path: root/configs/da850evm_defconfig
2016-07-14configs: da850evm: enable bootz commandSekhar Nori
Enable bootz command on Texas Instruments DA850 EVM board. This helps it boot zImage with device-tree blob passed. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Kevin Hilman <khilman@baylibre.com>
2014-08-30davinci: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Davinci board select menu to davinci/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="davinci"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
