path: root/fs
2014-08-25mtd,ubi,ubifs: sync with linux v3.15Heiko Schocher
snyc with linux v3.15: commit 1860e379875dfe7271c649058aeddffe5afd9d0d Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Jun 8 11:19:54 2014 -0700 Linux 3.15 Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: update for the sync with linux v3.14Heiko Schocher
while playing with the new mtd/ubi/ubifs sync, found some small updates for it: - add del_mtd_partition() to include/linux/mtd/mtd - mtd: add a debug_printf - remove some not used functions Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2014-08-25lib, linux: move linux specific defines to linux/compat.hHeiko Schocher
- move linux specific defines from usb and video code into linux/compat.h - move common linux specific defines from include/ubi_uboot.h to linux/compat.h - add for new mtd/ubi/ubifs sync new needed linux specific defines to linux/compat.h Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> [trini: Add spin_lock_irqsave/spin_unlock_irqrestore dummies from usb/lin_gadet_compat.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-08-09fs: implement size/fatsize/ext4sizeStephen Warren
These commands may be used to determine the size of a file without actually reading the whole file content into memory. This may be used to determine if the file will fit into the memory buffer that will contain it. In particular, the DFU code will use it for this purpose in the next commit. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-07-22catch wrong load address passed to fatload / ext2loadPavel Machek
If filename is passed instead of address to ext2load or fatload, u-boot silently accepts that, and uses 0 for load address and default filename from environment. That is confusing, display help instead. Signed-off-by: Pavel Machek <pavel@denx.de>
2014-07-18yaffs2: preprocessor cleanupJeroen Hofstee
Current code uses the preprocessor to change an else case to a statement without any if condition at all. Although this works, change the optional code to return early, so all optional code is contained within a single #ifdef. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-18yaffs2: cosmetic: remove self assignmentsJeroen Hofstee
Remove self assignments which is just dead code to prevent compiler warnings about non used arguments. For u-boot this does not prevent any warning though, on the contrary it actual introduces warnings when compiling with clang. Remove them. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19fs: ext4: fix writing zero-length filesStephen Warren
ext4fs_allocate_blocks() always allocates at least one block for a file. If the file size is zero, this causes total_remaining_blocks to underflow, which then causes an apparent hang while 2^32 blocks are allocated. To solve this, check that total_remaining_blocks is non-zero as part of the loop condition (i.e. before each loop) rather than at the end of the loop. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-06-11jffs2:jffs2_1pass.c: remove double bracesJeroen Hofstee
Clang interpretes an if condition like  "if ((a = b) == NULL) as it tries to assign a value in a statement. Hence if you do "if ((something)) it warns you that you might be confused. Hence drop the double braces for plane if statements. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-11ext4: correctly zero filenameJeroen Hofstee
Since ALLOC_CACHE_ALIGN_BUFFER declares a char* for filename sizeof(filename) is not the size of the buffer. Use the already known length instead. cc: Uma Shankar <uma.shankar@samsung.com> cc: Manjunatha C Achar <a.manjunatha@samsung.com> cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Marek Vasut <marex@denx.de>
2014-06-05disk: part_efi: clarify lbaint_t usageSteve Rae
- update the comments regarding lbaint_t usage - cleanup casting of values related to the lbaint_t type - cleanup of a type that requires a u64 Tested on little endian ARMv7 and ARMv8 configurations Signed-off-by: Steve Rae <srae@broadcom.com>
2014-05-12fs/fat: correct FAT16/12 file finding in root dirWu, Josh
When write a file into FAT file system, it will search a match file in root dir. So the find_directory_entry() will get the first cluster of root dir content and search the directory item one by one. If the file is not found, we will call get_fatent_value() to get next cluster of root dir via lookup the FAT table and continue the search. The issue is in FAT16/12 system, we cannot get root dir's next clust from FAT table. The FAT table only be use to find the clust of data aera in FAT16/12. In FAT16/12 if the clust is in root dir, the clust number is a negative number or 0, 1. Since root dir is located in front of the data area. Data area start clust #2. So the root dir clust number should < 2. This patch will check above situation before call get_fatenv_value(). If curclust is < 2, include minus number, we just increase one on the curclust since root dir is in continous cluster. The patch also add a sanity check for entry in get_fatenv_value(). Signed-off-by: Josh Wu <josh.wu@atmel.com>
