path: root/disk
2018-08-20[iot] Support dual bootloader in SPLLuo Ji
Move the A/B slot check to SPL, the A/B slot switch workflow is just like what we have in libavb_ab. Test: A/B select works fine on imx8m. Change-Id: Ie3d827a9be0298b491bf2bc8d48833597fd70e90 Signed-off-by: Luo Ji <ji.luo@nxp.com>
2018-06-13MLK-18591-3 android: Add FSL android fastboot supportYe Li
Porting the FSL android fastboot features from imx u-boot v2017.03 to support all SoCs: imx6/imx7/imx7ulp/imx8/imx8m Signed-off-by: Ye Li <ye.li@nxp.com>
2018-02-08Move most CONFIG_HAVE_BLOCK_DEVICE to KconfigAdam Ford
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to Kconfig allows us to drastically shrink the logic in config_fallbacks.h Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert LIB_UUID to KconfigAdam Ford
config_fallback.h has some logic that checks a variety of options and selects LIB_UUID if it hasn't already been selected. This will all LIB_UUID in Kconfig and select this option for the list of options to allow us to remove the logic from fallbacks Signed-off-by: Adam Ford <aford173@gmail.com>
2018-02-07part: Allocate only one legacy_mbr bufferAlexey Brodkin
Commit ff98cb90514d ("part: extract MBR signature from partitions") blindly switched allocated by ALLOC_CACHE_ALIGN_BUFFER buffer type from "unsigned char" to "legacy_mbr" which caused allocation of size = (typeof(legacy_mbr) * dev_desc->blksize) instead of just space enough for "legacy_mbr" structure. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Rob Clark <robdclark@gmail.com> Cc: Peter Jones <pjones@redhat.com> Cc: Alexander Graf <agraf@suse.de> Cc: Tom Rini <trini@konsulko.com>
2017-12-19Merge git://git.denx.de/u-boot-sunxiTom Rini
2017-12-07part: efi: Add default number of partition entries for sunxiMaxime Ripard
The SPL must be located at 8kB (16 sectors) offset. That's right in the middle of the GPT, so we need to define a smaller amount of partitions to accomodate for that location. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-12-07part: efi: Add a Kconfig option for the number of partition entriesMaxime Ripard
On some SoCs, the SPL needs to be located right in the middle of the GPT partition entries. One way to work around that is to create partition entries for a smaller number of partitions to accomodate with where the SPL will be. Create a Kconfig option to allow to do that. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-11-29disk: efi: correct the allocation size for mbr header in stackPatrick Delaunay
use ALLOC_CACHE_ALIGN_BUFFER_PAD for mbr header allocation in stack to fix alloc issue in is_gpt_valid() this patch fix also issue for GPT partition handling with blocksize != 512 in set_protective_mbr() Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-11-06disk: part_dos: fix part_get_info_extended() functionShawn Guo
The check in part_get_info_extended() for a successful partition searching misses a condition for extended partition. In case of (ext_part_sector == 0), we should anyway mark the partition as found, even if it's an extended partition, i.e. (is_extended(pt->sys_ind) == 0). Otherwise, the extended partition (type 0x0f) will never be identified, and the following recursive call to part_get_info_extended() will get a wrong 'part_num' and 'which_part' parameter. In the end, all those partitions in extended table will not be identified. Let's add the missing OR condition of (ext_part_sector == 0) for is_extended() check to fix the problem. The issue is discovered by running fastboot flash to an extended partition on eMMC. $ fastboot flash mmcsda5 cache.img target reported max download size of 536870912 bytes sending 'mmcsda5' (18796 KB)... OKAY [ 2.144s] writing 'mmcsda5'... FAILED (remote: cannot find partition) finished. total time: 2.261s Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2017-11-06gpt: Use cache aligned buffers for gpt_h and gpt_eLukasz Majewski
Before this patch one could receive following errors when executing "gpt write" command on machine with cache enabled: display5 factory > gpt write mmc ${mmcdev} ${partitions} Writing GPT: CACHE: Misaligned operation at range [4ef8f7f0, 4ef8f9f0] CACHE: Misaligned operation at range [4ef8f9f8, 4ef939f8] CACHE: Misaligned operation at range [4ef8f9f8, 4ef939f8] CACHE: Misaligned operation at range [4ef8f7f0, 4ef8f9f0] success! To alleviate this problem - the calloc()s have been replaced with malloc_cache_aligned() and memset(). After those changes the buffers are properly aligned (with both start address and size) to SoC cache line. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-10-23disk: efi: correct the overlap check on GPT header and PTEPatrick Delaunay
