path: root/fs
2018-03-09fs: ext4: Do not print mount fail message when not ext4 filesystemMarek Behún
Other filesystem drivers don't do this. Signed-off-by: Marek Behun <marek.behun@nic.cz>
2018-03-09yaffs2: iterator variable cannot be NULLHeinrich Schuchardt
The iterator of list_for_each() is never NULL. Identified with coccinelle. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-01-29fs: btrfs: Fix printf format character warningTom Rini
When printing a size_t value we need to use %zu for portability between 32bit and 64bit targets. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Behun <marek.behun@nic.cz>
2018-01-28fs: btrfs: Fix unaligned memory accessesAlberto Sánchez Molero
Loading files stored with lzo compression from a btrfs filesystem was producing unaligned memory accesses, which were causing a data abort and a reset on an Orange Pi Zero. The change in hash.c is not triggered by any error but follows the same pattern. Please confirm. Fixed according to doc/README.unaligned-memory-access.txt Signed-off-by: Alberto Sánchez Molero <alsamolero@gmail.com> Tested-by: Robert Nelson <robertcnelson@gmail.com>
2018-01-22fs: fat: Drop CONFIG_SUPPORT_VFATTuomas Tynkkynen
fat.h unconditionally defines CONFIG_SUPPORT_VFAT (and has done since 2003), so as a result VFAT support is always enabled regardless of whether a board config defines it or not. Drop this unnecessary option. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-22fs: FAT: Fix typo in FS_FAT_MAX_CLUSTSIZE descriptionTuomas Tynkkynen
2018-01-22fs: Migrate ext4 to KconfigTuomas Tynkkynen
Migrate the following symbols to Kconfig: CONFIG_FS_EXT4 CONFIG_EXT4_WRITE The definitions in config_fallbacks.h can now be expressed in Kconfig. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-19fs/fat: remove distractive message in file_fat_read_at()Heinrich Schuchardt
The message "reading %s\n" may be interesting when debugging but otherwise it is superfluous. Only output the message when debugging. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-19fs: remove distractive message in fs_read()Heinrich Schuchardt
The message "** %s shorter than offset + len **\n" may be interesting when debugging but it does not indicate an error. So we should not write it if we are not in debug mode. Fixes: 7a3e70cfd88c fs/fs.c: read up to EOF when len would read past EOF Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-10fat write: Fixed a problem with the case of file names when writing filesJean-Jacques Hiblot
commit 21a24c3bf35b ("fs/fat: fix case for FAT shortnames") made it possible that get_name() returns file names with some upper cases. find_directory_entry() must be updated to take this account, and use case-insensitive functions to compare file names. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-12-04mtd: nand: Rename nand.h into rawnand.hMasahiro Yamada
This header was renamed to rawnand.h in Linux. The following is the corresponding commit in Linux. commit d4092d76a4a4e57b65910899948a83cc8646c5a5 Author: Boris Brezillon <boris.brezillon@free-electrons.com> Date: Fri Aug 4 17:29:10 2017 +0200 mtd: nand: Rename nand.h into rawnand.h We are planning to share more code between different NAND based devices (SPI NAND, OneNAND and raw NANDs), but before doing that we need to move the existing include/linux/mtd/nand.h file into include/linux/mtd/rawnand.h so we can later create a nand.h header containing all common structure and function prototypes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-29fat: Use cache aligned buffers for fat_opendirNeil Armstrong
Before this patch one could receive following errors when executing "fatls" command on machine with cache enabled (ex i.MX6Q) : => fatls mmc 0:1 CACHE: Misaligned operation at range [4f59dfc8, 4f59e7c8] CACHE: Misaligned operation at range [4f59dfc8, 4f59e7c8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4f59dfc8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4f59e7c8 CACHE: Misaligned operation at range [4f59dfc8, 4f59e7c8] CACHE: Misaligned operation at range [4f59dfc8, 4f59e7c8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4f59dfc8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4f59e7c8 To alleviate this problem - the calloc()s have been replaced with malloc_cache_aligned() and memset(). After those changes the buffers are properly aligned (with both start address and size) to SoC cache line. Fixes: 09fa964bba80 ("fs/fat: Fix 'CACHE: Misaligned operation at range' warnings") Suggested-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-11-29fs: avoid possible NULL dereference in fs_devreadHeinrich Schuchardt
