Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
(cherry picked from commit 4c63a601b90db131e92d3f6f6da6a4bc2b287df1)
Use unified values for USB Product/Vendor numbers
when the config block is missing
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit 8fd734c49cc3dd0c5bc57b4922120483688e3099)
While this seems to work on the eMMC SKU, unfortunately, this no longer boots on the raw NAND one.
This reverts commit edb411e2e6aeb7214641a53d78d1dc4a943290a0.
configs/colibri_imx7_defconfig
This got dropped by a global 'make savedefconfig' resync as required patches
are still in flight.
Use CONFIG_DM_VIDEO=y by default for Colibri iMX6ULL.
Enable DM_VIDEO support for Colibri iMX7 NAND version.
We never really added a sensible DFU configuration for platforms
based on eMMC. Most of the things one might want to do can also be done
with UMS or fastboot, so drop the DFU configuration.
Enable DM_VIDEO for Colibri VF.
Added default environment for hdp loading.
Added hdp loading as default for iMX8QM MEK board.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
(cherry picked from downstream commit 432e5b4347841095c3b5a8a0d106f35deadd006e)
(cherry picked from downstream commit cb78a32fa8eb8c37932be003ebe4fa1f8c46c1d5)
Add thermal dts node
Enable thermal in defconfig
Signed-off-by: Peng Fan <peng.fan@nxp.com>
- fix complation error for CONFIG_USB
- update RPi3 DTBs to v5.1-rc6 state
- add defconfig for RPi3 B+
- Fix BCM2835_MBOX_TAG_TEST_PIXEL_ORDER define
After the transition to DM, only the mx6dl/solo wandboard
is supported.
Add FIT image support so that all the wandboard variants
can be supported, like it was prior to the DM conversion.
Successfully booted Linux on mx6q/solo/qp wandboards.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
We need to update TEXT BASE for TPL/SPL/U-Boot;
SPL no need relocate STACK after enable TPL, so remove it;
Don't enable pinctrl names so that SPL can get pinctrl dts;
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
There is a regression seen on Poplar platform, which doesn't even show
a U-Boot version banner on booting. It turns out that due to landing
of commit 3a7c45f6a772 ("simple-bus: add DM_FLAG_PRE_RELOC flag to
simple-bus driver"), we need to increase SYS_MALLOC_F_LEN from its
default size 0x400, as pre-relocation requires more memory there. Let's
increase SYS_MALLOC_F_LEN to 0x4000 to fix the regression.
Thanks to Andreas Färber <afaerber@suse.de> for reporting, and Bin Meng
<bmeng.cn@gmail.com> for trouble shooting.
Reported-by: Andreas Färber <afaerber@suse.de>
Tested-by: Andreas Färber <afaerber@suse.de>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2019.07
- menlo board
- allow SDB on Sabre
- HAB for mx6sl
- apalis board
Enable DM Video support on iMX53 M53Menlo and fix minor details
to restore previous behavior of the system.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Enable DM block and DM MMC and DM USB support on iMX53 M53Menlo .
Convert board code to match the DM support. This also enables DM
pincontrol to configure the SDHI pins.
Enable DM GPIO support on iMX53 M53Menlo and fix up board code where
applicable. Enable MALLOC_F to let the GPIO controllers bind early on.
Import iMX53 M53Menlo device tree from Linux next-20190607 3f310e51ceb1 .
Enable DT control in full U-Boot . Add U-Boot extras into separate DTSi,
the GPIO controllers need to be inited early, otherwise m53_set_clock()
won't be able to detect the correct CPU clock frequency by reading the
GPIO.
Enable SPL_BOARD_INIT globally to rk3399, this would
help to print the SPL banner during bootup.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Right now puma rk3399 board need to copy bl31-rk3399.bin and
rk3399m0.bin into u-boot source directory to make use of building
u-boot.itb.
