path: root/disk
2012-10-22disk: Address cast and format errorsTaylor Hutt
This change addresses a few printf-formatting errors, and a typecast error. Signed-off-by: Taylor Hutt <thutt@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22disk: Make the disk partition code work with no specific partition typesGabe Black
Currently, if the disk partition code is compiled with all of the parition types compiled out, it hits an #error which stops the build. This change adjusts that file so that those functions will fall through to their defaults in those cases instead of breaking the build. These functions are needed because other code calls them, and that code is needed because other config options are overly broad and bring in support we don't need along with support we do. Also reduce repetition of the 6-term #ifdef throughout the file. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-19disk: initialize name/part fields when returning a whole diskStephen Warren
When get_device_and_partition() finds a disk without a partition table, under some conditions, it "returns" a disk_partition_t that describes the entire raw disk. Make sure to initialize all fields in the partition descriptor in that case. The value chosen for name is just some arbitrary descriptive string. The value chosen for info matches the check at the end of get_device_and_partition(). However, it's probably not that important; it's not obvious that the value is really used. Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17disk: part_dos: print partition UUID in partition listStephen Warren
This information may be useful to compare against command "part uuid", or if you want to manually paste the information into the kernel command-line. Signed-off-by: Stephen Warren <swarren@nvidia.com> [trini: print_one_part / print_part_dos output strings didn't quite match before the changes] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17disk: part_dos: checkpatch cleanupsStephen Warren
Minor cleanups required so later patches don't trigger checkpatch. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-17disk: part_efi: set bootable flag in partition objectsStephen Warren
A partition is considered bootable if it either has the "legacy BIOS bootable" flag set, or if the partition type UUID matches the standard "system" type. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-17disk: part_efi: print raw partition attributesStephen Warren
When printing the EFI partition table, print the raw attributes. Convert struct gpt_entry_attributes to a union to allow raw access. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-17disk: part_efi: add new partition attribute definitionsStephen Warren
Add no_block_io_protocol and legacy_bios_bootable attribute definitions. These are sourced from UEFI Spec 2.3, page 105, table 19. Credits to the libparted source for the specification pointer. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-17disk: part_efi: print partition UUIDsStephen Warren
When printing the partition table, print the partition type UUID and the individual partition UUID. Do this unconditionally, since partition UUIDs are useful. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-17disk: part_efi: re-order partition list printf, change caseStephen Warren
The partition name is a long variable-length string. Move it last on the line to ensure consistent layout and that the entries align with the "header" line. Also, surround it in quotes, so if it's empty, it's obvious that something is still being printed. Also, change the case of the LBA numbers; lower-case looks nicer in my opinion, and will be more consistent with the UUID printing that is added later in this series. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-17disk: part_efi: remove indent level from loopStephen Warren
Simplify the partition printing loop in print_part_efi() to bail out early when the first invalid partition is found, rather than indenting the whole body of the loop. This simplifies later patches. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-17disk: get_device_and_partition() return value fixesStephen Warren
When no valid partitions are found, guarantee that we return -1. This most likely already happens, since the most recent get_partition_info() will have returned an error. However, it's best to be explicit. Remove an unnecessary assignment of ret=0 in the success case; this value is over-written with the processed partition ID later. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-08disk: part_dos: don't claim whole-disk FAT filesystemsStephen Warren
