path: root/boards.cfg
2013-11-13powerpc/t104xrdb: Add T1042RDB_PI board supportPriyanka Jain
T1042RDB_PI is Freescale Reference Design Board supporting the T1042 QorIQ Power Architecture™ processor. T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit. The board is designed with low power features targeted for Printing Image Market. T1042RDB_PI is similar to T1040RDB board with few differences like it has video interface, supports T1042 personality T1042RDB_PI board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Two on-board RGMII 10/100/1G ethernet ports. - SERDES Connections, 8 lanes supporting: — PCI — SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Video - DIU supports video at up to 1280x1024x32bpp - HDMI connector - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Device connected: EEPROM, thermal monitor, VID controller, RTC - Other IO - Two Serial ports - ProfiBus port - Four I2C ports Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-11-13powerpc/t104xrdb: Add T1040RDB board supportPriyanka Jain
T1040RDB is Freescale Reference Design Board supporting the T1040 QorIQ Power Architecture™ processor. T1040RDB board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Integrated 8-port Gigabit Ethernet switch - Four 1 Gbps Ethernet controllers - SERDES Connections, 8 lanes supporting: - PCI - SGMII - QSGMII - SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Devices connected: EEPROM, thermal monitor, VID controller - Other IO - Two Serial ports - ProfiBus port Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> [York Sun: fixed Makefile] Acked-by: York Sun <yorksun@freescale.com>
2013-11-11MPC824x: remove obsolete "PN62" boardWolfgang Denk
The MPC824x processors have long reached EOL, and the PN62 board has not seen any board-specific updates for more than a decade. It is now causing build issues. Instead of wasting time on things nobody is interested in any more, we rather drop this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@grandegger.com> cc: Tom Rini <trini@ti.com>
2013-11-11Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-09malta: add myself to maintainersPaul Burton
This patch adds me as a maintainer of the malta(el) board(s). I have access to physical Malta boards and the desire for U-boot to run well on them. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09qemu-malta: rename to just "malta"Paul Burton
This is in preparation for adapting this board to function correctly on a physical MIPS Malta board. The board is moved into an "imgtec" vendor directory at the same time in order to ready us for any other boards supported by Imagination in the future. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-08boards.cfg: remove git leftoversLuka Perkov
Remove 'HEAD' line which is most likely left there while rebasing. It was introduced in commit 877bfe37dc00b0ae59f37742954a62bce3fdf3a0. Signed-off-by: Luka Perkov <luka@openwrt.org>
2013-11-08boards.cfg: remove trailing whitespacePaul Burton
Commit 93e14596 "Coding Style cleanup: replace leading SPACEs by TABs" added trailing whitespace to a single line of boards.cfg. I presume this was unintentional, and it causes the file to change after running it through the reformat.py script. Remove the offending character. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-07Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-11-01dra7xx_evm: Enabled UART-boot mode and add dra7xx_evm_uart3 buildMinal Shah
UART booting is supported on this SoC, but via UART3 rather than UART1. Because of this we must change the board to use UART3 for all console access (only one UART is exposed on this board and a slight HW mod is required to switch UARTs). Signed-off-by: Minal Shah <minal.shah@ti.com> [trini: Make apply to mainline, reword commit] Signed-off-by: Tom Rini <trini@ti.com>
2013-11-01tricorder: add configuration for a flashcard u-bootAndreas Bießmann
The 'flashcard' u-boot configuration has a readonly environment and boots a bare kernel/initrd to program the device from an clean environment. Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de>
2013-11-01OMAP3: igep00x0: rename config file to omap3_igep00x0.hJavier Martinez Canillas
There seems to be a naming convention for the configuration files for boards using the same SoC family. This makes easier to do changes that affect different boards based on the same SoC. Since the IGEPv2 board and the IGEP COM Module use a TI OMAP35xx/DM37xx processor, is better to rename its board config to use this naming scheme. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-11-01ARM: IGEP0033: rename config file to am335x_igep0033.hJavier Martinez Canillas
