path: root/include
2015-02-17Revert "sunxi: configs/sunxi-common.h: Enable CONFIG_CMD_PART"Tom Rini
This reverts commit bd2a4888b123713adec271d6c8040ca9f609aa2f which was an older version of af21f2f which is what we actually want in. Signed-off-by: Tom Rini <trini@ti.com>
2015-02-17Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-02-1682xx/km82xx: read the IVM eeprom earlierValentin Longchamp
This allows to define the ethaddr env variable according to the the IVM content by reading the IVM in misc_init_r. Later, when HUSH is available the content read earlier is analyzed to populate some non env variables. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-02-16sunxi: Normalise FEL supportSimon Glass
Make sunxi's FEL code fit with the normal U-Boot boot sequence instead of creating its own. There are some #ifdefs required in start.S. Future work will hopefully remove these. This series is available at u-boot-dm, branch sunxi-working. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16sunxi: video: Do not use CONFIG_SYS_MEM_TOP_HIDE for the framebufferHans de Goede
Do not use CONFIG_SYS_MEM_TOP_HIDE for the framebuffer, instead override board_get_usable_ram_top to make sure that u-boot is not relocated into the area where we want to use the framebuffer, and patch the devicetree from sunxi_simplefb_setup() to tell the kernel to not touch the framebuffer. This makes u-boot properly see the framebuffer as dram, and initalize the level 2 cache for it, fixing the very slow cfb scrolling problem. As an added bonus this stops us from reserving the framebuffer when simplefb is not used because an older kernel is booted, or hdp is used and no hdmi cable was plugged in, freeing up the memory for kernel use in these cases. Reported-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-16config_distro_bootcmd.h: Enable CONFIG_CMD_PARTHans de Goede
The recent changes to config_distro_bootcmd.h require CONFIG_CMD_PART to be defined, as the default bootcmd now uses the "part" command. This fixes sunxi boards not booting with v2015.04-rc1. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2015-02-16Merge git://git.denx.de/u-boot-marvellTom Rini
2015-02-13Merge git://git.denx.de/u-boot-dmTom Rini
2015-02-13Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2015-02-13dm: mx6: sabre: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-13dm: stv0991: Move driver model CONFIGs to KconfigSimon Glass
2015-02-13arm: rmobile: Add SILK board supportVladimir Barinov
SILK is an entry level development board based on R-Car E2 SoC (R8A7794) This commit supports the following peripherals: - SCIF, I2C, Ethernet, QSPI, MMC, USB Host Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Reviewed-by: Tom Rini <trini@ti.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-12dm: introduce dev_get_addr interfacePeng Fan
Abstracting dev_get_addr can improve drivers that want to get device's address. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Drop unused driver model config_defaultsSimon Glass
These are now in Kconfig so we can drop them from the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: at91: snapper: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: sh: serial: Add support driver modelNobuhiro Iwamatsu
This adds driver model support with this driver. This was tested by Koelsch board and Gose board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: socfpga: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: mx6: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: sunxi: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-12dm: sandbox: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: tegra: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: x86: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: exynos: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: Move Raspberry Pi driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config header and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Add CMD_DM and CMD_DEMO to KconfigSimon Glass
Add Kconfig settings for these two options. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: Add Kconfig options for driver model SPL supportSimon Glass
The SPL support cannot be enabled yet, but we can add the Kconfig options in preparation for this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: i2c: Make API accessible even without CONFIG_DMSimon Glass
Make the driver model I2C API available always, even if driver model is not enabled. This allows for a 'soft' switch-over, where drivers can use the new structures in code which is compiled but not yet used. This makes migration easier in some cases. Fix up the existing drivers which define their own 'struct i2c_msg'. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-02-12dm: i2c: Add a dm_ prefix to driver model bus speed functionsSimon Glass
As with i2c_read() and i2c_write(), add a dm_ prefix to the driver model versions of these functions to avoid conflicts. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-02-12net: Use new checksum functionsSimon Glass
Drop the old checksum functions in favour of the new ones. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-02-12ppc: amcc: Omit unneeded ns16550 CONFIG if using driver modelSimon Glass
This comes from the device tree or a call to get_uart_clock(). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: canyonlands: Move to generic boardSimon Glass