2014-05-12fs: fat_write: fix the incorrect last cluster checkingWu, Josh
In fat_write.c, the last clust condition check is incorrect: if ((curclust >= 0xffffff8) || (curclust >= 0xfff8)) { ... ... } For example, in FAT32 if curclust is 0x11000. It is a valid clust. But on above condition check, it will be think as a last clust. So the correct last clust check should be: in fat32, curclust >= 0xffffff8 in fat16, curclust >= 0xfff8 in fat12, curclust >= 0xff8 This patch correct the last clust check. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2014-05-12fs:ext4:write:fix: Reinitialize global variables after updating a fileŁukasz Majewski
This bug shows up when file stored on the ext4 file system is updated. The ext4fs_delete_file() is responsible for deleting file's (e.g. uImage) data. However some global data (especially ext4fs_indir2_block), which is used during file deletion are left unchanged. The ext4fs_indir2_block pointer stores reference to old ext4 double indirect allocated blocks. When it is unchanged, after file deletion, ext4fs_write_file() uses the same pointer (since it is already initialized - i.e. not NULL) to return number of blocks to write. This trunks larger file when previous one was smaller. Lets consider following scenario: 1. Flash target with ext4 formatted boot.img (which has uImage [*] on itself) 2. Developer wants to upload their custom uImage [**] - When new uImage [**] is smaller than the [*] - everything works correctly - we are able to store the whole smaller file with corrupted ext4fs_indir2_block pointer - When new uImage [**] is larger than the [*] - theCRC is corrupted, since truncation on data stored at eMMC was done. 3. When uImage CRC error appears, then reboot and LTHOR/DFU reflashing causes proper setting of ext4fs_indir2_block() and after that uImage[**] is successfully stored (correct uImage [*] metadata is stored at an eMMC on the first flashing). Due to above the bug was very difficult to reproduce. This patch sets default values for all ext4fs_indir* pointers/variables. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-05-12fs:ext4:cleanup: Remove superfluous codeŁukasz Majewski
Code responsible for handling situation when ext4 has block size of 1024B can be ordered to take less space. This patch does that for ext4 common and write files. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-05-12fs: ubifs: drop __DATE__ and __TIME__Masahiro Yamada
__DATE__ and __TIME__ makes the build non-deterministic. Drop the debug message using them. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-12fs: fat: Fix cache align error message in fatwriteNobuhiro Iwamatsu
Use of malloc of do_fat_write() causes cache error on ARM v7 platforms. Perhaps, the same problem will occur at any other CPUs. This replaces malloc with memalign to fix cache buffer alignment. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Yoshiyuki Ito <yoshiyuki.ito.ub@renesas.com> Tested-by: Hector Palacios <hector.palacios@digi.com>
2014-03-04yaffs: Remove private list implementationSimon Glass
U-Boot already has a list implementation, and files which include both that and the yaffs implementation will get errors: In file included from ydirectenv.h:80:0, from yportenv.h:81, from yaffs_guts.h:19, from yaffs_allocator.h:19, from yaffs_allocator.c:14: yaffs_list.h:32:8: error: redefinition of ‘struct list_head’ struct list_head { ^ Remove the yaffs implementation. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26Revert "ext4fs: Add ext4 extent cache for read operations"Tom Rini
This reverts commit fc0fc50f38a4d7d0554558076a79dfe8b0d78cd5. The author has asked on the mailing list that we revert this for now as it breaks write support. Reported-by: Łukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21ubifs: fix checkpatch warningKaricheri, Muralidharan
Fix the following checkpatch warning:- WARNING: externs should be avoided in .c files Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
2014-02-21ext4fs: Add ext4 extent cache for read operationsIonut Nicu
