2021-10-27 | apalis-imx6: add usage of KSZ9XX12016.11-toradex-next2016.11-toradex | Oleksii Bidnichenko | |
Backport usage of a new KSZ9XX1 PHY by Apalis iMX6, the old driver located in micrel.c still used by other boards. If a board wants to use a new PHY the old one must be disabled. Backported from: commit f72e48ba4d98 ("board: apalis_imx6: Add KSZ9131 phy skew settings") Related-to: ELB-4181 Signed-off-by: Oleksii Bidnichenko <oleksii.bidnichenko@toradex.com> | |||
2018-07-27 | apalis_imx6: add configuration for tezi | Stefan Agner | |
Modify configuration for Tezi: - Enable SDP in SPL and U-Boot - Enable FDT relocation (in-place is causing issues with FIT images) - Remove video output - Use distroboot by default - Boot from external SD cards by default - Disable USB PID from config block (otherwise recovery mode download in U-Boot stage fails) Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> |
