path: root/board/trab/tsc2000.c
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-28Add generic support for samsung s3c2440C Nauman
This patch adds generic support for the Samsung s3c2440 processor. Global s3c24x0 changes to struct members converting from upper case to lower case. Signed-off-by: Craig Nauman <cnauman@diagraph.com> Cc: kevin.morfitt@fearnside-systems.co.uk Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Move s3c24x0 header files to asm-arm/arch-s3c24x0/kevin.morfitt@fearnside-systems.co.uk
This patch moves the s3c24x0 header files from include/ to include/asm-arm/arch-s3c24x0/. checkpatch.pl showed 2 errors and 3 warnings. The 2 errors were both due to a non-UTF8 character in David M?ller's name: ERROR: Invalid UTF-8, patch and commit message should be encoded in UTF-8 #489: FILE: include/asm-arm/arch-s3c24x0/s3c2410.h:3: + * David M?ller ELSOFT AG Switzerland. d.mueller@elsoft.ch As David's name correctly contains a non-UTF8 character I haven't fixed these errors. The 3 warnings were all because of the use of 'volatile' in s3c24x0.h: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt #673: FILE: include/asm-arm/arch-s3c24x0/s3c24x0.h:35: +typedef volatile u8 S3C24X0_REG8; +typedef volatile u16 S3C24X0_REG16; +typedef volatile u32 S3C24X0_REG32; I'll fix these errors in another patch. Tested by running MAKEALL for ARM8 targets and ensuring there were no new errors or warnings. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13Clean-up of s3c24x0 drivers excluding nand driverkevin.morfitt@fearnside-systems.co.uk
This patch re-formats the arm920t s3c24x0 driver files, excluding the nand driver, in preparation for changes to add support for the Embest SBC2440-II Board. The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patches 1/4 and 2/4 of this series Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-08-13trab: rename spi_init()Mike Frysinger
The local board-specific spi_init() function conflicts with the common SPI layer, so rename it to something board-specific. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-09ARM: Use do_div() instead of division for "long long".Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2006-06-16Fix TRAB channel switching delay for trab_fkt.bin standalone applikationWolfgang Denk
Patch by Martin Krause, 08 Nov 2005 In tsc2000_read_channel() the delay after setting the multiplexer to a temperature channel is increased from 1,5 ms to 10 ms. This is to allow the multiplexer inputs to stabilize after huge steps of the input signal level.
2005-02-24* Add support for ext2 filesystems and image timestamps to TQM5200 boardwdenk
* Add reset code for Coral-P on INKA4x0 board * Patch by Martin Krause, 28 Jun 2004: Update for TRAB board. * Fix some missing "volatile"s in MPC5xxx FEC driver
2003-09-12Move TRAB burn-in tests to TRAB board directoryLABEL_2003_09_12_1745wdenk
2003-09-11* Patch by Martin Krause, 11 Sep 2003:LABEL_2003_09_12_0110wdenk
add burn-in tests for TRAB board * Enable instruction cache on MPC5200 board