There seems to be a naming convention for the configuration files for boards using the same SoC family. This makes easier to do changes that affect different boards based on the same SoC. Since the IGEP COM AQUILA use a TI AM335x processor is better to rename its board config to use this naming scheme. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-10-24mpc85xx: introduce the kmp204x reference design supportValentin Longchamp
This patch introduces the support for Keymile's kmp204x reference design. This design is based on Freescale's P2040/P2041 SoC. The peripherals used by this design are: - DDR3 RAM with SPD support - SPI NOR Flash as boot medium - NAND Flash - 2 PCIe busses (hosts 1 and 3) - 3 FMAN Ethernet devices (FMAN1 DTSEC1/2/5) - 3 Local Bus windows, with one dedicated to the QRIO reset/power mgmt FPGA - 2 HW I2C busses - last but not least, the mandatory serial port The board/keymile/kmp204x code is mostly based on Freescale's P2041rdb support and was changed according to our design (that means essentially removing what is not present on the designs and a few adaptations). There is currently only one prototype board that is based on this design and this patch also introduces it. The board is called kmlion1. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> kmp204x: update the ENV #define The comments had to be refined as well as the total size Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> [York Sun: fix ddr.c] Acked-by: York Sun <yorksun@freescale.com>
2013-10-17ARM: mxs: Add PPC-AG BG0900 boardMarek Vasut
This board supports FEC Ethernet, SPI NOR and NAND flash. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Christoph Baumann <c.baumann@ppc-ag.de>
2013-10-17udoo: Add initial support for mx6q udoo boardFabio Estevam
Add basic support for mx6q udoo board. For further information about Udoo board: http://www.udoo.org/ Tested booting a mainline device tree kernel and a Yocto rootfs from mmc. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17arm: Remove IXP425 boards pdnb3 and scpuStefan Roese
Remove Prodrive pdnb3 board (including the scpu variant) support from mainline. As its unmaintained and not needed any more for quite some time. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Martijn de Gouw <martijn.de.gouw@prodrive.nl> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2013-10-16powerpc/p1010rdb: add p1010rdb-pb support with updating p1010rdb-paShengzhou Liu
- Rename old P1010RDB board as P1010RDB-PA. - Add support for new P1010RDB-PB board. - Some optimization. For more details, see board/freescale/p1010rdb/README. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: fix conflicts in boards.cfg] Acked-by: York Sun <yorksun@freescale.com>
2013-10-16powerpc/t1040qds: Add T1040QDS boardPrabhakar Kushwaha
T1040QDS is a high-performance computing evaluation, development and test platform supporting the T1040 QorIQ Power Architecture™ processor. T1040QDS board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Integrated 8-port Gigabit Ethernet switch - Four 1 Gbps Ethernet controllers - SERDES Connections, 8 lanes supporting: — PCI Express: supporting Gen 1 and Gen 2; — SGMII — QSGMII — SATA 2.0 — Aurora debug with dedicated connectors - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 8-bit, async, up to 2GB. - NOR: 8-bit or 16-bit, non-multiplexed, up to 512MB - GASIC: Simple (minimal) target within Qixis FPGA - PromJET rapid memory download support - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - QIXIS System Logic FPGA - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Power Supplies - Video - DIU supports video at up to 1280x1024x32bpp - USB - Supports two USB 2.0 ports with integrated PHYs — Two type A ports with 5V@1.5A per port. — Second port can be converted to OTG mini-AB - SDHC - SDHC port connects directly to an adapter card slot, featuring: - Supporting SD slots for: SD, SDHC (1x, 4x, 8x) and/or MMC — Supporting eMMC memory devices - SPI - On-board support of 3 different devices and sizes - Other IO - Two Serial ports - ProfiBus port - Four I2C ports Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: fix conflict in boards.cfg] Acked-by-by: York Sun <yorksun@freescale.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-10-14Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-10-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-10-08Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-10-07omap1510inn: arm925t: remove supportAlbert ARIBAUD
omap1510inn is orphan and has been for years now. Reove it and, as it was the only arm925t target, also remove arm925t support. Update doc/README.scrapyard accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-10-02Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-25samsung: trats2: add support for new board Trats2Piotr Wilczek
