path: root/board/armltd
2012-03-04integrator: remove fragile delay loop from PCI codeLinus Walleij
The reference implementation of the PCI initialization code almost everywhere contain this fragile loop of "a few usecs", and its use of volatile variables to delay a number of bus cycles is indeed uncertain. Reading the manual "Integrator/AP Users Guide", page 5-15 it is clearly stated: "Wait until 230ms after the end of the reset period before accessing V360EPC internal registers. The V360EPC supports the use of a serial configuration PROM and the software must wait for the device to detect the absence of this PROM before accessing any registers. The required delay is a function of the PCI Clock, but at the lower frequency (25MHz) is 230ms". So let's simply wait 230ms per the spec. This solves the compilation error that looked like this: pci.c: In function ‘pci_init_board’: pci.c:286:18: warning: variable ‘j’ set but not used Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-27integrator: rewrite the AP PCI driverLinus Walleij
The PCI support for the Integrator AP has apparently never been finished and I strongly suspect that it has never worked, so let's fix it. This is a list of the more or less un-splittable changes done in this driver rewrite: - Replace the register definitions stashed into the config file (!) with a copy if the register file from the Linux kernels arch/arm/include/asm/hardware/pci_v3.h - Delete the unreadable gigantic macros that perform the config accesses and replace them with copyedited code from Linux arch/arm/mach-integrator/pci_v3.c - Rewrite the rest of the setup code to use the v3_[read|write][lwb]() accessors. - Enable PCI by default in the AP board configuration. - Fix checkpatch warnings and make code more conformant. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-27integrator: stop calling pci_init() twiceLinus Walleij
The U-Boot startup infrastructure already makes sure pci_init() is called at a proper time, calling it again from within the board setup code will not make things better. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: enable Vpp and disable flash protectionLinus Walleij
This enables Vpp and disables the flash protection on the Integrator when starting U-Boot. The integrator/AP has double protection mechanisms: this one and the EBI protection bit (patch earlier), the Integrator/CP has only one line of protection in these registers. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: add system controller headerLinus Walleij
Break out the AP system controller and CP "CP controller" registers into a header file, it gives better overview than hardcoding its values and other disturbing practices. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: make flash writeable on bootLinus Walleij
This reconfigures the EBI (External Bus Interface) on the integrator so that chip select 1, handling the flash memory, is set to writeable. Without this it is not possible for U-Boot to access flash memory and it crashes on startup since CFI won't work properly. Since this is the first time we use the EBI, we create a header file for its registers. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: use io-accessors for board initLinus Walleij
Casting around to *(volatile ulong *) doesn't look good, so include the <asm/io.h> macros and use good old readl() instead. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: move text offset to configLinus Walleij
Do away with the config.mk file and move the text offset to the config files to make things easier. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-08integrator: do not test first part of the memoryLinus Walleij
When booting from Flash, the Integrator remaps its flash memory from 0x24000000 to 0x00000000, and starts executing it at 0x00000000. This ROM thus hides the RAM underneath and first 0x40000 bytes of the memory cannot be tested by get_ram_size(). So let's test from 0x40000 to the end of detected memory instead. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-28ARM: versatile: delete split_by_variant.shLinus Walleij
Since commit d388298a59ba375c76597b8f95b560afa971a0fb by Stefano Babic this file is no longer needed so delete it. Cc: Stefano Babic <sbabic@denx.de> Cc: Loïc Minier <loic.minier@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-04ARM: versatile: drop warningsStefano Babic
Drop warning: "passing argument 1 of 'get_ram_size' discards qualifiers from pointer target type" Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: support relocationLinus Walleij
The integrator board was apparently never converted over to support relocation until now. After this the integrator u-boot both compiles and boots on the Integrator AP. This also fixes the SDRAM memory size detection. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: make the compile work againLinus Walleij
The integratorap/cp config for u-boot was outdated and would not even compile, so fix the obvious missing bits for it to start building. After this "make ap920t_config/make all" starts working again. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-08-04ARM: versatile: fix board supportStefano Babic
Versatile board is used as example to run u-boot under qemu. The patch fixes relocation for all versatile boards and adds a versatileqemu target to be used under qemu. Patch tested only under qemu, not on real boards. Tested with QEMU emulator version 0.14.50. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Alessandro Rubini <rubini-list@gnudd.com> CC: Loïc Minier <loic.minier@linaro.org>
