path: root/README
2016-03-09MLK-10524: iMX6x: Implement workaround for Cortex-A9 errata 845369Nitin Garg
Under very rare timing circumstances, transitioning into streaming mode might create a data corruption. Present on Two or more processors or 1 core with ACP, all revisions. This erratum can be worked round by setting bit[22] of the undocumented Diagnostic Control Register to 1. Signed-off-by: Nitin Garg <nitin.garg@freescale.com> (cherry picked from commit 70ad44e523680de67dd8b7a7505d7f27799980ee)
2015-04-10Introduce CONFIG_SPL_PANIC_ON_RAW_IMAGEAlbert ARIBAUD \(3ADEV\)
introduce CONFIG_SPL_PANIC_ON_RAW_IMAGE. An SPL which define this will panic() if the image it has loaded does not have a mkimage signature. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-28generic-board: move __HAVE_ARCH_GENERIC_BOARD to KconfigMasahiro Yamada
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-13README: remove description about driver model configuration options (again)Masahiro Yamada
The Driver Model description in README was removed by commit 65eb659e56fa (README: remove description about driver model configuration options), and was revived by mistake by commit b79dadf846e5 when resolving the conflict. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-13ARM: Introduce erratum workaround for 621766Nishanth Menon
621766: Under a specific set of conditions, executing a sequence of NEON or vfp load instructions can cause processor deadlock Impacts: Every Cortex-A8 processors with revision lower than r2p1 Work around: Set L1NEON to 1 Based on ARM errata Document revision 20.0 (13 Nov 2010) Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13ARM: Introduce erratum workaround for 430973Nishanth Menon
430973: Stale prediction on replaced inter working branch causes Cortex-A8 to execute in the wrong ARM/Thumb state Impacts: Every Cortex-A8 processors with revision lower than r2p1 Work around: Set IBE to 1 Based on ARM errata Document revision 20.0 (13 Nov 2010) Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13ARM: Introduce erratum workaround for 454179Nishanth Menon
454179: Stale prediction may inhibit target address misprediction on next predicted taken branch Impacts: Every Cortex-A8 processors with revision lower than r2p1 Work around: Set IBE and disable branch size mispredict to 1 Also provide a hook for SoC specific handling to take place if needed. Based on ARM errata Document revision 20.0 (13 Nov 2010) Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13ARM: Introduce erratum workaround for 798870Nishanth Menon
Add workaround for Cortex-A15 ARM erratum 798870 which says "If back-to-back speculative cache line fills (fill A and fill B) are issued from the L1 data cache of a CPU to the L2 cache, the second request (fill B) is then cancelled, and the second request would have detected a hazard against a recent write or eviction (write B) to the same cache line as fill B then the L2 logic might deadlock." Implementations for SoC families such as Exynos, OMAP5/DRA7 etc will be widely different. Every SoC has slightly different manner of setting up access to L2ACLR and similar registers since the Secure Monitor handling of Secure Monitor Call(smc) is diverse. Hence an weak function is introduced which may be overriden to implement SoC specific accessor implementation. Based on ARM errata Document revision 18.0 (22 Nov 2013) Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-10Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: README Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-05README: remove description about driver model configuration optionsMasahiro Yamada
All the DM-related configuration options are described in Kconfig helps. They should not be duplicated in README. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-03-04arm: spl: Allow board_init_r() to run with a larger stackSimon Glass
At present SPL uses a single stack, either CONFIG_SPL_STACK or CONFIG_SYS_INIT_SP_ADDR. Since some SPL features (such as MMC and environment) require a lot of stack, some boards set CONFIG_SPL_STACK to point into SDRAM. They then set up SDRAM very early, before board_init_f(), so that the larger stack can be used. This is an abuse of lowlevel_init(). That function should only be used for essential start-up code which cannot be delayed. An example of a valid use is when only part of the SPL code is visible/executable, and the SoC must be set up so that board_init_f() can be reached. It should not be used for SDRAM init, console init, etc. Add a CONFIG_SPL_STACK_R option, which allows the stack to be moved to a new address before board_init_r() is called in SPL. The expected SPL flow (for CONFIG_SPL_FRAMEWORK) is documented in the README. Signed-off-by: Simon Glass <sjg@chromium.org> For version 1: Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-04ARM: tegra: support running in non-secure modeStephen Warren
When the CPU is in non-secure (NS) mode (when running U-Boot under a secure monitor), certain actions cannot be taken, since they would need to write to secure-only registers. One example is configuring the ARM architectural timer's CNTFRQ register. We could support this in one of two ways: 1) Compile twice, once for secure mode (in which case anything goes) and once for non-secure mode (in which case certain actions are disabled). This complicates things, since everyone needs to keep track of different U-Boot binaries for different situations. 2) Detect NS mode at run-time, and optionally skip any impossible actions. This has the advantage of a single U-Boot binary working in all cases. (2) is not possible on ARM in general, since there's no architectural way to detect secure-vs-non-secure. However, there is a Tegra-specific way to detect this. This patches uses that feature to detect secure vs. NS mode on Tegra, and uses that to: * Skip the ARM arch timer initialization. * Set/clear an environment variable so that boot scripts can take different action depending on which mode the CPU is in. This might be something like: if CPU is secure: load secure monitor code into RAM. boot secure monitor. secure monitor will restart (a new copy of) U-Boot in NS mode. else: execute normal boot process Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-02Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-02-25crypto/fsl - Add progressive hashing support using hardware acceleration.gaurav rana
