path: root/board
2013-11-25Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-11-25board: tqm5200: delete its own object make ruleMasahiro Yamada
2013-11-25board: h2200: Delete an unnecessary make ruleMasahiro Yamada
We have a generic rule to generate .o file from *.S in $(TOPDIR)/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-21am335x: fix GPMC config for NAND and NOR SPL bootpekon gupta
GPMC controller is common IP to interface with both NAND and NOR flash devices. Also, it supports max 8 chip-selects, which can be independently connected to any of the devices. But ROM code expects the boot-device to be connected to only chip-select[0]. Thus to resolve conflict between NOR and NAND boot. This patch: - combines NOR and NAND configs spread in board files to common gpmc_init() - configures GPMC based on boot-mode selected for SPL boot. Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-21sama5d3xek: support larger than 4G nand flashWu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com>
2013-11-17Makefile: rename all libraries to built-in.oMasahiro Yamada
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-17Makefile: specifiy an explicite object name rather than $(BOARD).oMasahiro Yamada
2013-11-17board: Do not add -DCONFIG_SYS_TEXT_BASE in board config.mkMasahiro Yamada
Board config.mk do not need to add -DCONFIG_SYS_TEXT_BASE to CPPFLAGS because the top level config.mk does instead. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-15nios2: remove unnecessary header include pathMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Thomas Chou <thomas@wytron.com.tw>
2013-11-15board: cogent: include header files in a more natural wayMasahiro Yamada
2013-11-14Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-11-13powerpc/t104xrdb: Add T1042RDB_PI board supportPriyanka Jain
T1042RDB_PI is Freescale Reference Design Board supporting the T1042 QorIQ Power Architecture™ processor. T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit. The board is designed with low power features targeted for Printing Image Market. T1042RDB_PI is similar to T1040RDB board with few differences like it has video interface, supports T1042 personality T1042RDB_PI board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Two on-board RGMII 10/100/1G ethernet ports. - SERDES Connections, 8 lanes supporting: — PCI — SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Video - DIU supports video at up to 1280x1024x32bpp - HDMI connector - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Device connected: EEPROM, thermal monitor, VID controller, RTC - Other IO - Two Serial ports - ProfiBus port - Four I2C ports Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-11-13powerpc/t104xrdb: Add T1040RDB board supportPriyanka Jain
T1040RDB is Freescale Reference Design Board supporting the T1040 QorIQ Power Architecture™ processor. T1040RDB board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Integrated 8-port Gigabit Ethernet switch - Four 1 Gbps Ethernet controllers - SERDES Connections, 8 lanes supporting: - PCI - SGMII - QSGMII - SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Devices connected: EEPROM, thermal monitor, VID controller - Other IO - Two Serial ports - ProfiBus port Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> [York Sun: fixed Makefile] Acked-by: York Sun <yorksun@freescale.com>
2013-11-13powerpc/p1010rdb: update readme for p1010rdb-pa and p1010rdb-pbShengzhou Liu
- Remove duplicate doc/README.p1010rdb - Rename README to README.P1010RDB-PA - Add new README.P1010RDB-PB P1010RDB-PB is a variation of previous P1010RDB-PA board. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2013-11-13powerpc/t1040: enable PBL tool for T1040Prabhakar Kushwaha
Use a default RCW of protocol 0x66. A PBI configure file which uses CPC as 256KB SRAM. It can be used by PBL tool on T1040 to build a pbl boot image. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-13i2c: sh_i2c: Update to new CONFIG_SYS_I2C frameworkNobuhiro Iwamatsu
This updates to new I2C framwwork on sh_i2c. And this also updates boards(kzm9g and ecovec) that using sh_i2c. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-12cm_t35: use scf0403 driverNikita Kiryanov
Use scf0403 driver to add scf0403x LCD support for cm-t35 and cm-t3730 boards. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-11-11MPC824x: remove obsolete "PN62" boardWolfgang Denk
The MPC824x processors have long reached EOL, and the PN62 board has not seen any board-specific updates for more than a decade. It is now causing build issues. Instead of wasting time on things nobody is interested in any more, we rather drop this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@grandegger.com> cc: Tom Rini <trini@ti.com>
2013-11-11Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-09malta: add script & instructions to flash U-bootPaul Burton
This patch adds a script which may be used with MIPS Navigator Console and a MIPS Nagivator Probe in order to flash U-boot to a MIPS Malta development board. Please see the newly added doc/README.malta for usage instructions. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: setup PIIX4 interrupt routePaul Burton
Without setting up the PIRQ[A:D] interrupt routes, PCI interrupts will be left disabled. Linux does not set up this routing but relies upon it having been set up by the bootloader, reading back the IRQ lines which the PIRQ[A:D] signals have been routed to. This patch routes PIRQA & PIRQB to IRQ 10, and PIRQC & PIRQD to IRQ 11. This matches the setup used by YAMON. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: enable RTC supportPaul Burton
This is actually required in order for a Linux kernel to boot successfully on a physical Malta board. Without enabling the RTC, a Malta Linux kernel will get stuck in its estimate_frequencies function on boot. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: disable L2 cachesPaul Burton
Malta boards may be used with cores which support L2 caches, however U-boot does not yet support L2 cache for MIPS. Thus for the moment we'll disable L2 caches by setting the L2B bit in Config2. This is specific to MTI/Imagination MIPS cores which is why this is done for the Malta board rather than generically. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: display "U-boot" on the LCD screenPaul Burton
