Add const to fix the compiler warning
cmd_hdmidet.c:34: warning: initialization from incompatible pointer type
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Register CCM_CHSCCDR (offset 0x34 in CCM) is named CCM_CHSCCDR in
reference manual, but was named chscdr in struct mxc_ccm_reg.
Signed-off-by: Thilo Jeremias <tjeremias@de.adit-jv.com>
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
This permits disabling the code relation in U-Boot which is useful when
debugging with an ICE.
To use it define CONFIG_SYS_SKIP_ARM_RELOCATION in your board.
Only the values used in the sabrelite board are
added currently. Add more as other boards use them.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Read memory setup registers to determine size
of available ram. This routine works for mx53/mx6x
I need this because when mx6solo called get_ram_size
with a too large maximum size, the system hanged.
Previously, the same value was returned for both mx6dl and mx6solo.
Check number of processors to differeniate.
Also, a freescale patch says that sololite has its cpu/rev
stored at 0x280 instead of 0x260.
I don't have a sololite to verify.
Microblaze platform can use CONFIG_OF_EMBED option
but also it is necessary to support boards
which don't want to use this option.
U-Boot doesn't compile dts/libdts.o for #undef CONFIG_OF_EMBED
case that's why it should be guarded by ifdef.
The patch
"include/linux/byteorder: import latest endian definitions from linux"
(sha1: eef1cf2d5cf1cae5fb76713e912263dedf110aeb)
Introduced a lot of compilation failures with unknow types.
include/linux/byteorder/big_endian.h:45:1: error: unknown type name '__le64'
include/linux/byteorder/big_endian.h: In function '__cpu_to_le64p':
include/linux/byteorder/big_endian.h:47:18: error: '__le64' undeclared (first use in this function)
include/linux/byteorder/big_endian.h:47:18: note: each undeclared identifier is reported only once for each function it appears in
include/linux/byteorder/big_endian.h:47:25: error: expected ';' before '__swab64p'
include/linux/byteorder/big_endian.h: At top level:
include/linux/byteorder/big_endian.h:49:1: error: unknown type name '__le64'
include/linux/byteorder/big_endian.h:53:1: error: unknown type name '__le32'
include/linux/byteorder/big_endian.h: In function '__cpu_to_le32p':
include/linux/byteorder/big_endian.h:55:18: error: '__le32' undeclared (first use in this function)
include/linux/byteorder/big_endian.h:55:25: error: expected ';' before '__swab32p'
include/linux/byteorder/big_endian.h:57:1: error: unknown type name '__le32'
include/linux/byteorder/big_endian.h:61:1: error: unknown type name '__le16'
Removing asm/bitops.h solved this problem.
Flushing caches is necessary because of soft reset
which doesn't clear caches.
Just remove ancient code.
Acked-by: Stephan Linz <linz@li-pro.net>
ext2_find_next_zero_bit must be also static if __swab32 is also static.
Warning:
include/asm/bitops.h:369:22: warning: '__fswab32' is static but
used in inline function 'ext2_find_next_zero_bit'
which is not static [enabled by default]
fdt.c:91:78: warning: Using plain integer as NULL pointer
fdt.c:103:78: warning: Using plain integer as NULL pointer
speed.c:55:11: warning: symbol 'corecnf_tab' was not declared. Should it be static?
speed.c:519:5: warning: symbol 'do_clocks' was not declared. Should it be static?
mpc8313erdb.c:73:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:74:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:75:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:76:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:79:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:80:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:81:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:82:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:85:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:86:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:87:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:88:17: warning: obsolete struct initializer, use C99 syntax
fsl_corenet_serdes.c:485:6: warning: symbol '__soc_serdes_init' was not declared. Should it be static?
cpu_init.c:185:6: warning: symbol 'invalidate_cpc' was not declared. Should it be static?