Currently only normal hashing is supported using hardware acceleration. Added support for progressive hashing using hardware. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> CC: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-24driver/ddr/fsl: Add sync of refreshYork Sun
Add sync of refresh for multiple DDR controllers. DDRC initialization needs to complete first. Code is re-ordered to keep refresh close. Signed-off-by: York Sun <yorksun@freescale.com>
2015-02-17cmd_eeprom: make it possible to define the used i2c busChristian Gmeiner
A SoC like the i.MX6 supports more then one i2c bus. In oder to be able to use the eeprom command add a new define to specify the i2c bus to use. If CONFIG_SYS_I2C_EEPROM_BUS is not defined there is no functional change, else a call to i2c_set_bus_num(..) is done before calling i2c_read(..) and i2c_write(..). Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-02-07arm, at91, wdt: make timeout configurableHeiko Schocher
make the HW WDT timeout configurable through the define CONFIG_AT91_HW_WDT_TIMEOUT. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-01-30Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
2015-01-29lib/rsa: Modify rsa to use DM driverRuchika Gupta
Modify rsa_verify to use the rsa driver of DM library .The tools will continue to use the same RSA sw library. CONFIG_RSA is now dependent on CONFIG_DM. All configurations which enable FIT based signatures have been modified to enable CONFIG_DM by default. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29dumpimage: add 'T' option to explicitly set the image typeGuilherme Maciel Ferreira
Some image types, like "KeyStone GP", do not have magic numbers to distinguish them from other image types. Thus, the automatic image type discovery does not work correctly. This patch also fix some integer type mismatches. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2015-01-05doc: fix grammatical errors in READMEJeremiah Mahler
Fix various spelling and grammatical errors in the README. Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-05powerpc: mpc824x: remove MPC824X cpu supportMasahiro Yamada
All the MPC824X boards are still non-generic boards: A3000, CPC45, CU824, eXalion, MVBLUE, MUSENKI, Sandpoint824x, utx8245 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Torsten Demke <torsten.demke@fci.com> Cc: Jim Thompson <jim@musenki.com> Cc: Greg Allen <gallen@arlut.utexas.edu>
2015-01-01Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2014-12-18ARM: Implement non-cached memory supportThierry Reding
Implement an API that can be used by drivers to allocate memory from a pool that is mapped uncached. This is useful if drivers would otherwise need to do extensive cache maintenance (or explicitly maintaining the cache isn't safe). The API is protected using the new CONFIG_SYS_NONCACHED_MEMORY setting. Boards can set this to the size to be used for the non-cached area. The area will typically be right below the malloc() area, but architectures should take care of aligning the beginning and end of the area to honor any mapping restrictions. Architectures must also ensure that mappings established for this area do not overlap with the malloc() area (which should remain cached for improved performance). While the API is currently only implemented for ARM v7, it should be generic enough to allow other architectures to implement it as well. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18fastboot: handle flash write to GPT partitionsSteve Rae
Implement a feature to allow fastboot to write the downloaded image to the space reserved for the Protective MBR and the Primary GUID Partition Table. Additionally, prepare and write the Backup GUID Partition Table. Signed-off-by: Steve Rae <srae@broadcom.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [Test HW: Exynos4412 - Trats2]
2014-12-08Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2014-12-08spl: MMC U-Boot image load from raw partitionPaul Kocialkowski
Raw images of U-Boot can be stored inside MMC partitions, so it makes sense to read the partition table, looking for a partition number instead of using a fixed sector address. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Only add mmc_load_image_raw_partition() when CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION to avoid warning, add missing conversion in spl_mmc_load_image()] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-05powerpc/mpc85xx:Put errata number for T104x NAND boot issuePrabhakar Kushwaha
When device is configured to load RCW from NAND flash IFC_A[16:31] are driven low after RCW loading. Hence Devices connected on IFC_CS[1:7] and using IFC_A[16:31] lines are not accessible. Workaround is already in-place. Put the errata number to adhere errata handling framework. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-04MMC SD fs boot partition config coding style and proper descriptionPaul Kocialkowski
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. In addition, it is not related to raw mode booting but to fs mode instead. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-26Merge git://git.denx.de/u-boot-fdtTom Rini
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23hush: add CONFIG_HUSH_PARSER to KconfigMasahiro Yamada