It is unwise to first dereference a variable and then to check if it was NULL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Marek Behun <marek.behun@nic.cz> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-27Merge git://www.denx.de/git/u-boot-imxTom Rini
2017-11-20yaffs2: rework yaffs_new_obj_idHeinrich Schuchardt
The iterator variable of list_for_each is never NULL. if (1 || A) is always true. Use break if entry found. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-11-20ubifs: no NULL check needed before freeHeinrich Schuchardt
kfree() calls free. free() checks if the parameter is NULL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-11-20ext4: recover from filesystem corruption when readingIan Ray
Some fixes when reading EXT files and directory entries were identified after using e2fuzz to corrupt an EXT3 filesystem: - Stop reading directory entries if the offset becomes badly aligned. - Avoid overwriting memory by clamping the length used to zero the buffer in ext4fs_read_file. Also sanity check blocksize. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-10-23mtd: remove MTDDEBUG() and CONFIG_MTD_DEBUGMasahiro Yamada
All users of this macro have been converted. Remove MTDDEBUG and related CONFIG options. ubifs_dbg_msg_key() is kept. It is silent unless DEBUG is defined. I am not touching scripts/config_whitelist.txt. The deprecated options will be dropped by the next resync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-16fs/jffs2/mini_inflate.c: use "static inline" instead of "inline"Vagrant Cascadian
This makes gcc no longer expect an out-of-line version of the functions being present elsewhere. This fixes a failure to build on several marvell targets with gcc-7 on Debian: https://bugs.debian.org/877963 Signed-off-by: Adrian Bunk <bunk@debian.org> Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2017-10-16jffs2: ECC corrected nand data is ignoredEngling, Uwe
Hello, I ran into a problem with the JFFS2 filesystem driver implemented in U-Boot. I've got a NAND device that has correctable ECC errors (corrected somewhere in mtd/nand/nand_base.c). The NAND driver tells the filesystem layer (jffs2_1pass.c) above that there occurred correctable ECC errors and returns with a "value > 0". The JFFS2 driver recognizes the corrected ECC errors as real error and skips this block because the only accepts a "return value == 0" as correct. This problem exists for over 8 years (I checked version 2010.09) so I'm a little bit worried that I interpreted something wrong or didn't get the whole context. Can someone confirm this bug (and the bugfix) in the u-boot jffs2 driver? There was a mail in 2012 that mentioned the same problem, but there was no patch: http://u-boot.10912.n7.nabble.com/JFFS2-seems-to-drop-nand-data-with-ECC-corrections-td142008.html Sometime after this discussion the return value of nand_read() changed from -EUCLEAN as correctable ECC error to a positive value with the count of ECC corrected errors. With kind reguards, Uwe Engling
2017-10-16fs: Set .opendir to fs_opendir_unsupported for btrfsMarek Behún
Otherwise fs_opendir will fault. Signed-off-by: Marek Behun <marek.behun@nic.cz>
2017-10-16fs: btrfs: Remove a foreign language noteMarek Behún
I accidentaly left a foreign language note in the code from development. Signed-off-by: Marek Behun <marek.behun@nic.cz>
2017-10-16fs: btrfs: Fix usage of uninitialized variablesMarek Behún
The variable res should be initialized to 0 in these functions, because if the searched key is not found, the variable is used uninitialized. Reported-by: Coverity (CID: 167335) Reported-by: Coverity (CID: 167336) Reported-by: Coverity (CID: 167337) Signed-off-by: Marek Behun <marek.behun@nic.cz>
2017-10-08fs/fat: Check malloc return values and fix memory leaksTuomas Tynkkynen
Check malloc() return values and properly unwind on errors so memory allocated for fat_itr structures get freed properly. Also fixes a leak of fsdata.fatbuf in fat_size(). Fixes: 2460098cffacd1 ("fs/fat: Reduce stack usage") Reported-by: Coverity (CID: 167225, 167233, 167234) Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-08fs/fat: Fix 'CACHE: Misaligned operation at range' warningsTuomas Tynkkynen
