752 chrome-os-partner:6344 TEST=on Lumpy, insert and remove a USB key in recovery mode. Change-Id: I3ba084caa41234c8629771e9dd8b06b811712cdb Reviewed-on: https://gerrit.chromium.org/gerrit/13250 Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Tested-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-20Security: Fix a security bug in the border_check function.Gabe Black
Because the offset and count parameters for the border_check function are unsigned, their total could overflow a uint32_t and end up wrapping to look smaller than the size of the flash even though it's mathematically larger. This change adds a check for that overflow. BUG=chromium-os:24222 TEST=Built and booted on a Lumpy. Change-Id: I63b04dcb519f740f6d591301bc3d4d533bbd4e05 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13219 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
This change plumbs the size of the GBB specified in the device tree to the functions that read it from the flash into memory, and adds checks to those functions to make sure they don't spill out of the in memory GBB. From a security standpoint this is a largely theoretical problem since the GBB is in the read only portion of flash and if that can be modified the machine is totally compromised, but it's possible somehow an attacker could force vboot to read the GBB from the wrong place. From a practical perspective it's not a bad idea to check this to avoid accidental memory corruption. BUG=chromium-os:24223 TEST=Built and booted on Lumpy. Built for Kaen. Change-Id: I4f33552f9d27321e73659520b08be52d775a6a9b Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13228 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-12-16Fix compilation of u-boot on non-coreboot platformsStefan Reinauer
https://gerrit.chromium.org/gerrit/#change,13110 assumed that the coreboot specific enable_beep() and disable_beep() functions are available on all ChromeOS platforms. However, at this point, only the coreboot port implements them. This CL fixes compilation on non-x86 / non-coreboot platforms. BUG=none TEST=build chromeos-u-boot for tegra2 kaen. Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: I084a2c505ea29180f711328dc969ad99c413b7cf Reviewed-on: https://gerrit.chromium.org/gerrit/13115 Reviewed-by: David James <davidjames@chromium.org> Reviewed-by: Sameer Nanda <snanda@chromium.org> Tested-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-16Add beep for x86 chormeos.Dylan Reid
Implement the VbExBeep function so that the DEV screen can beep. Much of this code was coppied from coreboot. BUG=chrome-os-partner:7114 TEST=manual, check that Stumpy beeps on DEV screen timeout and when booting from USB with dev_boot_usb=0. Change-Id: Icd4eabb0b10cc3d226db71e6a2b52d3ed7eb25ef Signed-off-by: Dylan Reid <dgreid@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/13110 Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-16For ChromeOS systems, don't show coreboot as BIOS vendor/versionStefan Reinauer
Instead, once we know which firmware we are actually running on, copy the FWID to the BIOS version in the SMBIOS table. BUG=chrome-os-partner:6827 TEST=Boot Stumpy, go to chrome://settings/about and see Google_Stumpy.... show up as "Firmware" Signed-off-by: Stefan Reinauer <reinauer@google.com> Also needs https://gerrit-int.chromium.org/#change,9288 Change-Id: I2e16a2fdb7fb835b0a0fbf08462d8a98b3cfe208 Reviewed-on: https://gerrit.chromium.org/gerrit/13098 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2011-12-15Don't use bogus gbb address when booting up rewriteable firmware.Vadim Bendebury
https://gerrit.chromium.org/gerrit/11152 introduced a bug where the gbb pointer used during rewriteable firmware boot is bogus. The pointer is retrieved from the 'chromeos-config' section of the device tree, but on x86 platform this memory area is never initialized. The fix is to make sure that the proper gbb address in the CPU address space is used before gbb contents are accessed. What it boils down to is that when CONFIG_HARDWARE_MAPPED_SPI is set, gbb address should be determined before setup_gbb_and_cdata() is called. To accomplish that fdt_decode_twostop_fmap() is being modified to retrieve the flash base address among other things. Calling this function before