path: root/config.mk
2020-05-15rename symbol: CONFIG_TEGRA -> CONFIG_ARCH_TEGRATrevor Woerner
Have this symbol follow the pattern of all other such symbols. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-04-10kconfig / kbuild: Re-sync with Linux 4.19Tom Rini
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig / kbuild: re-sync with Linux 4.18"). In this particular re-sync in order to keep clang support working a number of related changes needed to be pulled in that had been missed previously. Not all of these changes we easily traceable and so have been omitted from the list below. The imported Linux commits are: [From prior to v4.18] 9f3f1fd29976 kbuild: Add __cc-option macro d7f14c66c273 kbuild: Enable Large File Support for hostprogs 6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*' 24403874316a Shared library support 86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang 0294e6f4a000 kbuild: simplify ld-option implementation [From v4.18 to v4.19] 96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS 10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS 8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line 4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config 693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags) 2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F) c931d34ea085 arm64: build with baremetal linker target instead of Linux when available 5accd7f3360e kconfig: handle format string before calling conf_message_callback() a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c 0608182ad542 kconfig: split out useful helpers in confdata.c adc18acf42a1 kconfig: remove unneeded directory generation from local*config 79123b1389cc kconfig: create directories needed for syncconfig by itself 16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count d6c6ab93e17f kbuild: remove deprecated host-progs variable 56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol c151272d1687 kconfig: remove unused sym_get_env_prop() function 1880861226c1 kconfig: remove P_ENV property type e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile 4bf6a9af0e91 kconfig: add build-only configurator targets f1575595d156 kconfig: error out when seeing recursive dependency 5e8c5299d315 kconfig: report recursive dependency involving 'imply' f498926c47aa kconfig: improve the recursive dependency report 98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build 9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig 87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS 217c3e019675 disable stringop truncation warnings for now bc8d2e20a3eb kconfig: remove a spurious self-assignment fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config 5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments Note that this adds new cleanup work to do in that we should adapt the shared library support we have to what is now upstream. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2018-11-18Kbuild: add LDFLAGS_STANDALONEDaniel Schwierzeck
Introduce a new Makefile variable for passing LDFLAGS to standalone programs. Currently the variable CONFIG_STANDALONE_LOAD_ADDR is misued on some archs to pass a specific linker script. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-09-10Remove CONFIG_USE_STDINTMasahiro Yamada
You do not need to use the typedefs provided by compiler. Our compilers are either IPL32 or LP64. Hence, U-Boot can/should always use int-ll64.h typedefs like Linux kernel, whatever the typedefs the compiler internally uses. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-08-05Allow objcopy to work without filling gaps with 0xffSimon Glass
This is currently done for all targets, since 0xff is the default erased value for most flash devices. In some cases this is not what we want (e.g. for EFI images) so provide a command to do a vanilla objcopy. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-24kconfig: switch to single .config configurationMasahiro Yamada
When Kconfig for U-boot was examined, one of the biggest issues was how to support multiple images (Normal, SPL, TPL). There were actually two options, "single .config" and "multiple .config". After some discussions and thought experiments, I chose the latter, i.e. to create ".config", "spl/.config", "tpl/.config" for Normal, SPL, TPL, respectively. It is true that the "multiple .config" strategy provided us the maximum flexibility and helped to avoid duplicating CONFIGs among Normal, SPL, TPL, but I have noticed some fatal problems: [1] It is impossible to share CONFIG options across the images. If you change the configuration of Main image, you often have to adjust some SPL configurations correspondingly. Currently, we cannot handle the dependencies between them. It means one of the biggest advantages of Kconfig is lost. [2] It is too painful to change both ".config" and "spl/.config". Sunxi guys started to work around this problem by creating a new configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.) added "make *_felconfig" to enable CONFIG_SPL_FEL on both images. Changing the configuration of multiple images in one command is a generic demand. The current implementation cannot propose any good solution about this. [3] Kconfig files are getting ugly and difficult to understand. Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files. [4] The build system got more complicated than it should be. To adjust Linux-originated Kconfig to U-Boot, the helper script "scripts/multiconfig.sh" was introduced. Writing a complicated text processor is a shell script sometimes caused problems. Now I believe the "single .config" will serve us better. With it, all the problems above would go away. Instead, we will have to add some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM, but we will not have much. Anyway, this is what we do now in scripts/Makefile.spl. I admit my mistake with my apology and this commit switches to the single .config configuration. It is not so difficult to do that: - Remove unnecessary processings from scripts/multiconfig.sh This file will remain for a while to support the current defconfig format. It will be removed after more cleanups are done. - Adjust some makefiles and Kconfigs - Add some entries to include/config_uncmd_spl.h and the new file scripts/Makefile.uncmd_spl. Some CONFIG options that are not supported on SPL must be disabled because one .config is shared between SPL and U-Boot proper going forward. I know this is not a beautiful solution and I think we can do better, but let's see how much we will have to describe them. - update doc/README.kconfig More cleaning up patches will follow this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-10-27Provide option to avoid defining a custom version of uintptr_t.Gabe Black
There's a definition in stdint.h (provided by gcc) which will be more correct if available. Define CONFIG_USE_STDINT to use this feature, or USE_STDINT=1 on the 'make' commmand. This adjusts the settings for x86 and sandbox, with both have 64-bit options. Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org> Reviewed-by: Bill Richardson <wfrichar@google.com> Rewritten to be an option, since stdint.h is often available only in glibc. Changed to preserve a clear boundary between stdint and non-stdint Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23kbuild: clear VENDOR variable to fix build error on tcshMasahiro Yamada
Since the environment "VENDOR" is set in tcsh, it must be cleared in our makefile. Otherwise, boards without CONFIG_SYS_VENDOR fail to build: > make CROSS_COMPILE=arm-linux-gnueabi- wandboard_quad_defconfig all [ snip ] AR arch/arm/lib/lib.a CC arch/arm/lib/eabi_compat.o scripts/Makefile.build:55: /home/foo/u-boot/board/unknown/wandboard/ \ Makefile: No such file or directory make[2]: *** No rule to make target `/home/foo/u-boot/board/unknown/ \ wandboard/Makefile'. Stop. make[1]: *** [board/unknown/wandboard] Error 2 make: *** [__build_one_by_one] Error 2 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Tom Everett <tom@khubla.com> Reported-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-09-24Reactivate the tracing featureSimon Glass
This was lost sometime in the Kbuild conversion. Add it back. Check that the trace test now passes: $ ./test/trace/test-trace.sh Simple trace test / sanity check using sandbox /tmp/filemHKPGw Build sandbox O=sandbox FTRACE=1 GEN /home/sjg/c/src/third_party/u-boot/files/sandbox/Makefile Configuring for sandbox board... Check results Test passed Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-30kconfig: switch to KconfigMasahiro Yamada
This commit enables Kconfig. Going forward, we use Kconfig for the board configuration. mkconfig will never be used. Nor will include/config.mk be generated. Kconfig must be adjusted for U-Boot because our situation is a little more complicated than Linux Kernel. We have to generate multiple boot images (Normal, SPL, TPL) from one source tree. Each image needs its own configuration input. Usage: Run "make <board>_defconfig" to do the board configuration. It will create the .config file and additionally spl/.config, tpl/.config if SPL, TPL is enabled, respectively. You can use "make config", "make menuconfig" etc. to create a new .config or modify the existing one. Use "make spl/config", "make spl/menuconfig" etc. for spl/.config and do likewise for tpl/.config file. The generic syntax of configuration targets for SPL, TPL is: <target_image>/<config_command> Here, <target_image> is either 'spl' or 'tpl' <config_command> is 'config', 'menuconfig', 'xconfig', etc. When the configuration is done, run "make". (Or "make <board>_defconfig all" will do the configuration and build in one time.) For futher information of how Kconfig works in U-Boot, please read the comment block of scripts/multiconfig.py. By the way, there is another item worth remarking here: coexistence of Kconfig and board herder files. Prior to Kconfig, we used C headers to define a set of configs. We expect a very long term to migrate from C headers to Kconfig. Two different infractructure must coexist in the interim. In our former configuration scheme, include/autoconf.mk was generated for use in makefiles. It is still generated under include/, spl/include/, tpl/include/ directory for the Normal, SPL, TPL image, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-07build: define CPU only when arch/${ARCH}/cpu/${CPU} existsMasahiro Yamada
