path: root/arch
2014-09-02Merge branch 'master' of git://git.denx.de/u-boot-arcTom Rini
2014-09-02Merge git://git.denx.de/u-boot-dmTom Rini
2014-09-02mpc5xxx: Add stub implementation of cache functionsVasili Galka
Some drivers (e.g. net/e1000) reference these functions. So, this fixes the build of MVBC_P board. I'm not familiar with the MPC5xxx platform, maybe a full implementation shall be implemented instead of this stub in the future. Signed-off-by: Vasili Galka <vvv444@gmail.com> Cc: Wolfgang Denk <wd@denx.de>, Marek Vasut <marex@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2014-08-31dm: sandbox: dts: Add a GPIO bankSimon Glass
Add a bank of GPIOs for sandbox which can be used for testing this functionality. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-31mx6: tqma6: get board support back to Kconfig build systemMasahiro Yamada
The QS Systems TQMa6 board support was added by commit cb07d74e and lost by commit e82abaeb. Commit e82abaeb merged the IMX branch based on pre-Kconfig and the mainline based on post-Kconfig, simply deleting the boards.cfg file. As a result, some boards added just before the merge were lost. This commit adds Kconfig, defconfig, MAINTAINERS for TQMa6 board to work on the Kconfig infrastructure. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de>
2014-08-31Merge branch 'master' of git://git.denx.de/u-boot-niosTom Rini
2014-08-30nomadik: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Nomadik board select menu to nomadik/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="nomadik"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30highbank: kconfig: move common settingsMasahiro Yamada
Move Highbank-specific settings to highbank/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <robh@kernel.org>
2014-08-30orion5x: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Orion5x board select menu to orion5x/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="orion5x"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-08-30keystone: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Keystone board select menu to keystone/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="keystone"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com>
2014-08-30omap5: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP5 board select menu to omap5/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap5"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
2014-08-30omap4: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP4 board select menu to omap4/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap4"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-08-30davinci: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Davinci board select menu to davinci/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="davinci"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2014-08-30exynos: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Exynos board select menu to exynos/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="exynos"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-08-30versatile: kconfig: move common settingsMasahiro Yamada
Move Versatile-specific settings to versatile/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-08-30zynq: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Zynq board select menu to zynq/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="zynq"). Refactor board/xilinx/zynq/MAINTAINERS too. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Michal Simek <michal.simek@xilinx.com>
2014-08-30arm: Add missing .vectors section to linker scriptsBenoît Thébaudeau
Commit 41623c9 'arm: move exception handling out of start.S files' missed some linker scripts. Hence, some boards no longer had exception handling linked since this commit. Restore the original behavior by adding the .vectors section to these linker scripts. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-08-30arm64: Correct passing of Linux kernel argsTom Rini
The Documentation/arm64/booting.txt document says that pass in x1/x2/x3 as 0 as they are reserved for future use. Signed-off-by: Tom Rini <trini@ti.com>
2014-08-30arm: convert Cygnus and NSP boards to KconfigSteve Rae
Convert the bcm958300k and the bcm958622hr boards from "boards.cfg" to Kconfig. Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: add Cygnus and NSP boardsScott Branden
The bcm_ep board configuration is used by a number of boards including Cygnus and NSP. Add builds for the bcm958300k and the bcm958622hr boards. Signed-off-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: bcmnsp: Add bcmnsp u-architectureScott Branden
Base support for the Broadcom NSP SoC. Based on iproc-common and the SoC specific reset function. Signed-off-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: bcmcygnus: Add bcmcygnus u-architectureScott Branden
Base support for the Broadcom Cygnus SoC. Based on iproc-common and the SoC specific reset function. Signed-off-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: iproc: Initial commit of iproc architecture codeScott Branden
The iproc architecture code is present in several Broadcom chip architectures, including Cygnus and NSP. Signed-off-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: vf610: add NFC clock supportStefan Agner
Add NFC (NAND Flash Controller) clock support and enable them at board initialization time. Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-08-30arm: vf610: add NFC pin muxStefan Agner