bcsr.c:28:27: warning: non-ANSI function declaration of function 'enable_8568mds_duart'
bcsr.c:39:33: warning: non-ANSI function declaration of function 'enable_8568mds_flash_write'
bcsr.c:46:34: warning: non-ANSI function declaration of function 'disable_8568mds_flash_write'
bcsr.c:53:29: warning: non-ANSI function declaration of function 'enable_8568mds_qe_mdio'
bcsr.c:28:33: warning: non-ANSI function declaration of function 'enable_8569mds_flash_write'
bcsr.c:33:34: warning: non-ANSI function declaration of function 'disable_8569mds_flash_write'
bcsr.c:38:28: warning: non-ANSI function declaration of function 'enable_8569mds_qe_uec'
bcsr.c:63:47: warning: non-ANSI function declaration of function 'disable_8569mds_brd_eeprom_write_protect'
ngpixis.c:245:1: error: directive in argument list
ngpixis.c:247:1: error: directive in argument list
ctrl_regs.c:31:5: warning: symbol 'fsl_ddr_get_version' was not declared. Should it be static?
cpu.c:135:14: warning: non-ANSI function declaration of function 'cpu_mask'
cpu.c:154:18: warning: non-ANSI function declaration of function 'cpu_numcores'
cpu.c:37:17: warning: symbol 'cpu_type_list' was not declared. Should it be static?
cpu.c:117:17: warning: symbol 'cpu_type_unknown' was not declared. Should it be static?
fsl_lbc.c:14:6: warning: symbol '__lbc_sdram_init' was not declared. Should it be static?
and:
lc_common_dimm_params.c:15:1: warning: symbol 'compute_cas_latency_ddr3' was not declared. Should it be static?
making it static produces the following compiler warning:
lc_common_dimm_params.c:15:1: warning: 'compute_cas_latency_ddr3' defined but not used [-Wunused-function]
so we protect it with the preprocessor.
traps.c:*:1: warning: symbol 'print_backtrace' was not declared. Should it be static?
traps.c:93:1: warning: symbol '_exception' was not declared. Should it be static?
board.c:166:6: warning: symbol '__board_add_ram_info' was not declared. Should it be static?
board.c:174:5: warning: symbol '__board_flash_wp_on' was not declared. Should it be static?
board.c:187:6: warning: symbol '__cpu_secondary_init_r' was not declared. Should it be static?
board.c:265:12: warning: symbol 'init_sequence' was not declared. Should it be static?
board.c:348:5: warning: symbol '__fixup_cpu' was not declared. Should it be static?
board.c:405:53: warning: Using plain integer as NULL pointer
extable.c:66:9: warning: symbol 'ex_tab_message' was not declared. Should it be static?
making it static can produce a new build warning on some boards:
extable.c:66:12: warning: 'ex_tab_message' defined but not used [-Wunused-variable]
but ex_tab_message doesn't do much even when used, so just remove it.
a fixup __iomem definition in arch code appears to be placed there as a cover
up from a code import from linux when u-boot didn't yet have a compiler.h,
introduced by commit 812711ce6b3a386125dcf0d6a59588e461abbb87 "Implement
__raw_{read,write}[bwl] on all architectures".
git show 812711ce6b3a386125dcf0d6a59588e461abbb87:include/linux/compiler.h
fatal: Path 'include/linux/compiler.h' exists on disk, but not in '812711ce6b3a386125dcf0d6a59588e461abbb87'.
u-boot's byteorder headers did not contain endianness attributions
for use with sparse, causing a lot of false positives. Import the
kernel's latest definitions, and enable them by including compiler.h
and types.h. They come with 'const' added for some swab functions, so
fix those up, too:
include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default]
Also, note: u-boot's historic __BYTE_ORDER definition has been
preserved (for the time being at least).
We also remove ad-hoc barrier() definitions, since we're including
compiler.h in files that hadn't in the past:
macb.c:54:0: warning: "barrier" redefined [enabled by default]
In addition, including compiler.h in byteorder changes the 'noinline'
definition to expand to __attribute__((noinline)). This fixes
arch/powerpc/lib/bootm.c:
bootm.c:329:16: error: attribute '__attribute__': unknown attribute
bootm.c:329:16: error: expected ')' before '__attribute__'
bootm.c:329:25: error: expected identifier or '(' before ')' token
powerpc sparse builds yield:
include/common.h:356:22: error: marked inline, but without a definition
the unknown-reason inlining without a definition is considered obsolete
given it was part of the 2002 initial commit, and no arm version was
'fixed.'
