Added the following fdt fixup helpers:
* do_fixup_by_prop{_u32} - Find matching nodes by property name/value
* do_fixup_by_compat{_u32} - Find matching nodes by compat
The _u32 variants work the same only the property they are setting
is know to be a 32-bit integer instead of a byte buffer.
Added a fixup helper that uses aliases to set mac addresses
in the device tree based on the bd_t
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from
the device tree compiler (dtc) project.
Moved the generic fixup handling code out of cpu/mpc5xxx and cpu/mpc8260
into common/fdt_support.c and renamed:
do_fixup() -> do_fixup_by_path()
do_fixup_u32() -> do_fixup_by_path_u32()
Removed:
fdt_node_is_compatible
fdt_find_node_by_type
fdt_find_compatible_node
To ease merge of newer libfdt as we aren't using them anywhere at this time.
Also moved fdt_find_and_setprop out of libfdt into fdt_support.c for the same
reason.
Modify common/Makefile to conditionally compile the cmd_*.c files based
on the board config.
CONFIG_QE shouldn't be in the wrap of CONFIG_PCI, fix it.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
drivers/Makefile
rsdproto board support has wrong I2C frequency and wrong return value
handling.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
Ugh. I *hate* to back this change out, but these compiler flags don't
work for relocation on all versions of GCC. I've not been able to
reproduce the environment in my setup (and hence, not been able to
find a combination that *does* work), so I've got no choice but to go
back to the old gcc flags and linker script.
This patch has been sent on:
- 29 Sep 2007
Although mips_io_port_base is currently a part of IDE command, it is quite
fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move
it to MIPS general part, and introduce `set_io_port_base()' from Linux.
This patch is triggered by multiple definition of `mips_io_port_base' build
error on gth2 (and tb0229 also needs this fix.)
board/gth2/libgth2.a(gth2.o): In function `log_serial_char':
/home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base'
common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here
make: *** [u-boot] Error 1
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Basically, refactor the CFG_PIXIS_VBOOT_MASK values
into the separate board config files.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
This reverts commit 3649cd99ba815b6601868735765602f00ef3692b.
This reverts commit 6f7576b20ecf0d040c3ac3b032b5cbc860e38a90.
This reverts commit a85dd254c0577fca13627c46e93fc2ad4c4f1f00.
This reverts commit f3a52fe05923935db86985daf9438e2f70ac39aa.
This reverts commit 5af61b2f4b838a05f79be274f3e5a66edd2d9c96.
This reverts commit 057004f4a4863554d56cc56268bfa7c7d9738e27.
This reverts commit 8d17979d0359492a822a0a409d26e3a3549b4cd4.
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
This patch adds support for 1000BASE-X to functions "miiphy_speed ()" and
"miiphy_duplex()". It also adds function "miiphy_is_1000base_x ()", which
returns non-zero iff the PHY registers are configured for 1000BASE-X. The
"mii info" command is modified to distinguish between 1000BASE-T and -X.
Signed-off-by: Larry Johnson <lrj@acm.org>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
The configuration file has already enabled USB, but it
missed definition of CFG_OHCI_SWAP_REG_ACCESS, the USB
on MPC8641HPCN can not work because of the wrong USB
register endian.
And add the USB command to U-Boot commands list.
Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
To get the IDS8247 board working following are done:
- FCC2 is deactivated
- FCC1 is activated
- I2C is activated
- CFI driver is activated
- Adapted for use with LIBFDT
Signed-off-by: Sergej Stepanov <Sergej.Stepanov@ids.de>
Wolfgang is right: It's not a good idea to set up default initial
ethernet addresses for a board, even though they belong to the local
range.
This will change the failure mode from "IT manager screams at you for
using duplicate ethernet addresses" to a nice error message explaining
that the ethernet address hasn't been set properly.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