setup_gbb_and_cdata() allows to assign the gbb pointer before it is used. `google-binary-block' is not yet being removed from the cromeos-config section of the device tree as this could break some tests. BUG=chromium-os:22528 BUG=chrome-os-partner:7155 TEST=manual . build a new firmware image and program it on a Lumpy . verify that the device comes up as expected . modify the firmware to use read/write path as suggested by hungte@ cd ~/trunk/src/platform/vboot_reference/scripts/image_signing ./resign_firmwarefd.sh /build/lumpy/firmware/image.bin \ /build/lumpy/firmware/new_image.bin \ ../../tests/devkeys/firmware_data_key.vbprivk \ ../../tests/devkeys/firmware.keyblock \ ../../tests/devkeys/firmware_data_key.vbprivk \ ../../tests/devkeys/firmware.keyblock \ ../../tests/devkeys/kernel_subkey.vbpubk \ 1 0 . put new_image.bin into a lumpy flashrom . reboot the device . observe it come up, printing on the console 'vboot_twostop: jump to readwrite main firmware at 0x1110000, size 0xdffc0' along the way Change-Id: Ieeaadafdf31ee6199a6f1fce0b9684dd494a7602 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/12969 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-11-18Tidy up fdt_decode_alloc_region() to make alloc separateSimon Glass
Move the malloc() out of fdt_decode_alloc_region() and rename it accordingly. This makes the code somewhat cleaner and allows us to print a sensible error message. BUG=chromium-os:17062 TEST=build and boot on Kaen Change-Id: I8edc8809baa42578e74c5e42cf47494b31b774e7 Reviewed-on: https://gerrit.chromium.org/gerrit/11878 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-16UPSTREAM: Move simple_itoa to vsprintfSimon Glass
This function is generally useful and shouldn't hide away in hush. It has been moved as is. Signed-off-by: Simon Glass <sjg@chromium.org> (cherry picked from commit 3cce8a5496452285e1828984ad3945417205cfc3) Change-Id: I014f58e901e6b035b5eeb694c62e6e881a7b75c2 Reviewed-on: https://gerrit.chromium.org/gerrit/11791 Reviewed-by: Doug Anderson <dianders@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-04Introduce ability to use hardware SPI mapping for read accesses.Vadim Bendebury
On X86 systems the hardware maps the bootprom SPI flash chip into the top of memory address range. This could be used for accessing all information in the SPI flash. The vboot-reference code requires access to FMAP sections containing cryptographic information, and as of today, u-boot reads the whole sections, which are 64 KB in size, even though the actual areas accessed by vboot-reference are much smaller. A much faster way of accessing this information would be just passing around pointers to the appropriate memory areas. This would eliminate one copy, and also would make sure that only the areas actually accessed get fetched from SPI flash. This patch provides this ability trying to keep code changes to a minimum. New feature is enabled by defining CONFIG_HARDWARE_MAPPED_SPI. The firmware storage API for file reads changes when the new configuration option is set: a pointer to pointer to buffer is passed to the read_spi() function instead of a pointer to buffer. When the new feature is enabled the read_spi() function sets the pointer value to point to the requested data instead of copying the data into the buffer. A new data type is introduced (read_buf_type), which is set to be a (void *) if the new feature is not enabled, or (void **) otherwise. This type is used as the buffer pointer in the spi_read() function. Code allocating/freeing buffers used to keep data read from SPI flash is now conditionally compiled. Call sites for the spi_read() function are modified to adjust the buffer pointer parameter (pass the address of the parameter instead of the parameter, when the new feature is enabled). gbb field access functions can be aliased to gbb_init(), as they all in fact do the same - read a certain section of the gbb area. This change does not benefit the ARM implementations, and makes the code more complicated that it should be. Some u-boot rearchitecture along with vboot_reference API enhancements could address this. A tracking issue (http://code.google.com/p/chromium-os/issues/detail?id=22528) has been opened for that. BUG=chrome-os-partner:6585, chromium-os:22528 TEST=manual . build a new stumpy firmware image . boot the stumpy, observe it start up chromeos. . assess the boot timing using the cbmem.py utility (this modification shaves in excess of 100ms off the boot time). . disable the new feature, build a stumpy image, observe that is still boots chromeOs. . run emerge-terga2_kaen chromeos-u-boot to confirem that ARM version builds cleanly. Change-Id: I4e6ab530d24f5771b5a86a48d3f3135101b469a6 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/11152
