path: root/common/cmd_spibootldr.c
2010-08-09various cmd_* files: fixed layout a little bitFrans Meulenbroeks
Most of the files have U_BOOT_CMD on a separate line, but a few didn't and had the first line on the same line as U_BOOT_CMD. This changes these files by adding a line break and a tab Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2009-06-14Blackfin: new spibootldr commandMike Frysinger
Newer Blackfin parts can an on-chip ROM that can boot LDRs over SPI flashes, so add a new 'spibootldr' command to take advantage of it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