The directory arch/${ARCH}/cpu/${CPU} does not exist in avr32, blackfin, microblaze, nios2, openrisc, sandbox, x86. These architectures have only one CPU type. Defining CPU should not be required for such architectures. This commit allows cpu field (= the 3rd field of boards.cfg) to be kept blank. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Sonic Zhang <sonic.zhang@analog.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2014-03-12kbuild: rename SRCTREE to srctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used for instead. This commit renames SRCTREE to srctree and deletes the defition of SRCTREE. Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c, doc/DocBook/Makefile should be keep. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename TOPDIR to stctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used instead. This commit renames TOPDIR to srctree and delete the defition of TOPDIR. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07kbuild: improve Kbuild speedMasahiro Yamada
Kbuild brought about many advantages for us but a significant performance regression was reported by Simon Glass. After some discussions and analysis, it turned out its main cause is in $(call cc-option,...). Historically, U-Boot parses all config.mk (arch/*/config.mk and board/*/config.mk) every time descending into subdirectories. That means cc-options are evaluated over and over again. $(call cc-option,...) is useful but costly. So we want to evaluate them only in ./Makefile and spl/Makefile and export compiler flags. This commit changes the build system as follows: - Modify scripts/Makefile.build to not include config.mk Instead, add $(PLATFORM_CPPFLAGS) to asflags-y, ccflags-y, cppflags-y. - Export many variables Going forward, Kbuild will not parse config.mk files when it descends into subdirectories. If we want to set variables in config.mk and use them in subdirectories, they must be exported. This is the list of variables to get exported: PLATFORM_CPPFLAGS CPUDIR BOARDDIR OBJCOPYFLAGS LDFLAGS LDFLAGS_FINAL (used in nand_spl/board/*/*/Makefile) CONFIG_STANDALONE_LOAD_ADDR (used in examples/standalone/Makefile) SYM_PREFIX (used in examples/standalone/Makefile) RELFLAGS (used in examples/standalone/Makefile) - Delete CPPFLAGS This variable has been replaced with PLATFORM_CPPFLAGS - Copy gcclibdir from example/standalone/Makefile to arch/sparc/config.mk The reference in CONFIG_STANDALONE_LOAD_ADDR must be resolved before it is exported. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [on Sandbox] Tested-by: Stephen Warren <swarren@nvidia.com> [on Tegra]
2014-03-04kbuild: allow empty board directoriesMasahiro Yamada
U-Boot has compelled all boards to have board/${BOARD}/ or board/${VENDOR}/${BOARD}/ directory. Sometimes it does not seem suitable for some boards, for example Sandbox. (Is it a board?) And arcangel4 board has nothing to compile under the board directory. This commit makes the build system more flexible: If '<none>' is given to the 6th column (=Board name) of boards.cfg, Kbuild will not descend into the board directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04config.mk: Delete unused variable BCURDIRMasahiro Yamada
This variable was abolished by Kbuild series. I forgot to delete it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-25kbuild: rename OBJCFLAGS to OBJCOPYFLAGSMasahiro Yamada
Rename OBJCFLAGS to OBJCOPYFLAGS beforehand to use "cmd_objcopy" in scripts/Makefile.lib in an upcoming commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: move include directives of board configuration filesMasahiro Yamada
This commit changes the location of include directives of board configuration files. The purpose of this change is: - Slim down $(TOPDIR)/config.mk - Prevent $(TOPDIR)/Makefile from including the same configuration file twice - Do not include include/config.mk multiple times because ARCH, CPU, BOARD, VENDOR, SOC are exported Before this commit: - include/autoconf.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/autoconf.mk twice) - include/{spl,tpl}-autoconf.mk was included from $(TOPDIR)/config.mk - include/config.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/config.mk twice) After this commit: - include/autoconf.mk is included from $(TOPDIR)/Makefile and $(TOPDIR)/scripts/Makefile.build - include/{spl,tpl}-autoconf.mk is included from $(TOPDIR)/spl/Makefile and $(TOPDIR)/scripts/Makefile.build - include/config.mk is included from $(TOPDIR)/config.mk and $(TOPDIR)/spl/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makefile: move some flags to examples makefilesMasahiro Yamada