2011-11-02Move Memset from vboot_reference to vbexport/u-bootStefan Reinauer
All memory operations (except the "safe ones") live in the firmware so the fast operations can be used. Except Memset. This CL changes that problem. There is another CL for this issue (removing the function from vboot_reference) BUG=chrome-os-partner:6313 TEST=run coreboot/u-boot on Stumpy Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: Ic2ee5970d2ee9df64a9eda261a4348341cb4b31a Reviewed-on: https://gerrit.chromium.org/gerrit/10992 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Bill Richardson <wfrichar@chromium.org> Reviewed-by: Randall Spangler <rspangler@chromium.org>
2011-10-18Don't use ARM's hard coded RO value for EC status on x86.Stefan Reinauer
But let coreboot pre-fill that field instead. BUG=chrome-os-partner:6212 TEST=boot coreboot+u-boot on Lumpy, see EC firmware reported as RW in crossystem. Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: Icc4ac474e19dc72b61040faafbe1a184738564d0 Reviewed-on: http://gerrit.chromium.org/gerrit/10266 Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2011-10-17CHROMIUM: Clean up cros gpio codeSean Paul
This CL simplifies how cros gpios are handled by moving the required logic out of cros_gpio.c and into the application logic. This means that cros_gpio.c assumes that none of the gpios are required, and just returns an error when fetch is called. It's up to the caller of fetch to determine whether or not they should ignore the error or act upon it. BUG=chromium-os:21700 TEST=Tested on asymptote, ensured gpio access worked as expected. Change-Id: Ief3f1915026bfe981d345b9cc4709fef19edc7bf Signed-off-by: Sean Paul <seanpaul@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/10174 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-10-12[PATCH1/2] mrc cache: Add MRC cache FMAP entry support.Vadim Bendebury
Add code to retrieve the location of the MRC cache from the FMAP device tree definition. fdt_decode.c should be refactored (fmap_offset could be determined just once and used throughout without passing it as a parameter), will leave this for another day. BUG=chrome-os-partner:5808 TEST=manual . see test description in the second patch commit message. Change-Id: Ic4003d685609beb61d1dea324bd804a2838e471c Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/9961 Reviewed-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-10-11Refactor the memory wipe infrastructure to better support x86Gabe Black
The memory wipe infrastructure in u-boot makes some assumptions about how memory is arranged that make it not quite fit with x86. Specifically, it assumes that there is a single region of memory, and with certain exceptions that's what should be wiped. In x86, specifically in the e820 map, there are multiple regions of RAM, possibly multiple regions to exclued from that that may completely, partially, or not overlap with the others, and then u-boot related regions. This is addressed by making the memory wipe infrastructure a little more generic. Now, areas can be added and subtracted arbitrarily, and will accumulate in the order they're encountered. In the x86 use case, we can add the e820 regions marked as RAM, subtract the areas marked as anything else, and subtract the u-boot related regions. Rather than tracking the actual regions of the address space, this implementation tracks the boundaries between the regions using a linked list. The code itself is short and relatively simple, and I tried to ensure that it was as clear as possible to make any memory (or other) bugs easier to see and fix. BUG=chrome-os-partner:6195 BUG=chrome-os-partner:6194 TEST=Built and booted on kaen using the A-A cable. Ran vboot_test memwipe, and a modified version that took advantage of the new API. Change-Id: I122fbf499ef473350afa27b612cb0e565366b1ad Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: http://gerrit.chromium.org/gerrit/9715 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-10-10CHROMIUM: add scsi_write to SCSI driver.Hung-Te Lin
