path: root/lib
2015-01-01Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2014-12-29initcall: add explicit hint if initcall was relocatedAlexey Brodkin
Commit "initcall: Improve debugging support" makes sense and indeed simplifies process of matching initcalls executed with static disassembly. Until you are debugging relocation functionality. Existign output may make you think that at some point execution somehow returned back to non-relocated area. And there're many reasons/problems that may provoke this behavior. In order to make things clear let's add explicit mention in case initall was actually relocated like this: --->--- initcall: 810015f8 Relocation Offset is: 0efcf000 Relocating to 8ffcf000, new gd at 8fdced3c, sp at 8fdced20 initcall: 810015b8 initcall: 8ffd093c initcall: 8ffd0a14 initcall: 81001940 (relocated to 8ffd0940) initcall: 81001958 (relocated to 8ffd0958) --->--- Note "unexpected" jump from 0x8f... area to 0x81... area. Without explanation this raises many questions: execution jumped in relocated area right as expected and then for some reason returned back? But I hope comment in brackets will save some time for those curious developers who are careful enough to catch "unexpected jump to pre-reloc area" or those unlucky ones who'll have to deal with relocation debugging. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com>
2014-12-18pci: tegra: Add Tegra PCIe driverThierry Reding
Add support for the PCIe controller found on some generations of Tegra. Tegra20 has 2 root ports with a total of 4 lanes, Tegra30 has 3 root ports with a total of 6 lanes and Tegra124 has 2 root ports with a total of 5 lanes. This is based on the Linux kernel driver, originally submitted upstream by Mike Rapoport. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18ARM: tegra: Implement XUSB pad controllerThierry Reding
This controller was introduced on Tegra114 to handle XUSB pads. On Tegra124 it is also used for PCIe and SATA pin muxing and PHY control. Only the Tegra124 PCIe and SATA functionality is currently implemented, with weak symbols on Tegra114. Tegra20 and Tegra30 also provide weak symbols for these functions so that drivers can use the same API irrespective of which SoC they're being built for. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18power: Add AMS AS3722 PMIC supportThierry Reding
The AS3722 provides a number of DC/DC converters and LDOs as well as 8 GPIOs. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-13x86: Clean up asm-offsetsBin Meng
Move GD_BIST from lib/asm-offsets.c to arch/x86/lib/asm-offsets.c as it is x86 arch specific stuff. Also remove GENERATED_GD_RELOC_OFF which is not referenced anymore. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-11lib: errno: introduce errno_str(): returns errno related messagePrzemyslaw Marczak
The functions error's numbers are standarized - but the error messages are not. The errors are often handled with unclear error messages, so why not use an errno standarized messages. Advantages: - This could decrease the binary size. - Appended with a detailed information, the error message will be clear. This commit introduces new function: - const char *errno_to_str(int errno) The functions returns a pointer to the errno corresponding text message: - if errno is null or positive number - a pointer to "Success" message - if errno is negative - a pointer to errno related message Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-11lib: string: move strlcpy() to a common placeMasahiro Yamada
Move strlcpy() definition from drivers/usb/gadget/ether.c to lib/string.c because it is a very useful function. Let's add the prototype to include/linux/string.h too. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-08libfdt: move CONFIG_OF_LIBFDT and CONFIG_FIT to lib/MakefileMasahiro Yamada
2014-12-08libfdt: descend from lib/ to lib/libfdt/Masahiro Yamada
2014-12-08lib: bzip2: move bzip2 files to lib/bzip2/ directoryMasahiro Yamada
2014-12-08Replace <compiler.h> with <linux/compiler.h>Masahiro Yamada
Including <linux/compiler.h> is enough for general use. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-01Merge git://git.denx.de/u-boot-fdtTom Rini
2014-12-01Merge git://git.denx.de/u-boot-x86Tom Rini
2014-11-27fdt: remove fdtdec_get_alias_node() functionMasahiro Yamada
The fdt_path_offset() checks an alias too. fdtdec_get_alias_node(blob, "foo") is equivalent to fdt_path_offset(blob, "foo"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-26Merge git://git.denx.de/u-boot-fdtTom Rini
2014-11-25x86: Add initial video device init for Intel GMASimon Glass
Intel's Graphics Media Accelerator (GMA) is a generic name for a wide range of video devices. Add code to set up the hardware on ivybridge. Part of the init happens in native code, part of it happens in a 16-bit option ROM for those nostalgic for the 1970s. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-25x86: Add init for model 206AX CPUSimon Glass
