When using SUBLEVEL for the -rc? tag, this results in an ugly version
string like "2013.01.-rc1" - let's use EXTRAVERSION instead to get the
simple "2013.01-rc1"
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load},
and transparently handle either file-system. This scheme could easily be
extended to other filesystem types; I only didn't do it for zfs because
I don't have any filesystems of that type to test with.
Replace the implementation of {fat,ext[24]}{ls,load} with this new code
too.
The rules to generate u-boot-{no,}dtb-tegra.bin were almost identical.
Combine them into a single paremeterized rule. This will allow the next
patch to edit a single rule, rather than being cut/paste twice.
Signed-off-by: Tom Warren <twarren@nvidia.com>
SX1 does not build properly by itself, is not built
as part of MAKEALL arm or MAKEALL -a arm, and is only
present in Makefile, not boards.cfg. As it also has no
entry in MAINTAINERS, it is orphan and non-functional.
Remove it.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
The patch adds SPL for the arm1136 architecture and
inserts SPL (the produced binary) to clobber target
in the main Makefile.
This change adds CBFS support and some commands to use it to u-boot. These
commands are:
cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of
the ROM is an optional parameter which defaults to the standard 0xffffffff and
can be used to support multiple CBFSes in a system. The last one set up with
cbfsinit is the one that will be used.
cbfsinfo - Print information from the CBFS header.
cbfsls - Print out the size, type, and name of all the files in the current
CBFS. Recognized types are translated into symbolic names.
cbfsload - Load a file from CBFS into memory. Like the similar command for fat
filesystems, you can optionally provide a maximum size.
Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified.
The CBFS driver can also be used programmatically from within u-boot.
If u-boot needs something out of CBFS very early before the heap is
configured, it won't be able to use the normal CBFS support which caches some
information in memory it allocates from the heap. The
cbfs_file_find_uncached function searches a CBFS instance without touching
the heap.
Signed-off-by: Gabe Black <gabeblack@google.com>
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
The command declaration now uses the new LG-array method to generate
list of commands. Thus the __u_boot_cmd section is now superseded and
redundant and therefore can be removed. Also, remove externed symbols
associated with this section from include/command.h .
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
This patch adds essential components for generation of the contents of
the linker section that is used by the linker-generated array. All of
the contents is held in a separate file, u-boot.lst, which is generated
at runtime just before U-Boot is linked.
The purpose of this code is to especially generate the appropriate
boundary symbols around each subsection in the section carrying the
linker-generated arrays. Obviously, the interim linker code for actual
placement of the variables into the section is generated too. The
generated file, u-boot.lst, is included into u-boot.lds via the linker
INCLUDE directive in u-boot.lds .
Adjustments are made in the Makefile and spl/Makefile so that the
u-boot.lds and u-boot-spl.lds depend on their respective .lst files.
Tested-by: Joe Hershberger <joe.hershberger@ni.com>
Pull slightly modified version of Documentation/DocBook, the related perl
script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and
implant it into U-Boot. This will allow smooth generation of kerneldoc
style documentation.
It was necessary to modify the DocBook/Makefile to work with U-Boot build
system. The changes were only minor though and involved replacing the kbuild
specific parts.
It was also necessary to replace use of variables like KERNEL_VERSION with
U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so
the generated result actually matches.
Finally, it was necessary to adjust docproc.c, since the documentation in
U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in
case of the Linux kernel.
Some parts of the DocBook Makefile are unused, but to allow easier sync with
Linux kernel, these parts are still left in. The targets enabled now are
"htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results
of documentation build.
Linux scripts/docproc.c:
commit f0f3ca8d967462dafb815412b14ca3339b9817a6
Date: Wed Jun 15 11:53:13 2011 +0200
Linux scripts/kernel-doc:
commit 1b40c1944db445c1de1c47ffd8cd426167f488e8
Date: Sun Aug 12 10:46:15 2012 +0200
Linux Documentation/DocBook:
commit bb8187d35f820671d6dd76700d77a6b55f95e2c5
Date: Thu May 17 19:06:13 2012 -0400
patches.
Move files that are going to be common between T20 and T30 into 'tegra-common'
subdirs in AVP (arm720t), CPU (armv7), and shared (arch/arm/cpu/.) areas. Any
files that are left behind in '/tegra20' will be copied to '/tegra30' subdirs
and modified for that SoC. The 'common' files should need only minor changes.
Include files (arch/arm/include/asm/arch-tegra/tegra20) will be done in a
follow-on patch.
Builds fine w/MAKEALL -s tegra20. Checkpatch.pl is clean.
Add support for running source code checkers on u-boot source, e.g.,
using sparse to aid with typechecking. This comes in especially
handy as SoC vendors mix and match cores and devices with different
endianness, thus here we add CHECK_ENDIAN to the otherwise linux
kernel default CHECKFLAGS.
- Convert the non-relocation part of board_init_f to spl_board_init, turn on CONFIG_SPL_BOARD_INIT in the configs.
- Remove duplicated code.
- Add spl_boot_device() that returns the statically chosen boot device.
The 'clean' target has been removing all of spl but not u-boot itself.
For consistency and ease of testing, only remove SPL binaries / maps in
the clobber target, just like for full U-Boot
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
Update Makefile change for LIBS -> LIBS-y change.
Makefile
After removing the Apollon board, remove the OneNAND IPL too.
There are no users for it any more.
Cc: Minkyu Kang <promsoft@gmail.com>
Cc: Tom Rini <trini@ti.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
Up now only MX5 and MX6 can share code, because they have
a common source directory in cpu/armv7. Other not armv7
i.MX can profit of the same shared code. Move these files
into a directory accessible for all, similar to plat-mxc
in linux.
Delete the "mxsboot" binary if make mrproper is called.