Verified boot requires writing to GPT attributes (success / tries), so we need to implement *_write. "scsi write" command is also added to console for testing. BUG=chrome-os-partner:6258 TEST=(1) Modified GPT to trigger VBOOT updating GPT, and verified GPT changed successfully (by firmware) after reboot (2) ext2load usb 1:1 10000000 /part2.bin # load kernel partition dump scsi write 10000000 5000 5000 # write into kernel partition in #2 Change-Id: I8027b6075cdabf8df81ea1ba620ca0dcd3d33232 Signed-off-by: Hung-Te Lin <hungte@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/8841 Reviewed-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com>
2011-10-06Revert "Add support for a bios-base device tree/flashmap setting"Gabe Black
This reverts commit 8e93aec313c2807704b14fbd21123a9ffc86a087. The bios-base setting has been deprecated. BUG=None TEST=Built and booted on Stumpy. Change-Id: I792761ac44763b06bf1d3abb4db8e9e1a3f113c5 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: http://gerrit.chromium.org/gerrit/8823 Reviewed-by: Stefan Reinauer <reinauer@google.com>
2011-10-04CHROMIUM: Guard lib/chromeos/fdt_decode correctlySimon Glass
This file needs to depend on both CONFIG_CHROMEOS and CONFIG_OF_CONTROL. BUG=chromium-os:19353 TEST=build with CONFIG_OF_CONTROL, but without CONFIG_CHROMEOS; see that it now succeeds Change-Id: I94b2616b6bcb10619b00c5fe93adf2e36d459fb0 Reviewed-on: http://gerrit.chromium.org/gerrit/8682 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-09-23Use the vdat firmware index when setting up the ACPI crossystem data tableGabe Black
Instead of using a hardcoded value, set this field of the table used by the crossystem ACPI driver to whatever is stored in VDAT. BUG=chrome-os-partner:5944 BUG=chrome-os-partner:5961 BUG=chrome-os-partner:5962 TEST=Booted on Alex. Verified that corrupting firmware A made crossystem change mainfw_act to B instead of A. Signed-off-by: Gabe Black <gabeblack@google.com> Change-Id: I01b26508fede3d15e78b584b638e1393c5b03501 Reviewed-on: http://gerrit.chromium.org/gerrit/8189 Reviewed-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Hung-Te Lin <hungte@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org> Commit-Ready: Gabe Black <gabeblack@chromium.org>
2011-09-23Update VbExBeep() signature to match changed API.Bill Richardson
Signed-off-by: Bill Richardson <wfrichar@google.com> BUG=none TEST=none Change-Id: I636eee76069d9f6ae0679135b87f0006d59c2723 Reviewed-on: http://gerrit.chromium.org/gerrit/8242 Tested-by: Bill Richardson <wfrichar@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com>
2011-09-20Set up basic vboot data for use by crossystemGabe Black
This change sets up basic vboot data for use by crossystem. The pieces of information and what they're set to are below. I assumed that the constants defined in the coreboot version of this code describe all of the available settings for each option. Boot reason: BOOT_REASON_OTHER The choices here are BOOT_REASON_OTHER and BOOT_REASON_S3DIAG. I don't know what BOOT_REASON_S3DIAG is for or how to detect which to use. I believe S3 resume happens without going through u-boot, so hardcoding this to BOOT_REASON_OTHER seems reasonable for now at least. Active main firmware: ACTIVE_MAINFW_RW_A The choices are ACTIVE_MAINFW_RECOVERY, ACTIVE_MAINFW_RW_A and ACTIVE_MAINFW_RW_B. This information isn't stored in the crossystem_data_t structure. For now it's hard coded to ACTIVE_MAINFW_RW_A which is going to frequently be wrong. I suspect we also need to add a value which indicates that the read only firmware was used by itself. Active EC firmware: cdata->active_ec_firmware A direct match with data already gathered by u-boot/vboot. CHSW: Translation from booleans to bitfields. The cdata boot_write_protect_switch, boot_recovery_switch, and boot_developer_switch boolean fields are translated into the CHSW_FIRMWARE_WP_DIS, CHSW_RECOVERY_X86 and CHSW_DEVELOPER_SWITCH bitfields. The CHSW_RECOVER_EC bitfield is ignored since there's no obviously corresponding field in