2011-07-26Timer: Remove reset_timer_masked()Graeme Russ
In some circumstances, reset_timer_masked() was called be timer_init() in order to perform architecture specific timer initialisation. In such cases, the required code in reset_timer_masked() has been moved into timer_init()
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-05-31ARMV7: Vexpress: Add missing MMC headerDirk Behme
Add a header file with the missing function prototype to fix ca9x4_ct_vxp.c: In function 'cpu_mmc_init': ca9x4_ct_vxp.c:93: warning: implicit declaration of function 'arm_pl180_mmci_init' introduced by commit "ARMV7: Vexpress: Add MMC support" (f0c64526b7e51ba997a0f1baf9e74e6d497b957e) Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> CC: Andy Fleming <afleming@freescale.com> CC: Matt Waddel <matt.waddel@linaro.org>
2011-04-29ARMV7: Vexpress: Add MMC supportMatt Waddel
Added the board specific definitions to use the MMCI device. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2011-04-27ARMV7: Vexpress: Remove config.mkMatt Waddel
Remove obsolete board config.mk. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2010-12-08ARMV7: Vexpress: Fix build errorDirk Behme
Fix ca9x4_ct_vxp build error Configuring for ca9x4_ct_vxp board... board/armltd/vexpress/libvexpress.o: In function `udelay': u-boot.git/board/armltd/vexpress/ca9x4_ct_vxp.c:161: multiple definition of `udelay' lib/libgeneric.o:u-boot.git/lib/time.c:34: first defined here lib/libgeneric.o: In function `udelay': zlib.c:(.text+0x1ee8): undefined reference to `__udelay' Signed-of-by: Dirk Behme <dirk.behme@googlemail.com>
2010-12-08ARMV7: Vexpress: fix compile warningsMatt Waddel
Fixed "pointer from integer without a cast" warnings in Vexpress. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2010-12-08ARMV7: Vexpress: fix build errorsMatt Waddel
This patch fixes build errors in the vexpress system: - Removed sys_proto.h requirement from syslib.c. - Switched vexpress to the default armv7 linker script. - Renamed TEXT_BASE to CONFIG_SYS_TEXT_BASE. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2010-10-13board/armltd/integrator/split_by_variant.sh: fix 'echo -n'Andreas Bießmann
This patch fixes an error when running MAKEALL for ARM9. On OS X /bin/sh uses builtin echo which does not utilise '-n' switch. GNU manual for builtins recomend to use here-document style to solve this portability issue. This patch removes the usage of 'echo -n' and replace by here-document style or a oneline echo command. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Peter Pearse <peter.pearse@arm.com>
2010-10-13ARMV7: Versatile Express Coretile CortexA9x4 supportMatt Waddel
Adds support for the ARM quad-core Cortex-A9 processor This system includes a motherboard(Versatile Express), daughterboard (Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet, and flash systems work with these additions. The naming convention is: SOC -> CortexA9 quad core = ca9x4 daughterboard -> Coretile = ct motherboard -> Versatile Express = vxp This gives ca9x4_ct_vxp.c as the board support file. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2010-04-04arm/integrator: Remove unneccessary CONFIG_PCI check.Detlev Zundel
pci_eth_init() is already conditional to CONFIG_PCI so not every caller needs to have conditionals. This is the only place in the current code base where such a check is still at the calling site. Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Ben Warren <biggerbadderben@gmail.com> CC: Peter Pearse <peter.pearse@arm.com>
2009-12-05Generic udelay() with watchdog supportIngo van Lil
According to the PPC reference implementation the udelay() function is responsible for resetting the watchdog timer as frequently as needed. Most other architectures do not meet that requirement, so long-running operations might result in a watchdog reset. This patch adds a generic udelay() function which takes care of resetting the watchdog before calling an architecture-specific __udelay(). Signed-off-by: Ingo van Lil <inguin@gmx.de>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-18ARM: make split_by_variant.sh output more usefulWolfgang Denk
The board/armltd/integrator/split_by_variant.sh script used to print "Configuring for integrator*p board..." no matter which board name was being compiled. This made it difficult to match MAKEALL output to board names. This patch fixes this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-12versatile: update config and merge to cfi flash driverJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Peter Pearse <peter.pearse@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com>
2009-06-23integrator: merge integratorap and integratorcpJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Peter Pearse <peter.pearse@arm.com>
2009-06-23integratorap/cp: use cfi driverJean-Christophe PLAGNIOL-VILLARD
2009-06-23integratorap/cp/versatile: remove non used functionsJean-Christophe PLAGNIOL-VILLARD
2009-06-23integratorcp: split timer supportJean-Christophe PLAGNIOL-VILLARD
2009-06-23integratorap: split timer supportJean-Christophe PLAGNIOL-VILLARD
2009-06-23integratorap: split pci supportJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
2009-04-05arm: clean cache managementJean-Christophe PLAGNIOL-VILLARD
unify arm cache management except for non standard cache as ARM7TDMI Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-29move ARM Ltd. to vendor dirJean-Christophe PLAGNIOL-VILLARD