Add the setup code for the CPU so that it can be used at full speed. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-25x86: ivybridge: Add SATA initSimon Glass
Add code to set up the SATA interfaces on boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24Merge git://git.denx.de/u-boot-x86Tom Rini
Conflicts: arch/x86/cpu/Makefile Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23vsprintf: Add modifier for phys_addr_tThierry Reding
Provide a new modifier to vsprintf() to print phys_addr_t variables to avoid having to cast or #ifdef when printing them out. The %pa modifier is used for this purpose, so phys_addr_t variables need to be passed by reference, like so: phys_addr_t start = 0; printf("start: %pa\n", &start); Depending on the size of phys_addr_t this will print out the address with 8 or 16 hexadecimal digits following a 0x prefix. Signed-off-by: Thierry Reding <treding@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-22dm: fdt: Correct handling of aliases with embedded digitsSimon Glass
Since we scan from left to right looking for the first digit, "i2c0" returns 2 instead of 0 for the alias number. Adjust the code to scan from right to left instead. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21x86: ivybridge: Implement SDRAM initSimon Glass
Implement SDRAM init using the Memory Reference Code (mrc.bin) provided in the board directory and the SDRAM SPD information in the device tree. This also needs the Intel Management Engine (me.bin) to work. Binary blobs everywhere: so far we have MRC, ME and microcode. SDRAM init works by setting up various parameters and calling the MRC. This in turn does some sort of magic to work out how much memory there is and the timing parameters to use. It also sets up the DRAM controllers. When the MRC returns, we use the information it provides to map out the available memory in U-Boot. U-Boot normally moves itself to the top of RAM. On x86 the RAM is not generally contiguous, and anyway some RAM may be above 4GB which doesn't work in 32-bit mode. So we relocate to the top of the largest block of RAM we can find below 4GB. Memory above 4GB is accessible with special functions (see physmem). It would be possible to build U-Boot in 64-bit mode but this wouldn't necessarily provide any more memory, since the largest block is often below 4GB. Anyway U-Boot doesn't need huge amounts of memory - even a very large ramdisk seldom exceeds 100-200MB. U-Boot has support for booting 64-bit kernels directly so this does not pose a limitation in that area. Also there are probably parts of U-Boot that will not work correctly in 64-bit mode. The MRC is one. There is some work remaining in this area. Since memory init is very slow (over 500ms) it is possible to save the parameters in SPI flash to speed it up next time. Suspend/resume support is not fully implemented, or at least it is not efficient. With this patch, link boots to a prompt. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: ivybridge: Perform Intel microcode update on bootSimon Glass
Microcode updates are stored in the device tree. Work through these and apply any that are needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21fdt: Add a function to decode a variable-sized u32 arraySimon Glass
Sometimes an array can be of variable size up to a maximum. Add a helper function to decode this. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: Save the BIST value on resetSimon Glass
The built in self test value is available in register eax on start-up. Save it so that it can be accessed later. Unfortunately we must wait until the global_data is available before we can do this, so there is a little bit of shuffling to keep it around. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-21fdt: Add a function to decode a named memory regionSimon Glass
Permit decoding of a named memory region from the device tree. This allows easy run-time configuration of the address of on-chip SRAM, SDRAM, etc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Enhance flashmap function to deal with region propertiesSimon Glass
Flash regions can optionally be compressed or hashed. Add the ability to read this information from the flashmap. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Use the correct return types for fdtdec_decode_region()Simon Glass
Use the correct FDT data types for this function. Also add more debugging. Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-20include: move various macros to include/linux/kernel.hMasahiro Yamada
U-Boot has imported various utility macros from Linux scattering them to various places without consistency. In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN, container_of, DIV_ROUND_UP, etc. In include/linux/compat.h are min_t, max_t, round_up, round_down, etc. We also have duplicated defines of min_t in some *.c files. Moreover, we are suffering from too cluttered include/common.h. This commit moves various macros that originate in include/linux/kernel.h of Linux to their original position. Note: This commit simply moves the macros; the macros roundup, min, max, min2, max3, ARRAY_SIZE are different from those of Linux at this point. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20replace DIV_ROUND with DIV_ROUND_CLOSESTMasahiro Yamada