crossystem_data_t. HWID: cdata->hardware_id A direct match with data already gathered by u-boot/vboot. FWID: cdata->firmware_id A direct match with data already gathered by u-boot/vboot. FRID: cdata->readonly_firmware_id A direct match with data already gathered by u-boot/vboot. Active main firmware type: cdata->firmware_type A direct match with data already gathered by u-boot/vboot. Recovery reason: RECOVERY_REASON_NONE The choices are RECOVERY_REASON_NONE and RECOVERY_REASON_ME. Since u-boot has no information about the ME, this is hardcoded to RECOVERY_REASON_NONE. FMAP base address: cdata->fmap_offset An assumed direct match with data already gathered by u-boot/vboot. There is a little ambiguity as far as what this is the offset of and from. BUG=chrome-os-partner:5944 BUG=chrome-os-partner:5961 BUG=chrome-os-partner:5962 TEST=Booted successfully on both stumpy and alex. Used crossystem to verify that information like the firmware ID was extracted successfully. The GPIOs, which are not sent with this mechanism, seem to work sometimes but not always. Signed-off-by: Gabe Black <gabeblack@google.com> Change-Id: If7ea2a6470d8edf7122f87f289c19d4464775e8c Reviewed-on: http://gerrit.chromium.org/gerrit/7977 Commit-Ready: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com>
2011-09-19fdt: Move Chrome OS memory areas to fdtSimon Glass
This moves the last remaining hard-coded CONFIG to the fdt. BUG=chromium-os:17062 TEST=build for Seaboard Change-Id: Ic152ce12a0f87211e4cc98eef15601f0703137b1 Reviewed-on: http://gerrit.chromium.org/gerrit/7642 Tested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Anton Staaf <robotboy@chromium.org>
2011-09-15CHROMIUMOS: small code clean ups in boot_kernel/fdt_decodeSimon Glass
This just changes to standard 'blob' naming, and fixes a code style error. BUG=chromium-os:19353 TEST=build and boot on Seaboard Change-Id: Ib79d526ef612a181091ef15a5dd427ea73c53330 Reviewed-on: http://gerrit.chromium.org/gerrit/7681 Reviewed-by: Vadim Bendebury <vbendeb@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-09-14Add support for a bios-base device tree/flashmap settingGabe Black
This setting specifies where the bios image described by the "flash" section starts in the ROM. When the device tree is consumed by u-boot, this value is added to the given offset of accesses to the flash so that it ends up in the right place in the ROM. The binary fmap will reflect that address directly so that tools like flashrom can use it without modification. By not modifying the locations of the sections in the "flash" node of the device tree directly, we can continue to share definitions between boards that have the same layout for the BIOS image itself but who may be offset differently in the ROM. If not present, a default value of 0 is used. Unmodified device trees will continue to behave like they always have. The name bios-base isn't perfect since on ARM there is no bios. Another alternative firmware-base is also flawed because there are multiple firmwares in the ROM on x86. Yet another option, flashmap-base, doesn't quite work either because flashmap already has a very similarly named field which describes where the image described by the flashmap appears in the physical address space. Because bios-base fits the best on x86 and x86 is currently the only place it's used, that's the name I went with. BUG=chrome-os-partner:5844 TEST=Used this and other changes to compensate for the image offset and vboot on stumpy. Vbooted on x86-alex. Built with vboot_test and vbexport_test built in to verify that they still compile. Change-Id: Ie727fc2db27f7d0db8ebf7ed2b98bc97052b4923 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: http://gerrit.chromium.org/gerrit/7239 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-09-06Add SATA interface for vbexport.Vadim Bendebury
Copy device_ide.c into device_scsi.c, editing as appropriate along the way. Ensure that the new file is included if CONFIG_AHCI_SCSI is defined fro the platform. BUG=chromium-os:19837 TEST=manual . program updated image (including AHCI fixes and configuration changes) on an Alex. . restart the machine and enter `vboot_twostop' at u-boot prompt. Observe it boot up all the way to ChromeOs login screen. Change-Id: I146591c53f61722cc33f7261a1921aa07e861ee3 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/7234 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-08-31Fix refactoring problems introduced earlier.Vadim Bendebury