Logically, a disk that contains a raw FAT filesystem does not in fact have a partition table. However, test_part_dos() was claiming that such disks did in fact have a DOS-style partition table. This caused get_device_and_partition() not to return a whole-disk disk_partition_t, since part_type != PART_TYPE_UNKNOWN. part_dos.c's print_partition_extended() detected the raw FAT filesystem condition and printed a fake partition table that encompassed the whole disk. However, part_dos.c's get_partition_info_extended() did not return any valid partitions in this case. This combination caused get_device_and_partition() not to find any valid partitions, and hence to return an error. Fix test_part_dos() not to claim that raw FAT filesystems are DOS partition tables. In turn, this causes get_device_and_partition() to return a whole-disk disk_partition_t, and hence the following commands work: fatls mmc 0 / fatls mmc 0:auto / An alternative would be to modify print_partition_extended() to detect raw FAT filesystems, just like print_partition_extended() does, and to return a fake partition in this case. However, this seems logically incorrect, and also duplicates code, since get_device_and_partition() falls back to returning a whole-disk partition when there is no partition table on the device. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-28disk: allow - or empty string to fall back to $bootdeviceStephen Warren
Commit 10a37fd "disk: get_device_and_partition() "auto" partition" prevented the use of "-" on the command-line to request fallback to the $bootdevice environment variable instead. This patch allows that, or an empty string "" to be used. Tested: setenv bootfile /boot/zImage setenv bootdevice 0:1 ext2load mmc 0:1 ext2load mmc - ext2load mmc "" Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk: part_msdos: parse and store partition UUIDStephen Warren
The MSDOS/MBR partition table includes a 32-bit unique ID, often referred to as the NT disk signature. When combined with a partition number within the table, this can form a unique ID similar in concept to EFI/GPT's partition UUID. This patch generates UUIDs in the format 0002dd75-01, which matches the format expected by the Linux kernel. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk: part_efi: parse and store partition UUIDStephen Warren
Each EFI partition table entry contains a UUID. Extend U-Boot's struct disk_partition to be able to store this information, and modify get_partition_info_efi() to fill it in. The implementation of uuid_string() was derived from the Linux kernel, tag v3.6-rc4 file lib/vsprintf.c function uuid_string(). Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk: part_efi: range-check partition numberStephen Warren
Enhance get_partition_info_efi() to range-check the partition number. This prevents invalid partitions being accessed, and prevents access beyond the end of the gpt_pte[] array. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk: get_device_and_partition() "auto" partition and cleanupStephen Warren
Rework get_device_and_partition() to: a) Implement a new partition ID of "auto", which requests that U-Boot search for the first "bootable" partition, and fall back to the first valid partition if none is found. This way, users don't need to specify an explicit partition in their commands. b) Make use of get_device(). c) Add parameter to indicate whether returning a whole device is acceptable, or whether a partition is mandatory. d) Make error-checking of the user's device-/partition-specification more complete. In particular, if strtoul() doesn't convert all characters, it's an error rather than just ignored. The resultant device/partition returned by the function will be as follows, based on whether the disk has a partition table (ptable) or not, and whether the calling command allows the whole device to be returned or not. (D and P are integers, P >= 1) D D: No ptable: !allow_whole_dev: error allow_whole_dev: device D ptable: device D partition 1 D:0 !allow_whole_dev: error allow_whole_dev: device D D:P No ptable: error ptable: device D partition P D:auto No ptable: !allow_whole_dev: error allow_whole_dev: device D ptable: first partition in device D with bootable flag set. If none, first valid paratition in device D. Note: In order to review this patch, it's probably easiest to simply look at the file contents post-application, rather than reading the patch itself. Signed-off-by: Rob Herring <rob.herring@calxeda.com> [swarren: Rob implemented scanning for bootable partitions. I fixed a couple of issues there, switched the syntax to ":auto", added the error-checking rework, and ":0" syntax for the whole device] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk: introduce get_device()Stephen Warren
This patch introduces function get_device(). This looks up a block_dev_desc_t from an interface name (e.g. mmc) and device number (e.g. 0). This function is essentially the non-partition-specific prefix of get_device_and_partition(). Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk/part: introduce get_device_and_partitionRob Herring
All block device related commands (scsiboot, fatload, ext2ls, etc.) have simliar duplicated device and partition parsing and selection code. This adds a common function to replace various implementations. The new function has an enhancement over current versions. If no device or partition is specified on the command line, the bootdevice env variable will be used (scsiboot does this). Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-25disk/part: check bootable flag for DOS partitionsRob Herring
