path: root/lib
2013-11-25Merge branch 'sandbox1' of http://git.denx.de/u-boot-x86Tom Rini
2013-11-25Makefile: move some libraries to lib/MakefileMasahiro Yamada
2013-11-21sandbox: Correct data sizes and printf() strings in fdtdec.cSimon Glass
There are a few wwrnings in this file when building for sandbox. Addresses coming from the device tree need to be treated as ulong as elsewhere in U-Boot and we must use map_sysmem() to convert to a pointer when needed. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Hung-ying Tyan <tyanh@chromium.org>
2013-11-17lib: descend into sub directories only when it is necessaryMasahiro Yamada
2013-11-11time: fix gcc warnings on MIPS64Daniel Schwierzeck
Commit 8dfafdde88eb3e71d5569846396ae67a91017232 introduced new gcc warnings on MIPS64: time.c: In function 'tick_to_time': time.c:59:2: warning: comparison of distinct pointer types lacks a cast [enabled by default] time.c:59:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] In file included from time.c:10:0: ./u-boot-mips/include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *' time.c: In function 'usec_to_tick': time.c:76:2: warning: comparison of distinct pointer types lacks a cast [enabled by default] time.c:76:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] In file included from time.c:10:0: ./u-boot-mips/include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *' Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-11-08time: add weak annotation to timer_read_counter declarationRob Herring
A weak annotation is needed in order to prevent link errors when get_ticks is overridden. This fixes sandbox build. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-08env: fix the env export varnamePierre Aubert
The env export command doesn't export the first variable of the list since commit 5a31ea04c9ee5544fbb70ad7597ea4b294840eab "env grep" - reimplement command using hexport_r() Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2013-11-04Introduce common timer functionsRob Herring
Many platforms duplicate pretty much the same timer code yet they all have a 32-bit freerunning counter register. Create a common implementation that minimally requires 2 or 3 defines to add timer support: CONFIG_SYS_TIMER_RATE - Clock rate of the timer counter CONFIG_SYS_TIMER_COUNTER - Address of 32-bit counter CONFIG_SYS_TIMER_COUNTS_DOWN - Define if counter counts down All functions are weak or ifdef'ed so they can still be overriden by any platform. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: consolidate CONFIG_SYS_HZ definitionRob Herring
According to the README, CONFIG_SYS_HZ must be 1000 and most platforms follow that. In preparation to remove CONFIG_SYS_HZ from all these platforms, provide a common definition. The platforms which use a value other than 1000 will get build warning now. These configs are: include/configs/M5271EVB.h:#define CONFIG_SYS_HZ 1000000 include/configs/balloon3.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ include/configs/idmr.h:#define CONFIG_SYS_HZ (50000000 / 64) include/configs/mini2440.h:#define CONFIG_SYS_HZ 1562500 include/configs/mx1ads.h:#define CONFIG_SYS_HZ 3686400 include/configs/omap3_zoom2.h:#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV)) include/configs/omap730p2.h:#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV)) include/configs/palmld.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ include/configs/palmtc.h:#define CONFIG_SYS_HZ 3686400 /* Timer @ 3686400 Hz */ include/configs/rsk7203.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER) include/configs/rsk7264.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER) include/configs/rsk7269.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER) include/configs/scb9328.h:#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ include/configs/versatile.h:#define CONFIG_SYS_HZ (1000000 / 256) include/configs/zipitz2.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-10-31lib: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-20exynos5: dts: Add COMPAT string data for USB 3.0 PHY and XHCIVivek Gautam
Adding required compatible string for xHCI host controller as well as USB 3.0 PHY to enable dt support for usb 3.0 on exynos5. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-03lzo: correctly bounds-check output bufferKees Cook
This checks the size of the output buffer and fails if it was going to overflow the buffer during lzo decompression. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-09-03lzma: correctly bounds-check output bufferKees Cook
The output buffer size must be correctly passed to the lzma decoder or there is a risk of overflowing memory during decompression. Switching to the LZMA_FINISH_END mode means nothing is left in an unknown state once the buffer becomes full. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-09-03gzip: correctly bounds-check output bufferKees Cook
