Currently the timeout waiting for an ARP reply is hard set to 5 seconds.
On i.MX31ADS due to a hardware "strangeness" up to four first IP packets
to the boards get lost, which typically are ARP replies. By configuring
the timeout to a lower value we significantly improve the first network
transfer time on this board. The timeout is specified in milliseconds,
later internally it is converted to deciseconds, because it has to be
converted to hardware ticks, and CFG_HZ ranges from 900 to 27000000 on
different boards.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
MC13783 is a multifunction IS with an SPI interface to the host. This
driver handles the RTC controller in this chip.
This is an SPI driver for i.MX and MXC based SoCs from Freescale. So far
only implemented and tested on i.MX31, can with a modified register layout
and definitions be used for i.MX27, I think, MXC CPUs have similar SPI
controllers too.
- document 'bootm_low' and 'bootm_size' environment variables
- update inaccurate CFG_BOOTMAPSZ entry
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Some NOR flash chip from Spansion, for example, the s29ws-n MirrorBit
series require different addresses for buffered write commands. Define a
configuration option to support buffered writes on those chips. A more
elegant solution would be to automatically detect those chips by parsing
their CFI records, but that would require introduction of a fixup table
into the cfi_flash driver.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
finish off what commit 43ddd9c820fec44816188f53346b464e20b3142d,
"Remove deprecated CONFIG_OF_HAS_UBOOT_ENV and CONFIG_OF_HAS_BD_T"
started.
Add 82541ER device with latest integrated IGP2 PHY.
Introduced CONFIG_E1000_FALLBACK_MAC for NIC bring-up with empty eeprom.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Added option CONFIG_BOOTP_DHCP_REQUEST_DELAY. This provides an optional
delay before sending "DHCP Request" in net/bootp.c. Required to overcome
interoperability problems with Windows Server 200x DHCP server when U-Boot
client responds too fast for server to handle.
Signed-off-by: Aras Vaichas <arasv@magtech.com.au>
If CFG_MEM_TOP_HIDE is defined in the board config header, this specified
memory area will get subtracted from the top (end) of ram and won't get
"touched" at all by U-Boot. By fixing up gd->ram_size the Linux kernel
should gets passed the now "corrected" memory size and won't touch it
either. This should work for arch/ppc and arch/powerpc. Only Linux board
ports in arch/powerpc with bootwrapper support, which recalculate the
memory size from the SDRAM controller setup, will have to get fixed
in Linux additionally.
This patch enables this config option on some PPC440EPx boards as a workaround
for the CHIP 11 errata. Here the description from the AMCC documentation:
CHIP_11: End of memory range area restricted access.
Category: 3
Overview:
The 440EPx DDR controller does not acknowledge any
transaction which is determined to be crossing over the
end-of-memory-range boundary, even if the starting address is
within valid memory space. Any such transaction from any PLB4
master will result in a PLB time-out on PLB4 bus.
Impact:
In case of such misaligned bursts, PLB4 masters will not
retrieve any data at all, just the available data up to the
end of memory, especially the 440 CPU. For example, if a CPU
instruction required an operand located in memory within the
last 7 words of memory, the DCU master would burst read 8
words to update the data cache and cross over the
end-of-memory-range boundary. Such a DCU read would not be
answered by the DDR controller, resulting in a PLB4 time-out
and ultimately in a Machine Check interrupt. The data would
be inaccessible to the CPU.
Workaround:
Forbid any application to access the last 256 bytes of DDR
memory. For example, make your operating system believe that
the last 256 bytes of DDR memory are absent. AMCC has a patch
that does this, available for Linux.
This patch sets CFG_MEM_TOP_HIDE for the following 440EPx boards:
lwmon5, korat, sequoia
The other remaining 440EPx board were intentionally not included
since it is not clear to me, if they use the end of ram for some
other purpose. This is unclear, since these boards have CONFIG_PRAM
defined and even comments like this:
PMC440.h:
/* esd expects pram at end of physical memory.
* So no logbuffer at the moment.
It is strongly recommended to not use the last 256 bytes on those
boards too. Patches from the board maintainers are welcome.
Fix typo in README
The default settings for RTC DS1337 keeps the OSC
output, 32,768 Hz, on. This add CFG_RTC_DS1337_NOOSC to
turn it off.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
common/cmd_bootm.c
cpu/mpc8xx/cpu.c
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
Signed-off-by: Tor Krill <tor@excito.com>
Create doc/uImage.FIT documentation directory with the following files:
- command_syntax_extensions.txt : extended command syntax description
- howto.txt : short usage howto
- source_file_format.txt : internal new uImage format description
Add example image source files:
- kernel.its
- kernel_fdt.its
- multi.its
Update README appropriately.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Save FIT configuration provied in the first bootm argument and use it
when to get ramdisk/FDT subimages when second and third (ramdisk/FDT)
arguments are not specified.
This patch allocates a set of show_boot_progress() IDs for new uImage format
and adds show_boot_progress() calls in new uImage format handling code.
Makefile
doc/README.standalone
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc
will refuse to use load/store multiple insns; instead, it issues a
list of simple load/store instructions upon function entry and exit,
resulting in bigger code size, which in turn makes the build for a
few boards fail.
Use r2 instead.
allow to load the microde from flash or ram by download it through
the serial or other.
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
This patch adds support for the SPI controller found on Freescale PowerPC
processors such as the MCP834x family. Additionally, a new config option,
CONFIG_HARD_SPI, is added for general purpose SPI controller use.
[PATCH] net: add 'ethrotate' environment variable
This patch replaces the buildtime configuration option
CONFIG_NET_DO_NOT_TRY_ANOTHER through the 'ethrotate' runtime
configuration veriable. See README.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
This patch removes the FPGA subsystem configuration through
the CONFIG_FPGA bitmask configuration option.
See README for the new options:
CONFIG_FPGA,
CONFIG_FPGA_<vendor>,
CONFIG_FPGA_<family>
As noted by Kim Phillips, these lists tend to become out of date.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Changed the wording to properly describe the shadowing
of the environment from ROM to RAM
Signed-off-by: Bruce Adler <bruce.adler@acm.org>
and make some minor corrections to the FDT part of the README.
Implemented IETF RFC2090, Multicast TFTP. Initial implementation
on Realtek RTL8139 and Freescale TSEC.
Signed-off-by: David Updegraff <dave@cray.com>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
Added CONFIG_BOOTP_SERVERIP to allow the tftp server to be different
from the bootp server
Signed-off-by: Wilson Callan <wcallan@savantav.com>
