Add new PID4 0090 Verdin iMX8M Mini Quad 4GB WB ET to support
the new hardware variant.
Upstream-Status: Submitted [https://lore.kernel.org/all/20240528095941.872693-1-ghidoliemanuele@gmail.com/]
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
Add new PID4 0089 Verdin iMX95 Hexa 16GB WB IT to config block handling.
Add new PID4 0088 Aquila AM69 Octa 32GB WB IT to config block handling.
Add new product id 0087 Verdin iMX8M Mini Quad 2GB IT.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20240308141801.49081-1-jpaulo.silvagoncalves@gmail.com/]
Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
Add new product id 0086 Verdin iMX8M Mini DualLite 2GB IT.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20240131173204.100407-1-jpaulo.silvagoncalves@gmail.com/]
Add new i.MX 8M Plus Quad SKU to ConfigBlock handling.
0070: Verdin iMX8M Plus Quad 8GB WB IT
This SKU is identical to 0066 but with Industrial Temperature Grade SoC.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230515130641.26028-1-francesco@dolcini.it/]
[ backported from https://lore.kernel.org/u-boot/20220706121505.448579-1-dev@pschenker.ch/T/#u ]
Add new i.MX 8M Mini SKU to ConfigBlock handling.
0068: Verdin iMX8M Mini Quad 2GB WB IT No CAN
This SKU is identical to 0055 but without CAN. Mention this in the name
so those modules can be distinguished.
Reviewed-by: Francesco Dolcini <francesco.dolcini@toradex.com>
[ backported from https://lists.denx.de/pipermail/u-boot/2022-June/486993.html ]
Add new Toradex MAC OUI (8c:06:cb), to the config block. With this change
we extend the possible serial-numbers as follows:
For serial-numbers 00000000-16777215 OUI 00:14:2d is taken
For serial-numbers 16777216-33554431 OUI 8c:06:cb is taken
Lower 24-bit of the serial number are used in the NIC part of the MAC address,
the complete serial number can be calculated using the OUI.
[ps: use kdiff3 to autoresolve conflicts]
0067: Apalis iMX8 QuadMax 8GB Wi-Fi / BT IT
This module is identical to its 4GB counterpart
0037: Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT
except for the RAM size.
Add new i.MX 6ULL and 8M Plus SKUs to ConfigBlock handling:
0062: Colibri iMX6ULL 1GB IT (eMMC)
0063: Verdin iMX8M Plus Quad 4GB IT
0064: Verdin iMX8M Plus Quad 2GB Wi-Fi / BT IT
0065: Verdin iMX8M Plus QuadLite 1GB IT
0066: Verdin iMX8M Plus Quad 8GB Wi-Fi / BT
Add new i.MX 8M Mini/Plus SKUs to ConfigBlock handling:
0058: Verdin iMX8M Plus Quad 4GB Wi-Fi / BT IT
0059: Verdin iMX8M Mini Quad 2GB IT
0060: Verdin iMX8M Mini DualLite 1GB WB IT
0061: Verdin iMX8M Plus Quad 2GB
Related-to: ELB-3128
Add migration routine from PID8 pre-stored values on EEPROM
(including sane value checks).
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit 1da2138819aa573b3d53f06bede90ccd6509bb82)
This introduces support for EEPROM as a storage for the main Toradex
config block and additional config blocks on extra EEPROM chips (on
carrier board or video adapters).
To enable EEPROM as a storage for the main config block:
TDX_HAVE_EEPROM=y.
For additional EEPROMs please enable this Kconfig symbol:
TDX_CFG_BLOCK_EXTRA=y.
Information about existing EEPROM chips is provided via Device Tree
using aliases.
You can also write configuration for the carrier board using
create_carrier subcommand for cfgblock. Example:
Verdin iMX8MM # cfgblock create_carrier
Supported carrier boards:
UNKNOWN CARRIER = [0]
Verdin Carrier Board = [1]
Choose your carrier board (provide ID): 1
Enter carrier board version (e.g. V1.1B): V1.0A
Enter carrier board serial number: 10622780
Also with barcode:
Verdin iMX8MM # cfgblock create carrier -y 0156100010622780
(cherry picked from commit d3eedd52f8e244cc036db522bfff9549397a75ed)
Add defines for supported carrier boards and display adapters.
(cherry picked from commit 65b107bd845a0df51d52acfdfaeda76934e0dd40)
This changes the define from VERDIN_IMX8MNSL to VERDIN_IMX8MNQ_WIFI_BT
in order to have a related naming to VERDIN_IMX8MMQ_WIFI_BT_IT and also
have the information in for wifi bluetooth.
This as well changes to the final decided naming.
Related-to: ELB-2642
(cherry picked from commit 7d872c04cc4d6da4e7f322c9591e79939661f368)
Add support for storing configuration for Verdin iMX8M Mini and
Nano SoMs in Toradex config block.
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Add support for storing configuration for Apalis iMX8X SoM
Add all the latest new SKUs:
- Apalis iMX8 QuadXPlus 2GB Wi-Fi / BT IT
- Apalis iMX8 QuadMax 4GB IT
- Apalis iMX8 QuadPlus 2GB Wi-Fi / BT
- Apalis iMX8 QuadPlus 2GB",
- Colibri iMX8 QuadXPlus 2GB IT
- Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Clean-up handling of several SKUs.
Add support for new Colibri iMX6ULL SKUs.
While at it also checkpatch fix the whole files.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Add Toradex factory configuration block handling. The config block is a
data structure which gets stored to flash during production testing. The
structure holds such information as board resp. hardware revision,
product ID and serial number which is used as the NIC part of the
Ethernet MAC address as well. The config block will be read upon boot by
the show_board_info() function, displayed as part of the board
information and passed to Linux via device tree or ATAGs.