The 'block' field of fat_itr needs to be properly aligned for DMA and while it does have '__aligned(ARCH_DMA_MINALIGN)', the fat_itr structure itself needs to be properly aligned as well. While at it use malloc_cache_aligned() for the other aligned allocations in the file as well. Fixes: 2460098cffacd1 ("fs/fat: Reduce stack usage") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-06fs/ext4/ext4fs.c: Free dirnode in error path of ext4fs_lsTom Rini
As reported by Coverity, we did not free dirnode in the case of failure. Do so now. Reported-by: Coverity (CID: 131221) Cc: Stefan Brüns <stefan.bruens@rwth-aachen.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06fs/fat: Fix pathnames using '..' that lead to the root directoryTuomas Tynkkynen
If we end up back in the root directory via a '..' directory entry, set itr->is_root accordingly. Failing to do that gives spews like "Invalid FAT entry" and being unable to access directory entries located past the first cluster of the root directory. Fixes: 8eafae209c35 ("fat/fs: convert to directory iterators") Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-06fs/ext4: Fix group descriptor checksum calculationTuomas Tynkkynen
The current code doesn't compute the group descriptor checksum correctly for the filesystems that e2fsprogs 1.43.4 creates (they have 'Group descriptor size: 64' as reported by tune2fs). Extend the checksum calculation to be done as ext4_group_desc_csum() does in Linux. This fixes these errors in dmesg from running fs-test.sh and makes it succeed again: [1671902.620699] EXT4-fs (loop1): ext4_check_descriptors: Checksum for group 0 failed (35782!=10965) [1671902.620706] EXT4-fs (loop1): group descriptors corrupted! Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-03fs/btrfs: Fix warning in btrfs_check_super()Tom Rini
We specifically say that the last arg is u32, so use %lu. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-02fs: btrfs: Add U-Boot fs handlers.Marek Behún
Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/Kconfig create mode 100644 fs/btrfs/Makefile create mode 100644 fs/btrfs/btrfs.c create mode 100644 include/btrfs.h
2017-10-02fs: btrfs: Add single-device read-only BTRFS implementationMarek Behún
This adds the proper implementation for the BTRFS filesystem. The implementation currently supports only read-only mode and the filesystem can be only on a single device. Checksums of data chunks is unimplemented. Compression is implemented (ZLIB + LZO). Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/btrfs.h create mode 100644 fs/btrfs/chunk-map.c create mode 100644 fs/btrfs/compression.c create mode 100644 fs/btrfs/ctree.c create mode 100644 fs/btrfs/dev.c create mode 100644 fs/btrfs/dir-item.c create mode 100644 fs/btrfs/extent-io.c create mode 100644 fs/btrfs/hash.c create mode 100644 fs/btrfs/inode.c create mode 100644 fs/btrfs/root.c create mode 100644 fs/btrfs/subvolume.c create mode 100644 fs/btrfs/super.c
2017-10-02fs: btrfs: Add disk-to-cpu and cpu-to-disk conversion functionsMarek Behún
BTRFS on disk structures are stored in Little Endian. Add functions to convert this structures to cpu and to disk format. On Little Endian hosts, these functions do nothing. On Big Endian the CALL_MACRO_FROM_EACH from variadic-macro.h is used to define all the members for each structure on which cpu_to_le* or le*_to_cpu is to be called. Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/conv-funcs.h
2017-10-02fs: btrfs: Add btrfs_tree.h and ctree.h from Linux (and modified)Marek Behún
Add btrfs_tree.h and ctree.h from Linux which contains constants and structures for the BTRFS filesystem. Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/btrfs_tree.h create mode 100644 fs/btrfs/ctree.h
2017-10-02fs: Create a common fs_devread for ext4/reiserfs/zfsMarek Behún
The ext4, reiserfs and zfs filesystems all have their own implementation of the same function, *_devread. Generalize this function into fs_devread and put the code into fs/fs_internal.c. Signed-off-by: Marek Behun <marek.behun@nic.cz> [trini: Move fs/fs_internal.o hunk to the end of fs/Makefile as all cases need it] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-22fs/fat: Reduce stack usageTom Rini
We have limited stack in SPL builds. Drop itrblock and move to malloc/free of itr to move this off of the stack. As part of this fix a double-free issue in fat_size(). Signed-off-by: Tom Rini <trini@konsulko.com> --- Rework to use malloc/free as moving this to a global overflows some SH targets.