This patch add support for a new Samsung board Trats2. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-20boards.cfg: Fix the comment for invoking tools/reformat.py from vimAxel Lin
Add the missing bang (!) to execute external command, otherwise it does not work. Signed-off-by: Axel Lin <axel.lin@ingics.com>
2013-09-13Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: MAINTAINERS boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-09-12Merge and reformat boards.cfg and MAINTAINERSAlbert ARIBAUD
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
2013-09-11apf27: add support for the armadeus APF27 boardtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr> Signed-off-by: Eric Jarrige <eric.jarrige@armadeus.org> Signed-off-by: Nicolas Colombain <nicolas.colombain@armadeus.com>
2013-09-10ARM: mxs: Add SanDisk Sansa Fuze+ boardMarek Vasut
Add STMP3780-based Sansa Fuze+ board. This board is a small PMP device sporting a CPU which was later rebranded to i.MX233 . Currently supported is USB gadget mode and MMC . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-09-10ARM: mxs: Add Creative ZEN XFi3 boardMarek Vasut
Add STMP3780-based XFi3 board. This board is a small PMP device sporting a CPU which was later rebranded to i.MX233 . Currently supported is USB gadget mode and both external SD and internal Phison SD-NAND bridge . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-09-10ARM: mxs: Sort the mx23evk and mx23_olinuxinoMarek Vasut
These boards were not sortes in the boards.cfg, fix this. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-09-04Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-30exynos5250: Add arndale board supportChander Kashyap
Arndale board is based on samsung's exynos5250 soc. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
2013-08-21ARM: mxs: Add mx28evk_auart_console targetAndreas Wass
The target uses AUART 3 instead of the DUART for console output. Signed-off-by: Andreas Wass <andreas.wass@dalelven.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de>
2013-08-20ppc4xx: Remove CANBT boardMatthias Fuchs
This board and especially the CPU (PPC405CR) is EOL. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Wolfgang Denk <wd@denx.de>
2013-08-18Merge branch 'master' of git://88.191.163.10/u-boot-armTom Rini
Fixup an easy conflict over adding the clk_get prototype and USB_OTG defines for am33xx having moved. Conflicts: arch/arm/include/asm/arch-am33xx/hardware.h Signed-off-by: Tom Rini <trini@ti.com>
2013-08-17Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-15Add TI816X evm board supportTENART Antoine
Signed-off-by: Antoine Tenart <atenart@adeneo-embedded.com> [trini: Change to SPDX, fix a few compiler warnings, adapt to CONFIG_OMAP_COMMON] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15arm, da850: add ipam390 board supportHeiko Schocher
add the am1808 based ipam390 board from Barix. - 128MByte, DDR2, synchronous RAM 16bit databus to SDRAM interface - 128MByte, NAND Flash, 8bit databus to the NANDFlash Interface - Ethernet PHY Micrel KSZ8051R via RMII - Console on UART 0 - booting fron nand flash - spl falcon bootmode Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2013-08-15ARM: AM43xx: Add config fileLokesh Vutla
Add config file Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-08-09powerpc/c29xpcie: add support for C29XPCIE boardMingkai Hu
C29XPCIE board is a series of Freescale PCIe add-in cards to perform as public key crypto accelerator or secure key management module. It includes C293PCIE board, C293PCIE board and C291PCIE board. - 512KB platform SRAM in addition to 512K L2 Cache/SRAM - 512MB soldered DDR3 32bit memory - CPLD System Logic - 64MB x16 NOR flash and 4GB x8 NAND flash - 16MB SPI flash Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Singed-off-by: Po Liu <Po.Liu@freescale.com> [yorksun: Fixup include/configs/C29XPCIE.h] Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09p1020rdb-pd: platform supportHaijun.Zhang
Add new board p1020RDB-PD. P1020RDB-PD board was update from P1020RDB. DDR changed from DDR2 1G to DDR3 2G. NAND: 128 MiB Flash: 64 MiB Also change P1020RDB to P1020RDB-PC to distinguish from P1020RDB board. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> CC: Scott Wood <scottwood@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/T4240EMU: Add T4240EMU targetYork Sun
Add emulator support for T4240. Emulator has limited peripherals and interfaces. Difference between emulator and T4240QDS includes: ECC for DDR is disabled due the procedure to load images No board FPGA (QIXIS) NOR flash has 32-bit port for higher loading speed IFC and I2C timing don't really matter, so set them fast No ethernet Signed-off-by: York Sun <yorksun@freescale.com>