This commit moves some flags which are used under examples/ directory only. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move some flags to spl/MakefileMasahiro Yamada
Some flags are used for SPL (and TPL) build only. This commit moves them from config.mk to spl/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move more stuff to top MakefileMasahiro Yamada
2014-02-19Makefile: refactor include path settingsMasahiro Yamada
This commit merges commonly-used header include paths to UBOOTINCLUDE and NOSTDINC_FLAGS variables, which are placed at the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move more flags to the top MakefileMasahiro Yamada
Before this commit, most of compiler flags were defined in config.mk. But it is redundant because config.mk is included from all recursive make. This commit moves many complier flags to the top Makefile and export them. And we use new vaiarables to store them: KBUILD_CPPFLAGS, KBUILD_CFLAGS, KBUILD_AFLAGS. This will allow us to switch more smoothly to Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: Use Kbuild.includeMasahiro Yamada
This commit adjusts some files to use Kbuild.include. - Use cc-option defined in Kbuild.include (Delete cc-option in config.mk) - Use cc-version defined in (Delete cc-version in config.mk) - Move binutils-version and dtc-version to Kbuild.include by analogy to cc-version This commit also adds srctree (same as SRCTREE) to use Kbuild scripts. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move BFD_ROOT_DIR to tools/gdb/MakefileMasahiro Yamada
BFD_ROOT_DIR is used only in tools/gdb/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move some variable definitions to the top MakefileMasahiro Yamada
This commit moves some variable definitions from config.mk to the top Makefile: - HOSTCC, HOSTCFLAGS, HOSTLDFLAGS - AS, LD, CC, CPP, etc. - SHELL (renamed to CONFIG_SHELL) I'd like to slim down config.mk file because it is included from all recursive make. It is redundant to re-define the variables every time descending into sub directories. We should rather define them at the top Makefile and export them. U-Boot makefiles has been used "SHELL" variable to store shell chosen for the user, whereas Linux Kernel uses "CONFIG_SHELL". We should never use "SHELL" variable because it is a special variable for GNU Make. Changing SHELL may cause unpredictable side effects whose root cause is usually difficult to find. We should use a generic variable name "CONFIG_SHELL". We should not use the syntax as follows either: rm -f $(obj)tools/env/{fw_printenv,fw_setenv} This depends on "bash" although GNU Make generally invokes "sh" to run the each rule. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makfile: move suffix rules to Makefile.buildMasahiro Yamada
This commit moves suffix rules from config.mk to scripts/Makefile.build, which will allow us to switch smoothly to real Kbuild. Note1: post/lib_powerpc/fpu/Makefile has its own rule to compile C sources. We need to tweak it to keep the same behavior. Note2: There are two file2 with the same name: arch/arm/lib/crt0.S and eamples/api/crt0.S. To keep the same build behavior, examples/api/Makefile also has to be treaked. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19tools: convert makefiles to kbuild styleMasahiro Yamada
Before this commit, makefiles under tools/ directory were implemented with their own way. This commit refactors them by using "hostprogs-y" variable. Several C sources have been added to wrap other C sources to simplify Makefile. For example, tools/crc32.c includes lib/crc32.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-29sandbox: Use system headers first for sandbox's os.c in a different wayMasahiro Yamada
Commit cbe5cdfcd changed config.mk and arch/sandbox/cpu/Makefile to use -idirafter instead of -I and remove -nostdinc. But * Sandbox-specific code dirties config.mk * os.c is compiled without such compiler flags as: -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fno-stack-protector -fstack-usage -Wno-format-nonliteral This commit use -idirafter and remove the -nostdinc differently and more simply. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-12-13Makefile: Move some scripts imported from LinuxMasahiro Yamada
We have some scripts imported from Linux Kernel: setlocalversion, checkstack.pl, checkpatch.pl, cleanpatch They are located under tools/ directory in U-Boot now. But they were originally located under scripts/ directory in Linux Kernel. This commit moves them to the original location. It is true that binutils-version.sh and dtc-version.sh do not originate in Linux Kernel, but they should be moved by analogy to gcc-version.sh. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-21sandbox: Use system headers first for sandbox's os.cSimon Glass
This file must be compiled with system headers, even if U-Boot has headers of the same name. The existing solution for this is good enough for libfdt, but fails when we have headers like stdint.h in U-Boot. Use -idirafter instead of -I, and remove the -nostdinc and other things that we don't want for this file. The best way to do this is to keep a copy of the original flags, rather than trying to filter them later. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-11-17config.mk: delete unnecessary linesMasahiro Yamada
