The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
Apply changes from commit 44b4dbed to board/trab/memory.c, too.
Actually we'd need a major cleanup here - as it turns out,
board/trab/memory.c is more or less a verbatim copy of
post/drivers/memory.c ... but then, trab is EOL anyway,r
so this is not worth the effort.
Currently, both are defined as an unsigned long, but
should be phys_size_t. This should result in no real change,
since phys_size_t is currently an unsigned long for all the
default configs. Also add print_lnum to cmd_bdinfo to deal
with the potentially wider memsize.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Update etags build target
* Improve NetConsole support: add support for broadcast destination
address and buffered input.
* Cleanup compiler warnings for GCC 3.3.x and later
* Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
add burn-in tests for TRAB board
* Enable instruction cache on MPC5200 board