Switch to generic board so that this board will not be broken/removed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Move CANYONLANDS/GLACIER/ARCHES to KconfigSimon Glass
Move these options to Kconfig and remove them from the CONFIG files. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: canyonlands: config: Tidy up CONFIGs and config.mkSimon Glass
Many CONFIG options have an unnecessary value of 1. CONFIG_440 is set in the various board config files. Also simplify the CONFIG_440 check in config.mk Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12lsxl: switch from bootm to bootz for boot commandsMichael Walle
Use the bootz command to load zImages in case of any new boot scripts. Only the legacy one will still use bootm. Apart form the fact, that this will simplify the image generation process, it saves one copy of the kernel image: Common practice is to generate an uImage with a loading address of 0x8000. This uImage contains a compressed zImage, which will unpack the kernel image to the beginning of the RAM. But because there is already the compressed image the uncompressor first relocates the compressed image to a higher location. The load address is encoded into the uImage which is generated by the distributions and thus cannot be easily changed. By using the bootz command we can load the compressed image to a higher memory address and the decompressor doesn't have to reloacte the image. Signed-off-by: Michael Walle <michael@walle.cc>
2015-02-12lsxl: place the dtb below the inital ramdiskMichael Walle
The dtb was loaded at a memory address after the initial ramdisk. Thus a large ramdisk would overwrite the dtb. Move it to "ramdisk_start - 64k". 64k should be enough for the device tree blob. Also the kernel documentation arm/Booting suggests to put the dtb before the initial ramdisk. Signed-off-by: Michael Walle <michael@walle.cc>
2015-02-12lsxl: use default load addresses for legacy bootMichael Walle
The load addresses for the bootcmd_legacy script were taken from the original bootloader from Buffalo. But newer kernels are too big and the uncompressing will overwrite parts of the initial ramdisk. Therefore, we switch to the load addresses which are also used by the other boot script. Signed-off-by: Michael Walle <michael@walle.cc>
2015-02-11sunxi: configs/sunxi-common.h: Enable CONFIG_CMD_PARTHans de Goede
The recent changes to config_distro_bootcmd.h require CONFIG_CMD_PART to be defined, as the default bootcmd not uses the "part" command. This fixes sunxi boards not booting with v2015.04-rc1. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-11Add linux/compiler-gcc5.h to fix builds with gcc5Hans de Goede
Add linux/compiler-gcc5/h from the kernel sources at: commit 5631b8fba640a4ab2f8a954f63a603fa34eda96b Author: Steven Noonan <steven@uplinklabs.net> Date: Sat Oct 25 15:09:42 2014 -0700 compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompiles Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
Conflicts: include/splash.h Signed-off-by: Tom Rini <trini@ti.com>
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-02-10lcd: split splash code into its own functionNikita Kiryanov
lcd_logo() currently performs tasks well beyond just displaying the logo. It has code which displays splash image, it has logic which determines when the different display features are displayed, and it is coupled with the lcd console because it holds the responsibility of returning the lcd console base address. Make lcd_logo() just about the logo by: * Moving splash image display code into a dedicated function * Moving the logic regarding when various features are displayed to lcd_clear() (which is arguably not the correct name for housing such code either, but it is currently the most fitting location code wise) * Move the responsibility of setting the console base address to lcd_clear() too. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: dt: extract simplefb supportNikita Kiryanov
We now have api functions that can support compiling simplefb code as its own module. Since this code is not part of the display functionality, extract it to its own file. Raspberry Pi is updated to accommodate the changes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stephen Warren <swarren@wwwdotorg.org>
2015-02-10lcd: various cleanupsNikita Kiryanov
This cleanup mostly focuses on removing unnecessary whitespace and comments which are superfluous and/or do not conform to the coding style. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: split configuration_get_cmapNikita Kiryanov
configuration_get_cmap() is multiple platform-specific functions stuffed into one function. Split it into multiple versions, and move each version to the appropriate driver to reduce the #ifdef complexity. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: move platform-specific structs to their own headersNikita Kiryanov
common/lcd code is full of platform-specific code and definitions, which ideally should reside with the respective driver code. Take a step towards that goal by moving platform-specific structs from lcd.h to their own header files. The structs for the generic case (the #else for all the platform-specific cases) is retained in lcd.h as the default case. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10pmic:pfuz100 add switch mode and more registersPeng Fan
Add more pfuze register offset. And switch mode definition. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