Determine which partitions are bootable/active. In the partition listing, print "Boot" for partitions with the bootable/active flag set. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-25disk: make get_partition_info() always available to disk.cStephen Warren
Now that get_device_and_partition() always calls get_partition_info() when disk.c is compiled, we must always compile the function, rather than ifdef it away. The implementation must be conditional based on CONFIG_CMD_* etc., since that's what e.g. part_dos.c uses to ifdef out get_partition_info_dos(); CONFIG_DOS_PARTITION can be enabled even without those commands being enabled. Technically, this change is required before Rob's "disk/part: introduce get_device_and_partition" patch. However, at least when the compiler optimizer is turned on, it isn't required before then in practice, since get_device_and_partition() calls get_dev(), which is stubbed out in disk.c under exactly the same conditions that get_partition_info() is not compiled, and hence the compiler never generates code for the call to the missing function. However, in my later patch "disk: get_device_and_partition() "auto" partition and cleanup", the optimizer doesn't succeed at this, and may attempt to reference the undefined function. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-02part_mac: dcache: allocate cacheline-aligned buffersBenoît Thébaudeau
This patch forces the correct alignment for DMA operations of buffers used by part_mac.c. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de>
2012-06-21Block: Remove MG DISK supportMarek Vasut
This driver is unused and obsolete. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: unsik Kim <donari75@gmail.com>
2012-04-30part_dos: align disk buffers on cache line to enable DMA and cacheEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-27disk/part.c: Fix device enumeration through APITim Kientzle
The patch below fixes device enumeration through the U-Boot API. Device enumeration crashes when the system in question doesn't have any RAM mapped to address zero (I discovered this on a BeagleBone board), since the enumeration calls get_dev with a NULL ifname sometimes which then gets passed down to strncmp(). This fix simply ensures that get_dev returns NULL when invoked with a NULL ifname. Signed-off-by: Tim Kientzle <kientzle@freebsd.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-06part_efi: Fix compile errorsSanjeev Premi
Fix errors noticed after enabling CONFIG_EFI_PARTITION for the OMAP3 EVM board: part_efi.c: In function 'print_part_efi': part_efi.c:133:5: warning: passing argument 3 of 'is_gpt_valid' from incompatible pointer type part_efi.c:95:12: note: expected 'struct gpt_header *' but arg ument is of type 'struct gpt_header **' part_efi.c: In function 'get_partition_info_efi': part_efi.c:173:4: warning: passing argument 3 of 'is_gpt_valid ' from incompatible pointer type part_efi.c:95:12: note: expected 'struct gpt_header *' but arg ument is of type 'struct gpt_header **' part_efi.c: In function 'alloc_read_gpt_entries': part_efi.c:384:18: error: 'CONFIG_SYS_CACHELINE_SIZE' undeclare d (first use in this function) Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Anton staaf <robotboy@chromium.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-12-05disk: part_efi: fix regression due to incorrect buffer usageStephen Warren
Commit deb5ca80275e8cfa74d5680b41204e08a095eca5 "disk: part_efi: fix **pgpt_pte == NULL" modified the code to pass "&gpt_head" to is_gpt_valid() rather than the previous "gpt_head". However, gpt_head is a pointer to the buffer, not the actual buffer, since it was allocated using ALLOC_CACHE_ALIGN_BUFFER. This caused is_gpt_valid() to read the disk block onto the stack rather than into the buffer, causing the code to fail. This change reverts that portion of the commit mentioned above. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Doug Anderson <dianders@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Anton Staaf <robotboy@chromium.org>
2011-10-27disk: part_efi: fix **pgpt_pte == NULLDoug Anderson
Code was setting **pgpt_pte == NULL, which meant that the pointer to the gpt_pte would be stored at RAM address 00000000. This 'worked' on T20 (SDRAM starts @ 0x00000000), but hung gpt/EFI access on T30 (SDRAM starts @ 0x80000000). Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Doug Anderson <dianders@chromium.org>
2011-10-27cosmetic: Replace __FUNCTION__ with __func__ in part_efi.cDoug Anderson
This makes checkpatch happy. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25part_efi: dcache: allocate cacheline aligned buffersAnton staaf
Currently part_efi.c allocates buffers for the gpt_header, the legacy_mbr, and the pte (partition table entry) that may be incorrectly aligned for DMA operations. This patch uses ALLOC_CACHE_ALIGN_BUFFER for the stack allocated buffers and memalign to replace the malloc of the pte. Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-06part: show efi partition name when print out partition infoLei Wen