the partition starting at 0x4400 is refused with overlap error: $> gpt write mmc 0 "name=test,start=0x4400,size=0" Writing GPT: Partition overlap error! even if the 0x4400 is the first available offset for LBA35 with default value: - MBR=LBA1 - GPT header=LBA2 - PTE= 32 LBAs (128 entry), 3 to 34 And the command to have one partition for all the disk failed also : $> gpt write mmc 0 "name=test,size=0" After the patch : $> gpt write mmc 0 "name=test,size=0" Writing GPT: success! $> part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x01ce9fde "test" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: b4b84b8a-04e3-4000-0036-aff5c9c495b1 And 0x22 = 34 LBA => offset = 0x4400 is accepted as expected Reviewed-by: Łukasz Majewski <lukma@denx.de> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-10-16iso: Reduce verbosity on test and info callsAlexander Graf
The test and info callbacks into the partition callback struct are used by the "part list" command on the command line. That command is used by the distro script. With verb=1 set, "part list" thus throws a lot of warnings about partitions it can't find when an upper layer searches for partitions. So let's reduce verbosity to bring it to the same level of noise as the other partition targets. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-16part_efi: In is_gpt_valid() check argument validity before allocationTom Rini
While this goes somewhat against normal coding style we should ensure that dev_desc is not NULL before we dereference it in allocation of legacy_mbr. Reported-by: Coverity (CID: 167292) Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06disk: Provide API to get partition by name for specific typeSam Protsenko
There is already existing function part_get_info_by_name(). But sometimes user is particularly interested in looking for only specific partition type. This patch implements such an API that provides partition searching by name for specified partition type. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-05disk: part_dos: Use the original allocation scheme for the SPL caseFabio Estevam
Since commit ff98cb90514d ("part: extract MBR signature from partitions") SPL boot on i.MX6 starts to fail: U-Boot SPL 2017.09-00221-g0d6ab32 (Oct 02 2017 - 15:13:19) Trying to boot from MMC1 (keep in loop) Use the original allocation scheme for the SPL case, so that MX6 boards can boot again. This is a temporary solution to avoid the boot regression. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Rob Clark <robdclark@gmail.com> Tested-by: Peter Robinson <pbrobinson@gmail.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-20part: extract MBR signature from partitionsPeter Jones
EFI client programs need the signature information from the partition table to determine the disk a partition is on, so we need to fill that in here. Signed-off-by: Peter Jones <pjones@redhat.com> [separated from efi_loader part, and fixed build-errors for non- CONFIG_EFI_PARTITION case] Signed-off-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-18EFI: find EFI system partition by legacy MBR partition typeAndre Przywara
The UEFI spec allows an EFI system partition (ESP, with the bootloader or kernel EFI apps on it) to reside on a disk using a "legacy" MBR partitioning scheme. But in contrast to actual legacy disks the ESP is not marked as "bootable" using bit 7 in byte 0 of the legacy partition entry, but is instead using partition *type* 0xef (in contrast to 0x0b or 0x0c for a normal FAT partition). The EFI spec isn't 100% clear on this, but it even seems to discourage the use of the bootable flag for ESPs. Also it seems that some EFI implementations (EDK2?) even seem to ignore partitions marked as bootable (probably since they believe they contain legacy boot code). The Debian installer [1] (*not* mini.iso), for instance, contains such an MBR, where none of the two partitions are marked bootable, but the ESP has clearly type 0xef. Now U-Boot cannot find the ESP on such a disk (USB flash drive) and fails to load the EFI grub and thus the installer. Since it all boils down to the distro bootcmds eventually calling "part list -bootable" to find potential boot partitions, it seems logical to just add this "partition type is 0xef" condition to the is_bootable() implementation. This allows the bog standard arm64 Debian-testing installer to boot from an USB pen drive on Allwinner A64 boards (Pine64, BananaPi-M64). (Ubuntu and other distribution installers don't have a legacy MBR, so U-Boot falls back to El Torito there). [1] https://cdimage.debian.org/cdimage/daily-builds/daily/arch-latest/arm64/iso-cd/ Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-15fs: add fs_readdir()Rob Clark