Add pin mux for NAND Flash Controller (NFC). NAND can be connected using 8 or 16 data lines, this patch adds pin mux entries for all 16 data lines. Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-08-30ARM: Fix overflow in MMU setupMarek Vasut
The patch fixes a corner case where adding size to DRAM start resulted in a value (1 << 32), which in turn overflew the u32 computation, which resulted in 0 and it therefore prevented correct setup of the MMU tables. The addition of DRAM bank start and it's size can end up right at the end of the address space in the special case of a machine with enough memory. To prevent this overflow, shift the start and size separately and add them only after they were shifted. Hopefully, we only have systems in tree which have DRAM size aligned to 1MiB boundary. If not, this patch would break such systems. On the other hand, such system would be broken by design anyway. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-08-30arm: bcm281xx: Add Ethernet Clock supportJiandong Zheng
Enable Ethernet clock when Broadcom StarFighter2 Ethernet block (CONFIG_BCM_SF2_ETH) is enabled. Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: ep9315: Add .vectors section to lds and remove obsolete ldsSergey Kostanbaev
However ep9315 don't use interrupt vectors during startup, but _startup symbol is used inside uboot to calculate actual monitor size. Signed-off-by: Sergey Kostanbaev <sergey.kostanbaev@gmail.com> Cc: albert.u.boot@aribaud.net
2014-08-30socfpga: initialize designware ethernetPavel Machek
Enable initialization fo designware ethernet controller. With this patch, ethernet works in my configuration, provided I set ethernet address in the environment. Signed-off-by: Pavel Machek <pavel@denx.de>
2014-08-30nios2: link to CONFIG_SYS_MONITOR_BASE and remove text_base hookThomas Chou
This patch changes the link script to base at CONFIG_SYS_MONITOR_BASE. Then we can remove the text_base hook in nios2-generic board. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2014-08-30nios2: move nios2.h to arch asm directoryThomas Chou
The nios2.h is nios2 cpu specific, and should go arch asm directory. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2014-08-30nios2: divide nios2-io.h into each specific drivers and remove itThomas Chou
The nios2-io.h defines hardware registers and bits of several FPGA IP cores. It could be divided in to the specific drivers, including altera timer, altera sysid, altera uart and altera jtag uart. The altera pio and altera spi drivers use their own hardware definitions. The removal of nios2-io.h will help modularity and maintenance. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2014-08-29socfpga: Fix SOCFPGA build error for Altera dev kitChin Liang See
To fix the build error when build for Altera dev kit, not virtual target. At same time, set the build for Altera dev kit as default instead virtual target. With that, U-Boot is booting well and SPL still lack of few drivers. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2014-08-29socfpga: fix clock manager register definitionPavel Machek
Structure defining clock manager hardware was wrong, leading to wrong registers being accessed and hang in MMC init. This fixes structure to match hardware. Signed-off-by: Pavel Machek <pavel@denx.de>
2014-08-29arm: include config.h in arch/arm/lib/vectors.SChristian Riesch
config.h is required for CONFIG_SYS_DV_NOR_BOOT_CFG. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
2014-08-29ARM:asm:io.h use static inlineJeroen Hofstee
When compiling u-boot with W=1 the extern inline void for read* is likely causing the most noise. gcc / clang will warn there is never a actual declaration for these functions. Instead of declaring these extern make them static inline so it is actually declared. cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-08-29Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-08-29Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblazeTom Rini
2014-08-29Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2014-08-29Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-08-29Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2014-08-28Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-08-26arc: Fix printf size_t format related warnings (again...)Vasili Galka
The basic idea: Define size_t using the __SIZE_TYPE__ compiler-defined type. For detailed explanation see similar patch for the nios2 arch: http://patchwork.ozlabs.org/patch/379938/ Signed-off-by: Vasili Galka <vvv444@gmail.com> Cc: Alexey Brodkin <alexey.brodkin@synopsys.com>
2014-08-25ARM: DRA: Enable VTT regulatorLokesh Vutla
DRA7 evm REV G and later boards uses a vtt regulator for DDR3 termination and this is controlled by gpio7_11. Configuring gpio7_11. The pad A22(offset 0x3b4) is used by gpio7_11 on REV G and later boards, and left unused on previous boards, so it is safe enough to enable gpio on all DRA7 boards. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-08-25ARM: DRA7: Enable software leveling for dra7Sricharan R
Currently hw leveling is enabled by default on DRA7/72. But the hardware team suggested to use sw leveling as hw leveling is not characterized and seen some test case failures. So enabling sw leveling on all DRA7 platforms. Signed-off-by: Sricharan R <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-08-25keystone2: use EFUSE_BOOTROM information to configure PLLsVitaly Andrianov
This patch reads EFUSE_BOOTROM register to see the maximum supported clock for CORE and TETRIS PLLs and configure them accordingly. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