The output buffer size must not be reset by the gzip decoder or there is a risk of overflowing memory during decompression. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-08-10libfdt: SPDX-License-Identifier: GPL-2.0+ BSD-2-ClauseRoger Meier
Signed-off-by: Roger Meier <roger@bufferoverflow.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24Add eCos-2.0 SPDX-License-Identifier to source filesWolfgang Denk
2013-07-24Add LGPL-2.0+ SPDX-License-Identifier to source filesWolfgang Denk
2013-07-24Add LGPL-2.1+ SPDX-License-Identifier to source filesWolfgang Denk
2013-07-23fdtdec: Add compatible string for High speed i2cnaveen krishna chatradhi
Adds a new COMPAT string exynos5-hsi2c for high speed i2c controller available on exynos5 SoCs from Samsung. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-07-16tpm: add AUTH1 cmds for LoadKey2 and GetPubKeyReinhard Pfau
Extend the tpm library with support for single authorized (AUTH1) commands as specified in the TCG Main Specification 1.2. (The internally used helper functions are implemented in a way that they could also be used for double authorized commands if someone needs it.) Provide enums with the return codes from the TCG Main specification. For now only a single OIAP session is supported. OIAP authorized version of the commands TPM_LoadKey2 and TPM_GetPubKey are provided. Both features are available using the 'tpm' command, too. Authorized commands are enabled with CONFIG_TPM_AUTH_SESSIONS. (Note that this also requires CONFIG_SHA1 to be enabled.) Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-11ARM: Tegra: USB: EHCI: Add support for Tegra30/Tegra114Jim Lin
Tegra30 and Tegra114 are compatible except PLL parameters. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-03lib/rsa/rsa-sig.c: compile on OS XAndreas Bießmann
Interfaces exposed by error.h seems not to be used in rsa-sig.c, remove it. This also fixes an compile error on OS X: ---8<--- u-boot/lib/rsa/rsa-sign.c:23:19: error: error.h: No such file or directory --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl> Tested-by: Lubomir Popov <lpopov@mm-sol.com>
2013-06-26libfdt: Add fdt_find_regions()Simon Glass
Add a function to find regions in device tree given a list of nodes to include and properties to exclude. See the header file for full documentation. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add RSA support for image signingSimon Glass
RSA provides a public key encryption facility which is ideal for image signing and verification. Images are signed using a private key by mkimage. Then at run-time, the images are verified using a private key. This implementation uses openssl for the host part (mkimage). To avoid bringing large libraries into the U-Boot binary, the RSA public key is encoded using a simple numeric representation in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Add trace librarySimon Glass
Add a library which supports tracing of execution using built-in gcc features and a microsecond timer. This can be used to record a list of function which are executed, along with a timestamp for each. Later this information can be sent to the host for processing. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Add function to print a number with grouped digitsSimon Glass
Move bootstage's numbering printing code into a generic place so that it can be used by tracing also. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26cros: adds cros_ec keyboard driverHung-ying Tyan
This patch adds the driver for keyboard that's controlled by ChromeOS EC. Signed-off-by: Randall Spangler <rspangler@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-26cros: add cros_ec driverHung-ying Tyan
This patch adds the cros_ec driver that implements the protocol for communicating with Google's ChromeOS embedded controller. Signed-off-by: Bernie Thompson <bhthompson@chromium.org> Signed-off-by: Bill Richardson <wfrichar@chromium.org> Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Signed-off-by: Louis Yung-Chieh Lo <yjlou@chromium.org> Signed-off-by: Randall Spangler <rspangler@chromium.org> Signed-off-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2013-06-24EXYNOS5: FDT: Add compatible strings for SerialRajeshwari Shinde
Add required compatible information for s5p serial driver Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-06-20Makefile: move the common makefile line to public areaYing Zhang
Move the common makefile line shared by the SPL and non-SPL to the public area, so that we can avoid excessive SPL symbols. Some of them will be used by the SPL later. This patch is on top of the patch "common/Makefile: Add new symbol CONFIG_SPL_ENV_SUPPORT for environment in SPL". Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-19Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: spl/Makefile
