path: root/arch/mips
2012-03-19usb: replace wait_ms() with mdelay()Mike Frysinger
Common code has a mdelay() func, so use that instead of the usb-specific wait_ms() func. This also fixes the build errors: ohci-hcd.c: In function 'submit_common_msg': /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1519:9: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1816:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1827:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1844:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1563:11: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1583:9: sorry, unimplemented: called from here make[1]: *** [ohci-hcd.o] Error 1 Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marex@denx.de>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-08arch/mips/lib/board.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: board.c: In function 'board_init_r': board.c:262:8: warning: unused variable 's' [-Wunused-variable] (raised for configurations without ethernet support like vct_premium_small) Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2011-12-08arch/mips/lib/board.c: make (mostly) checkpatch cleanWolfgang Denk
Fix all errors and all warnings except for "externs should be avoided" which could require more extensive changes. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2011-10-23mips: Use getenv_ulong() in place of getenv(), strtoulSimon Glass
This changes the board code to use the new getenv_ulong() function. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-23mips: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentAnton Staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Shinya Kuribayashi <skuribay@pobox.com>
2011-10-22consolidate mdelay by providing a common function for all usersAnatolij Gustschin
There are several mdelay() definitions in the driver and board code. Remove them all and provide a common mdelay() in lib/time.c. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-10MIPS: Ingenic XBurst Jz4740 processor supportXiangfu Liu
Jz4740 is a multimedia application processor targeting for mobile devices like e-Dictionary, eBook, portable media player (PMP) and GPS navigator. Jz4740 is powered by Ingenic 360 MHz XBurst CPU core (JzRISC), in which RISC/SIMD/DSP hybrid instruction set architecture provides high integration, high performance and low power consumption. JzRISC incorporated in Jz4740 is the advanced and power-efficient 32-bit RISC core, compatible with MIPS32, with 16K I-Cache and 16K D-Cache, and can operate at speeds up to 400 MHz. On-chip modules such as LCD controller, embedded audio codec, multi- channel SAR-ADC, AC97/I2S controller and camera I/F offer a rich suite of peripherals for multimedia application. NAND controller (SLC/MLC), USB (host 1.1 and device 2.0), UART, I2C, SPI, etc. are also available. For more info about Ingenic XBurst Jz4740: http://en.ingenic.cn/eng/ http://www.linux-mips.org/wiki/Ingenic This patch introduces XBurst CPU support in U-Boot. It's compatible with MIPS32, but requires a bit different cache maintenance, timer routines, and boot mechanism using USB boot tool, so XBurst support can go into a separate new home, cpu/xburst/. Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net> Acked-by: Daniel <zpxu@ingenic.cn> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-09-03MIPS: mips32: fix wrong loop bound in flush_cache()Yao Cheng
The issue is found when calling flush_cache() with zero "size" argument. The bound of loop is miscalculated in this case and flush_cache() enters a wrong flushing loop. Signed-off-by: Yao Cheng <saturdaycoder@gmail.com> Cc: Shinya Kuribayashi <skuribay@pobox.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Cc: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-07-31MIPS: make cache operation mode configurableDaniel Schwierzeck
Currently the cache operation mode is hard-coded to CONF_CM_CACHABLE_NONCOHERENT. This is not appropiate for CPUs or SOCs which operate at a different mode. This patch makes the cache operation mode configurable via board config. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-07-31MIPS: rename INFINEON_EBU_BOOTCFG to CONFIG_SYS_XWAY_EBU_BOOTFGDaniel Schwierzeck
This define is a board-specific config option and should be renamed to follow the U-Boot naming convention. Additionally, add an explaining comment for this option. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-05-10MIPS: Move timer code to arch/mips/cpu/$(CPU)/Shinya Kuribayashi
Current timer routines (arch/mips/lib/timer.c) are implemented assuming that MIPS32 coprocessor (CP0) resources, Counter and Compare registers in this case, are available. But this doesn't always work. We need to make sure that all MIPS-based systems don't necessarily use CP0 counter/compare registers as time keeping resources. And some MIPS variant processors might come with different hardware specs with genuine MIPS32 CP0 registers. With this change, each $(CPU)/ directory can have its own timer code. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-05-10MIPS: Introduce --gc-sections for MIPSDaniel Schwierzeck
