Fix following warning while compilation for mcc200 board:
lcd.c: In function 'lcd_display_bitmap':
lcd.c:625: warning: unused variable 'cmap'
This patch also simplifies some ifdefs in lcd.c, introduces a generic
vidinfo_t, which new drivers are encouraged to use and old drivers to switch
over to.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Acked-by: Anatolij Gustschin <agust@denx.de>
This patch adds 16bpp BMP support to the common lcd code.
Use CONFIG_BMP_16BPP and set LCD_BPP to LCD_COLOR16 to enable the code.
At the moment it's only been tested on the MIMC200 AVR32 board, but extending
this to other platforms should be a simple task !!
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
NetLoop polls every cycle with getenv some environment variables.
This is horribly slow, especially when the environment is big.
This patch reads only the environment variables in NetLoop,
when they were changed.
Also moved the init part of the NetLoop function in a seperate
function.
Serial driver via the EmbeddedICE macrocell's DCC channel using
co-processor 14.
It does include a timeout to ensure that the system does not
totally freeze when there is nothing connected to read.
Although load address and image start address are same address,
bootm command always does memmove.
That is unnecessary memmove and can be taken few milliseconds
(about 500 msec to 1000 msec).
If skip this memmove, we can reduce the boot time.
Signed-off-by: Derek Ou <dou@siconix.com>
Don't use code of new MMC framework in cmd_mmc if CONFIG_GENERIC_MMC
isn't enabled.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
Here's a new framework (based roughly off the linux one) for managing
MMC controllers. It handles all of the standard SD/MMC transactions,
leaving the host drivers to implement only what is necessary to
deal with their specific hardware.
This also hooks the infrastructure into the PowerPC board code
(similar to how the ethernet infrastructure now hooks in)
Some of this code was contributed by Dave Liu <daveliu@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
This is to get it out of the way of incoming MMC framework
MMC cards are not memory, so we stop treating them that way.
The LUN number is not part of the Command Descriptor Block (CDB) for scsi inquiry, request sense, test unit ready, read capacity and read10 commands. This patch removes the LUN number information from the CDB.
Signed-off-by: Thomas Abraham <t-abraham@ti.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Move global '#ifdef CONFIG_xxx .... #endif' out of the .c files and into
the COBJS-$(CONFIG_xxx) in the Makefile. Also delete unused var in kgdb
code in the process.
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and
can be confusing when reading the code.
Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used
for system memory mapping purposes.
This fixes a bug that tmp environment memory not being released.
CONFIG_M68K bdinfo cleanup:
Fixed compiler warning about baudrate printing.
format '%d' expects type 'int', but argument 2 has type 'long unsigned int'.
Added printing of "cpufreq"
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Original patch from Ralph Kondziella
plus clean up by Wolfgang Denk
plus changes by John Rigby
use ips clock not lpc
port forward to current u-boot release
Signed-off-by: Ralph Kondziella <rk@argos-messtechnik.de>
Signed-off-by: John Rigby <jrigby@freescale.com>
We should check the return of usb_new_device() so that if no USB device is
found, we print out the right message rather than always saying "new usb
device found".
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
With this patch the USB related connection speed output ("usb tree" command and
debug output) is now high-speed enabled.
This patch also fixes a compilation warning when debugging is enabled.
Rather than forcing people to define a custom "LITTLEENDIAN", just use the
__LITTLE_ENDIAN one from the Linux byteorder headers that every arch is
already setting up.
The SanDisk Corporation U3 Cruzer Micro 1/4GB Flash Drive 000016244373FFB4
does not like to be reset, so check for it.
This patch populates the 'priv' field of the USB keyboard device_t
structure. The 'priv' field is populated with the address of the
'struct usb_device' structure that represents the USB device.
