This patch also removes now unnecessary config.mk in board directory and
make usage of new features in boards.cfg.
Adds support for the EMK TOP9000 CPU Module which is
based on ATMELs ARM926EJS AT91SAM9XE SoC.
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
This patch http://patchwork.ozlabs.org/patch/72962/ included a boards.cfg
change, but it was omitted when applied as
f1c574d4006d81301792e70fafc31ff39259e793
This fixes the NAND SPL build on MPC8315ERDB.
update suggested sort command in comment to produce desired order
suggest use of "column -t" to reformat
Signed-off-by: Eric Cooper <ecc@cmu.edu>
The barco board appears to be unmaintained since it was added about 5
years ago. The environment location has probably never been correct.
Drop it.
Cc: Marc Leeman <marc.leeman@barco.com>
The ERIC board appears to be unmaintained for more than 9 years. The
environment location has probably never been correct, and has been
definitely broken since for at least a year. Drop it.
Cc: Stefan Roese <sr@denx.de>
Cc: Swen Anderson <sand@peppercon.de>
start with sheevaplug configuration
add modifications by Alexander Holler <holler@ahsoftware.de>
change RAM definitions to one bank (128 MB)
change ident string and prompt
define MTD partitions and default environment variables
add support for LEDs
Without this fix, the NAND_SPL target (in nand_spl/) is not built
at all for those boards defining NAND_U_BOOT=y in boards.cfg.
Cc: Scott Wood <scottwood@freescale.com>
When P2020DS DDR2 was merged it was merged incorrectly and propogated to
boards.cfg. Fix this by moving DDR2 config to be associated with
P2020DS and not P1_P2_RDB.
Now that the boards.cfg file supports options to mkconfig, we can move
the bf527-ezkit-v2 target out of the Makefile and into boards.cfg.
Board support for the Guntermann & Drunck CATCenter Io.
Board support for the Guntermann & Drunck IoCon.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
The 100MHz configuation of the VoVPN-GW has never been supported, so
drop it now.
Initial support for Extreme Engineering Solutions XPedite5500 -
a P2020-based PMC/XMC single board computer.
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
Some U-Boot images for X-ES boards support multiple products in the same
family. For example, the XPedite5370, XPedite5371, and XPedite5372 are
similar enough that one U-Boot image can work on all 3 cards. To make it
clear that a U-Boot image can work on boards of the same family, rename
the boards with the least significant digit of 'x'.
While we're at it, change the board config file and make targets to be
lowercase.
Also change the default uImage and fdt filenames to "board.uImage" and
"board.dtb" to be more generic.
This board is broken and it's not possible to repair it.
This board is broken and impossible to repair without deep knowledge or
availability of the hardware.
Move the sh4 target boards out of the Makefile and into boards.cfg.
And fix sh4 of MAKEALL.
Move the sh3 target boards out of the Makefile and into boards.cfg.
And fix sh3 of MAKEALL.
Move the rsk7203 target out of the Makefile and into boards.cfg.
And fix sh2 of MAKEALL.
The "options" field at the moment is only documented in the changelog
which isn't terribly useful to people without git.
This patch adds support for the HP Jornada flashboards
that were made in 2008. Older flashroms should work if
memory registers are adjusted.
Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
Adpted for TEXT_BASE -> CONFIG_SYS_TEXT_BASE rename.
Removed now redundant board/jornada/config.mk file.
Removed unused empty jornada_init() function to silence
"jornada.c:35: warning: 'jornada_init' defined but not used"
The following hardware is currently supported:
- UART
- USB Host
- FPGA
This patch adds support for the Palm Tungsten|C PXA255 board. The support
includes:
- LCD
- MMC
- UART
- NOR
board/logicpd/imx31_litekit/config.mk
boards.cfg
This patch removes some functionality from at91rm9200ek board but the
remaining functionality does now work with newer at91 code and
arm-relocation.
Currently missing features are:
- dataflash booting (due to missing HW for testing)
- MMC/SD-Card
- first stage bootloader support is completely removed (not needed for
NOR)
Cause this board was (some days ago) reference for all at91rm9200 based
boards this should be a good starting point to convert all remaining
at91rm9200 borads to at91 code. Aside from that this is a good base to
get some drivers between at91sam/at91rm/avr32 merged.
The NC650 / CP850 boards have long been unmaintained and left broken.
As obviously nobody is interested in that code any more, we may as
well remove it.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
There are some boards where it's currently not possible to detect all
board information at runtime, therefore a new column was added to
boards.cfg .
This column can contain multiple options: a board configuration name,
optionally followed by a colon (':') and a list of options, which are
separated by comma (',').
In case of simple options like '256M_U_BOOT', these expand to
"#define CONFIG_MK_256M_U_BOOT 1" in config.h . In case of
assignments like 'RAM=8192', these expand to "#define CONFIG_MK_RAM
8192" in config.h .
Example:
FOO:HAS_BAR,BAZ=64
means:
- the name of the board config file is include/configs/FOO.h
- the generated file include/config.h will contain these
lines:
#define CONFIG_HAS_BAR 1
#define CONFIG_BAZ 64
[wd@denx.de: edited commit message; added code to deal with an
optional board configuration name]
The logodl board has long been unmaintained and left broken.
As obviously nobody is interestedin that code any more, we may as well
remove it.
Cc: August Hoeraendl <august.hoerandl@gmx.at>
Cc: Robert Schwebel <r.schwebel@pengutronix.de>
Cc: Marek Vasut <marek.vasut@gmail.com>
Rename mx51 to mx5 in order to support more mx51
like-style SOCs such as MX53 and the followings.
Signed-off-by: Jason Liu <r64343@freescale.com>
The IGEP module is a low-power, high performance production-ready
system-on-module (SOM) based on TI's OMAP3 family.The IGEP module
solution based upon TI OMAP3 provides a low-power/low-cost platform
for a variety of consumer/industrial/medical devices.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The IGEP v2 board is a low-cost, fan-less and industrial temperature
range single board computer that unleashes laptop-like performance and
expandability without the bulk, expense, or noise of typical desktop
machines. Its architecture shares much in common with other OMAP3 boards.
Acked-by: Steve Sakoman <steve.sakoman@linaro.org>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
Adds support for the ARM quad-core Cortex-A9 processor
This system includes a motherboard(Versatile Express), daughterboard
(Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet,
and flash systems work with these additions. The naming convention
is:
SOC -> CortexA9 quad core = ca9x4
daughterboard -> Coretile = ct
motherboard -> Versatile Express = vxp
This gives ca9x4_ct_vxp.c as the board support file.
Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
This patch provides support for the A4M072 board with the following features:
UART
NOR flash
FEC Ethernet
External SRAM
I2C EEPROM
CompactFlash cards on IDE/ATA port
USB Host
PCI initialization
The 7-segment LED indicator is not yet supported.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
The patch adds support for TTECH vision2 board.
The board has 512MB RAM, SDHC slot and 4MB SPI
device from StMicron.
The CCM board has long reached EOL, and support for it is no longer
relevant in current versions of U-Boot. Remove it.
