This variable is deprecated, therefore remove it.
And select the correct devicetree to load.
Related-to: ELB-1254
Related-to: ELB-1299
This patch basically just enables both RXC and TXC delay lines in the
PHY. This will compensate the missing delay from the MAC. Other skew
settings are not needed as the traces on board are routed exactly the
same length
This adds basic support for the new Micrel KSZ9131 phy.
(cherry picked from commit cc96ed419f7585db15855dd53046562aadece3fb)
(cherry picked from commit 28491c802d36accbb4d8562114ce8085ca53e1b0)
Do not undef CMD config defines which are set by Kconfig. This
allows to enable those commands using Kconfig.
(Taken from commit 26f0fb6c61e94f8ba52bcc0b4946d378e682ccff
'apalis-imx8: do not undef configs configured using Kconfig')
Related-to: TOR-498
Sometimes an ethernet PHY interface can’t complete
auto-negotiation and returns “timeout” error.
Overriding default timeout value fixes this issue.
Related-to: #58999
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This commit adds initial support for the Toradex Verdin iMX8MM 2GB WB IT
V1.0A module. They are now strapped to boot from eFuses which are
factory fused to properly boot from their on-module eMMC. U-Boot
supports either booting from the on-module eMMC or may be used for
recovery purpose using the universal update utility (uuu) aka mfgtools
3.0.
Functionality wise the following is known to be working:
- eMMC, 8-bit and 4-bit MMC/SD card slots
- Gigabit Ethernet
- GPIOs
- I2C
- USB_1 peripheral: fastboot or ums
- USB_2 host: USB mass storage
To prepare the program image for eMMC fastboot using imx-mkimage and
subsequently flash it using U-Boot proceed as follows:
cd imx-mkimage/
make SOC=iMX8MM flash_evk_emmc_fastboot
load mmc 1:1 $loadaddr flash.bin
setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200
mmc dev 0 1
mmc write ${loadaddr} 0x2 ${blkcnt}
To prepare the program image for use with USB recovery aka serial
downloader using imx-mkimage and subsequently download using uuu
with an uuu.auto script proceed as follows:
cd imx-mkimage/
uuu_version 1.3.34
SDP: boot -f flash.bin
CFG: SDPU: -vid 0x0525 -pid 0xb4a4
SDPU: delay 1000
SDPU: write -f flash.bin -offset 0x57c00
SDPU: jump
Fusing i.MX 8MM SoC and configuring eMMC for fastboot (already done
during manufacturing):
fuse prog 1 3 0x100020d6 (BT_FUSE_SEL, eMMC boot, SD1, fast boot, 4-bit DDR, high speed, 1.8V)
fuse prog 2 2 0x00000001 (enable boot ack)
mmc bootbus 0 1 0 2 (4-bit, reset bus width, DDR)
mmc partconf 0 1 1 0 (booting from boot area partition 1, send acknowledge)
SD manufaccture boot:
SD manufacture boot only works as long as the module is un-fused and
SD_1_PWR_EN is bypassed on the carrier board.
cd imx-mkimage/
sudo dd if=iMX8M/flash.bin of=/dev/mmcblk0 bs=1024 seek=33
Copied from linux, branch nxp/imx_4.14.98_2.2.0 @ e6c2f6322962.
Add configs to support evk_imx8mm 4GB DDR board. The 4GB DDR will
be split into two banks, one is 3GB (0x4000_0000~0xffff_0000) and
another is 1GB(0x1_0000_0000~0x1_4000_0000).
Test: build and boot with or without trusty.
Change-Id: I02f6465fc5709b15fd76820edb846452d011dd56
Signed-off-by: Ji Luo <ji.luo@nxp.com>
(cherry picked from commit e7db3f3b68bf792f7df5c113c385ebecd468f6ce)
This will actually clear the value of a variable that is potentially
still existing.
Define CONFIG_SKIP_RESOURCE_CHECING which skips the downstream
proprietary resource checking preventing us from booting any kind of
mainline device tree based Linux kernels.
While at it also fix some indentations/whitespaces.
tdxargs are meant for temporary adjusting U-Boot. Use defargs
that suits this purpose better.
As we have issues with MSI enabled we will disable it in default
environment.
Issue: Kernel panic
This commit uses the correct devicetree filename and makes sure, it
doesn't use earlycon by default
while at it make sure to use only tabs.
Initial board support for Apalis iMX8QXP using a copy of Colibri iMX8QXP.
The environment variable fdtfile is used in include/config_distro_bootcmd.h
hence we should make sure it is set by default.
Rather than using NXP proprietary boot script transition to using
proper distroboot one.
FDT relocation disabled seems to cause issues when using TorizonCore,
probably related to ramdisk.
Distro boot scripts require scriptaddr. Make sure it is defined to
a sensible address for both Apalis iMX8 as well as Colibri iMX8X.
Change default device tree to the regular one now that parallel RGB is
working.
The current loading address for the ramdisk images overlaps with
reserved memory for the decoder_boot section of the device tree (see
fsl-imx8qxp.dtsi). This generates a kernel panic early in the boot
process when trying to access that memory region.
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Fix ramdisk relocation address to work accross all our use cases.
a sensible address.
When booting U-Boot in recovery mode the default boot command for
automatic boots is substituted by bootcmd_mfg. For tezi we want this
command to source the boot script inside the boot container that the uuu
utility loads. The precise load address of this script is the one used
in the mkimage_imx8 utility to generate the boot container.
NOTE: this change affects both tezi U-Boot as well as BSP U-Boot. Since
currently only tezi is supporting recovery mode, this shouldn't be a
problem. Otherwise, consider adding preprocessor safeguards.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Tezi uses Distro Boot by default. Enable it and modify the appropriate
environment.
By default bootm can load kernels of up to 5MB. Our universal kernels in
imx8 are much larger than this, even when compressed. Since recovery
tezi needs to load from memory, allow for larger sizes to be loaded by
bootm.
fsl-imx8qm.dtsi). This generates a kernel panic early in the boot
Fused modules boot from eMMC rather than SD card.
Clean-up board file.
Clean-up configuration moving some stuff from include header file to
Kconfig defconfig.
Adjust copyright/licensing headers e.g. universally using SPDX license
identifier.
Fix Ethernet functionality. The FEC clock on i.MX 8X really has an
additional by 2 divider plus our design requires the ENET0_RCLK50M_OUT
on the ENET0_RGMII_TXC pin to be turned on for the Micrel PHY.
As long as the parallel RGB interface bring-up is not completed default
to dsihdmi device tree instead.
Kconfig defconfig.