SPL_BIN is already defined in spl/Makefile and it is used only in spl/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08Makefile: do not create a symbolic link to arch/${ARCH}/include/asmMasahiro Yamada
In-tree build: - Do not create a symbolic link from include/asm to arch/${ARCH}/include/asm - Add ${SRCTREE}/arch/arm/include into the header search path Out-of-tree build: - Do not create a directory ${OBJTREE}/include2 - Do not create a symbolic link from ${OBJTREE}/include2/asm to ${SRCTREE}/arch/${ARCH}/include/asm - Add ${SRCTREE}/arch/arm/include into the header search path Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-06Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-06cam_enc_4xx: Move CONFIG_SPL_PAD_TO to a config headerMasahiro Yamada
For most boards which define CONFIG_SPL_PAD_TO, it is defined in config header files. Currently, there exists only one exception, cam_enc_4xx board. This patch moves CONFIG_SPL_PAD_TO definition from board/ait/cam_enc_4xx/config.mk to include/configs/cam_enc_4xx.h. With this modification, we can delete a glue code in the top level config.mk: ifneq ($(CONFIG_SPL_PAD_TO),) CPPFLAGS += -DCONFIG_SPL_PAD_TO=$(CONFIG_SPL_PAD_TO) endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Heiko Schocher <hs@denx.de>
2013-09-06config.mk: Delete unnecessary codeMasahiro Yamada
Currently no makefiles (board-specific config.mk) set the following variables: CONFIG_SPL_TEXT_BASE CONFIG_UBOOT_PAD_TO CONFIG_RESET_VECTOR_ADDRESS CONFIG_TPL_PAD_TO For all target boards using above macros they are set in header files (include/configs/*.h), so we do not need to set them as CPPFLAGS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-08-20TPL : introduce the TPL based on the SPLYing Zhang
Due to the nand SPL on some board(e.g. P1022DS)has a size limit, it can not be more than 4K. So, the SPL cannot initialize the DDR with the SPD code. This patch introduces TPL to enable a loader stub that is loaded by the code from the SPL. It initializes the DDR with the SPD or other operations. The TPL's size is sizeable, the maximum size is decided by the memory's size that TPL runs. It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are three stage uboot images: * spl_boot, * tpl_boot, * final uboot image Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-19SPL: Makefile: Build a separate autoconf.mk for SPLJoel Fernandes
SPL defines CONFIG_SPL_BUILD but this does not percolate to the autoconf.mk Makefile. As a result the build breaks when CONFIG_SPL_BUILD is used in the board-specific include header file. With this, there is a possibility of having a CONFIG option defined in the header file but not defined in the Makefile causing all kinds of build failure and problems. It also messes things for up, for example, when one might want to undefine options to keep the SPL small and doesn't want to be stuck with the CONFIG options used for U-boot. Lastly, this also avoids defining special CONFIG_SPL_ variables for cases where some options are required in U-boot but not in SPL. We add a spl-autoconf.mk rule that is generated for SPL with the CONFIG_SPL_BUILD flag and conditionally include it for SPL builds. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-08-02Validate dtc is new enoughStephen Warren
Subsequent patches assume that dtc supports various recent features. These are available in dtc 1.4.0. Validate that dtc is at least that version. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-07-24Licenses: introduce SPDX Unique Lincense IdentifiersWolfgang Denk
Like many other projects, U-Boot has a tradition of including big blocks of License headers in all files. This not only blows up the source code with mostly redundant information, but also makes it very difficult to generate License Clearing Reports. An additional problem is that even the same lincenses are referred to by a number of slightly varying text blocks (full, abbreviated, different indentation, line wrapping and/or white space, with obsolete address information, ...) which makes automatic processing a nightmare. To make this easier, such license headers in the source files will be replaced with a single line reference to Unique Lincense Identifiers as defined by the Linux Foundation's SPDX project [1]. For example, in a source file the full "GPL v2.0 or later" header text will be replaced by a single line: SPDX-License-Identifier: GPL-2.0+ We use the SPDX Unique Lincense Identifiers here; these are available at [2]. Note: From the legal point of view, this patch is supposed to be only a change to the textual representation of the license information, but in no way any change to the actual license terms. With this patch applied, all files will still be licensed under the same terms they were