In an ext4 filesystem, the inode corresponding to a file has a 60-byte area which contains an extent header structure and up to 4 extent structures (5 x 12 bytes). For files that need more than 4 extents to be represented (either files larger than 4 x 128MB = 512MB or smaller files but very fragmented), ext4 creates extent index structures. Each extent index points to a 4KB physical block where one extent header and additional 340 extents could be stored. The current u-boot ext4 code is very inefficient when it tries to load a file which has extent indexes. For each logical file block the code will read over and over again the same blocks of 4096 bytes from the disk. Since the extent tree in a file is always the same, we can cache the extent structures in memory before actually starting to read the file. This patch creates a simple linked list of structures holding information about all the extents used to represent a file. The list is sorted by the logical block number (ee_block) so that we can easily find the proper extent information for any file block. Without this patch, a 69MB file which had just one extent index pointing to a block with another 6 extents was read in approximately 3 minutes. With this patch applied the same file can be read in almost 20 seconds. Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com>
2014-02-21fs/fdos: RemoveTom Rini
We have an unused FAT implementation in fs/fdos, remove. Signed-off-by: Tom Rini <trini@ti.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19fat: implement exists() for FAT fsStephen Warren
This hooks into the generic "file exists" support added in an earlier patch, and provides an implementation for the FAT filesystem. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19ext4: implement exists() for ext4fsStephen Warren
This hooks into the generic "file exists" support added in an earlier patch, and provides an implementation for the ext4 filesystem. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19sandbox: implement exists() functionStephen Warren
This hooks into the generic "file exists" support added in an earlier patch, and provides an implementation for the sandbox test environment. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19fs: don't pass NULL dev_desc to most filesystemsStephen Warren
FAT and ext4 expect that the passed in block device descriptor not be NULL. This causes problems on sandbox, where get_device_and_partition() succeeds for the "host" device, yet passes back a NULL device descriptor. Add special handling for this situation, so that the generic filesystem commands operate as expected on sandbox. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-02-19fs: implement infrastructure for an 'exists' functionStephen Warren
This could be used in scripts such as: if test -e mmc 0:1 /boot/boot.scr; then load mmc 0:1 ${scriptaddr} /boot/boot.scr source ${scriptaddr} fi rather than: if load mmc 0:1 ${scriptaddr} /boot/boot.scr; then source ${scriptaddr} fi This prevents errors being printed by attempts to load non-existent files, which can be important when checking for a large set of files, such as /boot/boot.scr.uimg, /boot/boot.scr, /boot/extlinux.conf, /boot.scr.uimg, /boot.scr, /extlinux.conf. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19fs: fix generic save command implementationStephen Warren
Fix a few issues with the generic "save" shell command, and fs_write() function. 1) fstypes[].write wasn't filled in for some file-systems, and isn't checked when used, which could cause crashes/... if executing save on e.g. fat/ext filesystems. 2) fs_write() requires the length argument to be non-zero, since it needs to know exactly how many bytes to write. Adjust the comments and code according to this. 3) fs_write() wasn't prototyped in <fs.h> like other generic functions; other code should be able to call this directly rather than invoking the "save" shell command. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-01-20yaffs2: Remove block number check from summary verificationCharles Manning
The summary already has other verification. This one is not needed. The check caused summaries to be ignored if they were not on the numbered block. This caused problems when a summary was embedded in an image and the image is written to a flash with bad blocks. Signed-off-by: Charles Manning <cdhmanning@gmail.com>
2014-01-20ext4fs: fix "invalid extent block" errorIonut Nicu
For files where we actually have extent indexes following an extent header (ext_block->eh_depth != 0), the do/while loop from ext4fs_get_extent_block() does not select the proper extent index structure. For example, if we have: ext_block->eh_depth = 1 ext_block->eh_entries = 1 fileblock = 0 index[0].ei_block = 0 the do/while loop will exit with i set to 0 and the ext4fs_get_extent_block() function will return 0, even if there was a valid extent index structure following the header. Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com> Signed-off-by: Mathias Rulf <mathias.rulf@nsn.com>
