path: root/doc
2006-10-28[PATCH] NAND: Partition name support added to NAND subsystemStefan Roese
chpart, nboot and NAND subsystem related commands now accept also partition name to specify offset. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Stefan Roese <sr@denx.de>
2006-10-24Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-10-24Add AVR32 architecture supportWolfgang Denk
Patch by Haavard Skinnemoen, 6 Sep 2006 16:23:02 +0200 This patch adds common infrastructure code for the Atmel AVR32 architecture. See doc/README.AVR32 for details. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-19Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-10-18Coding Style cleanup.Wolfgang Denk
2006-10-11Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-10-10Fix whitespace issues.Jon Loeliger
2006-10-10* Several improvements to the new NAND subsystem:Stefan Roese
- JFFS2 related commands implemented in mtd-utils style - Support for bad blocks - Bad block testing commands - NAND lock commands Please take a look at doc/README.nand for more details Patch by Guido Classen, 10 Oct 2006
2006-09-19Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
Conflicts: board/stxxtc/Makefile
2006-09-12Update NAND boot documentationStefan Roese
Patch by Stefan Roese, 12 Sep 2006
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-08-09Merge branch 'mpc85xx'Jon Loeliger
Conflicts: include/ft_build.h include/pci.h Resolved, though.
2006-08-09* Switched default PCI speed for 8540 ADS back to 33MHzMatthew McClintock
* Added comments and a printf to warn that PCI-X won't work at 33MHz Patch by Andy Fleming 17-Mar-2006 Signed-off-by: Andy Fleming <afleming@freescale.com>
2006-08-09Merge branch 'wd'Jon Loeliger
2006-07-31Change the space size of PEX IO in READMEHaiying Wang
2006-07-28PPC440 DDR setup: Set SDRAM0_CFG0[PMU]=0 for best performanceStefan Roese
AMCC suggested to set the PMU bit to 0 for best performace on the PPC440 DDR controller. Please see doc/README.440-DDR-performance for details. Patch by Stefan Roese, 28 Jul 2006
2006-07-27AMCC bamboo (440EP) U-Boot image reduced to 384kbyteStefan Roese
Please see doc/README.bamboo for details. Patch by Stefan Roese, 27 Jul 2006
2006-06-16Add support for CONFIG_SERIAL_MULTI on MPC5xxxWolfgang Denk
Patch by Martin Krause, 8 Jun 2006 This patch supports two serial consoles on boards with a MPC5xxx CPU. The console can be switched at runtime by setting stdin, stdout and stderr to the desired serial interface (serial0 or serial1). The PSCs to be used as console port are definded by CONFIG_PSC_CONSOLE and CONFIG_PSC_CONSOLE2. See README.serial_multi for details.
2006-05-26Add first draft of the MPC8641HPCN doc/README.Haiying Wang
Signed-off-by: Jon Loeliger <jdl@jdl.com>
2006-04-20Add MCF5282 support (without preloader)Heiko Schocher
relocate ichache_State to ram u-boot can run from internal flash Add EB+MCF-EV123 board support. Add m68k Boards to MAKEALL Patch from Jens Scharsig, 08 Aug 2005
2006-04-16Some code cleanupWolfgang Denk
2006-03-16Support for DDR with 32-data path. Addotional notes on injectingRafal Jaworowski
multiple-bit errors.
2006-03-16Add command for handling DDR ECC registers on MPC8349EE MDS board.Marian Balakowicz
2006-03-06Minor code cleanupWolfgang Denk
2006-03-06Merge the new NAND code (testing-NAND brach); see doc/README.nandWolfgang Denk
Rewrite of NAND code based on what is in 2.6.12 Linux kernel Patch by Ladislav Michl, 29 Jun 2005 [Merge with /home/tur/nand/u-boot]
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-10-13Add documentation for Open Firmware Flat Tree and usage.Wolfgang Denk
Patch by Pantelis Antoniou, 13 Oct 2005
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-09-25CleanupWolfgang Denk
2005-09-25Add ARM946E cpu and core module targets; remap memory to 0x00000000Wolfgang Denk
Patch by Peter Pearse, 2 Feb 2005
2005-08-15Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board.Wolfgang Denk
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005
2005-08-06Document switching between U-Boot and PlanetCore on RPXliteWolfgang Denk
by Sam Song, 24 Dec 2004
2005-08-06Add support for ep8248 boardWolfgang Denk
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup.
2005-08-02Merge with rsync://git-user@source.denx.net/git/u-boot.gitJon Loeliger
2005-08-01Major cleanup for AMCC PPC4xx eval boards.Stefan Roese
Patch by Stefan Roese, 01 Aug 2005
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
2005-07-25* Patch by Jon Loeliger, 2005-05-05Jon Loeliger
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2005-04-20Auto-size RAM on canmb board.wdenk
Cleanup.
2005-04-07* Patch by Stefan Roese, 06 Apr 2005:stroese
Updates for OCOTEA board: - Changed U-Boot size from 512kByte to 256kByte - Fixed flash driver to support boot from soldered user flash - Added README for switch from PIBS firmware to U-Boot
2005-04-03* Patch by Richard Klingler, 03 Apr 2005:wdenk
Add call to eth_halt() in net/net.c when called functions fail after eth_init() has been called. * Patch by Sam Song, 3 April 2005: - Update README.Netconsole - Update README
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-04-01* Patch by Masami Komiya, 30 Mar 2005:wdenk
add SNTP support and expand time server and time offset fields of DHCP support. See doc/README.SNTP * Patch by Steven Scholz, 13 Dec 2004: Fix bug in at91rm920 ethernet driver
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2005-01-09Patch by Florian Schlote, 08 Sep 2004:wdenk
Add support for SenTec-COBRA5272-board (Coldfire).
2004-12-10* Clean up CMC PU2 flash driverwdenk
* Update MAINTAINERS file * Fix bug in MPC823 LCD driver