before. Note 2: The apparent difference between the old "COPYING" and the new "Licenses/gpl-2.0.txt" only results from switching to the upstream version of the license which is differently formatted; there are not any actual changes to the content. Note 3: There are some recurring questions about linense issues, such as: - Is a "All Rights Reserved" clause a problem in GPL code? - Are files without any license header a problem? - Do we need license headers at all? The following excerpt from an e-mail by Daniel B. Ravicher should help with these: | Message-ID: <4ADF8CAA.5030808@softwarefreedom.org> | Date: Wed, 21 Oct 2009 18:35:22 -0400 | From: "Daniel B. Ravicher" <ravicher@softwarefreedom.org> | To: Wolfgang Denk <wd@denx.de> | Subject: Re: GPL and license cleanup questions | | Mr. Denk, | | Wolfgang Denk wrote: | > - There are a number of files which do not include any specific | > license information at all. Is it correct to assume that these files | > are automatically covered by the "GPL v2 or later" clause as | > specified by the COPYING file in the top level directory of the | > U-Boot source tree? | | That is a very fact specific analysis and could be different across the | various files. However, if the contributor could reasonably be expected | to have known that the project was licensed GPLv2 or later at the time | she made her contribution, then a reasonably implication is that she | consented to her contributions being distributed under those terms. | | > - Do such files need any clean up, for example should we add GPL | > headers to them, or is this not needed? | | If the project as a whole is licensed under clear terms, you need not | identify those same terms in each file, although there is no harm in | doing so. | | > - There are other files, which include both a GPL license header | > _plus_ some copyright note with an "All Rights Reserved" clause. It | > has been my understanding that this is a conflict, and me must ask | > the copyright holders to remove such "All Rights Reserved" clauses. | > But then, some people claim that "All Rights Reserved" is a no-op | > nowadays. License checking tools (like OSLC) seem to indicate this is | > a problem, but then we see quite a lot of "All rights reserved" in | > BSD-licensed files in gcc and glibc. So what is the correct way to | > deal with such files? | | It is not a conflict to grant a license and also reserve all rights, as | implicit in that language is that you are reserving all "other" rights | not granted in the license. Thus, a file with "Licensed under GPL, All | Rights Reserved" would mean that it is licensed under the GPL, but no | other rights are given to copy, modify or redistribute it. | | Warm regards, | --Dan | | Daniel B. Ravicher, Legal Director | Software Freedom Law Center (SFLC) and Moglen Ravicher LLC | 1995 Broadway, 17th Fl., New York, NY 10023 | (212) 461-1902 direct (212) 580-0800 main (212) 580-0898 fax | ravicher@softwarefreedom.org www.softwarefreedom.org [1] http://spdx.org/ [2] http://spdx.org/licenses/ Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-07-19mkimage: Use board config to get CONFIG_FIT_SIGNATURE valueSimon Glass
The value of this config variable is not available to image.h on the host, since the board config is not actually included. Bring this in so that mkimage will be built with image-signing support for sandbox at least. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-28mkimage: Build signing only if board has CONFIG_FIT_SIGNATURESimon Glass
At present mkimage is set up to always build with image signing support. This means that the SSL libraries (e.g. libssl-dev) are always required. Adjust things so that mkimage can be built with and without image signing, controlled by the presence of CONFIG_FIT_SIGNATURE in the board config file. If CONFIG_FIT_SIGNATURE is not enabled, then mkimage will report a warning that signing is not supported. If the option is enabled, but libraries are not available, then a build error similar to this will be shown: lib/rsa/rsa-sign.c:26:25: fatal error: openssl/rsa.h: No such file or directory Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add RSA support for image signingSimon Glass
RSA provides a public key encryption facility which is ideal for image signing and verification. Images are signed using a private key by mkimage. Then at run-time, the images are verified using a private key. This implementation uses openssl for the host part (mkimage). To avoid bringing large libraries into the U-Boot binary, the RSA public key is encoded using a simple numeric representation in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Support tracing in config.mk when enabledSimon Glass
Use -finstrument-functions when tracing is enabled (make FTRACE=1). Tracing is not currently supported by SPL even if sufficient memory is available. When tracing is enabled, we #define FTRACE. This can be used by board config files to conditionally enable the tracing options. Signed-off-by: Simon Glass <sjg@chromium.org>