Previous output: Marvell>> mmc part Partition Map for MMC device 1 -- Partition Type: EFI Part Start LBA End LBA gpt1 0x8C00 0xCBFF gpt2 0xCC00 0x57BFF gpt3 0x57C00 0xA2BFF gpt4 0xA2C00 0xECBFDE With the patch, the output becomes: Marvell>> mmc part Partition Map for MMC device 1 -- Partition Type: EFI Part Name Start LBA End LBA 1 ramdisk 0x00008C00 0x0000CBFF 2 system 0x0000CC00 0x00057BFF 3 userdata 0x00057C00 0x000A2BFF 4 remaining 0x000A2C00 0x00ECBFDE Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-07-27part_dos: fix crash with big sector sizeSergei Shtylyov
Apple iPod nanos have sector sizes of 2 or 4 KiB, which crashes U-Boot when it tries to read the MBR into 512-byte buffer situated on stack. Instead use the variable length arrays to be safe with any large sector size. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
2011-07-26disk/part.c: Make features optionalMatthew McClintock
If we don't want to build support for any partition types we can now add #undef CONFIG_PARTITIONS in a board config file to keep this from being compiled in. Otherwise boards assume this is compiled in by default Signed-off-by: Matthew McClintock <msm@freescale.com>
2011-04-12disk/part.c: fix potential stack overflow bugLei Wen
If the param pass to get_dev is not the one defined in the block_drvr, it could make uboot becomes unstable, for it would continue run after search complete the block_drvr table. Signed-off-by: Lei Wen <leiwen@marvell.com>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-19disk/part.c: fix relocation fixupHeiko Schocher
Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-18mmc: print out partition tableLei Wen
2010-08-10disk/part.c: 'usb storage' avoiding overflow when output capacitySergei Trofimovich
Before: Marvell>> usb storage Device 0: Vendor: StoreJet Rev: Prod: Transcend Type: Hard Disk Capacity: 28759.9 MB = 28.0 GB (488397168 x 512) After: Marvell>> usb storage Device 0: Vendor: StoreJet Rev: Prod: Transcend Type: Hard Disk Capacity: 238475.1 MB = 232.8 GB (488397168 x 512) Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
2010-07-24FAT32: fix support for superfloppy-format (PBR)Wolfgang Denk
"Superfloppy" format (in U-Boot called PBR) did not work for FAT32 as the file system type string is at a different location. Add support for FAT32. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-18part_dos: check status flags of partitionsDaniel Mack
Only read partitions which have 0x00 or 0x80 set in their status field. All others are invalid. Signed-off-by: Daniel Mack <daniel@caiaq.de>
2009-10-03Conditionally perform common relocation fixupsPeter Tyser
Add #ifdefs where necessary to not perform relocation fixups. This allows boards/architectures which support relocation to trim a decent chunk of code. Note that this patch doesn't add #ifdefs to architecture-specific code which does not support relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-09Partition support: remove newline from partition nameWolfgang Denk
Remove bogus newline character that got added to the .name field of the disk_partition_t structure. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-05-15IDE: bail out of dev_print() for unknown device typesWolfgang Denk
Commit 574b319512 introduced a subtle bug by mixing a list of tests for "dev_desc->type" and "dev_desc->if_type" into one switch(), which then mostly did not work because "dev_desc->type" cannot take any "IF_*" type values. A later fix in commit 8ec6e332ea changed the switch() into testing "dev_desc->if_type", but at this point the initial test for unknown device types was completely lost, which resulted in output like that for IDE ports without device attached: Device 1: Model: Firm: Ser#: Type: # 1F # Capacity: not available This patch re-introduces the missing test for unknown device types. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Detlev Zundel <dzu@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2009-03-20vsprintf: pull updates from Linux kernelMike Frysinger
This brings in support for the %p modifier which allows us to easily print out things like ip addresses, mac addresses, and pointers. It also converts the rarely used 'q' length modifier to the common 'L' modifier when dealing with quad types. While this new code is a bit larger (~1k .text), most of it should be made up by converting the existing ip/mac address code to use format modifiers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-18disk: convert part_* files to COBJ-$(CONFIG_XXX) styleMike Frysinger
Move the CONFIG_XXX out of the part_XXX.c file and into Makefile to avoid pointless compiles. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-27part_efi: Fix partition size calculation due to inclusive ending LBA.Richard Retanubun
The ending LBA is inclusive. Hence, the partition size should be ((ending-LBA + 1) - starting-LBA) to get the proper partition size. This is confirmed against the results from the parted tool. (e.g. use parted /dev/sda -s unit S print) and observe the size. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
