path: root/doc/README.SPL
2012-02-12doc: fix typosPeter Meerwald
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
2011-12-24sf: Add spi_boot() to allow booting from SPI flash in an SPLChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott Wood <scottwood@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-03arm, davinci: add support for new spl frameworkHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03spl: add option for adding post memory test to the SPL frameworkHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27SPL: Add DMA librarySimon Schwarz
Adding a DMA library to the SPL. It is used if CONFIG_SPL_DMA_SUPPORT is defined. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30spl: Add POWER library to new splSimon Schwarz
Adds power library to the new spl Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30spl: add NAND Library to new SPLSimon Schwarz
Adds NAND library to SPL. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-07-26spl: add initial support for a generic SPL frameworkDaniel Schwierzeck
Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