Needed to support efi file protocol. The fallback.efi loader wants to be able to read the contents of the /EFI directory to find an OS to boot. Modelled after POSIX opendir()/readdir()/closedir(). Unlike the other fs APIs, this is stateful (ie. state is held in the FS_DIR "directory stream"), to avoid re-traversing of the directory structure at each step. The directory stream must be released with closedir() when it is no longer needed. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-07part: mac: Suppress the error message after reading ddbBin Meng
Change to use 'debug' to output the error message if it fails to read the driver descriptor block. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-03disk: part: fix typoHeinrich Schuchardt
%s/Desriptor/Descriptor/g Fix lines over 80 characters with said typo. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-09-03part: efi: Disable overlap checkMaxime Ripard
The current code checks that no partitions overlap with the GPT partition table using the offset of the first LBA usable for that partition. This works fine, unless you have a partition entry that is further away than it usually is and you want to create partitions in the gap between the GPT header and the GPT partition entries, for example to reflash a bootloader that needs to be set there. Rework the test to something a bit smarter that checks whether a partition would overlap with either the GPT header or the partition entries, no matter where it is on the disk. Partitions that do not have a start LBA specified will still start at the first LBA usable set in the GPT header, to avoid weird behaviours. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03part: efi: make gpt_fill_pte take the device descriptorMaxime Ripard
The gpt_fill_pte will need to access the device block size. Let's pass the device descriptor as an argument. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03part: efi: rework the partition start and size in gpt_fill_pteMaxime Ripard
The start variable is only used inside a loop, and is never affected inside it, so it's a purely local variable. In the same way the partition size is accessed several times, so we can store it in a variable. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03part: efi: Fix offsetMaxime Ripard
Both the config option and the DT options specify the offset to set the GPT at in bytes, yet the code treats those values as block numbers. Fix that. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-26disk: part: align buffer so it can be used with DMA enabled driversStefan Agner
When using ISO partitions with a DMA enabled block device driver reading the ISO partition leads to unaligned DMA operations: CACHE: Misaligned operation at range [bffb7da8, bffb85a8] Align the buffer to make sure we pass a buffer which works for DMA operations. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13dm: blk: part: Add UCLASS_NVME and IF_TYPE_NVMEZhikang Zhang
This adds a new uclass id and block interface type for NVMe. Signed-off-by: Zhikang Zhang <zhikang.zhang@nxp.com> Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jon Nettleton <jon@solid-run.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-04GPT: add accessor function for disk GUIDAlison Chaiken
In order to read the GPT, modify the partition name strings, and then write out a new GPT, the disk GUID is needed. While there is an existing accessor for the partition UUIDs, there is none yet for the disk GUID. Changes since v6: none. Signed-off-by: Alison Chaiken <alison@peloton-tech.com>
2017-08-04partitions: increase MAX_SEARCH_PARTITIONS and move to part.hAlison Chaiken
Move MAX_SEARCH_PARTITIONS to part.h so that functions in cmd directory can find it. At the same time, increase the value to 64 since some operating systems use many, and the resources consumed by a larger value are minimal. Changes since v6: none. Signed-off-by: Alison Chaiken <alison@peloton-tech.com>
2017-08-04EFI: replace number with UUID_STR_LEN macroAlison Chaiken
2017-05-11disk: Return the partition number in part_get_info_by_name()Alex Deymo
Similar to what blk_get_device_part_str() does, this patch makes part_get_info_by_name() return the partition number in case of a match. This is useful when the partition number is needed and not just the descriptor. Signed-off-by: Alex Deymo <deymo@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-05SPARC: RemoveTom Rini