The 'priv' field can then be used in the 'usb_event_poll' function to
determine the USB device that requires to be polled. An
example of its usage in 'usb_event_poll' function is as below.
device_t *dev;
struct usb_device *usb_kbd_dev;
<snip>
dev = device_get_by_name("usbkbd");
usb_kbd_dev = (struct usb_device *)dev->priv;
iface = &usb_kbd_dev->config.if_desc[0];
USB changes the speed according to the port status
Signed-off-by: Michael Trimarchi <trimarchimichael@yahoo.it>
Prepare USB layer for ehci support
Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it>
Signed-off-by: Remy Böhmer <linux@bohmer.net>
Cleanup usb storage
The BF53x/BF56x parts do not have an on-chip ROM to boot LDRs out of
arbitrary memory locations, so implement a basic one in software.
Now that real documentation has been released for the OTP interface and
the on-chip ROM wrt writing/timings, implement support for reading/writing
as well as dumping/locking.
The Blackfin JTAG has the ability to pass data via a back-channel without
halting the processor. Utilize that channel to emulate a console.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Rather than have the board code initialize SATA automatically during boot,
make the user manually run "sata init". This brings the SATA subsystem in
line with common U-Boot policy.
Rather than having a dedicated weak function "is_sata_supported", people
can override sata_initialize() to do their weird board stuff. Then they
can call the actual __sata_initialize().
This patch fixes a bug (?) introduced after inclusion of the new
JFFS2 code.
When not using CONFIG_JFFS2_CMDLINE, the code in cmd_jffs2.c doesn't
fill in part->sector_size (keeping it as 0), but a correct value is
needed by the code in jffs2_1pass.c. This causes all JFFS2 accesses
to be in the same place of the memory, what obviously means
impossibility to use the JFFS2 partition.
This problem is fixed in this patch by including sector size
calculation in non-CONFIG_JFFS2_CMDLINE mtdparts_init variant.
Signed-off-by: Tomasz Figa <tomasz.figa_at_gmail.com>
Rather than special casing each environment type for enabling the saveenv
command, have them all behave the same. This avoids bitrot as new env
sources are added/removed.
U-Boot's gunzip() function does not handle the return code
of zlib's inflate() function correctly. gunzip() is implemented
to uncompress all input data in one run. So the correct return
code for the good case is Z_STREAM_END. In case of insufficient
output buffer memory inflate returns Z_OK. For gunzip() this
is an error.
It also makes sense to me to call inflateEnd() also in case
of an error.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
The iteration limit is passed to mtest as a fourth parameter:
[start [end [pattern [iterations]]]]
If no fourth parameter is supplied, there is no iteration limit and the
test will loop forever.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Support bootdelay=0 in abortboot for the CONFIG_AUTOBOOT_KEYED case
similar to the CONFIG_ZERO_BOOTDELAY_CHECK support for the
!CONFIG_AUTOBOOT_KEYED case.
Do this by reversing the loop so we do at least one iteration before
checking for timeout.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Error with CONFIG_NAND_LEGACY in common/cmd_nand.c:
With current code "nand read.jffs2s" (read and skip bad blocks) is always interpreted as
"nand read.jffs2" (read and fill bad blocks with 0xff). This is because ".jffs2" is
tested before ".jffs2s" and only the first two characters are compared.
Correction:
Test for ".jffs2s" first and compare the first 7 characters.
Enable nand lock, unlock and status of lock feature.
Not every device and platform requires this, hence,
it is under define for CONFIG_CMD_NAND_LOCK_UNLOCK
Nand unlock and status operate on block boundary instead
of page boundary. Details in:
http://www.micron.com/products/partdetail?part=MT29C2G24MAKLAJG-6%20IT
Intial solution provided by Vikram Pandita <vikram.pandita@ti.com>
Includes preliminary suggestions from Scott Wood
Signed-off-by: Nishanth Menon <nm@ti.com>
Update OneNAND command to support bad block awareness.
Also change the OneNAND command style to better match the
NAND version.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
The code in fdt_resize() to extend the fdt size to end on a page boundary
is wrong for fdt's not located at an address aligned on a page boundary.
What's even worse, the code would make actualsize shrink rather than grow
if (blob & 0xfff) was bigger than the amount of padding added by ALIGN(),
causing fdt_add_mem_rsv to fail.
Fix it by aligning end address (blob + size) to a page boundary instead.
For aligned fdt's this is equivalent to what we had before.
