path: root/common/cmd_mp.c
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-09-29powerpc/mp: add support for discontiguous coresTimur Tabi
Some SOCs have discontiguously-numbered cores, and so we can't determine the valid core numbers via the FRR register any more. We define CPU_TYPE_ENTRY_MASK to specify a discontiguous core mask, and helper functions to process the mask and enumerate over the set of valid cores. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-01-26Add support to disable cpu's in multicore processorsKumar Gala
Add a disable sub-command to the cpu command that allows for disabling cores in multicore processors. This can be useful for systems that are using multicore chips but aren't utilizing all the cores as a way to reduce power and possibly improve performance. Also updated an added missing copyright. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-08-1285xx: Rename CONFIG_NR_CPUS to CONFIG_NUM_CPUSKumar Gala
Use CONFIG_NUM_CPUS to match existing define used by 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-07-14Fix some more printf() format problems.Kumar Gala
2008-03-2685xx: Update multicore boot mechanism to ePAPR v0.81 specKumar Gala
The following changes are needed to be inline with ePAPR v0.81: * r4, r5 and now always set to 0 on boot release * r7 is used to pass the size of the initial map area (IMA) * EPAPR_MAGIC value changed for book-e processors * changes in the spin table layout * spin table supports a 64-bit physical release address Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-2685xx: Added support for multicore boot mechanismKumar Gala
Added the cpu command that provides a generic mechanism to get status, reset, and release secondary cores in multicore processors. Added support for using the ePAPR defined spin-table mechanism on 85xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