Displaying a message on the LCD screen is a simple yet effective way to show the user that the board has booted successfully. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: support for coreFPGA6 boardsPaul Burton
This patch adds support for running on Malta boards using coreFPGA6 core cards, including support for the msc01 system controller used with them. The system controller is detected at runtime allowing one U-boot binary to run on a Malta with either. Due to the PCI I/O base differing between Maltas using gt64120 & msc01 system controllers, the UART setup is modified slightly. A second UART is added so that there is one pointing at the correct address for each system controller. The Malta board then defines its own default_serial_console function to select the correct one at runtime. The incorrect UART will simply not function. Tested on: - A coreFPGA6 Malta running interAptiv and proAptiv bitstreams, both with and without an L2 cache. - QEMU. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: setup super I/O UARTsPaul Burton
On a real Malta the Super I/O needs to be configured before we are able to access the UARTs. This patch performs that configuration, setting up the UARTs in the same way that YAMON would. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09qemu-malta: rename to just "malta"Paul Burton
This is in preparation for adapting this board to function correctly on a physical MIPS Malta board. The board is moved into an "imgtec" vendor directory at the same time in order to ready us for any other boards supported by Imagination in the future. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-08Merge branch 'master' of git://www.denx.de/git/u-boot-usbTom Rini
2013-11-08sandbox: convert to common time functionsRob Herring
Convert sandbox to use common time functions. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-08include: delete include/linux/config.hMasahiro Yamada
Linux Kernel abolished include/linux/config.h long time ago. (around version v2.6.18..v2.6.19) We don't need to provide Linux copatibility any more. This commit deletes include/linux/config.h and fixes source files not to include this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08usb: ums: move ums code from trats to Samsung common directoryPrzemyslaw Marczak
UMS init was implemented in trats board file but mostly it comprises common code. Due to that it has been moved to common/ums.c to avoid code duplication in the future. Changes: - move ums initialization code from trats to common/ums.c - remove unused CONFIG_USB_GADGET_MASS_STORAGE from trats.h Changes v2: - move this patch at the top of code cleanups patches Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com>
2013-11-08usb: ums: fix disk capacity miscalculation and code cleanupPrzemyslaw Marczak
This patch prevents: - ums disk capacity miscalculation because of integer overflow Changes v2: - Prevents passing zero size disk capacity to ums gadget driver - Change function ums_get_capacity() to ums_disk_init() and do ums disk initialization before gadget init - Remove unnecessary code from mass storage driver Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-11-08usb: ums: code refactoring to improve reusability on other boards.Przemyslaw Marczak
This patch introduces some cleanups to ums code. Changes: ums common: - introduce UMS_START_SECTOR and UMS_NUM_SECTORS as defined in usb_mass_storage.h both default values as 0 if board config doesn't define them common cleanup changes: - change name of struct "ums_board_info" to "ums" - "ums_device" fields are moved to struct ums and "dev_num" is removed - change function name: board_ums_init to ums_init - remove "extern" prefixes from usb_mass_storage.h cmd_usb_mass_storage: - change error() to printf() if need to print info message - change return values to command_ret_t type at ums command code - add command usage string Changes v2: ums common: - always returns number of read/write sectors - coding style clean-up ums gadget: - calculate amount of read/write from device returned value. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com>
2013-11-08cosmetic: remove empty lines at the top of fileMasahiro Yamada
2013-11-08EP88x: remove remainders of dead boardMasahiro Yamada
Commit 1b0757e deleted the EP88x entry from boards.cfg file. But it missed to remove include/configs/EP88x.h and board/ep88x/. This commit removes them and adds EP88x to README.scrapyard. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2013-11-08kup: Delete an unused MakefileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Klaus Heydeck <heydeck@kieback-peter.de>
2013-11-07Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-11-06freescale: p1_p2_rdb_pc: rename COBJS-y to obj-yMasahiro Yamada
2013-11-05Merge branch 'u-boot-atmel/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-11-04arm: atmel: at91sam9n12ek: add usb host supportBo Shen
Add usb host support for at91sam9n12ek board. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-04ARM: vexpress: convert to common timer codeRob Herring
Convert vexpress to use the commmon timer code. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-04wandboard: README: Include the quad versionFabio Estevam
Wandboard quad was not ported into U-boot at the time of writing the README. Add it to the list of Wandboard variants. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-01cm_t35: update lcd predefinesNikita Kiryanov
Current predefines do not fit cm-t3730 very well (some of them produce artifacts in the image). Update LCD predefines to accommodate both cm-t35 and cm-t3730 modules. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-11-01am335x: Enable CONFIG_OMAP_WATCHDOG supportTom Rini
There is a board-specific portion for calling watchdog enable itself, in main U-Boot. Signed-off-by: Tom Rini <trini@ti.com>
2013-11-01cm-t35: move the display code to common placeIgor Grinberg
Compulab OMAP3 boards use the same display initialization code. Move the display initialization code to live under board/compulab/common directory. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-11-01cm-t35: move the eeprom code to common placeIgor Grinberg
Compulab boards use the same eeprom code, so move the eeprom related code to live under board/compulab/common directory. Also make several adjustments to eeprom functions namespace, so it will be generic for compulab boards. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