2017-09-15fs/fat: fix fatbuf leakRob Clark
A new fatbuf was allocated by get_fs_info() (called by fat_itr_root()), but not freed, resulting in eventually running out of memory. Spotted by running 'ls -r' in a large FAT filesystem from Shell.efi. fatbuf is mainly used to cache FAT entry lookups (get_fatent()).. possibly once fat_write.c it can move into the iterator to simplify this. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Łukasz Majewski <lukma@denx.de>
2017-09-15fs/fat: Clean up open-coded sector <-> cluster conversionsRob Clark
Use the clust_to_sect() helper that was introduced earlier, and add an inverse sect_to_clust(), plus update the various spots that open-coded this conversion previously. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fs/fat: fix case for FAT shortnamesRob Clark
Noticed when comparing our output to linux. There are some lcase bits which control whether filename and/or extension should be downcase'd. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fat/fs: move ls to generic implementationRob Clark
Add a generic implementation of 'ls' using opendir/readdir/closedir, and replace fat's custom implementation. Other filesystems should move to the generic implementation after they add opendir/readdir/closedir support. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fat/fs: remove a bunch of dead codeRob Clark
Spotted by chance, when trying to remove file_fat_ls(), I noticed there were some dead users of the API. Signed-off-by: Rob Clark <robdclark@gmail.com> Acked-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fs/fat: implement opendir/readdir/closedirRob Clark
Implement the readdir interface using the directory iterators. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fs: add fs_readdir()Rob Clark
Needed to support efi file protocol. The fallback.efi loader wants to be able to read the contents of the /EFI directory to find an OS to boot. Modelled after POSIX opendir()/readdir()/closedir(). Unlike the other fs APIs, this is stateful (ie. state is held in the FS_DIR "directory stream"), to avoid re-traversing of the directory structure at each step. The directory stream must be released with closedir() when it is no longer needed. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fat/fs: convert to directory iteratorsRob Clark
And drop a whole lot of ugly code! Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fs/fat: introduce new director iteratorsRob Clark
Untangle directory traversal into a simple iterator, to replace the existing multi-purpose do_fat_read_at() + get_dentfromdir(). Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de>
2017-09-15fs/fat: split out helper to init fsdataRob Clark
Want to re-use this in fat dirent iterator in next patch. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-26fs: ext4: Fix journal overrun issue reported by CoverityTom Rini
While &p_jdb[fs->blksz] is a valid expression (it points *one* char sized element past the end of the array, e.g. &p_jdb[fs->blksz + 1] is invalid (according to the C standard (C99/C11)). Changing this to tag = (struct ext3_journal_block_tag *)(p_jdb + ofs); Cc: Stefan Brüns <stefan.bruens@rwth-aachen.de> Suggested-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Reported-by: Coverity (CID: 165117, 165110) Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
2017-08-26fs: fat: fix fatwrite overflow calculationReno Farnesi
The overflow calculation was incorrect. Adding the start block of the partition is not needed because the sectors are already relative to the beginning of the partition. If you attempted to write a file smaller than cur_part_info.start blocks on a full partition the old calculation fails to catch the overflow. This would cause an infinite loop in the determine_fatent function. Old, incorrect calculation: ending sector of new file = start sector + file size (in sectors) last sector = partition start + total sectors on the partition Adding the partition start block number is not needed because sectors are already relative to the start of the partition. New calculation: ending sector of new file = start sector + file size (in sectors) last sector = total sectors on the partition Signed-off-by: Reno Farnesi <nfarnesi4@gmail.com>
2017-08-20fs/fat: Correct blk_dread() return value checkTom Rini
The function blk_dread will return -ENOSYS on failure or on success the number of blocks read, which must be the number asked to read (otherwise it failed somewhere). Correct this check. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