The SPARC architecture is currently unmaintained, remove. Cc: Francois Retief <fgretief@spaceteq.co.za> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-20part_efi: support padding between the GPT header and partition entriesPhilipp Tomsich
Some architectures require their SPL loader at a fixed address within the first 16KB of the disk. To avoid an overlap with the partition entries of the EFI partition table, the first safe offset (in bytes, from the start of the device) for the entries can be set through CONFIG_EFI_PARTITION_ENTRIES_OFF (via Kconfig) When formatting a device with an EFI partition table, we may need to leave a gap between the GPT header (always in LBA 1) and the partition entries. The GPT header already contains a field to specify the on-disk location, which has so far always been set to LBA 2. With this change, a configurable offset will be translated into a LBA address indicating where to put the entries. Now also allows an override via device-tree using a config-node (see doc/device-tree-bindings/config.txt for documentation). Tested (exporting an internal MMC formatted with this) against Linux, MacOS X and Windows. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: __maybe_unused on config_offset to avoid warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-17gpt: Fix uuid string formatVincent Tinelli
Change GPT UUID string format from UUID to GUID per specification. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-17SPL: add support to boot from a partition typeDalon Westergreen
the socfpga bootrom supports mmc booting from either a raw image starting at 0x0, or from a partition of type 0xa2. This patch adds support for locating the boot image in the first type 0xa2 partition found. Assigned a partition number of -1 will cause a search for a partition of type CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE and use it to find the u-boot image Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
2017-02-08cmd: gpt: backup boot code before writing MBRVincent Tinelli
On some cases the first 440 bytes of MBR are used to keep an additional information for ROM boot loader. 'gpt write' command doesn't preserve that area and makes boot code gone. Preserve boot code area when run 'gpt write' command. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Signed-off-by: Brennan Ashton <brn@deako.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28disk: convert CONFIG_PARTITION_TYPE_GUID to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_AMIGA_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_PARTITIONS to KconfigPatrick Delaunay
2016-12-27disk: Fixed capacity messageJean-Jacques Hiblot
With capacities getting bigger, we can see see messages with negative numbers like "Capacity: 1907729.0 MB = 1863.0 GB (-387938128 x 512)". Here the printed LBA is -387938128 when it should have been 3907029168. To fix this, use the right format when displaying the unsigned integers. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reported-by: Yan Liu <yan-liu@ti.com>
2016-10-01disk: part: refactor generic name creation for DOS and ISOPetr Kulhavy
In both DOS and ISO partition tables the same code to create partition name like "hda1" was repeated. Code moved to into a new function part_set_generic_name() in part.c and optimized. Added recognition of MMC and SD types, name is like "mmcsda1". Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01fastboot: add support for writing MBRPetr Kulhavy
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME) to write MBR partition table. Partitions are now searched using the generic function which finds any partiiton by name. For MBR the partition names hda1, sda1, etc. are used. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01disk: part: implement generic function part_get_info_by_name()Petr Kulhavy
So far partition search by name has been supported only on the EFI partition table. This patch extends the search to all partition tables. Rename part_get_info_efi_by_name() to part_get_info_by_name(), move it from part_efi.c into part.c and make it a generic function which traverses all part drivers and searches all partitions (in the order given by the linked list). For this a new variable struct part_driver.max_entries is added, which limits the number of partitions searched. For EFI this was GPT_ENTRY_NUMBERS. Similarly the limit is defined for DOS, ISO, MAC and AMIGA partition tables. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com>