also fixed:
ydirectenv.h:60:0: warning: "inline" redefined [enabled by default]
and:
Configuring for devconcenter - Board: intip, Options: DEVCONCENTER
make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1
make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2
powerpc-fsl-linux-size: './u-boot': No such file
4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration':
include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available
4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here
and:
In file included from crc32.c:50:0:
crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration]
crc32table.h:4:1: error: initializer element is not constant
crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]')
[trini: Remove '#endif' in include/common.h around setenv portion]
Remove unused header
Signed-off-by: Vikram Narayanan <vikram186@gmail.com>
Timer is initialized already in board_init_r function in
(common/spl/spl.c) No need to initialize it again
Cc: Dinh Nguyen <dinguyen@altera.com>
When CONFIG_SYS_L2CACHE_OFF is defined we end up with a few warnings
currently. Re-order functions so that we don't have that anymore.
Board can implement function setup_board_tags which is used for adding atags
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Add back common.h header that was removed in previous patch so that
CONFIG_TEGRA can be evaluated correctly.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Initialize this variable to avoid a compiler warning about possible
use of uninitialized variable with gcc 4.4.6.
Change tegra SPL to use common SPL framework. Any tegra specific
initialization is now done in spl_board_init() instead of
board_init_f()/board_init_r(). Only one SPL boot target is supported
on tegra, which is boot to RAM image. jump_to_image_no_args() must be
overridden on tegra so the host CPU can be initialized.
Tested-by: Lucas Stach <dev@lynxeye.de>
Add an ASSERT() to u-boot.lds to detect an SPL that doesn't fit within
SPL_TEXT_BASE..SPL_MAX_SIZE.
Different .lds files implement this check in two possible ways:
1) An ASSERT() like this
2) Defining a MEMORY region of size SPL_MAX_SIZE, and re-directing all
linker output into that region. Since u-boot.lds is used for both
SPL and main U-Boot, this would entail only sometimes defining a
MEMORY region, and only sometimes performing that redirection, and
hence option (1) was deemed much simpler, and hence implemented.
Note that this causes build failures at least for NVIDIA Tegra Seaboard
and Ventana. However, these are legitimate; the SPL doesn't fit within
the required space, and this does cause runtime issues.
Acked-by: Allen Martin <amartin@nvidia.com>
Acked-by: Tom Rini <trini@ti.com>
These boards have long reached EOL, and there has been no indication
of any active users of such hardware for years. Get rid of the dead
weight.
Cc: Wolfgang Grandegger <wg@denx.de>
When -ffunction-sections or -fdata-section are used, symbols are placed
into sections such as .data.eserial1_device and .bss.serial_current.
Update the linker script to explicitly include these. Without this
change (at least with my gcc-4.5.3 built using crosstool-ng), I see that
the sections do end up being included, but __bss_end__ gets set to the
same value as __bss_start.
CONFIG_BAUDRATE and KS8695_UART_LINEC_WLEN8 used for UART registers
This is a dead code, remove it.
Clean up away old macros and such, so the file doesn't start piling
up cruft.
clean
This driver is no longer used, remove it.
This stuff has been rotting in the tree for a while now. Remove it.
This stuff has been rotting in the tree for a year now. Remove it.
imx-regs.h is meant to contain SoC register definitions.
Common SoC funtions should go to sys_proto.h instead.
The woodburn board is based on the MX35 SOC.
Support for both external (NOR) and internal
(SD Card) boot mode are added. It uses the
generic SPL framework to implement the internal boot
mode.
The following peripherals are supported:
- Ethernet (FEC)
- SD Card
- NAND (512 MB)
- NOR Flash
In the internal boot mode, a simple imximage header
is generated to set the address in internal RAM
where the SOC must copy the SPL code. The initial setup
is then demanded to the SPL itself.
The patch adds SPL for the arm1136 architecture and
inserts SPL (the produced binary) to clobber target
in the main Makefile.
The functions are required to use the generic
SPL Framework.
This patch modifies start.S for the arm1136 to make it
conform to start.S in armv7 architecture, to make it
usable if the SPL framework is used.
Patch fix warnings compiling with ELDK-4.2:
clock.c: In function 'get_standard_pll_sel_clk':
clock.c:341: warning: 'freq' may be used uninitialized in this function
Reported-by : Marek Vasut <marex@denx.de>