All architectures but MIPS are using --gc-sections on final linking. This patch introduces that feature for MIPS to reduce the memory and flash footprint. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-05-07MIPS: Coding style cleanups on common assembly filesShinya Kuribayashi
Fix style issues and alignments globally. No logical changes. - Replace C comments with AS line comments where possible - Use ifndef where possible, rather than if !defined for simplicity - An instruction executed in a delay slot is now indicated by a leading space, not by C comment Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-05-07MIPS: Remove mips_cache_lock() featureShinya Kuribayashi
As requested in commit e1390801a3c1a2b6d12fa90be368efc19f5b9bfd ([MIPS] Request for the 'mips_cache_lock()' removal), such feature is no longer needed for current MIPS implementation of U-Boot, and no one in the tree uses it for years. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-04-02MIPS: Au1x00: Move all Au1x00 specific code to separate subdirectoryDaniel Schwierzeck
Au1x00 is a SoC and its specific code should reside in an own SoC subdirectory. Also add -mtune=4kc flag for CPU optimization. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Thomas Lange <thomas@corelatus.se> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-02MIPS: IncaIP: Move all IncaIP specific code to separate subdirectoryDaniel Schwierzeck
IncaIP is a SoC and its specific code should reside in an own SoC subdirectory. Also add -mtune=4kc flag for CPU optimization. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-02MIPS: Optimize the setup of CPU optimization flagsDaniel Schwierzeck
The current MIPS CPU config.mk code always expects a MIPS 4kc core. This is not appropiate for other CPUs and SoCs. Replace the current MIPSFLAGS code by cc-option macro and use -march=mips32r2 as default optimization level for all MIPS32 CPUs. Note: Since commit f62fb99941c625605aa16a0097b396a5c16d2c88 all toolchains with binutils prior to v2.16 are not working anymore. As agreed with Shinya Kuribayashi the support for those toolchains will be dropped officially with this patch. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-02MIPS: Move content of arch/mips/cpu to arch/mips/cpu/mips32Daniel Schwierzeck
All current CPUs and SoCs are based on MIPS32 arch. The complete code resides in the global arch/mips/cpu directory. This is not suitable if other MIPS architectures like MIPS64 or Octeon should be supported in the future. To achieve this the current CPU code is moved to its own mips32 subdirectory. All MIPS32 boards have to use mips32 as config switch in board.cfg. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-02MIPS: Purple: Remove Purple supportDaniel Schwierzeck
The Purple SoC and eval board are not actively maintained since years. This patch removes the support completely as aggreed with Wolfgang Denk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-19board_init_r: Removed unused cmdtp variableRichard Retanubun
Follow up to commit 620f1f6a64095ed558e68d37f1965d015cd49b02 removed compiler warning for (now) unused cmd_tbl_t* cmdtp
2010-09-19common: move TOTAL_MALLOC_LEN to include/common.hHeiko Schocher
Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19relocation: fixup cmdtableHeiko Schocher
fixup_cmdtable() did all work for fixing up the cmdtable, if CONFIG_RELOC_FIXUP_WORKS is not defined. CONFIG_RELOC_FIXUP_WORKS is missing for i386! I talked with Graeme Russ, and he will fix this soon. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19arm: get rid of bi_envHeiko Schocher
bi_env is nowhere used, so delete it! Signed-off-by: Heiko Schocher <hs@denx.de> similar patch posted from Dirk Behme Tue Jul 27 18:36:09 CEST 2010 http://lists.denx.de/pipermail/u-boot/2010-July/074542.html
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-09-19Make getenv() work before relocation.Wolfgang Denk
So far, getenv() would work before relocation is most cases, even though it was not intended to be used that way. When switching to a hash table based implementation, this would break a number of boards. For convenience, we make getenv() check if it's running before relocation and, if so, use getenv_f() internally. Note that this is limited to simple cases, as we use a small static buffer (32 bytes) in the global data for this purpose. For this reason, it is also not a good idea to convert all current uses of getenv_f() into getenv() - some of the existing use cases need to be able to deal with longer variable values, so getenv_f() is still needed and recommended for use before relocation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-04-13mips: Move cpu/mips/* to arch/mips/cpu/*Peter Tyser
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