Cc: Fabio Estevam <festevam@gmail.com>
CC: Albert Aribaud <albert.u.boot@aribaud.net>
The call to SYSTEM_MAP assumes that the u-boot output is in $PWD when
it really should be in $(obj). This fixes building out of tree.
* 'master' of git://git.denx.de/u-boot-usb:
MUSB driver: Timeout is never detected as the while loop does not end
usb: fix ulpi_set_vbus prototype
pxa25x: Add UDC registers definitions
USB: Fix strict aliasing in ohci-hcd
usb: Optimize USB storage read/write
ehci: Optimize qTD allocations
usb_stor_BBB_transport: Do not delay when not required
usb_storage: Remove EHCI constraints
usb_storage: Restore non-EHCI support
ehci-hcd: Boost transfer speed
ehci: cosmetic: Define used constants
ehci: Fail for multi-transaction interrupt transfers
arm:trats: Enable g_dnl composite USB gadget with embedded DFU function on TRATS
arm:trats: Support for USB UDC driver at TRATS board.
dfu:cmd: Support for DFU u-boot command
dfu: MMC specific routines for DFU operation
dfu: DFU backend implementation
dfu:usb: DFU USB function (f_dfu) support for g_dnl composite gadget
dfu:usb: Support for g_dnl composite download gadget.
ehci: cosmetic: Define the number of qt_buffers
New, separate driver at ./drivers/dfu has been added. It allows platform
and storage independent operation of DFU.
It has been extended to use new MMC level of command abstraction.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
The elftosb call needs to use a target param specific for i.MX28. This
patch allow for later addition of i.MX233.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Add SPL options to tegra20 config files and enable SPL build for
tegra20 boards. Also remove redundant code from u-boot that is not
contained in SPL.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Add target for tegra20 u-boot image. This is a concatenation of tegra
spl and normal u-boot binaries. For non-devicetree builds this is
named "u-boot-nodtb-tegra.bin" for devicetree builds is named
"u-boot-dtb-tegra.bin".
In preparation for splitting out the armv4t code from tegra20, move
the tegra20 SoC code to arch/arm/cpu/tegra20-common. This code will
be compiled armv4t for the arm7tdmi and armv7 for the cortex A9.
This gets us rid of duplication of the same file.
Parameters used for configuring certain SoC peripherals are parsed
from the cfg file and appended as part of the ais image's header. The
u-boot-spl.ais generated is flashed separately to the nand, so do not
delete the file after generation of u-boot.ais.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
This patch moves all bootcount implementations into a common
directory: drivers/bootcount. The generic bootcount driver
is now usable not only by powerpc platforms, but others as well.
Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Manfred Rudigier <manfred.rudigier@omicron.at>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de>
Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Tested-by: Christian Riesch <christian.riesch@omicron.at>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Provides a tool to build boot Image for PBL(Pre boot loader) which is
used on Freescale CoreNet SoCs, PBL can be used to load some instructions
and/or data for pre-initialization. The default output image is u-boot.pbl,
for more details please refer to doc/README.pblimage.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Commit 8b5a02640adf77301f943e8754992c50df004e8a ("Makefile: cosmetic:
optimize usage of LIBS-y") broke the build of boards that have a board
vendor "common" directory, by introducing a space between "LIBS-" and
"y".
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Synchronize with ALL-y handling and code in spl/Makefile.
The top Makefile and the SPL Makefile have lines like those:
ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP34XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),)
LIBS += $(CPUDIR)/omap-common/libomap-common.o
endif
ifeq ($(SOC),mx5)
LIBS += $(CPUDIR)/imx-common/libimx-common.o
endif
This should be done in the arch/CPU/SoC specific sub-makefiles to
keep the top Makefiles clean. This patch also allows adding of new
arch/CPU/SoC specific libraries in the future without touching
the top Makefiles.
Signed-off-by: Uma Shankar <uma.shankar@samsung.com>
Signed-off-by: Manjunatha C Achar <a.manjunatha@samsung.com>
Signed-off-by: Iqbal Shareef <iqbal.ams@samsung.com>
Signed-off-by: Hakgoo Lee <goodguy.lee@samsung.com>
U-Boot port is based on sources forked from GRUB-0.97 by Sun in 2004,
which can be found here:
http://src.opensolaris.org/source/xref/onnv/onnv-gate/usr/src/grub/grub-0.97/stage2/zfs-include/zfs.h
Released by Sun for GRUB under the license:
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
GRUB official releases include ZFS in version:
ftp://alpha.gnu.org/gnu/grub/grub-1.99~rc1.tar.gz
And patched against GRUB Bazaar repository for ashift fixes (4KB HDDs)
more conveniently found at github:
https://github.com/pendor/grub-zfs/commit/e7b6ef3ac3b9685ac4c394c897b1d4221b7381f1
Signed-off-by: Jorgen Lundman <lundman@lundman.net>
Since run_command() and run_command_list() are important and a little
confusing, add some basic tests to check that the behaviour is correct.
Note: I am not sure that this should be committed, nor where it should go
in the source tree. Comments welcome.
To run the unit tests use the ut_cmd command available in sandbox:
make sandbox_config
make
./u-boot -c ut_cmd
(To test both hush and built-in parsers, you need to manually change
CONFIG_SYS_HUSH_PARSER in include/configs/sandbox.h and build/run again)
* 'master' of git://git.denx.de/u-boot-mips:
MIPS: fix renaming of inca-swap-bytes to xway-swap-bytes
make would spit out a message like
Generating /tmp/build/include/generated/asm-offsets.h
even when running with option "-s". Fix this.
Fix some remains of the renaming of inca-swap-bytes introduced in
commit 60b74bde9280e85f4423c05a50ecc41de56ad980
MIPS: INCA-IP: rename inca-swap-bytes host tool
