path: root/board/genietv/flash.c
2011-11-07board/genietv/flash.c: Fix flash initializationWolfgang Denk
The GENIETV has only one NOR flash bank. Remove all code trying to deal with a second bank. This also fixes a number of GCC 4.6 build warnings: flash.c:65:12: warning: array subscript is above array bounds [-Warray-bounds] flash.c:66:12: warning: array subscript is above array bounds [-Warray-bounds] flash.c:69:12: warning: array subscript is above array bounds [-Warray-bounds] flash.c:183:2: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type ' Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-07board/genietv/flash.c: CodingStyle cleanupWolfgang Denk
Make (mostly) checkpatch clean (don't convert to use I/O accessors yet, so there will be "Use of volatile is usually wrong" warnings left. Signed-off-by: Wolfgang Denk <wd@denx.de>