2014-01-20ext4fs: use EXT2_BLOCK_SIZE instead of fs->blkszIonut Nicu
Using fs->blksz in ext4fs_get_extent_block() is not correct since fs->blksz is not initialized on the read path. Use EXT2_BLOCK_SIZE() instead which will produce the desired output. Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com> Signed-off-by: Mathias Rulf <mathias.rulf@nsn.com>
2014-01-20fs/ext4: fix calling put_ext4 with truncated offsetMa Haijun
Curently, we are using 32 bit multiplication to calculate the offset, so the result will always be 32 bit. This can silently cause file system corruption when performing a write operation on partition larger than 4 GiB. This patch address the issue by simply promoting the terms to 64 bit, and let compilers decide how to do the multiplication efficiently. Signed-off-by: Ma Haijun <mahaijuns@gmail.com>
2014-01-20fs/ext4: fix partition size get truncated in calculationMa Haijun
It may cause file system corruption when do a write operation. This issue only affects boards that use 32 bit lbaint_t. Signed-off-by: Ma Haijun <mahaijuns@gmail.com>
2013-12-13yaffs2: Use lldiv for 64bit divisionTom Rini
2013-12-13JFFS2: Correct jffs2_1pass_build_lists to use lldivTom Rini
Since part_info size became 64bit we need to use lldiv here. Signed-off-by: Tom Rini <trini@ti.com>
2013-11-17fs: descend into sub directories when it is necessaryMasahiro Yamada
2013-11-17Makefile: move fs/fat/ entry to drivers/MakefileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-11-08fs:fat: fix set file name functionPiotr Wilczek
Curently memcpy copies string without null terminating char because function strlen returns only number of characters excluding null terminating character. Replace memcpy with strcpy. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Tom Rini <trini@ti.com>
2013-10-31fs: move some file system to fs/MakefileMasahiro Yamada
This commit moves some subdirectories of fs from the toplevel Makefile to fs/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-10-31fs: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-15mtd: fix warnings due to 64-bit partition supportScott Wood
commit 39ac34473f3c96e77cbe03a49141771ed1639486 ("cmd_mtdparts: use 64 bits for flash size, partition size & offset") introduced warnings in a couple places due to printf formats or pointer casting. This patch fixes the warnings pointed out here: http://lists.denx.de/pipermail/u-boot/2013-October/164981.html Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Tom Rini <trini@ti.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-10-07Fix number base handling of "load" commandWolfgang Denk
As documented, almost all U-Boot commands expect numbers to be entered in hexadecimal input format. (Exception: for historical reasons, the "sleep" command takes its argument in decimal input format.) This rule was broken for the "load" command; for details please see especially commits 045fa1e "fs: add filesystem switch libary, implement ls and fsload commands" and 3f83c87 "fs: fix number base behaviour change in fatload/ext*load". In the result, the load command would always require an explicit "0x" prefix for regular (i. e. base 16 formatted) input. Change this to use the standard notation of base 16 input format. While strictly speaking this is a change of the user interface, we hope that it will not cause trouble. Stephen Warren comments (see [1]): I suppose you can change the behaviour if you want; anyone writing "0x..." for their values presumably won't be affected, and if people really do assume all values in U-Boot are in hex, presumably nobody currently relies upon using non-prefixed values with the generic load command, since it doesn't work like that right now. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/171172 Acked-by: Tom Rini <trini@ti.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-09-06fs: fat: don't call disk_write with zero sector numWu, Josh
In the set_cluster() function, it will convert the buffer size to sector numbers. Then call disk_write() to write by sector. For remaining buffer, the size is less than a sector, call disk_write() again to write them in one sector. But if the total buffer size is less then one sector, the original code will call disk_write() with zero sector number. It is unnecessary. So this patch fix this. Now it will not call disk_write() if total buffer size is less than one sector. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2013-08-19SPDX-License-Identifier: convert BSD-3-Clause filesWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini Don't remove some copyrights by accident] Signed-off-by: Tom Rini <trini@ti.com>