It was noticed that the system fails to come up while running the latest u-boot from the 2011.06 branch. Further investigation has discovered that the problem is due to the fact that the initialization of the verified boot wrapper was not handled properly and that the IDE index reported by the IDE discovery routine was wrong. BUG=chromium-os:19599 TEST=manual . build and install the new firmware image on an Alex with a valid ChromeOS image . restart the machine . enter vboot_two at u-boot prompt observe the machine to bring up the ChromeOs login screen. Change-Id: Icc78d682d5c81d6f08d31896c32c8cd48d0a4f2d Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/7030 Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com>
2011-08-30CHROMIUMOS: Refactor boot_device to support multiple devices nicelySimon Glass
Now that we have MMC, USB and IDE, with some enabled for only some platforms, the code has become ugly. This refactors the code to separate out each device into its own file, with a generic start/scan interface. This also fixes the problem with indexing of devices, where it could not cope with MMC and IDE active at the same time. BUG=chromium-os:19518 TEST=build on Seaboard; vbexport_test diskinfo See that all boot devices are found with SD and USB inserted Change-Id: I4844f7b33885ec01e922686a17c90afdf0a55a9d Reviewed-on: http://gerrit.chromium.org/gerrit/6254 Tested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Anton Staaf <robotboy@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/6918 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-08-29CHROMIUM: guard boot_kernel fdt codes with #ifdefChe-Liang Chiou
boot_kernel sets up pointer to crossystem data for embedding into kernel device tree unconditionally regarding CONFIG_OF_UPDATE_FDT_BEFORE_BOOT. This patch guards boot_kernel codes that are specific to kernel device tree with the config flag. Note: x86 boards might use a mechanism other than device tree to deliver crossystem data to kernel. BUG=none TEST=emerge-{tegra2_aebl,x86-alex} chromeos-u-boot Change-Id: Ifd04af1681d72c918c838ba3713ddecaca0ff18a Reviewed-on: http://gerrit.chromium.org/gerrit/6466 Tested-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-08-29CHROMIUMOS: Add vbexport_init() to set up librarySimon Glass
We need to register available boot devices. It seems reasonable that this library should be initialized before use. BUG=chromium-os:19518 TEST=build on Seaboard; vbexport_test diskinfo See that all boot devices are found with SD and USB inserted Change-Id: I17a535dc85b5aaee669ea67b439632bafb19c806 Reviewed-on: http://gerrit.chromium.org/gerrit/6501 Reviewed-by: Anton Staaf <robotboy@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-29Choose the right boot function for x86Stefan Reinauer
BUG=chrome-os-partner:4552 TEST=vboot_twostop does not fail with an error after loading the kernel. Change-Id: I16016239716c8030ea63c7da6bd99a2f03b0e40d Reviewed-on: http://gerrit.chromium.org/gerrit/5549 Tested-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2011-08-29Only include mmc.h when mmc is enabled.Stefan Reinauer
From http://gerrit.chromium.org/gerrit/#change,6253 BUG=none TEST=none Change-Id: I3145aa84a8426506d8dc44d094da4884f079b3b4 Reviewed-on: http://gerrit.chromium.org/gerrit/6355 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-08-29Look for an IDE boot device on non-MMC systems.Stefan Reinauer
This is a rewrite of http://gerrit.chromium.org/gerrit/#change,5547 which tries to integrate more transparently into vbexport's code and at the same time removes some (false) assumptions about always booting from MMC. BUG=none TEST=none Change-Id: I18f3b91f307b16622de9ced97ab00454c29941fe Reviewed-on: http://gerrit.chromium.org/gerrit/6232 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Reinauer <reinauer@google.com>
2011-08-29CHROMIUMOS: tidy msleep castSimon Glass
BUG=chromium-os:19353 TEST=build for Seaboard Change-Id: Iba1da73cdd5a8e3972240e939a40ee4a32e83786 Reviewed-on: http://gerrit.chromium.org/gerrit/6252 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