2013-06-13FDT: Add compatible string for DWMMCAmar
Add required compatible information for DWMMC driver. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Signed-off-by: Amar <amarendra.xt@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-03tpm: Add support for new Infineon I2C TPM (SLB 9645 TT 1.2 I2C)Vincent Palatin
Add support for Infineon's new SLB 9645 TT 1.2 I2C TPMs, which supports clockstretching, combined reads and a bus speed of up to 400khz. The device also has a new device id. This is based on the kernel patch provided by Infineon : https://gerrit.chromium.org/gerrit/42332 Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Luigi Semenzato <semenzato@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Vincent Palatin <vpalatin@chromium.org> Tested-by: Tom Wai-Hong Tam <waihong@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org>
2013-05-31Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-14libfdt: Add fdt_next_subnode() to permit easy subnode iterationSimon Glass
Iterating through subnodes with libfdt is a little painful to write as we need something like this: for (depth = 0, count = 0, offset = fdt_next_node(fdt, parent_offset, &depth); (offset >= 0) && (depth > 0); offset = fdt_next_node(fdt, offset, &depth)) { if (depth == 1) { /* code body */ } } Using fdt_next_subnode() we can instead write this, which is shorter and easier to get right: for (offset = fdt_first_subnode(fdt, parent_offset); offset >= 0; offset = fdt_next_subnode(fdt, offset)) { /* code body */ } Also, it doesn't require two levels of indentation for the loop body. Signed-off-by: Simon Glass <sjg@chromium.org> (Cherry-picked from dtc commit 4e76ec79) Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2013-05-10Export fdt_stringlist_contains()Simon Glass
This function is useful outside libfdt, so export it. Ref: DTC commit b7aa300e Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: David Gibson <david@gibson.dropbear.id.au>
2013-05-09env: throw an error when an empty key is usedLucian Cojocar
If the environment contains an entry like "=value" "\0" we should throw an error when parsing the environment. Otherwise, U-Boot will enter in an infinite loop. Signed-off-by: Lucian Cojocar <cojocar@gmail.com>
2013-05-05lib: import bitrev library from the linux kernelMike Dunn
This patch adds the bitrev library from the linux kernel. This is a simple algorithm that uses an 8 bit look-up table to reverse the bits in data types of 8, 16, or 32 bit widths. The docg4 nand flash driver uses it. [port from linux kernel v3.9 commit 7ee32a6d30d1c8a3b7a07a6269da8f0a08662927] [originally added: v2.6.20 by commit a5cfc1ec58a07074dacb6aa8c79eff864c966d12] Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-01"env grep" - add support for regular expression matchesWolfgang Denk
When CONFIG_REGEX is enabled, the new option "-e" becomes available which causes regular expression matches to be used. This allows for example things like these: - print all MAC addresses: => env grep -e eth.*addr eth1addr=00:10:ec:80:c5:15 ethaddr=00:10:ec:00:c5:15 - print all variables that have at least 2 colons in their value: => env grep -v -e :.*: addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off panic=1 eth1addr=00:10:ec:80:c5:15 ethaddr=00:10:ec:00:c5:15 ver=U-Boot 2013.04-rc1-00289-g497746b-dirty (Mar 22 2013 - 12:50:25) etc. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-05-01Add SLRE - Super Light Regular Expression libraryWolfgang Denk
Downloaded from http://slre.sourceforge.net/ and adapted for U-Boot environment. Used to implement regex operations on environment variables. Code size is ~ 3.5 KiB on PPC. To enable this code, define the CONFIG_REGEX option in your board config file. Note: There are more recent versions of the SLRE library available at http://slre.googlecode.com ; unfortunately, the new code has a heavily reorked API which makes it less usable for our purposes: - the return code is strings, which are more difficult to process - we don't get any information any more which sub-string of the data was matched by the given regex - it is much more cumbersome to work with arbitrary expressions, where for example the number of substrings for capturing are not known at compile time Also, there does not seem to be any real changes or improvements of the functionality. Because of this, we deliberately stick with the older code. Note 2: the test code (built when SLRE_TEST is defined) was modified to allow for more extensive testing; now we can test the regexp matching on all lines on a text file (instead of the whole data in the file as a single block). Signed-off-by: Wolfgang Denk <wd@denx.de>