The README file states that the macros beginning with "CONFIG_SYS_" depend on the hardware etc. and should not be meddled with if you do not what you're doing. We have already screwed up with this policy; we have given the prefix "CONFIG_SYS_" to many user-selectable configurations. Here, "CONFIG_SYS_HUSH_PARSER" is one of them. Users can enable it if they want to use a more powerful command line parser, or disable it if they only need a simple one. This commit attempts to rename CONFIG_SYS_HUSH_PARSER to CONFIG_HUSH_PARSER and move it to Kconfig. Every board maintainer is expected to enable CONFIG_HUSH_PARSER (= add "CONFIG_HUSH_PARSER=y" to his defconfig file) and remove "#define CONFIG_SYS_HUSH_PARSER" from his header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23fs: make it possible to read the filesystem UUIDChristian Gmeiner
Some filesystems have a UUID stored in its superblock. To allow using root=UUID=... for the kernel command line we need a way to read-out the filesystem UUID. changes rfc -> v1: - make the environment variable an option parameter. If not given, the UUID is printed out. If given, it is stored in the env variable. - corrected typos - return error codes changes v1 -> v2: - fix return code of do_fs_uuid(..) - document do_fs_uuid(..) - implement fs_uuid_unsuported(..) be more consistent with the way other optional functionality works changes v2 -> v3: - change ext4fs_uuid(..) to make use of #if .. #else .. #endif construct to get rid of unreachable code Hit any key to stop autoboot: 0 => fsuuid fsuuid - Look up a filesystem UUID Usage: fsuuid <interface> <dev>:<part> - print filesystem UUID fsuuid <interface> <dev>:<part> <varname> - set environment variable to filesystem UUID => fsuuid mmc 0:1 d9f9fc05-45ae-4a36-a616-fccce0e4f887 => fsuuid mmc 0:2 eb3db83c-7b28-499f-95ce-9e0bb21cda81 => fsuuid mmc 0:1 uuid1 => fsuuid mmc 0:2 uuid2 => printenv uuid1 uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887 => printenv uuid2 uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81 => Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-11-21dm: Update documentation to include CONFIG_DM... optionsSimon Glass
Add documentation for the various driver model options that are now available. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21fdt: Add ft_system_setup() function for system device tree additionsSimon Glass
Add an additional function for adding information to the device tree before booting. This permits additions which are not board-specific. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-17spl, nand: add option to boot raw u-boot.bin image onlyHeiko Schocher
enable to boot only a raw u-boot.bin image from nand with the CONFIG_SPL_NAND_RAW_ONLY define. This option saves space on boards where spl space is low. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-07doc: fix documentation of out-of-tree buildTimo Ketola
Correct environment variable for output directory is KBUILD_OUTPUT. Signed-off-by: Timo Ketola <timo@exertus.fi>
2014-10-27doc: Update documentation according to the EXT SPL support patch setGuillaume GARDET
Update documentation according to the EXT SPL support patch set. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-10-27Provide option to avoid defining a custom version of uintptr_t.Gabe Black
There's a definition in stdint.h (provided by gcc) which will be more correct if available. Define CONFIG_USE_STDINT to use this feature, or USE_STDINT=1 on the 'make' commmand. This adjusts the settings for x86 and sandbox, with both have 64-bit options. Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org> Reviewed-by: Bill Richardson <wfrichar@google.com> Rewritten to be an option, since stdint.h is often available only in glibc. Changed to preserve a clear boundary between stdint and non-stdint Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-26Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-10-23kconfig: move CONFIG_SYS_HZ to lib/KconfigMasahiro Yamada
CONFIG_SYS_HZ is always defined as 1000 in config_fallbacks.h (but some boards still have redundant definitions). This commit moves the definition and the document in README to Kconfig. Since lib/Kconfig can assure that CONFIG_SYS_HZ is 1000, the sanity check in lib/time.c should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-10-23Makefile: Add CONFIG_BUILD_TARGET to automatically build an special imageStefan Roese
Add target to build it automatically upon "make" / MAKEALL. This can/should be set by board / cpu specific headers if a special U-Boot image is required for this SoC / board. E.g. used by Marvell Armada XP to automatically build the u-boot.kwb target. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-22doc: Remove note about auto-complete not working with hushSimon Glass
It does seem to work (tested on link), so update the docs. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22usb: dwc2: Add driver for Synopsis DWC2 USB IP blockOleksandr Tymoshenko
This is the USB host controller used on the Altera SoCFPGA and Raspbery Pi. This code has three checkpatch warnings, but to make sure it stays at least readable and clear, these are not fixed. These bugs are in the USB request handling combinatorial logic, so any abstracting of those is out of question. Tested on DENX MCV (Altera SoCFPGA 5CSFXC6C6U23C8N) and RPi B+ (BCM2835). Signed-off-by: Oleksandr Tymoshenko <gonzo@bluezbox.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Cc: Vince Bridgers <vbridger@altera.com> Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2014-10-16fsl_sec : Change accessor function to take care of endiannessRuchika Gupta
SEC registers can be of type Little Endian or big Endian depending upon Freescale SoC. Here SoC defines the register type of SEC IP. So update acessor functions with common SEC acessor functions to take care both type of endianness. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-26Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-09-25driver/ddr: Restruct driver to allow standalone memory spaceYork Sun
U-boot has been initializing DDR for the main memory. The presumption is the memory stays as a big continuous block, either linear or interleaved. This change is to support putting some DDR controllers to separated space without counting into main memory. The standalone memory controller could use different number of DIMM slots. Signed-off-by: York Sun <yorksun@freescale.com>
