Backport usage of a new KSZ9XX1 PHY by Apalis iMX6, the old driver
located in micrel.c still used by other boards. If a board
wants to use a new PHY the old one must be disabled.
Backported from:
commit f72e48ba4d98 ("board: apalis_imx6: Add KSZ9131 phy skew settings")
Related-to: ELB-4181
Signed-off-by: Oleksii Bidnichenko <oleksii.bidnichenko@toradex.com>
Some Colibri iMX6 IT were found which were freezing at higher temperature.
Using the SPL to do a dynamic calibration at each boot fixes the issue.
The DDR calibration routines are gated by conditionals for the
i.MX6DQ SOCs, but with the use of the sysinfo parameter, these
are usable on at least i.MX6SDL and i.MX6SL variants with DDR3.
Also, since only the Novena board currently uses the dynamic
DDR calibration routines, these routines waste space on other
boards using SPL.
Add a KConfig entry to allow boards to selectively include the
DDR calibration routines.
Signed-off-by: Eric Nelson <eric@nelint.com>
(cherry picked from commit a425bf72816abbc3996540e42c33a386e8b8a221)
Modify configuration for Tezi:
- Use distroboot by default
- Boot from external SD cards by default
- Disable USB PID from config block (otherwise recovery mode download
in U-Boot stage fails)
- Enable SDP in U-Boot
- Enable FDT relocation (in-place is causing issues with FIT images)
Modify configuration for Tezi unified recovery mode:
- Remove video output
- Currently only for recovery (no flash/eMMC support)
- Boot from external SD cards using distroboot first by default
- Enable SDP in SPL and U-Boot
Use device tree to set MTD partitions of the NAND chip.
Add DFU configuration which allows access to all MTD partitions.
Note that DFU is mostily suited for smaller image uploads e.g.
to update U-Boot but does not work well for large images such as
rootfs since DFU copies the whole image in a memory buffer first.
Follow commits 59b9b3dfb and 2533000f4 which:
unified the USB PID when the config block is missing
added CONFIG_OF_LIBFDT_OVERLAY
Set the ver environment variable consistently in all modules.
Move the define form include/configs into the defconfig were
applicable and create a new minimal defconfig.
This adds support for Colibri iMX7 Dual 1GB modules which come
with on-board eMMC storage (whereas the other Colibri iMX7
modules use raw NAND). A subselection (variant) for the
Colibri iMX7 target is used to maximize sharing.
The resulting U-Boot boots at least from serial downloader mode.
Use i.MX bootaux support introduced for i.MX 6SoloX/i.MX 7 for
Vybrid too. Starting the Cortex-M4 core on Vybrid works a bit
differently, namely it uses a GPR register to define the initial
PC. There is no way to define the initial stack (the stack is
set up in a boot ROM). This is not a problem for most firmwares
since the firmwares startup code reinitialize the stack as part
of the firmware startup code anyway.
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
Use device-tree fixup to communicate the MTD partitions to the
kernel. Remove mtdparts from the kernel command line.
Enable Serial Download Protocol (SDP) in SPL. This is useful to
make use of imx_usb to download the complete U-Boot (u-boot.img)
after SPL has been downloaded.
The EFI loader is for most use cases not necessary so disable it
by default.
(cherry picked from commit df9aa4068201394a9b2d7c30fbf34a815467c2d2)
Enable default boot command.
FIT image support is used by the upcoming Toradex Easy Installer
and also can be useful for more advanced boot scenarios.
Enable the display driver on Apalis T30. Unfortunately the PWM pin
muxing wasn't any good neither which made that display stay dark.
(cherry picked from commit 2da21c1d130fa11a5bd9876c8e72fa0d57585106)
On popular request enable the display driver on Colibri T30. A few
notes about some things encountered during porting: While analogue VGA
(e.g. via the on-carrier RAMDAC) worked just fine from the beginning
the EDT display flickered like crazy which turned out to be a pin
muxing issue. Unfortunately the PWM pin muxing wasn't any good neither
which made that display stay dark. Enjoy.
(cherry picked from commit 201cc6d4e4c8213fbd103e74b0f2f2ca591edf54)
Migrate Colibri T20 to U-Boot 2016.11.
(cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
Device tree overlays might prove useful in the future, enable it
by default on all our modules.
Migrate Apalis/Colibri T30 to U-Boot 2016.11.
(cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
Use default CONFIG_OF_SEPARATE configuration which appends the device
tree at the end of the U-Boot binary.
by default.
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
The CAAM driver of the downstream i.MX 7 Linux kernel seems not to
work well when booting in non-secure:
caam 30900000.caam: Entropy delay = 3200
caam 30900000.caam: failed to acquire DECO 0
caam 30900000.caam: Entropy delay = 3600
caam: probe of 30900000.caam failed with error -11
Unable to handle kernel NULL pointer dereference at virtual address 00000004
Default booting in secure mode. If non-secure is preferred (e.g.
required for virtualization on a mainline kernel) one can use
setenv bootm_boot_mode nonsec
Introduce USB Gadget config option. This allows to combine Makefile
entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Ravi Babu <ravibabu@ti.com>
(cherry picked from commit e94793c844a40606252f2e3f6428063e057b3fd2)
All modules use the common g_dnl_bind_fixup implementaton which
calculates the PID according to product id (read from the config
block) plus offset of 0x4000. In case there is no config block
support (e.g. SPL) or in case the config block is not readable,
fall back to a generic product id (product id 0, which can be
interpreted as "Unknown Module").
Actually make use of that shiny new CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK.
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
This adds board support for the Toradex module family Colibri iMX6.
The familiy consists of a module with i.MX6 DualLite, i.MX6 Solo, both
with a version for commercial and industrial temperature range.
(cherry picked from commit a02d517b0182f83771565eba1329fb323674ec58)
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
(cherry picked from commit 592f4aed6db765172e21f228800b49f9a27ff201)
Add serial platform data to board file.
Enable driver model for PXA serial driver.
(cherry picked from commit 136179bec19f4bc84227cba138214ea392a723ea)
With em humble DM and Kconfig migraters U-Boot binary size keeps
increasing. Drop a bunch of less needed stuff to save another precious
20+ KB.
(cherry picked from commit fc127d184aea293ec415dd66e3282dba0b66c5f3)
Migrate the PXA serial driver to be configured via Kconfig.
(cherry picked from commit d804a5e1c369e59f23723cd21e1e422b7702a0ac)
With our common code in place actually make use of it across all our
modules.
(cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
Deactivate CONFIG_DISPLAY_BOARDINFO in favour of
CONFIG_DISPLAY_BOARDINFO_LATE which also displays on the LCD.
(cherry picked from commit b05d6806cd6a95d46c22036a684a09501fdb2264)
Defconfigs should remain the same except CONFIG_SYS_EXTRA_OPTIONS.
Drop NAND specific defconfig as flash type is runtime detected.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Reviewed-by: Javier Martinez Canillas <javier@samsung.com>