So, add environment variable
- BL31 for bl31.bin (instead of bl31-rk3399.bin to compatible with other
platform BL31 env)
- PMUM0 for rk3399m0.bin
If the builds are not exporting BL31, PMUM0 env, the fit_spl_atf.sh will
notify with warning about which document to refer for more information
like this:
WARNING: BL31 file bl31.bin NOT found, resulting binary is non-functional
Please read Building section in doc/README.rockchip
WARNING: PMUM0 file rk3399m0.bin NOT found, resulting binary is non-functional
The ROCK64 is a credit card size SBC based on Rockchip RK3328
Quad-Core ARM Cortex A53.
This series allow building u-boot SPL and u-boot.itb for Rock64
board. The proprietary TPL is stil required for deploy:
./tools/mkimage -n rk3328 -T rksd \
-d ./rkbin/bin/rk33/rk3328_ddr_333MHz_v1.16.bin idbloader.img
cat ./spl/u-boot-spl.bin >> idbloader.img
dd if=idbloader.img of=/dev/sdcard seek=64 conv=notrunc
dd if=u-boot.itb of=/dev/sdcard seek=16384 conv=notrunc
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Enable SPL support and some related option in Kconfig.
[cherry picked from https://github.com/rockchip-linux/u-boot/commit/430b01462bf3f24aaf7920ae2587a6943c39ab5d with minor modifications]
- boot failure fix for Intel edison
- tangier wdt conversion to driver model
Convert legacy driver to use watchdog class.
This board does not require watchdog support.
Signed-off-by: Felix Brack <fb@ltec.ch>
Extra "not DM" controllers support is disabled.
u-boot BSP still good enough to upgrade and run images.
Signed-off-by: Oleksandr Zhadan <oleks@arcturusnetworks.com>
Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
- PCIe driver change to support DM model
- T2080QDS migrated to use PCIe DM model
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- Update STM32MP entry in MAINTAINERS
- Handle correctly binding for g-tx-fifo-size for USB DWC2 driver
- Fix trusted STM32MP1 defconfig with correct ethernet driver
Enable the DM PCIe driver in T2080QDS defconfig.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
- LS1046AFRWY support
- USB errata fix and secure boot defconfig support for LS1028A
- Enabled SDHC and SATA for LX2160
- LS1046A serdes fixes
- other minor fixes
LS1046AFRWY board supports LS1046A family SoCs. This patch
add base support for this board.
Board support's 4GB ddr memory, i2c, micro-click module,microSD card,
serial console,qspi nor flash,ifc nand flash,qsgmii network interface,
usb 3.0 and serdes interface to support two x1gen3 pcie interface.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
LS1028A includes an integrated PCI bus with 11 PCI functions residing on
bus 0. ECAM plus the device register space takes up 256MB of address
space.
Signed-off-by: Alex Marginean <alexm.osslist@gmail.com>
With this setting enabled, the on-board QSPI cannot be
properly flashed. There are no error messages, but the simple
write / read / compare tests fail.
This is already disabled in the qspi and tfa defconfigs for the
LS1046ARDB platform.
Signed-off-by: Maciej Pijanowski <maciej.pijanowski@3mdeb.com>
Cc: piotr.krol@3mdeb.com
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Add secure boot defconfig for ls1028aqds and ls1028ardb boards.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
Select the correct Ethernet driver from Synopsis.
Initially, "Synopsys Designware Ethernet MAC" driver was wrongly
selected instead of "Synopsys DWC Ethernet QOS device" driver.
Fixes: commit f90b3f5b68ed ("configs: stm32mp15: Enable Ethernet feature")
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
- Drop zipitz2 board (Tom)
- Add DEPRECATED option (Tom)
- Mark legacy or non-dm drivers as DEPRECATED (Jagan)
- More board removal
In order to migrate this symbol to Kconfig introduce a new symbol to
guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then
provide the exact final location o the script.
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a
choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and
CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs,
headers and whitelist.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers
and whitelist. This patch is a follow-up on a patch by Christian
Gmeiner with the added config/header/whitelist updates.
Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Last change to this board was done in 2016, has no prospects of
ever being converted to DM, drop it.
Cc: Chris Brandt <chris.brandt@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