The Linux-compatible macro DIV_ROUND_CLOSEST is a bit more flexible and safer than DIV_ROUND. For example, foo = DIV_ROUND_CLOSEST(x, y++) works expectedly, but foo = DIV_ROUND(x, y++) does not. (y is incremented twice.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27Tidy up data sizes and function comment in display_optionsSimon Glass
Use inttypes.h and uint64_t to correct the code so that it will not issue warnings on 64-bit machines where 'uint64_t' is 'unsigned long'. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-27Use uint64_t instead of u64 in put_dec()Simon Glass
Use the correct type required by do_div(). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-27Use uint64_t for time typesSimon Glass
Unfortunately 'unsigned long long' and 'uint64_t' are not necessarily compatible on 64-bit machines. Use the correct typedef instead of writing the supposed type out in full. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-25lmb: make local functions staticJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-23kconfig: move CONFIG_USE_PRIVATE_LIBGCC to KconfigMasahiro Yamada
The private libgcc is supported only on ARM, MIPS, PowerPC, SH, x86. Those architectures should "select" HAVE_PRIVATE_LIBGCC and CONFIG_USE_PRIVATE_LIBGCC should depend on it. Currently, this option is enabled on Tegra boards and x86 architecture. Move the definition from header files to Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-10-23kconfig: move CONFIG_SYS_HZ to lib/KconfigMasahiro Yamada
CONFIG_SYS_HZ is always defined as 1000 in config_fallbacks.h (but some boards still have redundant definitions). This commit moves the definition and the document in README to Kconfig. Since lib/Kconfig can assure that CONFIG_SYS_HZ is 1000, the sanity check in lib/time.c should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-10-23Merge git://git.denx.de/u-boot-x86Tom Rini
2014-10-23Merge git://git.denx.de/u-boot-fdtTom Rini
2014-10-22x86: dts: Add device tree compatible string for Intel IPCSimon Glass
Add this to the table so that it can be recognised. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22fdt: Add a function to return PCI BDF tripletThierry Reding
The fdtdec_pci_get_bdf() function returns the bus, device, function triplet of a PCI device by parsing the "reg" property according to the PCI device tree binding. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-10-22fdt: Add resource parsing functionsThierry Reding
Add the fdt_get_resource() and fdt_get_named_resource() functions which can be used to parse resources (memory regions) from an FDT. A helper to compute the size of a region is also provided. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-22fdt: Add functions to retrieve stringsThierry Reding
Given a device tree node, a property name and an index, the new function fdt_get_string_index() will return in an output argument a pointer to the index'th string in the property's value. The fdt_get_string() is a shortcut for the above with the index being 0. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-22fdt: Add a function to get the index of a stringThierry Reding
Given a device tree node and a property name, the new fdt_find_string() function will look up a given string in the string list contained in the property's value and return its index. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-22fdt: Add a function to count stringsThierry Reding
Given a device tree node and a property name, the fdt_count_strings() function counts the number of strings found in the property value. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-22initcall: Display error number when an error occursSimon Glass
Now that some initcall functions return a useful error number, display it when something goes wrong. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-09-24kconfig: move CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED to KconfigMasahiro Yamada
If this option is enabled, the objects under lib/ directory are compiled with speed optimization, not size optimization. (Currently, only used by some Blackfin boards.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-16kbuild: force to define __UBOOT__ in all the C sourcesMasahiro Yamada
U-Boot has imported various source files from other projects, mostly Linux. Something like #ifdef __UBOOT__ [ modification for U-Boot ] #else [ original code ] #endif is an often used strategy for clarification of adjusted parts, that is, easier re-sync in future. Instead of defining __UBOOT__ in each source file, passing it from the top Makefile would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
